AGCO Allis Tractor 220 220FWA Parts Catalog 79001596
Brand: AGCO Allis
Model:
AGCO Allis 220 Tractor
AGCO Allis 220FWA Tractor
Part Number: 79001596
Number of Pages: 198 Pages
Engine - Gasket Sets
Engine - Gasket Sets (Continued)
Engine - Cylinder Block
Engine - Crankshaft
Engine - Piston, Connecting Rod
Engine - Cylinder Head
Engine - Oil Pump, Prior S N 3d-13419
Engine - Oil Pump, Eff. S N 3d-13419 & Up
Engine - Oil Pan, Prior S N 3d-13419
Engine - Oil Filter
Engine - Idler Gear
Air Intake & Exhaust System - Intake Manifold
Air Intake & Exhaust System - Turbocharger Asy., Thompson
Air Intake & Exhaust System - Turbocharger, Thompson
Air Intake & Exhaust System - Turbocharger Asy., Airesearch,
Air Intake & Exhaust System - Air Cleaner & Muffler
Air Intake & Exhaust System - Air Pre-Cleaner
Cooling System - Water Pump
Fuel System - Throttle Control
Fuel System - Fuel Filter Lines
Fuel System - Injection Pump Components, Housing & Drive
Fuel System - Injection Pump Components, Transfer Pump
Fuel System - Fuel Injection Lines
Fuel System - Fuel Tank & Lines
Fuel System - Ether Starting System
Electrical & Instruments - Instrument Panel, With Cab
Electrical & Instruments - Instrument Panel, Without Cab
Electrical & Instruments - Electrical System
Electrical & Instruments - Road & Field Lamps
Electrical & Instruments - Starting Motor
Electrical & Instruments - Starting Motor, Commutator Frame,
Electrical & Instruments - Generator
Sheet Metal, Frame & Seat - Side Frame
Sheet Metal, Frame & Seat - Radiator, Grille
Sheet Metal, Frame & Seat - Rear Frame, Fenders & Console
Sheet Metal, Frame & Seat - Platform & Battery Box
Sheet Metal, Frame & Seat - Hood Support
Sheet Metal, Frame & Seat - Padded Seat
Sheet Metal, Frame & Seat - Seat, Fold-Up
Sheet Metal, Frame & Seat - Seat Linkage
Sheet Metal, Frame & Seat - Protective Frame & Canopy
Clutch - Engine Clutch
Drive Train - Housing, Torque, Transmission
Drive Train - Housing & Sleeve, Final Drive
Drive Train - Shift Control, Range Transmission
Drive Train - P.T.O. Shafts & Manifold
Drive Train - Transmission Shafts & Gears
Drive Train - Countershaft & Reverse Idler
Drive Train - Range Transmission
Drive Train - Transmission Gear Shift
Drive Train - Transmission, Front Wheel Assist
Drive Train - Final Drive & Rear Axle & Brake
Brake - Brake Pedals
Hitch - Lift Arms & Housing
Hitch - Draft Arms & Torsion Bar
Hitch - Drawbar, Standard
Hitch - Upper Link
Hitch - Lift Link
Hitch - Control Levers, Position, Traction Booster
Axles, Steering & Wheels - Front Axle
Axles, Steering & Wheels - Axle & Frame, Front Wheel Assist
Axles, Steering & Wheels - Axle Parts, Front Wheel Assist
Axles, Steering & Wheels - Differential Asy.
Axles, Steering & Wheels - Steering Wheel & Brake
Axles, Steering & Wheels - Control Valve
Axles, Steering & Wheels - Rear Wheel, 67 X 34-25
Hydraulic System - Hydraulic Pump
Hydraulic System - Plunger Section, Double-Acting
Hydraulic System - Sensing & Outlet Section
Hydraulic System - Power Steering Lines
Hydraulic System - Power Steering Cylinder
Hydraulic System - Hydraulic Lines, Traction Booster
Hydraulic System - Hydraulic Lines, P.T.O. & Filter
Hydraulic System - P.T.O. Valve
Hydraulic System - Hydraulic Lines, Remote
Hydraulic System - Remote Cylinder, W Stroke Control
Cab - Cab, Stolper Cab
Cab - Heater, Stolper Cab
Cab - Blower, Stolper Cab
Cab - Electrical System, Stolper Cab
Cab - Cab, La Porte Cab
Cab - Cab Support, La Porte Cab
Cab - Heater & Evaporator, La Porte Cab
Cab - Cab Blower, La Porte Cab
Cab - Condenser, La Porte Cab
Cab - Compressor Mounting, La Porte Cab
Cab - Lines, La Porte Cab
Cab - Windshield Wiper & Electrical, La Porte Cab
