AGCO Allis Tractor 6275 Vario Cab DX3.90 Vario Cab Parts Catalog 79007814
Brand: AGCO Allis
Model:
AGCO Allis 6275 Vario Cab Tractor
AGCO Allis DX3.90 Vario Cab Tractor
Part Number: 79007814
Number of Pages: 314 Pages
Engine - Crankcase
Engine - Crankcase, Front Cover
Engine - Crankcase, Idler Gear Bearing
Engine - Crankcase, Breather
Engine - Oil Pan
Engine - Cylinder, Pieces, Cyl. Unit
Engine - Crankshaft
Engine - Crankshaft, Mass-Balancing Gear
Engine - Connecting Rod, 3lbs 12oz
Engine - Piston
Engine - Cylinder Head
Engine - Cylinder Head, Rocker Arm Cover
Engine - Camshaft
Engine - Pushrods And Rocker Arm
Engine - Pump, Lube Oil & Pressure Pipe
Engine - Cooler, Oil
Engine - Cooler, Oil, Lube Oil Filter
Engine - Oil Pipes, Oil Suction Pipe
Engine - Pump, Injection
Engine - Pump Injection, Lube Oil Pipe
Engine - Injector, Pieces, Cyl. Unit
Engine - Fuel Filter Element
Engine - Fuel Pipes, Injection Lines
Engine - Fuel Pipes, Overflow Pipe
Engine - Air Intake, Suction Pipe
Engine - Blower, Cooling Air, With Air Conditioning
Engine - Cooling, Air Ducting, Stay Plate
Engine - Cooling, Air Ducting, Air Shield
Engine - Cooling, Air Ducting, Air Cowling Base
Engine - Manifold, Exhaust
Engine - Alternator, 55 And 65 Amp
Engine - Alternator Mounting Brackets
Engine - Engine Oil Pressure Switch
Engine - Gasket Set
Transmission - Clutch Release Mechanism
Transmission - Clutch Control Assembly, Foot Release
Transmission - Clutch Control Assembly, Pto
Transmission - Transmission Housing
Transmission - Rear Axle Housing
Transmission - Transmission Overview
Transmission - Input Shaft Asy.
Transmission - Main Shaft Assembly
Transmission - Intermediate Shaft Asy.
Transmission - Gearshift Assembly
Transmission - Front Wheel Drive Transmission
Transmission - Control Handle
Transmission - Intermediate Shaft - Brake
Transmission - Differential Gear Asy.
Transmission - Rear Axle Housing Assembly, Heavy Duty
Transmission - Pto Shaft, 540 Rpm Pto
Transmission - Pto Shaft, 540 1000 Rpm Pto
Transmission - Control Linkage, 540 Rpm Pto
Transmission - Front Pto Transmission
Transmission - Control Assembly, Front Pto
Transmission - Pto Shield
Brake - Control Assembly, Parking Brake
Brake - Brake Drum Assembly
Brake - Brake Control Asy.
Brake - Brake Lines
Hydraulic System - Steering Lines, Bosch (Items 1, 3, 82-85)
Hydraulic System - Hydraulic Pump
Hydraulic System - Hydraulic Lift, Housing & Rocker Asy.
