AGCO Allis Tractor 7085 DX4.70 Parts Catalog 79007990
Brand: AGCO Allis
Model:
AGCO Allis 7085 Tractor
AGCO Allis DX4.70 Tractor
Part Number: 79007990
Number of Pages: 455 Pages
Engine - Crankcase
Engine - Idler Gear Asy
Engine - Front Cover
Engine - Crankcase, Locking Parts
Engine - Valve, Breather
Engine - Oil Pan, Standard, 2wd
Engine - Cylinder
Engine - Crankshaft, Mass-Balancing Gear
Engine - Connecting Rod
Engine - Cylinder Head
Engine - Camshaft
Engine - Lifter Mechanism
Engine - Lube Oil, Pump, Prior To Engine S N 7014 591
Engine - Lube Oil, Hydraulic Oil Cooler
Engine - Lube Oil, Cooler, Filter Head
Engine - Oil Line, Pressure
Engine - Oil Lines, Lube Oil Line, Prior To Engine S N
Engine - Injection Pump
Engine - Injector, Cylinder Unit
Fuel System - Lines
Intake And Exhaust - Air Intake
Engine Cooling - Blower, Hydraulic
Engine Cooling - Blower, Piping, Rh Side
Engine Cooling - Blower, Piping, Lh Side
Engine Cooling - Exhaust Thermostat
Engine Cooling - Ducting, Baffle Mounting Plate
Engine Cooling - Ducting, Air Cowling Base
Engine Cooling - Ducting, Air Shield
Engine Cooling - Ducting, Front Stay Plate, Prior To Engine
Intake And Exhaust - Manifold, Exhaust
Intake And Exhaust - Turbocharger
Intake And Exhaust - Turbocharger, Single Parts
Electrical - Alternator, 55a Amp
Electrical - Alternator, 95 Amp
Electrical - Alternator, Attachments, Prior To Engine S N
Electrical - Alternator, Belt Set
Electrical - Starter Motor, 2.7 Kw
Electrical - Switch - Oil Pressure
Electrical - Wiring, 33 + 65 Amp
Fuel System - Starting Aid, Flame-Type Pin Plug, Prior To
Engine - Gaskets
Clutch - Clutch Release Assembly, Prior S N
Clutch - Clutch Release Assembly, Eff. S N
Clutch - Clutch Assembly, Dual
Clutch - Clutch Assembly, Control, Dual
P.T.O. - Control Assembly, Mechanical
Transmission - Housing
Transmission - Lube Oil Supply
Transmission - Lube Oil Supply, Filter
Transmission - Transmission Asy., 5 Speed
Transmission - Layshaft Asy.
Transmission - Change Speed Gearbox, Layshaft
Transmission - Shaft - Main
Transmission - Shaft - Intermediate, 5-Speed
Transmission - Creep Gear, Reverse
Transmission - Gearshift Assembly, Shift Stick
Transmission - Gearshift Assembly, Cover
Transmission - Gearshift Assembly, Shift Rods & Forks
Transmission - Gearshift Assembly, Flanged Bearing
Front Axle - Front Wheel Drive, Front Axle Drive
Front Axle - Control, Front Wheel Drive, Prior S N 7434 3000
Transmission - Drive - Bevel
Transmission - Differential, Gear
Transmission - Differential Lock
Transmission - Axle, Rear
P.T.O. - Rear Pto Drive, Single Stub Shaft, Prior S N
P.T.O. - Rear Pto Drive, Single Shaft, Effective S N
P.T.O. - Pto Shaft, Single Stub - Rear, Prior S N 7434 3000
