AGCO Allis Tractor 6260 Star Cab DX 3.50 Star Cab Parts Catalog 79007778
Brand: AGCO Allis
Model:
AGCO Allis 6260 Star Cab Tractor
AGCO Allis DX 3.50 Star Cab Tractor
Part Number: 79007778
Number of Pages: 419 Pages
Engine - Crankcase
Engine - Crankcase, Front Cover
Engine - Crankcase, Idler Gear Bearing
Engine - Crankcase, Breather
Engine - Oil Pan
Engine - Cylinder, Pieces, Cyl. Unit
Engine - Crankshaft
Engine - Connecting Rod, Unit Pieces
Engine - Piston
Engine - Cylinder Head, Unit Pieces
Engine - Camshaft
Engine - Pump, Lube Oil
Engine - Cooler, Oil, Lube Oil Cooler
Engine - Oil, Pipes
Engine - Pump, Injection
Engine - Pump, Injection, Overflow Valve
Engine - Pump, Injection, Lube Oil Pipe
Engine - Injector, Pieces, Cyl. Unit
Engine - Fuel, Filter, Filter Cartridge
Engine - Fuel, Pipes, Injection Pipes
Engine - Fuel, Pipes, Overflow Pipe
Engine - Air, Intake, Intake Manifold
Engine - Blower, Cooling Air
Engine - Cooling Air, Ducting, Baffle Mounting Plate
Engine - Cooling Air, Ducting, Cover
Engine - Cooling Air, Ducting, Air Guide Upper Part
Engine - Cooling Air, Ducting, Stay Plate
Engine - Manifold, Exhaust, Up Exhaust
Engine - Alternator
Engine - Alternator, Mounting Brackets
Engine - Electrical Accessories, Oil Press Switch
Engine - Gaskets
Transmission - Clutch
Transmission - Clutch, Dual
Transmission - Travel Clutch
Transmission - Pto Clutch
Transmission - Control Assembly, Pto Clutch, Hand Lever
Transmission - Housing, Clutch
Transmission - Housing, Clutch, Transmission Case
Transmission - Change Speed Gearbox, Transmission
Transmission - Change Speed Gearbox, Drive Shaft
Transmission - Change Speed Gearbox, Reduction Gear
Transmission - Change Speed Gearbox, Bearing Cap
Transmission - Change Speed Gearbox, Main Shaft
Transmission - Change Speed Gearbox, Layshaft
Transmission - Change Speed Gearbox, Reverse Gear
Transmission - Change Speed Gearbox, Creep Gear
Transmission - Gearshift Assembly
Transmission - Gearshift Assembly, Creep Gear
Transmission - Gearshift Assembly, Reduction Gear
Transmission - Front Wheel Drive
Transmission - Control Assembly, Front Wheel Drive
Transmission - Bevel Drive
Transmission - Shaft, Intermediate
Transmission - Differential, Gear
Transmission - Differential Lock, Control Assembly
Transmission - Axle, Rear, Disc Brake
Transmission - Shaft, Pto Rear, Standard
Transmission - Shaft, Pto Rear, Two-Speed
Transmission - Pto Shaft-Single, Control Assembly, 540 Rpm
Transmission - Pto Shaft-2 Speed, Control Assembly
Transmission - Pto Shaft-Single, Switch
Transmission - Pto Shaft-Two Speed, Switch Gear
Transmission - Shaft, Front Pto
Transmission - Pto Shaft, Control Assembly
Transmission - Pto Shaft, Hand Lever
Transmission - Guard, Rear Pto
Brakes - Parking Brake, 180 X 60
Brakes - Parking Brake-Stick, Control Assembly
Brakes - Parking Brake-Linkage, Control Assembly
Brakes - Operating Brake, Disc Brake, Hydraulic Rear
Brakes - Service Brake Control Assembly
Brakes - Service Brake, Control Assembly
Brakes - Operating Brake, Disc Brake, Control Assembly
Hydraulics - Oil Supply, Pump Tandem
Hydraulics - Oil Supply, Hydraulic Pump, Bosch
Hydraulics - Hydraulic Lift
Hydraulics - Lift Housing
Hydraulics - Hydraulic Lift, Oil Dipstick Lock
Hydraulics - Breather Pipe
Hydraulics - Additional Oil Tank
Hydraulics - Intermediate Unit I, Sealing Valve
Hydraulics - Intermediate Unit Ii, Sealing Control Valve
Hydraulics - Terminal Unit
Hydraulics - Hydraulic Control, Front Pipes
Hydraulics - Hydraulic Control, Control Assembly
Hydraulics - Hydraulic Coupling Kit, With Banjo Fittings,
Hydraulics - Hydraulic Coupling Kit - O-Ring Couplers
Hydraulics - Hydraulic Control - Coupling Kit
Hydraulics - Coupler Asy - For Pioneer Couplers
Hitch, Lift And Draw Bar - Three-Point Hitch, Catergory Ii
Hitch, Lift And Draw Bar - Three-Point Hitch, Top-Link
Hitch, Lift And Draw Bar - Three-Point Hitch, Connecting Rod
Hitch, Lift And Draw Bar - Lift, Front Power
Hitch, Lift And Draw Bar - Lift, Front Power, Pipes
Hitch, Lift And Draw Bar - Hydraulic Cylinder - Front Hitch
Hitch, Lift And Draw Bar - Hitch, Deutz, Top Link-Telescopic,
Front Axles & Steering - Front Axle Bracket
Front Axles & Steering - Telescopic Axle, Spindles & Hubs
Front Axles & Steering - Tie Rod - Telescopic Axle
Front Axles & Steering - Front Axle Asy. - 4wd
Front Axles & Steering - Front Axle - 4wd, Planetary Drive
Front Axles & Steering - Front Axle - 4wd, Differential,
Front Axles & Steering - Front Axle - 4wd, Differential Asy.
