AGCO Allis Tractor 6680 Parts Catalog 79013781
Brand: AGCO Allis
Model: AGCO Allis 6680 Tractor
Part Number: 79013781
Number of Pages: 506 Pages
Parts Catalog Information
Engine - Crankcase
Engine - Front Cover
Engine - Rods, Pistons And Crankshaft
Engine - Counterweight
Engine - Camshaft
Engine - Oil Pan, Filter And Cooler
Engine - Oil Pump And Drive
Engine - Breather And Lines
Engine - Breather Components
Fuel System - Injectors And Injection Pump
Fuel System - Pump, Filter And Governor
Fuel System - Thermo Starting Aid
Fuel System - Governor Components
Fuel System - Governor Controls
Fuel System - Injection Pump Components
Fuel System - Injector Components
Fuel System - Fuel Filter Components
Fuel System - Fuel Pump Components
Engine Cooling - Blower Shield
Intake And Exhaust - Manifold
Intake And Exhaust - Exhaust Muffler
Clutch - Clutch Assembly-Organic 12 , Prior S N 1076
Clutch - Clutch Assembly - Cera-Metallic 13 , Eff. S N 1271
Clutch - Hydraulic Controls And Linkage
Clutch - Clutch Release
Clutch - Clutch Slave Cylinder Components
Clutch - Master Cylinder
Transmission - Gearbox Housing
Transmission - Gearbox Supports
Transmission - Reverse Gear
Transmission - Reverse Gear Controls, Fork And Rail
Transmission - Reverse Gear Controls, Gear Shift
Transmission - Hi-Lo
Transmission - Hi-Lo Controls
Transmission - Main Driven Shaft
Transmission - Gear Shift Assembly
Transmission - Gear Control Device
Transmission - Synchro Power Fifth Gear W Controls
Transmission - Fifth Gear With Synchro Power
Transmission - Synchro Power Hydraulic Hi-Lo Gear
Transmission - Hi-Lo Reduction Clutch
Transmission - Hi-Lo Reduction Clutch Housing
Transmission - Syncro Power W Mechanical Controls
Transmission - Syncro Power With Hydraulic Controls
Transmission - Reduction Gear
Transmission - Creeper Gear
Transmission - Range Controls
Transmission - Differential
Transmission - Differential Lock Fork Mechanical
Transmission - Differential Lock Control Mechanical
Transmission - Differential Lock Fork, Electrohydraulic
Transmission - Rear Axle Housing
Brakes - Rear Brake
Brakes - Parking Brake
Brakes - Hydraulic Controls And Linkage
Brakes - Cylinder Components
Brakes - Hand Brake
Brakes - Pedal Support
Front Axle And Differential - Front Support
Front Axle And Differential - Clutch Housing
Front Axle And Differential - Adjustable Axle - 2wd
Power Steering - Cylinder - 2wd
Power Steering - Cylinder Components - 2wd
Front Axle And Differential - Front Axle - 4wd, Prior S N
Front Axle And Differential - Front Axle - 4wd, Eff. S N 5651
Brakes - Front Brake System - 4wd
Brakes - Front Brake - 4wd
Power Steering - Cylinder - 4wd
Power Steering - Cylinder Components - 4wd
Front Axle And Differential - Differential - 4wd
Front Axle - Front Differential Lock - 4wd
Front Axle - Mechanical Front Differential, Locking Control
Front Axle - Electrohydraulic Front Differential, Locking
Front Axle - Planetary - 4wd
Front Axle - Front Differential Lock Control - 4wd
Front Axle - Transmission Shaft - 4wd
Front Axle - Pto - 4wd
Front Axle - Control - 4wd
Front Axle - Control Electrohydraulic - 4wd
Front Axle - Front Differential Cylinder Supply Line
P.T.O. - Transmission Shaft - Clutch Without, Synchro Power -
P.T.O. - Transmission Shaft - Clutch With, Synchro Power -
P.T.O. - Front Pto
P.T.O. - Hydraulic Clutch, With Mechanical Controls
P.T.O. - Controlled Hydraulic Clutch, Electrohydraulically
P.T.O. - Hydraulic Clutch - Pto
P.T.O. - Electrohydraulically Controlled, Hydraulic Clutch -
P.T.O. - Dual Shaft Pto
P.T.O. - Pump Control
P.T.O. - Four Speed Economy
P.T.O. - Mechanical Control - Pto
P.T.O. - Coupling Control
P.T.O. - Oil Filter - Pto
P.T.O. - Oil Suction - Pto
Power Steering - Steering Column With Adjustable, Steering
Power Steering - Control Unit Components
Power Steering - Pump And Lines
Power Steering - Pump, Filter And Lines, (Prior S N 1070)
Power Steering - Pump, Filter And Lines, (Eff. S N 1071)
Power Steering - Solenoid Valve Casing
Power Steering - Cooler With Lines - First Design
Power Steering - Steering Lines - 2wd
Power Steering - Steering Lines - 4wd
Power Steering - Hydrosteering - Two Cylinder, Single Acting
Power Steering - Oil Flow Control Valve Casing
Power Steering - Oil Flow Control Valve Case, Fuel Supply
Power Steering - Pump Components
Sheet Metal And Frame - Grill And Side Panels