P.T.O. - Pto Shaft, Single Stub - Rear, Eff. S N 7434 3000
P.T.O. - Rear Pto Drive, Double Stub Shaft, Prior S N
P.T.O. - Rear Pto Drive, Double Stub Shaft, Effective S N
P.T.O. - Pto Shaft, Double Stub - Rear, Prior S N 7434 3000
P.T.O. - Pto Shaft, Double Stub, Effective S N 7434 3000 -
P.T.O. - Pto Shaft, Double Stub, Effective S N 7434 3447,
P.T.O. - Control Assembly, Rear Pto, Standard Pto Shaft
P.T.O. - Shaft - Front Pto
P.T.O. - Control Assembly, Front Pto Shaft, Type 1
P.T.O. - Control Assembly, Front Pto Shaft, Type 2
P.T.O. - Control Assembly, Front Pto Shaft, Type 1 & 2
P.T.O. - Pto Guard, Single Stub Shaft
P.T.O. - Pto Guard, Double Stub Shaft
P.T.O. - Guard, Rear Pto, Single Stub Shaft
Brake - Parking Brake
Brake - Control Assembly
Brake - Service Brake, Disc
Brake - Service Brake, Control Asy - Master Cylinder, Prior
Brake - Service Brake, Control Assembly, Lines
Hydraulic System - Oil Supply, Hydraulic Pump
Hydraulic System - Oil Supply, Filter
Hydraulic System - Oil Supply, Hydraulic Pump, 19, 11 Ccm, U,
Hydraulic System - Hydraulic Lift
Hydraulic System - Hydraulic Lift, Housing Asy
Hydraulic System - Hydraulic Lift, Arms
Hydraulic System - Hydraulic Lift, Shaft & Linkage
Hydraulic System - Hydraulic Lift, Control Assembly
Hydraulic System - Hydraulic Lift, Intake Filter
Hydraulic System - Cylinder, Hydraulic Lift, 0=55 Mm
Hydraulic System - Oil Tank, Auxiliary
Hydraulic System - Control Unit, Deutz, Intermediate Unit,
Hydraulic System - Control Valve, End Unit
Hydraulic System - Control Unit, End Plate, Fastenings
Hydraulic System - Hydraulic Control Assembly, Levers &
Hydraulic System - Control Assembly - Remote Hydraulic Hoses,
Hydraulic System - Control Assembly, Hydraulic, Front Lift
Hydraulic System - Control Assembly, Hydraulic Coupling
Hydraulic System - Coupler Asy., Eff. S N 7434 0674 For 2wd,
Hydraulic System - Three Point Hitch, Extendable Link
Hydraulic System - Three Point Hitch, Claw Type, Upper Link
Hydraulic System - Three Point Hitch, Claw Type, Lower
Hydraulic System - Three Point Hitch, Top Link Asy.- Clevis
Hydraulic System - Three Point Hitch, Top Link, Telescopic
Hydraulic System - Three Point Hitch, Top Link, Front Lift
Hydraulic System - Three Point Hitch, Extendible Link
Hydraulic System - Power Front Hitch Assembly
Hydraulic System - Power Front Hitch, Lines & Cylinders,
Hydraulic System - Power Front Hitch, Cylinder Asy.
Hydraulic System - Hitch, Non-Power
Front Axle - Bracket Asy., Front Axle
Front Axle - Axle, Telescopic
Front Axle - Tie Rod, Telescopic Axle
Front Axle - Steering Axle, Driven, Axle Shafts & Housings
Front Axle - Steering Axle, Driven, Differential
Front Axle - Steering Axle, Driven, Differential Case Asy.
Front Axle - Steering Axle, Driven, Hub Asy.
