AGCO Allis Tractor 4W-305 Parts Catalog 79006380
Brand: AGCO Allis
Model: AGCO Allis 4W-305 Tractor
Part Number: 79006380
Number of Pages: 354 Pages
Engine - Gasket Sets
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Housing
Engine - Piston & Connecting Rod
Engine - Timing Gear Cover
Engine - Lubricating System, Oil Pump
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Bypass Oil Filter
Engine - Lubricating System, Full Flow Oil Filter
Air Intake & Exhaust System - Manifolds, Intake & Exhaust
Air Intake & Exhaust System - Turbocharger, Components
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Pre-Cleaner Extension
Cooling System - Water Pump
Cooling System - Water Pump Idler
Cooling System - Belts & Pulleys
Cooling System - Radiator
Cooling System - Outlet Manifold & Thermostat
Cooling System - Inlet Manifold & Oil Cooler
Cooling System - Water Conditioner
Fuel System - Fuel Injection System
Fuel System - Fuel Injection System, Snubber Valve
Fuel System - Fuel Injection System, Line
Fuel System - Fuel Injection System, Fuel Injector
Fuel System - Fuel Filter, Primary
Fuel System - Fuel Filter, Secondary
Fuel System - Tanks & Lines, Prior To S N 1171
Fuel System - Tanks & Lines, Eff. S N 1171
Fuel System - Fuel Shut-Off & Throttle, Prior To S N 1133
Fuel System - Fuel Shut-Off & Throttle, Eff. S N 1133
Fuel System - Ether Starting System
Electrical & Instruments - Chassis Electrical System
Electrical & Instruments - Engine Electrical System, Wiring
Electrical & Instruments - Instrument Panel, Analog
Electrical & Instruments - Instrument Panel, Digital
Electrical & Instruments - Batteries & Cables
Electrical & Instruments - Electrical System, Cab Lighting
Electrical & Instruments - Electrical Lighting, Work Lamp
Electrical & Instruments - Electrical System, Stadium Lamps
Electrical & Instruments - Electrical System, Wiper & Control
Electrical & Instruments - Electrical Lighting, Head Lamp
Electrical & Instruments - Wiring, Remote Electric Socket
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Front Frame
Sheet Metal, Frame & Seat - Front Support & Side Frames
Sheet Metal, Frame & Seat - Grille, Hood & Hood Support
Sheet Metal, Frame & Seat - Steps & Fuel Tank Supports
Sheet Metal, Frame & Seat - Fenders
Sheet Metal, Frame & Seat - Cover - Hydraulic Valve
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Steering, Steering Column
Sheet Metal, Frame & Seat - Console
Sheet Metal, Frame & Seat - Seat Mounting, Prior To S N 1342
Sheet Metal, Frame & Seat - Seat Mounting, Eff. S N 1342
Sheet Metal, Frame & Seat - Seat Suspension
Sheet Metal, Frame & Seat - Seat Suspension, Eff. S N 1192
Sheet Metal, Frame & Seat - Seat, Olympic
Sheet Metal, Frame & Seat - Seat, Luxury Cloth
Sheet Metal, Frame & Seat - Decals
Drive Train - Transmission, Engine Mounting
Drive Train - Transmission, Housing - Power Director
Drive Train - Transmission, Torque Limiter
Drive Train - Transmission, Input Shaft
Drive Train - Transmission, Power Director Clutch
Drive Train - Transmission, Main Shaft
Drive Train - Transmission, Countershaft
Drive Train - Transmission, Gear Shift & Linkage
Drive Train - Controls, Manual Shift
Drive Train - Differential, Front Differential
Drive Train - Front Main Housing, W No-Spin Differential Lock
Drive Train - Axle, Front Axle
Drive Train - Housings, Drop Box & P.T.O.
