AGCO Allis Tractor 6690 Parts Catalog 79013783
Brand: AGCO Allis
Model: AGCO Allis 6690 Tractor
Part Number: 79013783
Number of Pages: 524 Pages
Publication Information
Engine - Crankcase
Engine - Front Cover
Engine - Crankshaft
Engine - Counterweights
Engine - Camshaft
Engine - Cylinder Head
Engine - Oil Filter And Oil Pan
Engine - Oil Pump
Engine - Oil Lines - Turbo Charger
Intake And Exhaust - Breather And Lines
Intake And Exhaust - Breather Components
Fuel System - Injector And Pump
Fuel System - Governor, Fuel Pump And Filter
Fuel System - Thermostarter
Fuel System - Governor Components
Fuel System - Governor Controls
Fuel System - Injection Pump Components
Fuel System - Injector Components
Fuel System - Fuel Filter
Fuel System - Pre-Filter Components
Fuel System - Fuel Pump Components
Engine Cooling - Cooling Blower
Engine Cooling - Blower
Intake And Exhaust - Manifolds
Intake And Exhaust - Muffler
Intake And Exhaust - Air Cleaner
Intake And Exhaust - Air Cleaner Components
Intake And Exhaust - Pre-Filter Components
Transmission - Clutch Assembly-Organic 12 , Prior S N 1126
Transmission - Clutch Assembly - Cera-Metallic 13 , Eff. S N
Transmission - Clutch Housing
Clutch - Clutch Control
Clutch - Clutch Release
Clutch - Clutch Cylinder Components
Clutch - Master Cylinder
Transmission - Gearbox
Transmission - Gearbox Supports
Transmission - Reverse Gear
Transmission - Reverse Gear Controls, Shift Fork And Rail
Transmission - Reverse Gear Controls, Gear Shift
Transmission - Hi-Lo Gear
Transmission - Hi-Lo Gear Controls
Transmission - Main Shaft - Driven
Transmission - Gear Control, Shift Rails And Forks
Transmission - Gear Shift Controls
Transmission - Synchro Power Fifth Gear Controls
Transmission - Five Speed Gearbox With Synchro Power
Transmission - Synchro Power, Hi-Lo Gear, 30 X 30
Transmission - Hi-Lo Reduction Clutch
Transmission - Hi-Lo Reduction Clutch Housing
Transmission - Synchro Power With Mechanical Controls
Transmission - Synchro Power With Hydraulic Controls
Transmission - Reduction Gear
Transmission - Creeper Gear
Transmission - Reduction Controls
Transmission - Reduction Controls, Shift Lever
Transmission - Differential
Transmission - Differential Lock Control, Mechanical
Transmission - Differential Lock Control, Electrohydraulic
Transmission - Rear Axle Housing
Transmission - Rear Reduction And Axle Shaft
Brakes - Rear Brakes
Brakes - Parking Brake
Brakes - Hydraulic Controls And Lines
Brakes - Brake Cylinder Components
Brakes - Pedal Supports
Front Axle - Front Support
Front Axle - Adjustable Axle - 2wd
Power Steering - Power Steering Cylinder - 2wd
Power Steering - Cylinder Components - 2wd
Power Steering - Front Axle - 4wd, W Mech. Diff. Lock, Prior
Power Steering - Front Drive Axle With Electro, Hydraulic
Power Steering - Front Axle - 4wd, Eff. Axle S N 5651
Brakes - Front Brake Lines - 4wd
Brakes - Front Brake - 4wd
Power Steering - Cylinder - 4wd
Power Steering - Cylinder Components - 4wd
Front Axle - Differential Lock - 4wd
Front Axle - Front Differential Lock Control, Mechanical,
Front Axle - Differential & Axle Shafts - 4wd
Front Axle - Differential Lock Control, Front - 4wd
Front Axle - Transmission Shaft - 4wd
Front Axle - 4wd - P.T.O.