Front Axle - Shaft, Universal Joint, With Partial Protection
Front Axle - Shaft, Universal Joint, With Complete Protection
Power Steering - Steering Column, Lines And Fittings,
Power Steering - Axle Driven - 4wd Sige 4180
Power Steering - Steering Column, Tilt & Telescopic
Power Steering - Control Pump, Danfoss
Power Steering - Steering Column, Danfoss
Power Steering - Control Pump, -Zf-
Power Steering - Cylinder, Hydraulic, Telescopic Axle
Hood And Sheet Metal - Hood
Hood And Sheet Metal - Hood Support, Eff. S N 7434 6332,
Hood And Sheet Metal - Instruments, Panel And Box
Hood And Sheet Metal - Speed Control Device
Hood And Sheet Metal - Shutdown Device
Hood And Sheet Metal - Fenders, Front 2wd, Telescopic Axle,
Hood And Sheet Metal - Fenders, Front 4wd, For 12.4-24,
Hood And Sheet Metal - Fenders, Rear
Hood And Sheet Metal - Deck
Cab - Cab Structure And Glass, Rops, With Out Cap
Cab - Protective Yoke - Front, Prior S N 7434 0560 For 2wd,
Cab - Protective Yoke - Front, Eff. S N 7434 0560 For 2wd, Eff. S N 7435 1971 For 4wd
Cab - Cab Structure And Glass, Cab
Cab - Cab Structure And Glass, Front Wall
Cab - Windshield - Front
Cab - Window - Rear
Cab - Cover
Cab - Cab Structure And Glass, Side Window
Cab - Cab Structure And Glass, Side Window Asy., Prior S N 7434 0678 For 2wd, Prior S N 7435 2767 For 4wd
Cab - Cab Structure And Glass, Side Window Asy., Eff. S N 7434 0678 For 2wd, Eff. S N 7435 2767 For 4wd
Cab - Cab Door, Prior S N 7434 0560-7435 1971
Cab - Cab Door, Eff. S N 7438 0263-7439 1745
Cab - Cab Structure And Glass, Rear Window
Cab - Paneling Cab, Sound Absorbing, Roof Paneling
Cab - Paneling Cab, Sound Absorbing, Side Paneling
Cab - Floor Mats
Cab - Seat - Pivot Type
Cab - Seat - Pivot Type, Seat Asy.
Cab - Seat - Pivot Type, Base Asy.
Cab - Seat, Pivot Adapter
Cab - Foot Plate
Cab - Battery Carrier
Cab - Mirror, Driving, Rops
Cab - Reflector, Rear
Cab - Screw Plug
Fuel System - Tank, Fuel
Fuel System - Tank, Fuel, Line
Fuel System - Filter, Standard
Intake And Exhaust - Air Cleaner, Dry-Type, W O Air Intake
Intake And Exhaust - Air Cleaner, Dry-Type, Air Intake From
Intake And Exhaust - Muffler
Electrical - Wiring System - Front
Electrical - Wiring System - Rear
Electrical - Block Heater
Cab - Switch Box With Instruments, Main Switch
Cab - Pilot Lamp
Cab - Windshield Wiper
Cab - Interior Lights & Cigarette Lighter
Lights - Headlights, At Top, Used Only With Front Hitch
Lights - Work Lamps, Front
Lights - Headlight, Sealed-Beam
Lights - Lights, Front Fender
Cab - Heating - Oil To Air, Heating System And Breather, With
Cab - Heating - Oil To Air, Heat Exchanger
Cab - Heating - Oil To Air, Blower, Prior To S N
Cab - Heating - Auxiliary, 1.7 Kw
Cab - Heater - Fuel Fired
Cab - Air Conditioning
Cab - Air Conditioning, Compressor
Cab - Air Conditioning, Evaporator
Cab - Air Conditioning, Lines Prior S N 7434 0598 (2wd);
Hitch, Lift, And Drawbar - Hitch Pin
Hitch, Lift, And Drawbar - Bracket, Puller
Hitch, Lift, And Drawbar - Drawbar, With Small Swing,
Wheels - Front Wheels - Std
Wheels - Rear Wheels - Adjustable
Wheels - Wheels, Long Pin
Weights - Weights, Rear Wheel
Miscellaneous - Paints
Miscellaneous - Loctite
Brand: AGCO Allis
Model:
Engine - Crankcase
Engine - Cylinder
Engine - Camshaft
Fuel System - Lines
Engine - Gaskets
Cab - Window - Rear
Cab - Cover
Cab - Floor Mats
Cab - Foot Plate
Cab - Screw Plug
Cab - Pilot Lamp
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
