AGCO Allis Tractor 6265 Vario Cab DX 3.70 Vario Cab Parts Catalog 79007816
Brand: AGCO Allis
Model:
AGCO Allis 6265 Vario Cab Tractor
AGCO Allis DX 3.70 Vario Cab Tractor
Part Number: 79007816
Number of Pages: 312 Pages
Engine - Crankcase
Engine - Idler Gear Bearing
Engine - Front Cover
Engine - Spray Nozzle
Engine - Breather, Dipstick & Guard Plate
Engine - Oil Pan
Engine - Crankshaft
Engine - Mass-Balancing Gear
Engine - Connecting Rod, 3lbs 12oz
Engine - Piston, 1st Type
Engine - Cylinder Head
Engine - Cylinder
Engine - Camshaft
Engine - Lube Oil Pump & Pressure Pipe
Engine - Lube Oil Filter
Engine - Injection Pump
Engine - Injector
Engine - Filter Cartridge
Engine - Injection Lines
Engine - Pump Overflow Line
Engine - Intake Manifold
Engine - Stay Plate
Engine - Air Shield
Engine - Air Cowling Base
Engine - Exhaust Manifold, Vertical Muffler
Engine - Alternator, 55 Amp
Engine - Generator Mounting Brackets
Engine - Engine Oil Pressure Switch
Engine - Gasket Sets
Transmission - Clutch Release Mechanism
Transmission - Clutch Control Assembly, Foot Release
Transmission - Clutch Control Assembly, Pto
Transmission - Transmission Housing
Transmission - Rear Axle Housing
Transmission - Transmission Overview
Transmission - Input Shaft Asy.
Transmission - Main Shaft Asy.
Transmission - Intermediate Shaft Assembly
Transmission - Gearshift Assembly
Transmission - Front Wheel Drive Transmission
Transmission - Control Handle
Transmission - Intermediate Shaft - Brake
Transmission - Differential Gear Asy.
Transmission - Rear Axle Housing Asy., Standard
Transmission - Pto Shaft, 540 Rpm Pto
Transmission - Pto Shaft, 540 1000 Rpm Pto
Transmission - Control Linkage, 540 Rpm Pto
Transmission - Front Pto Transmission
Transmission - Control Assembly, Front Pto
Brake - Control Assembly, Parking Brake
Brake - Brake Drum Asy.
Brake - Brake Control Asy.
Brake - Brake Lines
Hydraulic System - Steering Lines
Hydraulic System - Hydraulic Pump
Hydraulic System - Hydraulic Lift, Housing & Rocker Asy.
Hydraulic System - Hydraulic Lift, Hydraulic Parts & Cover
Hydraulic System - Hydraulic Lift, Lift Arms
Hydraulic System - Hydraulic Lift, Lift Shaft, Lever &
Hydraulic System - Hydraulic Lift, Auxiliary Cylinder
Hydraulic System - Hydraulic Lift &, Oil Dipstick Lock
Hydraulic System - Hydraulic Lift, Oil Filter
Hydraulic System - Hydraulic Lift, Hydraulic Cylinder - Early
Hydraulic System - Auxiliary Oil Reservoir
Hydraulic System - Intermediate Valve, Single - Acting
Hydraulic System - Intermediate Valve, Double - Acting
Hydraulic System - Terminal Valve, Single - Acting
Hydraulic System - Terminal Plate
Hydraulic System - Hydraulic Control - Front Hitch, Coupler
Hydraulic System - Front Lift, Hydraulic Lines
Hydraulic System - 3-Point Linkage - Category Ii
Hydraulic System - Top Link - Category Ii
Hydraulic System - Connecting Rod
Hydraulic System - Hydraulic Cylinder - Front Hitch
Hydraulic System - Top Link Telescopic
Front Axles & Steering - Front Axle Bracket
Front Axles & Steering - Telescopic Axle, Spindles & Hubs
Front Axles & Steering - Tie Rod - Telescopic Axle
Front Axles & Steering - Front Axle Asy. - 4wd
Front Axles & Steering - Front Axle - 4wd, Planetary Drive
Front Axles & Steering - Front Axle - 4wd, Differential,
Front Axles & Steering - Front Axle - 4wd, Differential Asy.
Front Axles & Steering - Front Axle - 4wd, Universal Joint
Front Axles & Steering - Power Steering Lines - 2wd
Front Axles & Steering - Power Steering Lines - 4wd
Front Axles & Steering - Steering Column
Front Axles & Steering - Power Steering Pump - Danfoss
Front Axles & Steering - Power Steering Pump-Zf-
Front Axles & Steering - Power Steering Pump - Zf -
Front Axles & Steering - Power Steering Cylinder - 2wd
Body - Engine Hood
Body - Console & Dashboard
Body - Speed Control
Body - Front Fender - 2wd, For 6.50-16 & 7.50-16 Tires
Body - Front Fenders - 2wd, For 10.00-16 Tires
Body - Front Fenders - 4wd, For 11.2-24 Tires
Body - Front Fenders - 4wd, For 13.6-24 Tires
Body - Deck
Body - Rops
Body - Front Wall & Frame
Body - Windshield
Body - Lower Front Frame
Body - Side Walls
Body - Door Frame
Body - Door, Prior S N 7746 0634 For 2wd, Prior S N 7750 0583
Body - Door, Eff. S N 7746 0634 For 2wd, Eff. S N 7750 0583
Body - Rear Wall
Body - Rear Window Assembly
Body - Sound Absorbant Liners
Body - Folding Seat Assembly
Body - Folding Seat - Rail & Mounting
Body - Foot Plate, Used W O Vario Cab
Body - Toolbox & Mounting, Type I
Body - Driving Mirror, W Vario Cab
Body - Decals
Body - Decals, Deutz-Allis & Deutz-Fahr
Engine Supply - Fuel Tank
Engine Supply - Fuel Filter
Engine Supply - Dry-Type Air Cleaner, W Intake Under Hood
Engine Supply - Exhaust - Vertical
Electrical Equipment - Main Wiring
Electrical Equipment - Wiring - Oil Fired Heater
Electrical Equipment - Instrument Panel Asy., W Gauges &
Electrical Equipment - Pilot Light Asy.
Electrical Equipment - Water Reservoir
Electrical Equipment - Headlight - Canopy, Used W Front Hitch
Electrical Equipment - Rear Work Lamp Group
Electrical Equipment - Work Lamp
Electrical Equipment - Front Fender Lamps
Heating System - Auxilary Heater & Mounting
Heating System - Auxilary Heater Lines, 1.7 Kw
Heating System - Heater, Fuel Fired
Hitch Assembly - Clevis
Hitch Assembly - Hitch Pin
Hitch Assembly - Towing Clevis
Hitch Assembly - Drawbar
Wheels - Front Wheels - Fixed
Wheels - Front Wheels - Adjustable, 4wd
Wheels - Rear Wheels - Manual Adjust
Wheels - Weights
Wheels - Designation And Specification
Miscellaneous - Paint, Loctite, Sealing Compound & Activator
Remote Couplers - Hydraulic Couplers - Pioneer
Remote Couplers - Coupler Asy - For Pioneer Couplers
Remote Couplers - Hydraulic Coupling Kit, With Banjo Fittings
Remote Couplers - Hydraulic Coupling Kit - O-Ring Couplers,