Front Axle - Control - 4wd
Front Axle - Control Electrohydraulic - 4wd
Front Axle - Front Differential Cylinder Supply Line
P.T.O. - Transmission Clutch Shaft, Without Synchro Power -
P.T.O. - Transmission Clutch Shaft, With Synchro Power, 30 X
P.T.O. - Front
P.T.O. - Clutch - Front
P.T.O. - Hydraulic Clutch, With Mechanical Controls
P.T.O. - Hydraulic Clutch, With Electrohydraulic Controls
P.T.O. - Hydraulic Clutch, Electro Hydraulic Controlled
P.T.O. - Hydraulic Clutch, Electro Hydraulic Controls
P.T.O. - Hydraulic Pump Drive
P.T.O. - Four Speed Economy
P.T.O. - Pto With Added Shafts
P.T.O. - Mechanical Control
P.T.O. - Engagement Control
Power Steering - Steering Column-Adjustable
Power Steering - Steering Control Unit And Lines
Power Steering - Control Unit Components
Power Steering - Steering Pump, Filter And Lines
Power Steering - Steering Pump Components, Sunstrand Hema
Power Steering - Cooler And Lines
Power Steering - Steering Lines - 2wd
Power Steering - Steering Lines Dual Cylinder, Single Acting
Power Steering - Steering Lines Single Cylinder
Hydraulics - Solenoid Valve
Hydraulics - Pressure Regulating Valve
Hydraulics - Pressure Regulating Valve, Hydraulic Lines
Sheet Metal And Frame - Hood
Sheet Metal And Frame - Hood Support And Grille
Sheet Metal And Frame - Shields
Sheet Metal And Frame - Bulkheads And Supports
Sheet Metal And Frame - Fan And Belt Guard
Sheet Metal And Frame - Solenoid Valves Shield
Sheet Metal And Frame - Instrument Panel
Sheet Metal And Frame - Fuel Throttle Controls
Sheet Metal And Frame - Bulkheads Without Heating
Sheet Metal And Frame - Front Fenders
Sheet Metal And Frame - Platform
Sheet Metal And Frame - Platform Supports
Sheet Metal And Frame - Platform Console - Cab
Sheet Metal And Frame - Rops Safety Frame
Sheet Metal And Frame - Rops Canopy
Fuel System - Fuel Tank And Lines
Fuel System - Fuel Supply Lines And Pre Filter
Fuel System - Auxiliary Tank
Seat - Seat Sable'
Seat - Seat Components - Cab Models
Seat - Seat - Rops Models
Seat - Seat Components - Rops Models
Electrical - Lights
Electrical - Light Components
Electrical - Alternator, Starting Motor And Battery
Electrical - Electric Starting Equipment, Prior Tractor S N
Electrical - Electric Starting Equipment, Eff. Tractor S N
Electrical - Fuse Box Conversion
Electrical - Electrical Controls
Electrical - Ignition Switch & Flasher
Electrical - Control Box - Steering Column
Electrical - Thermo-Starter
Electrical - Alternator Components
Electrical - Starter Components, Iskra
Electrical - Starter Components, Bosch
Electrical - Starter Components, Marelli 1st Type
Electrical - Control Switches, Steering Column, Late
Electrical - Digital Clock
Wheels - Wheels - 2wd
Wheels - Wheels - 4wd, Siriac Type Rims
Wheels - Wheels - 4wd, Delachaux Type Rims
Cab - Cab Frame
Cab - Door Latches, Locks & Mirrors
Cab - Glasses And Weatherseals
Cab - Interior Trim
Cab - Console
Cab - Throttle Control
Cab - Windshield Wiper
Cab - Windshield Wiper Components
Air Conditioning And Heating System - Cab Ventilation Ducting
Air Conditioning And Heating System - Air Conditioning
Air Conditioning And Heating System - Compressor Components,
Air Conditioning And Heating System - Condenser And Lines
Air Conditioning And Heating System - Heater Controls And
