AGCO Allis Tractor 180 185 Parts Catalog 79001559
Brand: AGCO Allis
Model:
AGCO Allis 180 Tractor
AGCO Allis 185 Tractor
Part Number: 79001559
Number of Pages: 255 Pages
Engine - Gasket Sets, 180 Gasoline
Engine - Gasket Sets, 180 Gasoline (Continued)
Engine - Gasket Sets, 180 -- 185 Diesel
Engine - Gasket Sets, 180 -- 185 Diesel (Continued)
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Timing Gear Cover, Diesel
Engine - Timing Gear Cover, Gas
Engine - Idler Gear, Diesel -- Hydraulic Housing & Gear
Engine - Lubricating System, Oil Pump, Prior S N 2d-31132 -- Oil Pump, Eff. S N 2d-31132 & 2g-11739 & Up
Engine - Lubricating System, 185 -- Eff. S N 2d-96079
Engine - Lubricating System, Oil Pan -- Oil Filter
Air Intake & Exhaust System - Manifold, Intake & Exhaust
Air Intake & Exhaust System - Manifold, Exhaust, Diesel -- Muffler
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Air Heater, Diesel -- Indicator, Air Cleaner Restriction
Air Intake & Exhaust System - Air Pre-Cleaner
Cooling System - Water Pump -- Thermostat
Cooling System - Radiator
Fuel System - Fuel Pump, Gasoline -- Lines, Carburetor
Fuel System - Carburetor, Gasoline
Fuel System - Governor, Gas
Fuel System - Tank, Lines, Gas
Fuel System - Tank, Lines, Diesel -- Prior 180 S N 9472 -- Eff. 180 S N 9472 & Up, Model 185
Fuel System - Filter, Tank -- Sending Unit, Fuel Tank
Fuel System - Controls, Throttle, Model 180
Fuel System - Controls, Throttle, Model 185 -- Fuel Injection System, Pump Drive
Fuel System - Injection Pump System, Pump -- Housing & Drive, Model 180
Fuel System - Injection Pump System, Pump -- Housing & Drive, Model 185
Fuel System - Injection Pump System, Pump -- Transfer, Head & Rotor
Fuel System - Fuel Injection System, Pump -- Housing & Drive
Fuel System - Fuel Injection System, Lines -- Diesel - Prior S N 2d-26977, Allis-Chalmers
Fuel System - Fuel Injection System, Lines -- Diesel - Eff. S N 2d-26977 & Up, Allis-Chalmers
Fuel System - Fuel Injection System, Lines, Bosch
Fuel System - Fuel Injection System, Fuel Injector, Bosch
Fuel System - Fuel Injection System, Hand Primer Pump, Diesel -- Fuel Injector - Diesel - Allis Chalmers
Fuel System - Fuel Injection System, Lines - Primer Pump, Diesel -- Fuel Injection System - Fuel Filter, Diesel
Fuel System - Ether Starting System, Diesel -- Ether Starting System - Start Pilot, Diesel
Fuel System - Ether Starting System, Hobbs, Diesel
Electrical & Instruments - Engine Electrical System Ignition, Gasoline -- Distributor, Gasoline
Electrical & Instruments - Electrical System, Wiring
Electrical & Instruments - Engine Electrical System Generator
Electrical & Instruments - Engine Electrical System Starting Motor, Delco-Remy - Diesel
Electrical & Instruments - Engine Electrical - System Starting Motor, Lucas
Electrical & Instruments - Starting Motor, Nippondenso
Electrical & Instruments - Engine Electrical System - Starting Motor, Lucas
Electrical & Instruments - Engine Electrical System - Starting Motor, Gasoline
Electrical & Instruments - Electrical Lighting, Warning, Work & Headlamps
Electrical & Instruments - Electrical Lighting, Tail Lamp -- Flood Lamp
Electrical & Instruments - Remote Electric Socket, 7-Prong
Electrical & Instruments - Instruments, Panel & Gauges -- Tach-Hour Meter & Drive
Electrical & Instruments - Radio
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Side Frame, Front Support & Weight, Model 180 -- Rear Hood & Fuel Support
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Side Frame, Front Support & Weight, Model 185
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Hood, Grille & Side Sheets, Model 180
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Hood, Grille & Side Sheets, Model 185
