AGCO Allis Tractor 160 Parts Catalog 79001597
Brand: AGCO Allis
Model: AGCO Allis 160 Tractor
Part Number: 79001597
Number of Pages: 153 Pages
Engine - Engine Asy. Gasket Sets
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Pistons & Crankshaft
Engine - Timing Gear Cover
Engine - Oil Pan & Pump
Engine - Oil Feed Lines
Air Intake & Exhaust System - Air Cleaner
Air Intake & Exhaust System - Air Precleaner
Air Intake & Exhaust System - Muffler
Cooling System - Radiator
Cooling System - Water Pump
Fuel System - Fuel Injection Pump
Fuel System - Fuel Injector
Fuel System - Fuel Lift Pump
Fuel System - Fuel Lines
Fuel System - Throttle Controls, Standard & Lcg Tractor
Fuel System - Throttle Control, Basic & Intermediate Tractor
Fuel System - Fuel Shut-Off
Electrical & Instruments - Electrical Wiring
Electrical & Instruments - Starting Motor
Electrical & Instruments - Alternator, Standard & Lcg Tractor
Electrical & Instruments - Battery & Regulator
Electrical & Instruments - Instrument Panel
Electrical & Instruments - Electric Lighting & Switch
Sheet Metal, Frame & Seat - Front Weights
Sheet Metal, Frame & Seat - Radiator Shell & Hood Support
Sheet Metal, Frame & Seat - Hood
Sheet Metal, Frame & Seat - Battery Support
Sheet Metal, Frame & Seat - Platform & Fenders
Sheet Metal, Frame & Seat - Protective Frame & Canopy
Sheet Metal, Frame & Seat - Seat & Seat Support
Drive Train - Clutch Housing
Drive Train - Transmission
Drive Train - Gear Shift
Drive Train - Shift Forks & Rods
Drive Train - Mainshaft & Gears
Drive Train - Range Control & Gears
Drive Train - P.T.O. Shaft & Lever
Drive Train - Final Drive Housing
Drive Train - Rear Axle
Drive Train - Differential
Brake - Brake & Clutch Controls
Brake - Brake Locking Control
Brake - Brake & Brake Housing
Hitch - Lift Housing
Hitch - Lift Arms
Hitch - Draft Sensing Linkage
Hitch - 3-Point Hitch
Hitch - Winging Screw Components
Hitch - Position & Draft Control
Hitch - Position Control Linkage
Axle, Steering & Wheel - Front Axle, Standard & Lcg Tractor
Axle, Steering & Wheel - Tie Rod
Axle, Steering & Wheel - Steering Control & Valve
Axle, Steering & Wheel - Rear Wheels
Hydraulic System - Hydraulic Strainer & Lines, Second Type
Hydraulic System - Hydraulic Filter
Hydraulic System - Reservoir & Lines
Hydraulic System - Power Steering Pump
Hydraulic System - Remote Cylinder Valve
Hydraulic System - Valve, Position Control
Hydraulic System - First Type Remote Lines
