AGCO Allis Tractor 4660 Parts Catalog 79016063
Brand: AGCO Allis
Model: AGCO Allis 4660 Tractor
Part Number: 79016063
Number of Pages: 216 Pages
Parts Catalog Information
Engine - Crankcase
Engine - Front Cover
Engine - Pistons, Rods And Crankshaft
Engine - Camshaft
Engine - Gasket Set
Engine - Gasket Set, Major Overhaul
Engine - Cylinder Head
Engine - Oil Pan, Filter And Cooler
Fuel System - Injector Pump
Fuel System - Injectors And Lines
Fuel System - Injector Components
Fuel System - Thermo Starter
Fuel System - Injector Pump Components
Fuel System - Fuel Pump
Engine Cooling - Cooling Fan
Intake And Exhaust - Manifolds
Intake And Exhaust - Muffler
Clutch - Clutch Assembly
Clutch - Control Device
Clutch - Hand Clutch Control
Transmission - Gearbox
Transmission - Gearbox Rear
Transmission - Main Shaft
Transmission - Driven Shaft
Transmission - Reduction Gear Reverse Gear Shaft
Transmission - Creeper Gear
Transmission - Gear Shift, Forks And Rails
Transmission - Differential
Transmission - Differential Lock Control
Transmission - Rear Axle Housing
Transmission - Reduction Gears And Axle Shafts
Brakes - Rear Brake
Brakes - Foot Pedals
Brakes - Parking Brake
Front Axle - Front Support, 4wd
Front Axle - Adjustable Axle, With Hydrosteering - 2wd
Front Axle - Front Axle, With Hydrosteering - 4wd
Front Axle - Differential - 4wd
Front Axle - Planetary And Axle Shafts - 4wd
Front Axle - Transmission Shaft - 4wd
Pto - Pto Control- 4wd
Pto - Power Take Off
Pto - Control Lever
Power Steering - Steering Column
Power Steering - Lines & Hoses - 2wd
Power Steering - Lines & Hoses - 4wd
Power Steering - Valve
Power Steering - Cylinder Components - 2wd
Power Steering - Cylinder Components - 4wd
Sheet Metal And Frame - Hood
Sheet Metal And Frame - Grill - Front
Sheet Metal And Frame - Front Bulkhead - Engine
Sheet Metal And Frame - Fan Belt Guard
Sheet Metal And Frame - Rear Bulkhead - Engine
Sheet Metal And Frame - Supports
Sheet Metal And Frame - Instrument Panel
Sheet Metal And Frame - Throttle Control Device
Fuel System - Fuel Shutoff
Sheet Metal And Frame - Front Fenders - 2wd
Sheet Metal And Frame - Front Fenders - 4wd
Sheet Metal And Frame - Rear Fenders
Sheet Metal And Frame - Floor Plates
Sheet Metal And Frame - Rops
Fuel System - Tank And Lines
Intake And Exhaust - Air Cleaner & Support
Intake And Exhaust - Air Cleaner Components
Fuel System - Ether Starting Aid
Fuel System - Filter
Seat - Seat Assembly
Seat - Suspension Assembly
Electrical - Lights
Electrical - Light Components
Electrical - Alternator, Starting Motor And Battery, 55 Amp
Electrical - Wiring System
Electrical - Miscellaneous Equipment
Electrical - Alternator, 55 Amp
Electrical - Starter
Wheels - Front Wheels
Wheels - Rear Wheels
Hitch, Lift And Drawbar - Lift Housing - Three Point Hitch
Hitch, Lift And Drawbar - Lift Bracket - Three Point Hitch
Hitch, Lift And Drawbar - Pump, Filter And Lines
Power Steering - Pump, Turolla
Power Steering - Pump, Bosch
Hitch, Lift And Drawbar - Lift - Three Point Hitch
Hitch, Lift And Drawbar - Valve And Regulator
Hitch, Lift And Drawbar - Inner Control Devices
Hitch, Lift And Drawbar - Lift Controls - Three Point Hitch
Hitch, Lift And Drawbar - Draft Sensing
Hitch, Lift And Drawbar - Hydraulic Pump Drive
Hitch, Lift And Drawbar - Remote Valve
Hitch, Lift And Drawbar - Additional Remote Valve
Hitch, Lift And Drawbar - Valve Components
Hitch, Lift And Drawbar - Three Point Hitch
Hitch, Lift And Drawbar - Swinging Drawbar
Pto - Shield
Decals - Safety Decals
Decals - Speed Charts
Accessories - Front Weights
Accessories - Tool Kit
Accessories - Rops Canopy
Recommended Dealer Stock - Recommended Dealer Stock, This