Sheet Metal, Frame & Seat - Decals, Model 180
Sheet Metal, Frame & Seat - Decals, Model 185
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Platform
Sheet Metal, Frame & Seat - Sheet Metal & Frame, Fenders & Tool Box
Sheet Metal, Frame & Seat - Protective Frame & Canopy, Model 180
Sheet Metal, Frame & Seat - Protective Frame & Canopy, Model 185
Sheet Metal, Frame & Seat - Seat, Latch & Support, Model 180 -- Model 185 Prior S N 6559
Sheet Metal, Frame & Seat - Seat, Linkage, Model 180 -- Model 185 Prior S N 6559
Sheet Metal, Frame & Seat - Seat, Fold-Up
Sheet Metal, Frame & Seat - Seat, Linkage, Eff. 185 S N 6559
Sheet Metal, Frame & Seat - Seat, (Optional) & Super Deluxe
Clutch - Transmission, Engine Clutch -- Controls, Clutch Pedal
Clutch - Transmission, Engine Clutch Shaft
Drive Train - Torque Housing -- Transmission - Housing
Drive Train - Transmission, Idler Shaft & Gears -- Intermediate Shaft & Gears
Drive Train - Transmission, Clutch Shaft -- Clutch
Drive Train - Transmission, Main Shaft -- Countershaft
Drive Train - Transmission, Input Shaft -- Gearshift
Drive Train - Transmission, Control Cover, Gear Shift
Drive Train - Controls, Power Director P.T.O. With Clutch
Drive Train - Controls, P.T.O. Without Clutch -- P.T.O. Shifter
Drive Train - Front Shaft & Housing, Without Clutch
Drive Train - P.T.O., Front Shaft & Housing, With Clutch
Drive Train - P.T.O., Shaft & Gears, 2-Speed Output Shaft
Drive Train - P.T.O., Intermediate P.T.O. Shaft 2-Speed Output Shaft -- Rear Shaft, 1-Speed Output Shaft
Drive Train - P.T.O., Clutch -- Differential & Final Drive
Drive Train - Differential & Final Drive, Rear Axle
Drive Train - Belt Pulley -- Belt Pulley Shifter
Brake -- Brake Controls - Model 180
Brake - Brake, Controls, Model 185
Hitch & Lift - Lift Shaft, Housing -- 3-Point Hitch, Lift Links, Model 180 - Prior S 185-5707
Hitch & Lift - 3-Point Hitch, Lift Link, Eff. S N 185-5707
Hitch & Lift - 3-Point Hitch, Upper Link -- Drawbar
Hitch & Lift - 3-Point Hitch, Torsion Bar & Lower Links
Hitch & Lift - Controls, Position & Traction Booster
Axle, Steering & Wheel - Axle, Roll Shift, Model 180 -- Spindle & Tie Rod, Model 180
Axle, Steering & Wheel - Axle, Roll Shift, Model 185
Axle, Steering & Wheel - Axle, Dual Front -- Steering Control, Interchangeable Front Axle
Axle, Steering & Wheel - Axle, Wheel, Single Front
Axle, Steering & Wheel - Wheels, Dual & Roll Shift, Front -- Tools
Axle, Steering & Wheel - Rear Wheel -- Power Shift, 38 , 30 , 28 , 26 Rims
Axle, Steering & Wheel - Wheel, Weights
Axle, Steering & Wheel - Steering, Control -- Power Steering Valve, 180 & 185 Prior S N 11784
Axle, Steering & Wheel - Valve, Power Steering, 185 Eff. S N 11784
Hydraulic System - Pump, Hydraulic
Hydraulic System - Controls, Valve & Lever
Hydraulic System - Valve, Remote Cylinder -- Valve, Lift Arm
Hydraulic System - Valve, Traction Booster & Outlet
Hydraulic System - Lines, Power Steering, Model 180
Hydraulic System - Lines, Power Steering, Model 185 -- Cylinder, Power Steering
Hydraulic System - Lines, Power Shift Valve -- P.T.O. Valve
Hydraulic System - Lines, P.T.O.
Hydraulic System - Lines, Valve, Power Director
Hydraulic System - Lines, Oil Filter -- Lines, Intake
Hydraulic System - Lines, Lift & Traction Booster -- Lines, Remote Cylinder & Breakaway Coupler Without Slotted Bracket
Hydraulic System - Lines, Breakaway Coupler, Quick Release
Hydraulic System - Lines, Lift Cylinder
Hydraulic System - Cylinder, Lift Arm,
Hydraulic System - Lines, Front Remote Cylinder -- Cylinder, Remote 2-1 2 Double & Single Acting
Hydraulic System - Coupler, Breakaway -- Coupler, Hose
Brand: AGCO Allis
Model:
Engine - Crankshaft
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
