AGCO Allis Tractor 185 Parts Catalog 79005580
Brand: AGCO Allis
Model: AGCO Allis 185 Tractor
Part Number: 79005580
Number of Pages: 204 Pages
Engine - Gasket Sets
Engine - Gasket Sets (Continued)
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Timing Gear Cover, Diesel
Engine - Idler Gear
Engine - Lubricating System, Oil Pump
Engine - Lubricating System, Oil Pan
Air Intake & Exhaust System - Manifold, Intake
Air Intake & Exhaust System - Muffler
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Air Heater
Air Intake & Exhaust System - Air Pre-Cleaner
Cooling System - Water Pump
Cooling System - Radiator
Fuel System - Tank, Lines
Fuel System - Filter, Fuel Tank
Fuel System - Controls, Fuel Shut-Off & Throttle
Fuel System - Fuel Injection System, Pump -- Housing & Drive
Fuel System - Injection Pump System
Fuel System - Fuel Injection System, Lines, (Allis-Chalmers),
Fuel System - Fuel Injection System, Lines (Bosch)
Fuel System - Fuel Injection System, Fuel Injector (Bosch)
Fuel System - Fuel Injection System, Hand Primer Pump
Fuel System - Fuel Injection System, Lines, Primer Pump
Fuel System - Ether Starting System
Electrical & Instruments - Instruments, Wiring
Electrical & Instruments - Engine Electrical System
Electrical & Instruments - Starting Motor, Nippondenso
Electrical & Instruments - Instruments, Panel & Gauges
Electrical & Instruments - Radio
Electrical & Instruments - Wiring, Remote Electric Socket
Electrical & Instruments - Electrical Lighting, Warning Lamp
Electrical & Instruments - Electrical Lighting, Tail Lamp
Electrical & Instruments - Electrical Lighting, Wiring
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Side Frame,
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Hood
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Platform
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Battery Box
Sheet Metal, Frame & Seat - Protective Frame & Canopy
Sheet Metal, Frame & Seat - Steering, Control
Sheet Metal, Frame & Seat - Seat, Linkage
Sheet Metal, Frame & Seat - Seat, Fold-Up
Sheet Metal, Frame & Seat - Decals, Prior S N 15272
Sheet Metal, Frame & Seat - Decals, Eff. S N 15272
Clutch - Transmission, Engine Clutch Shaft
Drive Train - Torque Housing
Drive Train - Transmission, Idler Shaft & Gears
Drive Train - Transmission, Clutch Shaft
Drive Train - Transmission, Main Shaft
Drive Train - Transmission, Input Shaft
Drive Train - Transmission, Control Cover, Gear Shift
Drive Train - Controls, Power Director, P.T.O. With Clutch,
Drive Train - Controls, P.T.O. Without Clutch
Drive Train - P.T.O., Front Shaft & Housing, Without Clutch
Drive Train - P.T.O., Front Shaft & Housing, With Clutch
Drive Train - P.T.O., Shaft & Gears, 2-Speed Output Shaft
Drive Train - P.T.O., Intermediate P.T.O. Shaft
Drive Train - P.T.O., Clutch
Drive Train - Differential & Final Drive, Rear Axle
Brake
Brake - Brake, Controls
Hitch - Lift Shaft, Housing
Hitch - 3-Point Hitch, Lift Link, Prior S N 14290
Hitch - 3-Point Hitch, Upper Link
Hitch - 3-Point Hitch, Torsion Bar & Lower Links
Hitch - Hitch, Quick
Hitch - Controls, Position & Traction Booster
Axle, Steering & Wheels - Axle, Roll Shift
Axle, Steering & Wheels - Front Wheel
Axle, Steering & Wheels - Rear Wheel, Non-Power Adjust
Axle, Steering & Wheels - Rear Wheel, Power Adjust
Hydraulic System - Valve, Power Steering
Hydraulic System - Pump, Hydraulic
Hydraulic System - Valve, Remote Cylinder
Hydraulic System - Controls, Valve & Lever
Hydraulic System - Valve, Traction Booster & Outlet
Hydraulic System - Lines, Power Steering
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Valve, Power Director
Hydraulic System - Lines, P.T.O., With Clutch
Hydraulic System - Power Director Valve & Lines
Hydraulic System - Lines, Oil Filter
Hydraulic System - Lines, Lift & Traction Booster
Hydraulic System - Lines, Lift Cylinder
Hydraulic System - Cylinder, Lift Arm
Hydraulic System - Lines, Hydraulic Outlets
Hydraulic System - Lines, Breakaway Coupler, Quick Release
