AGCO Allis Tractor 5215 Synchro-Shift Parts Catalog 79009297
Brand: AGCO Allis
Model: AGCO Allis 5215 Synchro-Shift Tractor
Part Number: 79009297
Number of Pages: 168 Pages
Engine - Gasket Set, Cylinder Head
Engine - Gasket Set, Intermediate
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Idle Gear
Engine - Oil Pan
Engine - Timing Gear Cover
Engine - Piston & Connecting Rod
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Governor
Air Intake And Exhaust - Manifold, Intake & Exhaust
Air Intake And Exhaust - Muffler & Air Cleaner
Cooling - Water Pump
Cooling - Water Outlet
Cooling - Radiator
Fuel System - Lines & Primary Filter
Fuel System - Fuel Injection Pump
Fuel System - Fuel Filter Asy.
Fuel System - Throttle & Controls
Fuel System - Fuel Tank
Electrical And Instruments - Wiring, Battery & Gauges
Electrical And Instruments - Starter, Alternator & Regulator
Electrical And Instruments - Alternator
Electrical And Instruments - Starting Motor
Electrical And Instruments - Lighting, Lamps
Sheet Metal, Frame And Seat - Front Frame, W Weights
Sheet Metal, Frame And Seat - Hood And Grille
Sheet Metal, Frame And Seat - Rear Hood, Instrument Panel
Sheet Metal, Frame And Seat - Platform
Sheet Metal, Frame And Seat - Fenders
Sheet Metal, Frame And Seat - Seat
Sheet Metal, Frame And Seat - Protective Frame
Sheet Metal, Frame And Seat - Decals
Drive Train - Clutch, Housing
Drive Train - Drive Shaft, Main Drive
Drive Train - Transmission, Housing
Drive Train - Transmission, Main Shaft & Cover
Drive Train - Transmission, Countershaft
Drive Train - Transmission, Gears & Pinion Shaft
Drive Train - Transmission, Reverse Gear
Drive Train - Transmission, Range Shift Control
Drive Train - Controls, Gear Shift & Linkage
Drive Train - Controls, Front Drive
Drive Train - Controls, P.T.O. Shift, Transmission
Drive Train - Differential & Final Drive, Housing
Drive Train - Differential & Final Drive, Rear
Drive Train - Differential & Final Drive, Axle, Right Hand
Drive Train - Differential & Final Drive, Axle, Left Hand
Drive Train - Differential, Lock Control
Drive Train - Differential & Final Drive, Gears, Front Drive
Drive Train - Drive Shaft, Front Axle, 4-Wheel Drive
Drive Train - Pto Shaft, And Gears
Drive Train - Pto Shaft, Extension
Brakes - Brake, Right Hand
Brakes - Controls & Linkage
Hitch And Lift - Lift Shaft & Housing
Hitch And Lift - 3-Point Hitch
Hitch And Lift - Pto Guard & Drawbar
Hitch And Lift - Rear Weight, Hitch Mounted
Axles, Steering And Wheels - Steering
Axles, Steering And Wheels - Tie Rods
Axles, Steering And Wheels - Front Axle, 2-Wheel Drive
Axles, Steering And Wheels - Front Axle, 4-Wheel Drive
Axles, Steering And Wheels - Front Axle, Hub, 4-Wheel Drive
Axles, Steering And Wheels - Wheels And Tires, Agriculture
Axles, Steering And Wheels - Wheels And Tires, Turf
Hydraulic System - Lines
Hydraulic System - Lift Pump
Hydraulic System - Lift Housing, Linkage & Valve
Hydraulic System - Lift Housing, Cover Asy.
Hydraulic System - Lift Cylinder, Valve & Cover
Hydraulic System - Lift Control
Hydraulic System - Remote Valve, One Spool
Hydraulic System - Power Steering (First Type), Four Wheel Dr
Hydraulic System - Power Steering Cylinder (First Type)
Hydraulic System - Power Steering Cylinder (Second Type)
Brand: AGCO Allis
Engine - Idle Gear
Engine - Oil Pan
Engine - Crankshaft
Engine - Governor
Cooling - Radiator
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
