AGCO Allis Tractor 6670 Parts Catalog 79013779
Brand: AGCO Allis
Model: AGCO Allis 6670 Tractor
Part Number: 79013779
Number of Pages: 485 Pages
Parts Catalog Information
Engine - Crankcase
Engine - Front Cover
Engine - Crankshift And Pistons
Engine - Balancer
Engine - Camshaft
Engine - Cylinder Head
Engine - Oil Pan And Filter
Engine - Oil Pump And Drive
Engine - Breather
Engine - Oil Breather Components
Fuel System - Injection Pumps And Injectors
Fuel System - Pump, Filter, And Governor
Fuel System - Thermo Starting Aid
Fuel System - Governor
Fuel System - Governor Controls
Fuel System - Injection Pump Components
Fuel System - Injector Nozzle
Fuel System - Fuel Filter
Fuel System - Fuel Pump
Engine Cooling - Cooling Blower Shield
Engine Cooling - Blower
Intake And Exhaust System - Manifold
Intake And Exhaust System - Exhaust Muffler
Clutch - Clutch Assembly, Standard (Prior S N 1076)
Clutch - Control Pedal And Linkage
Clutch - Clutch Release
Clutch - Clutch Slave Cylinder Components
Clutch - Clutch Master Cylinder Components
Transmission - Gearbox Housing
Transmission - Gearbox Supports
Transmission - Reverse Gear
Transmission - Reverse Shift Fork And Rail
Transmission - Reverse Gear Controls
Transmission - Hi-Lo Gear
Transmission - Hi-Lo Gear Controls
Transmission - Main Driven Shaft
Transmission - Gear Shift Assembly
Transmission - Fifth Gear With Synchro Power Controls
Transmission - Five Speed Gearbox With Synchro Power
Transmission - Synchro Power Hydraulic Hi-Lo Gear
Transmission - Hi-Lo Reduction Clutch
Transmission - Hi-Lo Reduction Clutch Housing
Transmission - Synchro Power Mechanical Controls
Transmission - Synchro Power, Hydraulic Control
Transmission - Reduction Gear
Transmission - Creeper Gear
Transmission - Reduction Controls
Transmission - Range Controls
Transmission - Differential
Transmission - Differential Locking Control, Mechanical
Transmission - Differential Locking Control, Electrohydraulic
Transmission - Rear Axle Housing
Transmission - Rear Reduction Gear And Axle Shafts
Brakes - Rear Brakes
Brakes - Parking Brake
Brakes - Brake Controls
Brakes - Master Cylinder
Brakes - Hand Brake
Front Axle - Front Support
Front Axle - Clutch Housing
Front Axle - Adjustable Front Axle - 2wd
Power Steering - Cylinder - 2wd
Power Steering - Cylinder Components - 2wd
Front Axle - Front Axle - 4wd, Prior S N 3063
Front Axle - Front Axle - 4wd, Eff. S N 3063
Brakes - Front Brake System - 4wd
Brakes - Front Brake - 4wd
Power Steering - Cylinder - 4wd
Power Steering - Cylinder Components - 4wd
Front Axle - Differential - 4wd
Front Axle - Front Differential Lock - 4wd
Front Axle - Differential And Axle Shafts - 4wd
Front Axle - Axle Shafts With Differential Lock, 4wd
Front Axle - Mechanical Front Differential, Locking Control
Front Axle - Electrohydraulic Front Differential, Locking
Front Axle - Differential Lock Control, Front - 4wd
Front Axle - Transmission Shaft - 4wd
Front Axle - Pto - 4wd
Front Axle - Control - 4wd
Front Axle - Control Electrohydraulic - 4wd
Front Axle - Valve Body Engage - 4wd
Front Axle - Front Differential Cylinder Lines
Front Axle - Transmission Shaft Clutch Without, Synchro Power
P.T.O. - Transmission Shaft Clutch With, Synchro Power - Pto
P.T.O. - Front Pto
P.T.O. - Front
P.T.O. - Hydraulic Clutch, With Mechanical Controls
P.T.O. - Hydraulic Clutch - Pto
P.T.O. - Electrohydraulically Controlled, Hydraulic Clutch -
P.T.O. - Valve Body And Hydraulic Slave Units
P.T.O. - Sequence Valve, For Electrohydraulic Controls
P.T.O. - Elecyrohydraulic Control - Pto
P.T.O. - Four Speed Economy
P.T.O. - Four Speed Economy-Pto
P.T.O. - Dual Shaft Pto
P.T.O. - Mechanical Control - Pto
P.T.O. - Coupling Control
Power Steering - Steering Control With Adjustable, Steering
Power Steering
Power Steering - Control Unit Components
Power Steering - Power Steering - 2wd
Power Steering - Power Steering - 4wd
Power Steering - Hydraulic Pump Components
Sheet Metal And Frame - Hood
Sheet Metal And Frame - Hood Guards
Sheet Metal And Frame - Bulkheads And Supports
Sheet Metal And Frame - Fan Belt Guard
Sheet Metal And Frame - Solenoid Valves Protection Casing
Sheet Metal And Frame - Instrument Panel
Fuel System - Fuel Shutoff And Throttle
Sheet Metal And Frame - Platform
Sheet Metal And Frame - Platform Supports
Sheet Metal And Frame - Platform Console
