AGCO Allis Tractor 170 175 Parts Catalog 79001560
Brand: AGCO Allis
Model:
AGCO Allis 170 Tractor
AGCO Allis 175 Tractor
Part Number: 79001560
Number of Pages: 253 Pages
Engine - Gasket Sets, Gasoline
Engine - Cylinder Block, Gasoline -- Camshaft, Gasoline
Engine - Cylinder Head, Gasoline
Engine - Crankshaft & Flywheel, Gasoline -- Piston & Connecting Rod, Gasoline
Engine - Valve Operating Mechanism, Gasoline
Engine - Lubricating System, Oil Pan, Gasoline -- Oil Pump, Gasoline
Engine - Lubricating System, Oil Filter & Lines, Gasoline
Engine - Timing Gear Cover, Gasoline -- Engine Adapter, Gasoline
Engine - Gasket Set, Diesel
Engine - Cylinder Block, Diesel
Engine - Cylinder Head, Diesel -- Engine Adapter, Diesel
Engine - Crankshaft & Flywheel, Diesel -- Piston & Connecting Rod, Diesel
Engine - Valve Operating Mechanism, Diesel -- Timing Gear & Cover, Diesel
Engine - Lubricating System, Oil Pan & Balancer, Diesel -- Oil Filter, Diesel
Engine - Lubricating System, Oil Pump & Balancer, Diesel
Air Intake & Exhaust System - Air Cleaner -- Air Cleaner Indicator
Air Intake & Exhaust System - Muffler -- Air Pre-Cleaner
Air Intake & Exhaust System - Manifolds, Intake & Exhaust,
Cooling System - Water Pump, Gasoline -- Thermostat, Gasoline
Cooling System - Water Pump, Diesel
Cooling System - Thermostat, Diesel -- Radiator
Fuel System - Fuel Injection System, Pump - Housing & Drive, Diesel
Fuel System - Fuel Injection System -- Pump - Transfer Head & Rotor, Diesel
Fuel System - Fuel Injection System, Diesel Lines -- Prior S N 236u93188 & S N 248u8332
Fuel System - Fuel Injection System, Diesel Lines, Eff. S N 236u93188 & Up & S N 248u8332 & Up
Fuel System - Fuel Injection System, Fuel Filter - Diesel Lines -- Lift Pump, Prior S N 236u93188 & S N 248u8332
Fuel System - Fuel Injection System, Fuel Filter - Diesel Lines Eff. S N 236u93188 & Up & S N 248u8332 & Up
Fuel System - Fuel Injection System, Lift Pump, Eff. S N 236u93188 & Up & S N 248u8332 & Up
Fuel System - Fuel Injection System, Fuel Filter, Diesel
Fuel System - Carburetor, 170 - Gasoline
Fuel System - Carburetor, 175 - Gasoline
Fuel System - Governor, Gasoline
Fuel System - Fuel Shut-Off & Throttle, Model 170
Fuel System - Fuel Shut-Off & Throttle, Model 175
Fuel System - Fuel Tank, Diesel, Gas
Fuel System - Fuel Tank Filter, Gas -- Fuel Tank Sending Unit
Fuel System - Ether Starting System, Manual Type, Electric Type
Fuel System - Starting Aid, Thermostart, Diesel
Electrical & Instruments - Ignition, Gasoline
Electrical & Instruments - Distributor, Gasoline
Electrical & Instruments - Electrical System, Wiring
Electrical & Instruments - Starting Motor, Gasoline
Electrical & Instruments - Starting Motor, Diesel
Electrical & Instruments - Alternator
Electrical & Instruments - Electrical Lighting, Warning Lamp
Electrical & Instruments - Electrical Lighting, Tail Lamp,
Electrical & Instruments - Electrical Lighting, Work & Head Lamp -- Flood Lamp
Electrical & Instruments - Remote Electric Socket, 7-Prong
Electrical & Instruments - Instrument Panel
Electrical & Instruments - Tach-Hour Meter & Drive -- Radio
Sheet Metal, Frame & Seat - Side Frame, Front Support & Weight Carrier
Sheet Metal, Frame & Seat - Support, Rear Hood & Fuel Tank
Sheet Metal, Frame & Seat - Hood, Grille & Side Sheet
Sheet Metal, Frame & Seat - Decals
Sheet Metal, Frame & Seat - Fenders
Sheet Metal, Frame & Seat - Platform