Drive Train - Transmission -- Drop Box, Range Shafts & Gears
Drive Train - P.T.O., P.T.O. & Pump Drive
Drive Train - Controls, Range Shift Control
Drive Train - Controls, Range Shift & Park Lock
Drive Train - Rear Frame, Housing
Drive Train - Rear Frame, Shafts & Gears
Drive Train - Differential & Final Drive, Housing - Rear
Drive Train - P.T.O., Main Shaft & Idler, Rear
Drive Train - P.T.O., Clutch & Brake
Drive Train - P.T.O., 1000 Rpm Output Shaft
Drive Train - Differential & Final Drive, Rear Differential
Drive Train - Axle, Rear Axle
Drive Train - Drive Line, Front Axle
Drive Train - Drive Line, Rear Axle, Prior To S N 1133
Drive Train - Drive Line, P.T.O., Prior To S N 1133
Brake
Brake - Brake, Controls, Prior To S N 1199
Brake - Brake, Controls, Eff. S N 1199
Hitch & Lift - Lift Shaft, Housing
Hitch & Lift - 3-Point Hitch, Torsion Bar, Lift Link
Hitch & Lift - Drawbar, Standard
Hitch & Lift - Drawbar, Wide Swing
Hitch & Lift - Hitch, Quick
Axles, Steering & Wheels - Wheels, Front & Rear
Axles, Steering & Wheels - Wheels, Front & Rear, Power Adjust
Axles, Steering & Wheels - Weight Mounting Hardware
Axles, Steering & Wheels - Weight Mounting Hdw., Power Adjust
Hydraulic System - Lines, Power Steering
Hydraulic System - Lines, Hydraulic Pump
Hydraulic System - Lines, Hyd. Filter & Power Director Lube
Hydraulic System - Pump, Power Steering
Hydraulic System - Gear Pump Hydraulic
Hydraulic System - Valve, Power Steering
Hydraulic System - Flow Control Valve
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Lines, Power Director Lube & Cooler
Hydraulic System - Lines, Rear Cooler
Hydraulic System - Valve, Power Director
Hydraulic System - Solenoid Valve, P.D. Valve
Hydraulic System - Solenoid Valve, P.D. Valve, Eff. S N 1285
Hydraulic System - Controls, Power Director, Cable Controls
Hydraulic System - Lines, P.T.O. & Brake, External
Hydraulic System - P.T.O., Brake & Manifold
Hydraulic System - Lines, P.T.O. & Brake, Internal
Hydraulic System - Valve, Brake
Hydraulic System - Valve, P.T.O.
Hydraulic System - Lines, Filter To Gerotor
Hydraulic System - Valve, Manifold - Pump Inlet
Hydraulic System - Pump, Gerotor
Hydraulic System - Piston Pump, W Drive Shaft Seal
Hydraulic System - Compensator Asy., Prior To S N 1142
Hydraulic System - Controls, Cable Controls - P.T.O.
Hydraulic System - Controls, Position & Traction Booster,
Hydraulic System - Controls, Traction Booster, Eff. S N 1133
Hydraulic System - Lines, Piston Pump, Remote Valve & Lift
Hydraulic System - Valve, Inlet
Hydraulic System - Valve, Draft Control
Hydraulic System - Controls, Remote Valves
Hydraulic System - Seal Kit, W Lift & 3 Or 4 Remotes
Hydraulic System - Seal Kits, W O Lift & 3 Or 4 Remotes
Hydraulic System - Lines, Lift Assist Cylinders
Hydraulic System - Lift Cylinder
Hydraulic System - Lines, Breakaway Coupler - 3 & 4 Remotes
Hydraulic System - Lines, Breakaway Coupler -- 3 & 4 Remotes
Hydraulic System - Filter, Differential
Cab - Cab Frame, Exterior
Cab - Cab Frame, Interior
Cab - Battery Box, Doors, Hinges & Anchors
Cab - Cab Support
Cab - Doors, Cab - L.H. & R.H.
Cab - Cab Windows, Glass, Gaskets & Hardware
Cab - Air Conditioning - Heating, Lines - Tractor End
Cab - Air Conditioning - Heating, Lines - Cab End
Cab - Air Conditioning - Heating, Blower
Cab - Air Conditioning - Heating, Compressor
