AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
702,019
Brand: AGCO Allis
Type of Machine: Tillage, Semi Mounted, Wheel Type Moldboard Plow
Model:
AGCO Allis 2000 Semi Mounted
AGCO Allis 3000 Semi Mounted
AGCO Allis 2500 Wheel Type Moldboard Plow
Part Number: 79003823
Number of Pages: 133 Pages
Frames - Beam Frames
Frames - Front Pivot
Frames - Front Pivot Adapter, 3000 Series
Frames - Main Hitch, Pull Type Plows, 3000 Series
Frames - Steering Linkage & Tubes, Prior To April 1970
Frames - Steering Linkage & Tubes, Eff. April 1970
Frames - Stub Beam & Plates, Shear Bolt
Frames - Stub Beam, Re-Set
Frames - Stub Beam & Plates, Spring Trip
Frames - Guide, 3000 Series
Wheels - Transport Wheel, Front, 3000 Series
Wheels - Transport Wheel, Rear
Wheels - Gauge Wheel & Bracket, 4 Bolt Hub, Type 1
Wheels - Gauge Wheel & Bracket, 4 Bolt Hub, Type Ii
Wheels - Gauge Wheel & Bracket, 6 Bolt Hub, Type I
Wheels - Gauge Wheel & Bracket, 6 Bolt Hub, Type Ii
Hydraulics - Hydraulic Lines, Lift & Lower, 3 & 4 Bottom
Hydraulics - Hydraulic Lines, Lift & Lower, 4, 5 & 6 Bottom
Hydraulics - Hydraulic Lines, Lift & Lower, 6, 7 & 8 Bottom
Hydraulics - Hydraulic Lines, Re-Set Stub Beams
Hydraulics - Accumulator
Hydraulics - Cylinder
Bottoms - Plow Bottom, 386
Bottoms - Plow Bottom, 387
Bottoms - Plow Bottom, 390
Bottoms - Plow Bottom, 392
Bottoms - Plow Bottom, 394 Slat
Bottoms - Landside Plates, 386 & 387 Bottoms
Bottoms - Trash Coverboards, 386, 387, 390, 392 & 394 Bottoms
Bottoms - Trash Coverboards, 387 & 392 Bottoms, Plastic
Coulters - Coulter, Single Arm Shear Bolt
Coulters - Coulter, Double Arm Shear Bolt
Coulters - Coulter, Single Arm Rubber Mounted
Coulters - Coulter, Concave Disk
Coulters - Coulter, Concave Disk, Single Arm Rubber Mounted
Beam Frames
Main Hitch
Beaming Screw & Support
Steering Linkage & Tubes, Front
Stub Beam, Re-Set
Lift Wheel
Gauge Wheel, Type I
Gauge Wheel, Type Ii
Hydraulic Lines, Re-Set Stub Beams, All Sizes
Accumulator
Hydraulic Cylinder
Plow Bottom, 386
Plow Bottom, 387
Plow Bottom, 392
Trash Coverboard, 386, 387, 390, 392 & 394 Bottoms, Metal