Fuel System - Tank And Lines
Fuel System - Pre-Filter Components
Intake And Exhaust System - Air Cleaner
Intake And Exhaust System - Air Filter
Cab - Seat - Sable'
Cab - Seat
Electrical System - Lights
Electrical System - Digital Clock
Electrical System - Alternator, Starter And Battery
Electrical System - Electrical Starting, Prior S N 1083
Electrical System - Electrical Starting, Eff. S N 1173
Electrical System - Electrical Controls
Electrical System - Electric Starting System
Electrical System - Starter Components, Iskra
Electrical System - Starter Components, Bosch
Electrical System - Starter Components, Marelli - 1st Type
Electrical System - Alternator Components
Electrical System - Control Switches Steering Column, Prior S N 1002
Wheels - Wheels - 2wd
Wheels - Wheel - 4wd
Cab - Body
Cab - Mirror
Cab - Front Glass And Door Glass
Cab - Side Glass And Rear Glass
Cab - Interior Trim
Cab - Console
Cab - Windshield Washer And Wiper
Cab - Rear Window Wiper
Cab - Windshield Wiper Components
Air Conditioning And Heating System - Ventilation And Air
Air Conditioning And Heating System - Blower Fan And Housing
Air Conditioning And Heating System - Evaporator And Hoses
Air Conditioning And Heating System - Evaporator And Fan
Air Conditioning And Heating System - Ventilation Air
Air Conditioning And Heating System - Condensor
Air Conditioning And Heating System - Compressor Components
Air Conditioning And Heating System - Heating Blower And
Air Conditioning And Heating System - Heating Alternator
Air Conditioning And Heating System - Heater Alternator, Dual
Air Conditioning And Heating System - Heater Fan And Wiring, (Prior S N 1147)
Air Conditioning And Heating System - Enhanced Heater
Air Conditioning And Heating System - Enhanced Heater Components, (Eff. S N 1147)
Air Conditioning And Heating System - Enhanced Heater, (Eff. S N 1147)
Front Hitch And Lift - Front Hydraulic Power Lift Lines
Front Hitch And Lift - Front Hydraluic Lift Accumulator
Hydraulics - Oil Filters - Main Hydraulics
Hydraulics - Oil Suction - Main Hydraulics
Hydraulics - Pump Control
Hydraulics - Hydraulic Housing
Hydraulics - Manifold
Hydraulics - Hydraulic Pump
Hydraulics - Hydraulic Pump Components, Bosch (16cc)
Hydraulics - Hydraulic Pump Components, Bosch (22cc)
Hydraulics - Lift With 14.5 Cm Deg. , Cycle Pump
Hydraulics - Lift
Hydraulics - Regulating Valve
Hydraulics - Internal And External Controls
Hydraulics - Tie Rods And Control Levers
Hydraulics - Ground Control
Hydraulics - Draft Sensing
Hydraulics - Three Way Auxiliary Valve
Hydraulics - Distributor Three-Way Auxiliary Valve
Hydraulics - Valve Components
Hydraulics - 4-Way Auxiliary Distributor, Eff. S N 1057 - 1075
Hydraulics - 4-Way Auxiliary Distributor, Eff S N 1076
Hydraulics - Hydraulic Distributor Parts
Hydraulics - Control 5-Way Auxiliary
Hydraulics - Controls - Six Way Auxiliary Valve, Eff. S N 1057 - 1075
Hydraulics - Six Way Auxiliary Valve, Eff. S N 1076
Hydraulics - Controls - Six Way Valve, Eff. S N 1076
Hydraulics - Hydraulic Valve Components
Rear Hitch And Drawbar - Three Point Hitch And Drawbar
Rear Hitch And Drawbar - Three Point Hitch, Telescopic Lower
Rear Hitch And Drawbar - Rear Swinging Drawbar, Prior S N
Rear Hitch And Drawbar - Rear Swinging Drawbar, Eff. S N 1076
Accessories - Pto Guard
Accessories - Front Guard - Pto
Accessories - Front Mudguards - 2wd, (For 7.50 X 16 Tires)
Accessories - Front Muduards - 4wd, (For 12.4 X 24 -13.6 X
Accessories - Fenders Extensions
Accessories - Radio Mounting
Accessories - Starter Slave Solenoiod Kit
Accessories - Ether Starting Aid Kit, 1st Type
Accessories - Ether Starting Aid Kit, 2nd Type Push-Button
Accessories - Manual Intake Shutter
Accessories - Air Inlet Shutter
Accessories - Pioneer Remote Coupler Assembly, 1st And 2nd
Accessories - Pioneer Remote Coupler Assembly, 3rd
Accessories - Air Chamber Heater
Accessories - Eberspacher Cab Heater
Accessories - Tool Pouch
Accessories - Front Weights
Accessories - Rear Weights
Decals - Speed Charts
Decals - Safety Decals
Brand: AGCO Allis
Engine - Crankcase
Engine - Balancer
Engine - Camshaft
Engine - Breather
Brakes - Hand Brake
P.T.O. - Front Pto
P.T.O. - Front
Power Steering
Cab - Seat - Sable'
Cab - Seat
Cab - Body
Cab - Mirror
Cab - Interior Trim
Cab - Console
Hydraulics - Lift
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
