AGCO Allis Tractor 5215 HST Parts Catalog 79008076
Brand: AGCO Allis
Model: AGCO Allis 5215 HST Tractor
Part Number: 79008076
Number of Pages: 190 Pages
Engine - Gasket Set, Cylinder Head
Engine - Gasket Set, Intermediate
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Idle Gear
Engine - Oil Pan
Engine - Timing Gear Cover
Engine - Piston & Connecting Rod
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Governor
Engine - Oil Pump & Filter, Prior S N 1402
Air Intake And Exhaust - Manifolds, Intake & Exhaust
Air Intake And Exhaust - Muffler & Air Cleaner
Cooling - Water Pump
Cooling - Water Outlet
Cooling - Radiator
Fuel System - Lines & Primary Filter
Fuel System - Fuel Injection Pump
Fuel System - Fuel Filter Asy.
Fuel System - Injector
Fuel System - Throttle & Controls
Fuel System - Fuel Tank
Electrical & Instruments - Wiring, Battery & Gauges
Electrical & Instruments - Alternator
Electrical & Instruments - Starting Motor
Electrical & Instruments - Lighting, Lamps
Sheet Metal, Frame & Seat - Front Frame
Sheet Metal, Frame & Seat - Hood & Grille
Sheet Metal, Frame & Seat - Rear Hood
Sheet Metal, Frame & Seat - Console & Platform
Sheet Metal, Frame & Seat - Fenders
Sheet Metal, Frame & Seat - Seat
Sheet Metal, Frame & Seat - Protective Frame
Drive Train - Gasket Set
Drive Train - Clutch Housing
Drive Train - Main Drive Shaft
Drive Train - Transmission, Rear Main Housing
Drive Train - Controls, Range Shift
Drive Train - Controls, Pto Shift
Drive Train - Controls, Front Drive Shift
Drive Train - Transmission, Main Drive
Drive Train - Transmission, Counter Shaft
Drive Train - Transmission, Drive Pinion Shaft
Drive Train - Differential Assembly, Rear
Drive Train - Differential Lock, Rear
Drive Train - Axle, Right Hand
Drive Train - Axle, Left Hand
Drive Train - Front Drive Shaft, 4-Wheel Drive
Drive Train - Drive Shaft, Front Axle, 4-Wheel Drive
Drive Train - Pto Shaft
Drive Train - Pto Shaft, Extension
Drive Train - Mid Pto Shaft
Drive Train - Hydrostatic Transmission
Drive Train - Controls, Pedal Linkage, Hydrostatic
Drive Train - Controls, Transmission Speed
Brake - Brake, Right Hand
Brake - Controls & Linkage
Hitch & Lift - Lift Shaft & Housing
Hitch & Lift - 3-Point Hitch
Hitch & Lift - Pto Guard & Drawbar
Hitch & Lift - Rear Weight, Hitch Mounted, Mfg. #72097209
Axles, Steering & Wheels - Steering
Axles, Steering & Wheels - Tie Rods
Axles, Steering & Wheels - Front Axle, 2-Wheel Drive
Axles, Steering & Wheels - Front Axle, 4-Wheel Drive
Axles, Steering & Wheels - Front Axle, Hub, 4-Wheel Drive
Axles, Steering & Wheels - Front Axle, Differential Asy.
Axles, Steering & Wheels - Wheels & Tires, Agriculture
Axles, Steering & Wheels - Wheel, Weight-Rear
Axles, Steering & Wheels - Wheels & Tires, Turf
Hydraulic System - Transmission Lines & Filter, Oil Cooler
Hydraulic System - Pump & Lines
Hydraulic System - Lift Pump
Hydraulic System - Lift Housing, Linkage & Valve
Hydraulic System - Lift Housing, Cover Asy.
Hydraulic System - Lift Cylinder, Valve & Cover
Hydraulic System - Lift Control
Hydraulic System - Remote Valve, Two Spool
Hydraulic System - Remote Valve, One Spool
Hydraulic System - Remote Valve, Controls, Mfg. No. 72111095
Hydraulic System - Power Steering, 2 Wheel Drive (First Type)
Hydraulic System - Power Steering (First Type), 4 Wheel Drive
Hydraulic System - Power Steering Cylinder (First Type)
Hydraulic System - Steering Cylinder (Second Type)
Hydraulic System - Power Steering Cylinder (Second Type)
Brand: AGCO Allis
Engine - Idle Gear
Engine - Oil Pan
Engine - Crankshaft
Engine - Governor
Cooling - Radiator
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
