AGCO Allis Tractor 5220 Synchro-Shift Parts Catalog 79007514
Brand: AGCO Allis
Model: AGCO Allis 5220 Synchro-Shift Tractor
Part Number: 79007514
Number of Pages: 181 Pages
Engine - Gasket Set, Cylinder Head
Engine - Gasket Set, Intermediate
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Valve Operation Mechanism
Engine - Timing Gear Cover
Engine - Idle Gear
Engine - Oil Pump & Filter
Engine - Governor
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Muffler
Cooling System - Radiator
Cooling System - Thermostat & Housing
Cooling System - Water Pump
Fuel System - Pump, Lines & Filter
Fuel System - Fuel Injection System, Fuel Injection Pump
Fuel System - Fuel Injection System, Injector
Fuel System - Controls, Throttle & Controls
Fuel System - Fuel Tank
Electrical & Instruments - Engine Electrical System
Electrical & Instruments - Instruments, Gauges & Wiring
Electrical & Instruments - Electrical Lighting, Head Lamp
Electrical & Instruments - Engine Electrical System,
Sheet Metal, Frame & Seat - Front Frame
Sheet Metal, Frame & Seat - Fender
Sheet Metal, Frame & Seat - Platform
Sheet Metal, Frame & Seat - Hood & Grille
Sheet Metal, Frame & Seat - Protective Frame & Canopy, Rops
Sheet Metal, Frame & Seat - Decals
Sheet Metal, Frame & Seat - Instrument Panel
Sheet Metal, Frame & Seat - Seat
Drive Train - Transmission, Gasket Set
Drive Train - Clutch, Housing
Drive Train - Clutch, Main & P.T.O.
Drive Train - Transmission, Input Shaft
Drive Train - Controls, Clutch
Drive Train - Transmission, Housing
Drive Train - Transmission, Main Shaft & Covers
Drive Train - Transmission, Countershaft
Drive Train - Transmission, Reverse Gear
Drive Train - Transmission, Controls, Gear Shift & Linkage
Drive Train - Transmission, Controls, Standard Range Control
Drive Train - Transmission, Controls, Reduction Range Control
Drive Train - Transmission, Controls, Front Drive
Drive Train - Transmission, Controls, P.T.O. Shift
Drive Train - Transmission, Reduction & Pinion Gears
Drive Train - Transmission, Range
Drive Train - Differential & Final Drive, Housing
Drive Train - Differential & Final Drive, Rear
Drive Train - Differential, Lock Control
Drive Train - Differential & Final Drive, Front
Drive Train - Differential & Final Drive, Axle, Right Hand
Drive Train - Differential & Final Drive, Axle, Left Hand
Drive Train - Differential & Final Drive, Drive Shaft
Drive Train - P.T.O., Shaft, Front
Drive Train - P.T.O., Shaft & Gears, Intermediate
Drive Train - P.T.O., Extension Shaft
Brake - Brake, Left Hand
Brake - Brake, Right Hand
Brake - Brake, Controls
Hitch & Lift - Lift Shaft & Housing
Hitch & Lift - 3-Point Hitch
Hitch & Lift - Drawbar
Axle, Steering & Wheels - Steering
Axle, Steering & Wheels - Tie Rod, 2-Wheel Drive
Axle, Steering & Wheels - Tie Rod, 4-Wheel Drive
Axle, Steering & Wheels - Front Axle, 2-Wheel Drive
Axle, Steering & Wheels - Front Axle, 4-Wheel Drive
Axle, Steering & Wheels - Front Hub, Front Axle
Axle, Steering & Wheels - Turf Wheel, Front
Axle, Steering & Wheels - Agriculture Wheel, Front
Axle, Steering & Wheels - Wheel, 4-Wheel Drive, Front
Hydraulic System - Lines, Pump & Filter
Hydraulic System - Steering System, Lines & Pump
Hydraulic System - Steering System, Cylinder & Lines
Hydraulic System - Pump, Lift
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Linkage & Valve
Hydraulic System - Valve, Lift Control
Hydraulic System - Valve, Remote & Outlet
Hydraulic System - Controls, Remote Valves, Type 1
Hydraulic System - Controls, Remote Valves, Type 2
Hydraulic System - Controls, Hydraulic Lift
Hydraulic System - Cylinder, Hydraulic Lift