Sheet Metal, Frame & Seat - Protective Frame & Canopy
Sheet Metal, Frame & Seat - Cab, Hard Top
Sheet Metal, Frame & Seat - Cab, Half Top
Sheet Metal, Frame & Seat - Seat Linkage
Sheet Metal, Frame & Seat - Seat, Padded -- Seat, Fold-Up
Clutch - Engine Clutch
Clutch - Engine Clutch Shaft
Clutch - Front Shaft, Engine Clutch -- Clutch Pedal & Linkage
Drive Train - P.T.O. Shifter
Drive Train - Torque Housing
Drive Train - Controls, R.H. Power Director & L.H. Shuttle Clutch Control
Drive Train - Transmission Clutch
Drive Train - P.T.O., Shaft & Gears, 2-Speed Output Shaft, With Shuttle Clutch
Drive Train - Transmission Main Shaft
Drive Train - Differential -- Transmission Countershaft
Drive Train - Transmission Housing, Final Drive Housing
Drive Train - Control Cover, Gear Shift
Drive Train - P.T.O. Shaft & Gears
Drive Train - Final Drive & Rear Axle, Model 170
Drive Train - Final Drive & Rear Axle, Cane Tractor
Drive Train - Final Drive & Rear Axle, Model 175 Tractor
Brake System - Brake -- Brake Control
Hitch & Lift - Housing, Lift Arm Shaft
Hitch & Lift - 3-Point Hitch, Torsion Bar & Lower Links
Hitch & Lift - 3-Point Hitch, Lift Link
Hitch & Lift - Upper Link -- Quick Hitch
Hitch & Lift - Drawbar -- Drawbar, Cane Tractor
Hitch & Lift - Controls, Position & Traction Booster
Axle, Steering & Wheels - Front Axle, Roll Shift -- Spindle & Tie Rod
Axle, Steering & Wheels - Pedestal & Spindle, Dual
Axle, Steering & Wheels - Front Axle, Single
Axle, Steering & Wheels - Steering Control, Prior S N 170-7500 & S N 175-2035
Axle, Steering & Wheels - Front Wheel, Dual & Roll Shift -- Single
Axle, Steering & Wheels - Rear Wheel, Power Shift
Axle, Steering & Wheels - Rear Wheel, Non-Power Shift
Axle, Steering & Wheels - Wheel Weights -- Tools
Hydraulic System - Valve, Power Steering
Hydraulic System - Hydraulic Pump, Prior S N 170-7500 & S N 175-2035
Hydraulic System - Hydraulic Pump & Drive, Eff. S N 170-7500 & Up & S N 175-2035 & Up
Hydraulic System - Hydraulic Pump & Drive, Prior S N 170-7500 & S N 175-2035
Hydraulic System - Control Valve & Lever
Hydraulic System - Valve, Traction Booster Sensing & Outlet
Hydraulic System - Valve, Traction Booster Hand Control -- Valve, Inlet
Hydraulic System - Valve, Remote Cylinder
Hydraulic System - Valve, Power Steering Relief (For 175 Tractor Only) -- Lines, Oil Cooler
Hydraulic System - Cylinder, Power Steering
Hydraulic System - Lines, Power Steering, Prior S N 170-7500 & S N 175-2035
Hydraulic System - Lines, Power Steering, Eff. S N 170-7500 & Up & 175-2035 & Up -- Lines, Lift Cylinder
Hydraulic System - Cylinder, Lift Arm, Prior S N 170-5019 -- Lift Arm, Eff. S N 170-5019 & 175
Hydraulic System - Lines, Remote Cylinder, Rear -- Remote Cylinder, Front
Hydraulic System - Lines, Intake & Filter, Prior S N 170-7500 & S N 175-2035
Hydraulic System - Lines, Intake & Filter, Eff. S N 170-7500 & S N 175-2035
Hydraulic System - Lines, Sump & Pump, Eff. S N 170-7500 & S N 175-2035
Hydraulic System - Lines, Breakaway Coupler
Hydraulic System - Coupler, Hose -- Coupler, Breakaway
Hydraulic System - Lines, Shuttle Clutch
Hydraulic System - Cylinder, Remote, 2-1 2 Double- & Single-Acting
Hydraulic System - Hydraulic Lines, Lift, Traction Booster & Sump, Prior S N 170-7500 & S N 175-2035
Hydraulic System - Hydraulic Lines, Lift, Traction Booster & Sump Eff. S N 170-7500 & S N 175-2035