Hydraulic System - Hydraulic Lift, Hydraulic Parts & Cover
Hydraulic System - Hydraulic Lift, Lift Arms
Hydraulic System - Hydraulic Lift, Lift Shaft
Hydraulic System - Hydraulic Lift, Auxiliary Cylinder
Hydraulic System - Hydraulic Lift &, Oil Dipstick Lock
Hydraulic System - Hydraulic Lift, Oil Filter
Hydraulic System - Hydraulic Lift, Hydraulic Cylinder
Hydraulic System - Auxiliary Oil Reservoir
Hydraulic System - Intermediate Valve, Single - Acting
Hydraulic System - Intermediate Valve, Double - Acting
Hydraulic System - Terminal Valve, Single - Acting
Hydraulic System - Terminal Plate
Hydraulic System - Hydraulic Control - Front Hitch
Remote Couplers - Hydraulic Couplers - Pioneer
Remote Couplers - Coupler Asy - For Pioneer Couplers
Remote Couplers - Hydraulic Coupling Kit, With Banjo Fittings
Remote Couplers - Hydraulic Coupling Kit - O-Ring Couplers
Remote Couplers - Front Lift, Hydraulic Lines
Remote Couplers - 3-Point Linkage - Category Ii
Remote Couplers - Top Link - Category Ii
Remote Couplers - Connecting Rod
Remote Couplers - Hydraulic Cylinder - Front Hitch
Remote Couplers - Top Link Telescopic
Front Axles & Steering - Front Axle Bracket
Front Axles & Steering - Telescopic Axle, Spindles & Hubs
Front Axles & Steering - Tie Rod - Telescopic Axle
Front Axles & Steering - Front Axle Asy. - 4wd
Front Axles & Steering - Front Axle - 4wd, Planetary Drive
Front Axles & Steering - Front Axle - 4wd, Differential,
Front Axles & Steering - Front Axle - 4wd, Differential Asy.
Front Axles & Steering - Front Axle-4wd, Universal Joint Asy.
Front Axles & Steering - Power Steering Lines - 2wd
Front Axles & Steering - Power Steering Lines - 4wd
Front Axles & Steering - Steering Column
Front Axles & Steering - Power Steering Pump - Danfoss
Front Axles & Steering - Power Steering Pump-Zf-
Front Axles & Steering - Power Steering Cylinder - 2wd
Body - Engine Hood
Body - Console & Dashboard
Body - Speed Control
Body - Front Fender - 2wd, For 7.50-18 & 7.50-20 Tires
Body - Front Fenders - 2wd, For 10.00-16 Tires
Body - Front Fenders - 4wd, For 11.2-24 Tires
Body - Front Fenders - 4wd, With Front-End Loader
Body - Deck
Body - Rops, Type I
Body - Front Wall & Frame
Body - Windshield
Body - Lower Front Frame
Body - Side Walls
Body - Door Frame
Body - Door, Prior S N 7754 0364 For 2wd
Body - Door, Effective With S N 7754 0363 For 2wd
Body - Rear Wall
Body - Rear Window Assembly
Body - Sound Absorbent Liners
Body - Folding Seat Assembly
Body - Folding Seat - Rail & Mounting
Body - Foot Plate, Used W O Vario Cab
Body - Toolbox & Mounting, Type I
Body - Driving Mirror, W Vario Cab
Body - Decals
Body - Decals, Deutz-Allis & Deutz-Fahr
Engine Supply - Fuel Tank
Engine Supply - Fuel Filter, Optional
Engine Supply - Dry-Type Air Cleaner, W Intake Under Hood
Engine Supply - Exhaust - Vertical
Electrical Equipment - Main Wiring
Electrical Equipment - Wiring - Oil Fired Heater
Electrical Equipment - Instrument Panel Asy.
Electrical Equipment - Pilot Light Asy.
Electrical Equipment - Water Reservoir
Electrical Equipment - Headlight - Sealed Beam Halogen
Electrical Equipment - Rear Work Lamp Group
Electrical Equipment - Work Lamp
Electrical Equipment - Front Fender Lamps
Heating System - Auxilary Heater & Mounting
Heating System - Heater, Fuel Fired
Heating System - Auxilary Heater Lines, 1.7 Kw
Hitch Assembly - Clevis
Hitch Assembly - Hitch Pin
Hitch Assembly - Trailer Bracket
Hitch Assembly - Drawbar
Wheels - Front Wheels - Fixed
Wheels - Front Wheels - Adjustable, 4wd
Wheels - Rear Wheels - Manual Adjust
Wheels - Weights
Miscellaneous - Paint, Loctite, Sealing Compound, Activator