Sheet Metal And Frame - Rear Panel
Sheet Metal And Frame - Bulkheads And Supports
Sheet Metal And Frame - Metal Toolbox
Sheet Metal And Frame - Fan And Belt Guard
Sheet Metal And Frame - Solenoid Valves Shield
Sheet Metal And Frame - Instrument Panel
Sheet Metal And Frame - Control Panel Bulkheads W O Heating
Fuel System - Fuel Shut Off And Throttle
Sheet Metal And Frame - Deck Supports
Sheet Metal And Frame - Platform
Sheet Metal And Frame - Interior Trim
Sheet Metal And Frame - Console
Sheet Metal And Frame - Safety Frame - Rops
Sheet Metal And Frame - Rops Canopy
Fuel System - Tank
Fuel System - Auxiliary Tank
Intake And Exhaust - Air Cleaner
Intake And Exhaust - Air Cleaner Components
Intake And Exhaust - Pre-Filter Components
Seat - Seat - Sable'
Electrical System - Lights
Electrical System - Digital Clock
Electrical System - Alternator Starter And Battery
Electrical System - Electrical Starting, Prior S N 1341
Electrical System - Electrical Starting, Eff. S N 1341
Electrical System - Electrical Controls
Electrical System - Electric Starting
Electrical System - Electric Starting Equipment
Electrical System - Alternator Components
Electrical System - Starter Components, Iskra
Electrical System - Starter Components, Bosch
Electrical System - Starter Components, Marelli 1st Type
Electrical System - Starter Components, Marelli 2nd Type
Electrical System - Control Switches Steering Column
Wheels - Wheels - 2wd
Wheels - Wheels - 4wd
Cab - Body
Cab - Mirror And Door Handle
Cab - Glasses And Weatherseals
Cab - Interior Trim
Cab - Electric Windshield Wiper
Cab - Windshield Wiper
Cab - Cab Ventilation Ducting
Air Conditioning & Heating System - Evaporator And Hoses
Air Conditioning & Heating System - Evaporator And Fan
Air Conditioning & Heating System - Compressor And Line
Air Conditioning & Heating System - Ventilation Air
Air Conditioning & Heating System - Ventilation - Heating
Air Conditioning & Heating System - Heater Alternator, Dual
Air Conditioning & Heating System - Heater, Prior S N 1316
Air Conditioning & Heating System - Enhanced Heater
Air Conditioning & Heating System - Enhanced Heater Components, Eff. S N 1316
Air Conditioning & Heating System - Enhanced Heater, Eff. S N 1316
Air Conditioning & Heating System - Alternator
Front Hitch And Lift - Front Hydraulic Power Lift
Front Hitch And Lift - Lifting Cylinder
Hydraulics - Hydraulic Housing
Hydraulics - Hydraulic Pump Components, Bosch 22cc
Hydraulics - Hydraulic Valve And Regulator, Prior S N 1137
Hydraulics - Hydraulic Valve And Regulator, Eff. S N 1138
Hydraulics - Inner And Outer Control Devices
Hydraulics - Connecting Rod & Control Lever Devices
Hydraulics - Ground Control
Hydraulics - Sensing Unit
Hydraulics - Valve And Lines - Three Way
Hydraulics - Three Way Auxiliary Hydraulic Equipment
Hydraulics - 4-Way Auxiliary Distributor, Eff. S N 1138 -
Hydraulics - 4-Way Auxiliary Distributor, Eff. S N 1147
Hydraulics - Hydraulic Distributor Parts
Hydraulics - 5-Way Auxiliary Distributor
Hydraulics - 5-Way Auxiliary Equipment
Hydraulics - Valve Components
Hydraulics - 6-Way Auxiliary Distributor, Eff. S N 1138 -
Hydraulics - 6-Way Auxiliary Distributor, Eff. S N 1147
Hydraulics - Hydraulic Valve Components
Hydraulics - Hydraulic Cylinders
Rear Hitch And Drawbar - Three Point Hitch And Drawbar
Rear Hitch And Drawbar - Telescopic Lower Links
Rear Hitch And Drawbar - Cylinders - Auxiliary Hydraulic
Rear Hitch And Drawbar - Rear Swinging Drawbar, Prior S N
Rear Hitch And Drawbar - Rear Swinging Drawbar, Eff. S N 1147
Accessories - Pto Guard
Accessories - Front Guard - Pto
Accessories - Front Mudguards - 2wd, (For 7.50 X 16 Tires)
Accessories - Front Muduards - 4wd, (For 12.4 X 24 -13.6 X
Accessories - Fenders Extensions
Accessories - Rear Wiper
Accessories - Radio Mounting
Accessories - Starter Slave Solenoiod Kit
Accessories - Ether Starting Aid Kit, 1st Type
Accessories - Ether Starting Aid Kit, 2nd Type Push-Button
Accessories - Manual Intake Shutter
Accessories - Air Inlet Shutter
Accessories - Pioneer Remote Coupler Assembly, 1st And 2nd
Accessories - Pioneer Remote Coupler Assembly, 3rd
Accessories - Air Chamber Heater
Accessories - Eberspacher Cab Heater
Accessories - Tool Pouch
Accessories - Front Weights
Accessories - Rear Weights
Decals - Speed Charts
Decals - Safety Decals
Recommended Dealer Stock - Recommended Dealer Stock, Note
