AGCO Allis Tractor 7060 Parts Catalog 79003882
Brand: AGCO Allis
Model: AGCO Allis 7060 Tractor
Part Number: 79003882
Number of Pages: 417 Pages
Engine - Gasket Sets
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel
Engine - Piston & Connecting Rod
Engine - Timing Gear Cover
Engine - Lubricating System, Oil Pump, (Prior S N 3d-35252)
Engine - Lubricating System, Oil Pump (Eff.S N 3d-35252 & Up)
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Oil Cooler & Filter
Engine - Lubricating System, Bypass Oil Filter
Air Intake & Exhaust System - Manifolds, Intake & Exhaust
Air Intake & Exhaust System - Turbocharger, Components, Aires
Air Intake & Exhaust System - Turbocharger, Components, Rajay
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust System - Air Cleaner, Pre-Clnr & Muffler
Air Intake & Exhaust System - Indicator, Air Cleaner Restrict
Cooling System - Water Pump
Cooling System - Radiator
Cooling System - Thermostat
Cooling System - Water Conditioner
Fuel System - Fuel Injection System, Pump - Housing & Drive
Fuel System - Fuel Injection System, Pump - Transfer, Head &
Fuel System - Fuel Injection System, Lines
Fuel System - Fuel Injection System, Lines, Bosch, Eff. S N 7
Fuel System - Fuel Injection System, Fuel Injector, Bosch, Ef
Fuel System - Fuel Injection System, Filter, Prior Tractor S
Fuel System - Fuel Injection System, Filter, Eff. S N 7562
Fuel System - Fuel Injection System, Fuel Injector (Prior S N
Fuel System - Fuel Injection System, Hand Primer Pump, Prior
Fuel System - Electric Fuel Pump, Eff. Tractor S N 7824
Fuel System - Ether Starting System
Fuel System - Tank, Lines, Prior Tractor S N 2513
Fuel System - Tank, Lines, Eff. Tractor S N 2513
Fuel System - Controls, Fuel Shut-Off & Throttle
Electrical & Instruments - Engine Electrical System, Wiring &
Electrical & Instruments - Engine Electrical System, Starting
Electrical & Instruments - Engine Electrical System, Alternat
Electrical & Instruments - Instruments, Wiring
Electrical & Instruments - Instruments, Panels & Gauges, Prio
Electrical & Instruments - Instruments, Panels & Gauges, Eff.
Electrical & Instruments - Electrical System, Wiring Cab, Pri
Electrical & Instruments - Electrical System, Cab Wiring, Eff
Electrical & Instruments - Electrical System, Wiring, Protect
Electrical & Instruments - Electrical Lighting, Wheel Guard T
Electrical & Instruments - Electrical System, Tape Player & R
Electrical & Instruments - Electrical System, Cab Lighting, E
Electrical & Instruments - Console Lamp
Electrical & Instruments - Electrical Lighting, Tail Lamps
Electrical & Instruments - Electrical Lighting, Warning Lamps
Electrical & Instruments - Electrical Lighting, Work Lamp, Wh
Electrical & Instruments - Stadium Lights & Remote Mirrors, E
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Front Suppor
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Battery Box
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Control Leve
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Platform & S
Sheet Metal, Frame & Seat - Sheet Metal & Frame, L.H. Steps &
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Protective F
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Fenders
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Hood & Panel
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Seat, Linkage
Sheet Metal, Frame & Seat - Seat, Fold--Up, Marathon
Sheet Metal, Frame & Seat - Seat, Suspension, Luxury Cloth, E
Sheet Metal, Frame & Seat - Seat, Luxury Cloth, Eff. S N 6001
Sheet Metal, Frame & Seat - Decal, Prior S N 6001
Sheet Metal, Frame & Seat - Decal Set, Eff. S N 6001
Drive Train - Transmission, Housing, Power Director Tractor
Drive Train - Transmission, Torque Limiter, Power Director Tr
Drive Train - Transmission, Power Director Clutch
Drive Train - Transmission, Mainshaft W Bushings, Power Direc
Drive Train - Transmission, Mainshaft W O Bushings, Power Dir
Drive Train - Transmission, Countershaft, Power Director Trac
Drive Train - Transmission, Gearshift & Linkage, Power Direct
Drive Train - Transmission, Gearshift & Linkage, Eff.S N 6001
Drive Train - Controls, Manual Shift, Eff. S N 6001
Drive Train - Transmission, Housing, Power Shift Tractor
Drive Train - Transmission, Torque Limiter, Power Shift Tract
Drive Train - Transmission, Front Bearing
Drive Train - Transmission, A1, A2, B1, B2 Clutch Housing, Po
Drive Train - Transmission, C1, C2 Clutch Housing, Power Shif
Drive Train - Transmission, Rear Bearing