Front Axles & Steering - Front Axle-4wd, Universal Joint Asy.
Front Axles & Steering - Power Steering, Telescopic Axle
Front Axles & Steering - Power Steering, Driven Axle
Front Axles & Steering - Power Steering, Steering Column
Front Axles & Steering - Power Steering Pump - Danfoss
Front Axles & Steering - Power Steering Pump-Zf
Front Axles & Steering - Power Steering Cylinder - 2wd
Body - Hood Engine
Body - Instrument Box
Body - Speed Control
Body - Shutdown Device
Body - Front Fender - 2wd, Telescopic Axle
Body - Mudguards, Front, Driven Axle, For 11.2-24 Tires
Body - Mudguards, Rear, Standard
Body - Cab Structure And Glass, Drivers Cab
Body - Cab Structure And Glass, Drivers Cab, Support
Body - Cab Structure And Glass, Drivers Cab-Roof
Body - Cab Structure And Glass, Window, Front, Fixed
Body - Cab Structure And Glass, Vent Window, Rear
Body - Cab Structure And Glass, Windscreen
Body - Cab Structure And Glass, Side Wall, Right Hand
Body - Cab Structure And Glass, Side Pane, Right Hand
Body - Cab Structure And Glass, Cab Door, Front
Body - Cab Structure And Glass, Rear Window, At Bottom
Body - Cab Structure And Glass, Rear Flap
Body - Control Console
Body - Cab Panelling, Sound Absorbing, Roof
Body - Panelling, Cab (Sound Absorbing), Side Panelling
Body - Floor Covering, Lining
Body - Driver Seat, Base Plate, Fabric-Covering
Body - Driver Seat, Comfort Seat Adjusting Device,
Body - Seat Driver, Comfort Seat, Spring Assy,
Body - Seat Driver, Super-Grammer
Body - Foot Plate
Body - Toolbox And Mounting Bracket, With Air Conditioning
Body - Driving Mirror
Body - Driving Mirror, Inside Mirror
Body - Reflector Rear
Body - Decals
Body - Decals, Deutz-Allis & Deutz-Fahr
Engine Supply - Fuel Tank
Engine Supply - Gauge, Fuel
Engine Supply - Fuel Filter, Optional
Engine Supply - Air Cleaner, Dry-Type
Engine Supply - Air Cleaner, Dry-Type, With Intake Stack
Engine Supply - Muffler, With Outlet Stack
Electrical Equipment - Main Wiring
Electrical Equipment - Auxiliaries-Heating, System, Clock
Electrical Equipment - Block Heater, Mfg. No. 76567140-8
Electrical Equipment - Switch Box With Instruments
Electrical Equipment - Pilot Light
Electrical Equipment - Tachometer
Electrical Equipment - Windshield Washing System, Front
Electrical Equipment - Windshield Washing System, Rear
Electrical Equipment - Headlight, Top Auxiliaries
Electrical Equipment - Headlight, At Top
Electrical Equipment - Headlight, Sealed-Beam Halogen
Electrical Equipment - Headlight, Auxiliaries Acc, Work Lamp
Electrical Equipment - Headlight, Work Lamp
Electrical Equipment - Lights, Front
Heating System - Heater, Fuel Fired
Heating System - Hot Air Heating, Air Distributor
Heating System - Auxiliary Heating, D3l 3.2 Kw
Cooling System - Ventilation, Breather
Cooling System - Blower
Cooling System - Air Conditioning
Cooling System - Air Conditioning Pipes
Cooling System - Air Conditioning, Condenser
Cooling System - Air Conditioning, Compressor
Cooling System - Air Conditioning, Vaporizer
Hitch Assembly - Hitch Pin, Front Lift
Hitch Assembly - Carrier, Weight
Hitch Assembly - Hitch, Trailer, Bracket
Hitch Assembly - Drawbar, With Small Swing
Wheels - Wheels, Standard Front
Wheels - Wheels, Adjustable Rear
Wheels - Rear Wheels - Power Adjust
Miscellaneous - Paint, Loctite, Sealing Compound, Activator
