AGCO Allis Tractor 7080 Parts Catalog 79003878
Brand: AGCO Allis
Model: AGCO Allis 7080 Tractor
Part Number: 79003878
Number of Pages: 356 Pages
Engine - Gasket Sets
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Piston & Connecting Rod
Engine - Lubricating System, Oil Pump, Prior S N 3d-35252
Engine - Lubricating System, Oil Pump, Eff. S N 3d-35252 & Up
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Oil Cooler & Filter
Engine - Lubricating System, Bypass Oil Filter
Engine - Timing Gear Cover
Air Intake & Exhaust System - Manifolds, Intake & Exhaust
Air Intake & Exhaust System - Turbocharger, Components
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Indicator
Cooling System - Water Pump
Cooling System - Thermostat
Cooling System - Belts
Cooling System - Water Conditioner
Cooling System - Radiator
Fuel System - Fuel Injection System, Pump -- Housing & Drive
Fuel System - Fuel Injection System, Pump -- Transfer
Fuel System - Fuel Injection System, Lines
Fuel System - Fuel Injection System, Lines, Bosch
Fuel System - Fuel Injection System, Fuel Injector, Bosch
Fuel System - Fuel Injection System, Filter
Fuel System - Fuel Injection System, Hand Primer Pump
Fuel System - Electric Fuel Pump, Eff. S N 3660
Fuel System - Ether Starting System
Fuel System - Tank, Lines, Prior S N 1467
Fuel System - Tank, Lines, Eff. S N 1467
Fuel System - Controls, Fuel Shut-Off & Throttle
Electrical & Instruments - Engine Electrical System
Electrical & Instruments - Instruments, Wiring
Electrical & Instruments - Instruments, Panel & Gauges
Electrical & Instruments - Electrical System, Cab Wiring
Electrical & Instruments - Electrical System, Cab Lighting
Electrical & Instruments - Electrical Lighting
Electrical & Instruments - Console Lamp
Electrical & Instruments - Electrical Lighting, Tail Lamps
Electrical & Instruments - Electrical Lighting, Work Lamp,
Electrical & Instruments - Remote Electrical Socket, 2-Prong
Electrical & Instruments - Stadium Lamps & Remote Mirrors
Sheet Metal, Frame & Seat - Sheet Metal & Frame
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Battery Box
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Console
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Fenders
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Seat, Linkage
Sheet Metal, Frame & Seat - Seat, Fold-Up
Sheet Metal, Frame & Seat - Seat, Suspension, Luxury Cloth,
Sheet Metal, Frame & Seat - Seat, Luxury Cloth, Eff. S N 3001
Sheet Metal, Frame & Seat - Decal, Prior S N 3001
Sheet Metal, Frame & Seat - Decal Set, Eff. S N 3001
Drive Train - Transmission, Housing
Drive Train - Transmission, Torque Limiter
Drive Train - Transmission, Power Director Clutch
Drive Train - Transmission, Mainshaft W Bushings
Drive Train - Transmission, Mainshaft, W O Bushings
Drive Train - Transmission, Countershaft
Drive Train - Transmission, Gearshift & Linkage
Drive Train - Controls, Manual Shift, Eff. S N 3001
Drive Train - Transmission, Range Shaft & Gears
Drive Train - Transmission, Range Shift Control
Drive Train - Controls, Differential Lock & Range Shift
Drive Train - Differential & Final Drive, Housing
Drive Train - P.T.O., Main Shaft & Idler
Drive Train - P.T.O., Clutch & Brake
Drive Train - P.T.O., 1000 Rpm Output Shaft
Drive Train - Differential & Final Drive, Rear Axle
Brake
Brake - Brake, Controls
Hitch & Lift - Lift Shaft, Housing
Hitch & Lift - 3-Point Hitch, Torsion Bar, Lift Link
Hitch & Lift - Drawbar, Standard
Hitch & Lift - Drawbar, Wide Swing
Hitch & Lift - Hitch, Quick, Standard Lift, Prior S N 3705
Hitch & Lift - Hitch, Quick, Increased Lift, Eff. S N 3705
Axles, Steering & Wheels - Axle, Front
Axles, Steering & Wheels - Steering, Tie Rod
Axles, Steering & Wheels - Wheels, Front
Axles, Steering & Wheels - Wheels, Rear, Non-Power Adjust
Axles, Steering & Wheels - Wheel, Rear, Power Adjust
Hydraulic System - Lines, Power Steering, Prior S N 3371
Hydraulic System - Lines, Power Steering, Eff. S N 3371
Hydraulic System - Pump, Dual, Prior S N 1905
Hydraulic System - Pump, Dual, Eff. S N 3347
Hydraulic System - Valve, Power Steering, Prior S N 3202
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Lines, Power Director, Prior S N 3371
Hydraulic System - Lines, Power Director, Eff. S N 3371
Hydraulic System - Valve, Power Director
Hydraulic System - Valve, Power Director Shifting Valve
Hydraulic System - Controls, Power Director, Cable Controls
Hydraulic System - Lines, P.T.O., Brake & Differential Lock
Hydraulic System - Valve, P.T.O., Prior To S N 3113
Hydraulic System - Valve, P.T.O., Eff. S N 3113 Thru S N 4198
Hydraulic System - Valve, P.T.O., Eff. S N 4199
Hydraulic System - Controls, P.T.O., Cable Controls
Hydraulic System - Pump, Piston, W Out Drive Shaft Seal,
Hydraulic System - Piston Pump, W Drive Shaft Seal
Hydraulic System - Controls, Position & Traction Booster
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift
Hydraulic System - Valve, Inlet -- Without Lift
Hydraulic System - Valve, Inlet -- With Lift
Hydraulic System - Valve, Remote
Hydraulic System - Controls, Remote Valve, Cable Control
Hydraulic System - Seal Kit, Without Lift
Hydraulic System - Seal Kit, With Lift
Hydraulic System - Cylinder, Standard Lift, 4.5 Diameter
Hydraulic System - Cylinder, Lift (W Increased Lift)
Hydraulic System - Cylinder, Remote With Stroke Control
Hydraulic System - Cylinder, Remote 3 Diameter
Hydraulic System - Pump, Scavenger, Prior To S N 1720
Hydraulic System - Lines, Break-Away Coupler
Hydraulic System - Filter, Differential
Hydraulic System - Valve, Brake, Prior S N 3653
Hydraulic System - Valve, Differential Lock
Cab - Cab, Front View, Prior S N 3001
Cab - Cab, Rear View, Prior S N 3001
Cab - Cab, Frame, Eff. S N 3001
Cab - Door, Cab -- Left, Eff. With S N 3001
Cab - Cab Support, Eff. With S N 3001
Cab - Cab Windows, Glass, Gaskets & Hardware, Eff. S N 3001
Cab - Liners, Eff. S N 3001
Cab - Air Conditioning -- Heating, Lines
Cab - Air Conditioning -- Heating, Compressor
Cab - Air Conditioning -- Heating, Heater & Evaporator