Air Conditioning And Heating System - Heating Alternator,
Air Conditioning And Heating System - Heater Alternator, Dual
Air Conditioning And Heating System - Enhanced Heater Alternator, Eff. S N 1925 Except S N 1712
Air Conditioning And Heating System - Heater Components
Air Conditioning And Heating System - Enhanced Heater, Eff
Hitch, Lift And Drabber - Front Hitch And Lift
Hitch, Lift And Drabber - Front Lift Lines
Hitch, Lift And Drabber - Front Lift Valve
Hitch, Lift And Drabber - Front Lift Cylinder Components
Hitch, Lift And Drabber - Hydraulic Housing
Hitch, Lift And Drabber - Hydraulic Oil Filter - Main
Hitch, Lift And Drabber - Hydraulic Oil Filter Intake
Hitch, Lift And Drabber - Hydraulic Pump And Lines
Hitch, Lift And Drabber - Hydraulic Pump Components,
Hitch, Lift And Drabber - Rear Lift System
Hitch, Lift And Drabber - Hydraulic Lift Valve, Prior Tractor
Hitch, Lift And Drabber - Hydraulic Lift Valve, Eff. Tractor
Hitch, Lift And Drabber - Inner And Outer Control Levers
Hitch, Lift And Drabber - Tie Rods And Control Levers
Hitch, Lift And Drabber - Control Linkage
Hydraulics - Ground Control
Hydraulics - Draft Sensing
Hydraulics - 3-Way Auxiliary Valves
Hydraulics - 3-Way Auxiliary Valve Control Levers
Hydraulics - 3-Way Auxiliary Valve Components
Hydraulics - 4-Way Auxiliary Valves, Eff. Tractor S N
Hydraulics - 4-Way Auxiliary Valve Control Levers, Eff. Tractor S N 1293-1462
Hydraulics - 4-Way Auxiliary Valves, Eff. Tractor S N 1463
Hydraulics - 4-Way Auxiliary Valve Control Levers, Eff. Tractor S N 1463
Hydraulics - 4-Way Auxiliary Valve Components, Eff. Tractor S N 1293-1462
Hydraulics - 5-Way Auxiliary Valves, Prior S N 1293
Hydraulics - 5-Way Auxiliary Valve Control Levers, Prior S N
Hydraulics - 5-Way Auxiliary Valve Components, Prior S N 1293
Hydraulics - 6-Way Auxiliary Valves, S N 1293-1462, Optional
Hydraulics - 6-Way Auxiliary Valve Control Levers, S N 1293-1462, Optional
Hydraulics - 6-Way Auxiliary Valves, Eff. Tractor S N 1463, Optional
Hydraulics - 6-Way Auxiliary Valve Control Levers, Eff. Tractor S N 1463, Optional
Hydraulics - 6-Way Auxiliary Valve Components, Eff. Tractor S N 1293-1462, Optional
Hydraulics - Valve Kit, Eff. S N 1463
Hydraulics - Remote Couplers, Pioneer
Hydraulics - Hydraulic Couplers, Pioneer
Hitch, Lift And Drabber - Three Point Hitch
Hitch, Lift And Drabber - 3-Point Hitch, Telescopic Links
Hitch, Lift And Drabber - Auxiliary Hydraulic Lift Cylinders, Optional
Hitch, Lift And Drabber - Rear Swinging Drabber, Prior S N
Hitch, Lift And Drabber - Rear Swinging Drabber, Eff. S N
Accessories - Rear P.T.O. Guard
Accessories - Front P.T.O Guard
Accessories - Radio Bracket
Accessories - Rear Fenders
Accessories - Extensions For Fender
Accessories - Rear Wiper
Accessories - Starter Slave Solenoid Kit, Prior S N 1506
Accessories - Ether Starting Aid Kit, 1st Type
Accessories - Ether Starting Aid Kit, 2nd Type Push-Button
Accessories - Manual Intake Shutter
Accessories - Air Inlet Shutter
Accessories - Pioneer Remote Coupler Assembly, 1st And 2nd
Accessories - Pioneer Remote Coupler Assembly, 3rd
Accessories - Air Chamber Heater
Accessories - Eberspacher Cab Heater
Accessories - Front Weights
Accessories - Tool Kit
Decals - Smv Emblem
Decals - Speed Charts
Decals - Safety Decals
Recommended Dealer Stock