Drive Train - Transmission, Front Carrier Asy., Power Shift
Drive Train - Transmission, Middle Carrier Asy., Power Shift
Drive Train - Transmission, Shaft & Gears, Power Shift
Drive Train - Transmission, Range Shaft & Gears
Drive Train - Transmission, Range Shift Control
Drive Train - Controls, Inching, Power Shift
Drive Train - Controls, Speed Selector, Power Shift
Drive Train - Controls, Differential Lock & Range Shift, Cabl
Drive Train - Differential & Final Drive, Housing
Drive Train - P. T. O., Main Shaft & Idler
Drive Train - P. T. O., Clutch & Brake
Drive Train - P. T. O., 2-Speed Output Shaft
Drive Train - P. T. O., 1000 Rpm Output Shaft
Drive Train - Differential & Final Drive, Rear Axle
Drive Train - Differential & Final Drive, Housing -- Rear Axl
Drive Train - Differential & Final Drive, Rear Axle, Hi-Clear
Brake
Brake - Brake, Controls
Hitch & Lift - Lift Shaft, Housing
Hitch & Lift - 3-Point Hitch, Torsion Bar, Lift Link, Upper &
Hitch & Lift - Drawbar, Standard
Hitch & Lift - Drawbar, Wide Swing
Hitch & Lift - Hitch, Quick, Standard
Hitch & Lift - Hitch, Quick, Heavy Duty
Axles, Steering & Wheels - Axle, Front
Axles, Steering & Wheels - Axle, Front, High Clearance
Axles, Steering & Wheels - Steering, Tie Rod
Axles, Steering & Wheels - Wheel, Front
Axles, Steering & Wheels - Wheel, Rear, Power Adjust
Axles, Steering & Wheels - Wheel, Rear, Non-Power Adjust
Hydraulic System - Lines, Power Steering, Prior S N 6001
Hydraulic System - Lines, Power Steering, Eff. S N 6001
Hydraulic System - Pump, Dual, Prior S N 7043
Hydraulic System - Pump, Dual, Eff. S N 7043
Hydraulic System - Valve, Power Steering, Prior S N 6595
Hydraulic System - Valve, Cooler Relief, Eff. S N 5045 - 6000
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Lines, Power Director, Prior S N 6001
Hydraulic System - Lines, Power Director, Eff. S N 6001
Hydraulic System - Valve, Power Director
Hydraulic System - Valve, Power Director Shifting Valve, Prio
Hydraulic System - Valve, Power Director Shifting Valve, Eff.
Hydraulic System - Controls, Power Director, Cable Controls
Hydraulic System - Lines, Power Shift, (Prior S N 6001)
Hydraulic System - Lines, Power Shift, Eff. S N 6001
Hydraulic System - Lines & Filter, Power Shift, Eff. S N 6001
Hydraulic System - Valve, Power Shift
Hydraulic System - Lines, P.T.O., Brake & Differential Lock,
Hydraulic System - Valve, P.T.O., Prior S N 6322
Hydraulic System - Valve, P.T.O., Eff. S N 6322 Thru 9044
Hydraulic System - Valve, P.T.O., Eff. S N 9045
Hydraulic System - Controls, P.T.O., Cable Controls
Hydraulic System - Pump, Piston, W Out Drive Shaft Seal, Prio
Hydraulic System - Piston Pump, W Drive Shaft Seal, Eff. S N
Hydraulic System - Controls, Position & Traction Booster, Cab
Hydraulic System - Controls, Position & Traction Booster, Con Control Levers Eff. S N 6001
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift
Hydraulic System - Valve, Inlet -- With Lift
Hydraulic System - Valve, Inlet -- Without Lift
Hydraulic System - Valve, Remote
Hydraulic System - Controls, Remote Valve, Cable Controls, Pr
Hydraulic System - Controls, Remote Valve, Cable Controls, Ef
Hydraulic System - Seal Lift, With Lift
Hydraulic System - Shim Kit
Hydraulic System - Seal Kit, Without Lift
Hydraulic System - Cylinder, Standard Lift, 4.5 Diameter
Hydraulic System - Cylinder, Lift, W Increased Lift, 5.0 Dia
Hydraulic System - Cylinder, Remote With Stroke Control
Hydraulic System - Cylinder, Remote -- 3'' Diameter
Hydraulic System - Pump, Scavenger, Prior S N 3369
Hydraulic System - Lines, Break-Away Coupler
Hydraulic System - Filter, Differential
Hydraulic System - Valve, Brake, Prior S N 7720
Hydraulic System - Valve, Differential Lock, Prior S N 1425
Hydraulic System - Valve, Differential Lock, Eff. S N 1425
Cab - Front View, Prior S N 6001
Cab - Rear View, Prior S N 6001
Cab - Cab, Frame, Eff. S N 6001
Cab - Door, Cab -- Left, Eff. S N 6001
Cab - Cab, Cab Support, Eff. S N 6001
Cab - Cab Windows, Glass, Gaskets & Hardware, Eff. S N 6001
Cab - Liners, Eff. S N 6001
Cab - Air Conditioning -- Heating, Lines & Compressor Mountin
Cab - Air Conditioning -- Heating, Lines, Eff. S N 6001
Cab - Air Conditioning -- Heating, Compressor
Cab - Air Conditioning -- Heating, Blower
Cab - Air Conditioning -- Heating, Heater & Evaporator, Prior
Cab - Air Conditioning -- Heating, Heater & Evaporator, Eff.
Brand: AGCO Allis
Engine - Crankshaft
Engine - Flywheel
Brake
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
