AGCO Allis Moldboard Plow 70 Series 80 Series Parts Catalog 79001513
Brand: AGCO Allis
Type of Machine: Tillage, Moldboard Plow
Model:
AGCO Allis 70 Series Moldboard Plow
AGCO Allis 80 Series Moldboard Plow
Part Number: 79001513
Number of Pages: 233 Pages
Mounted - Beams, 70 Series 2-Bottom, (10'' & 12'')
Mounted - Beams, For 70 Series 2-Bottom, (12'' Or 14'')
Mounted - Beams, For 70 Series, 2-Bottom, (14'' Or 16'')
Mounted - Beams, For 70 Series, 3-Bottom, (10'' Or 12'')
Mounted - Beams, For 70 Series, 3-Bottom, (12' Or 14'')
Mounted - Beams
Mounted - Beams, For 73 Series, 3-Bottom, (14'' Or 16'')
Mounted - Beams, For 80 Series,
Mounted - Beams, For 80 Series, 4-Bottom, (14 Or 16 )
Mounted - Pull Bar & Beaming Screw,
Mounted - Pull Bar & Beaming Screw, For 70 & 80 Series,
Mounted - Tower, Lift Bar & Braces,
Mounted - Truss Bar,
Semi-Mounted With Vertical Pivot - Beams, For 70 & 80 Series,
Semi-Mounted With Vertical Pivot - Pull Bar & Lift Links,
Semi-Mounted With Vertical Pivot - Bracket & Pivot,
Semi-Mounted With Vertical Pivot - Truss Bars,
Semi-Mounted With Vertical Pivot - Swinging Ram Anchor,
Semi-Mounted With Vertical Pivot - Steering Tubes,
Semi-Mounted With Vertical Pivot - Draft Plates,
Semi-Mounted With Vertical Pivot - Gauge Wheel,
Semi-Mounted With Vertical Pivot - Rear Wheel,
3-Point Hitch Type - Beams, For 70 & 80 Series Mounted Plows,
3-Point Hitch Type - Tower & Lift Bar, For 70 & 80 Series,
3-Point Hitch Type - Lift Bar & Tower, For 70 & 80 Series,
3-Point Hitch Type - Lever & Ram Anchors, For 70 & 80 Series,
3-Point Hitch Type - Lead Adjusting Linkage,
3-Wheel Type - Beams, For 70 & 80 Series, 3-Bottom,(14 Or16 )
3-Wheel Type - Beams, For 70 & 80 Series, 4-Bottom,(14 Or16 )
3-Wheel Type - Beams, For 70 & 80 Series Plows, 5-Bottom,
3-Wheel Type - Beams, For 74 Series, 4-Bottom, (14 Or 16 )
3-Wheel Type - Hitches, For 70 & 80 Series, 3- & 4-Bottom,
3-Wheel Type - Tandem Hitch, For 70 & 80 Series, 4-Bottom,
3-Wheel Type - Drawbar & Lift Links, Traction Booster Hitch
3-Wheel Type - Drawbar & Lift Links, Traction Booster Hitch,
3-Wheel Type - Truss Bars,
3-Wheel Type - Clevis Asy.,
3-Wheel Type - Beaming Screw,
3-Wheel Type - Lift Tubes, For 70 & 80 Series Plows,
3-Wheel Type - Lift Axle & Hangers, For 70 & 80 Series,
3-Wheel Type - Furrow Axle & Hangers, For 70 & 80 Series,
3-Wheel Type - Furrow Axle, For 70 & 80 Series, 5-Bottom,
3-Wheel Type - Gauge Wheel, For Tandem Hitch, 70 & 80 Series,
3-Wheel Type - Rear Wheel, For 70 & 80 Series, 3- & 4-Bottom,
3-Wheel Type - Rear Wheel, For 70 & 80 Series, 5-Bottom,
With Rear Wheel - Beams, For 70 Series, 4-Bottom, (12 Or14 )
With Rear Wheel - Beams, For 73 Series, 3-Bottom, (14 Or16 )
With Rear Wheel - Beams, For 80 Series, 3-Bottom,
With Rear Wheel - Beams, For 80 Series, 4-Bottom,
Two-Way - Beams, For 70 Series, 2-Bottom, (16'' Or 18'')
Two-Way - Beams, For 70 Series, 3-Bottom, (14'' Or 16'')
Two-Way - Beams, For 80 Series, 2-Bottom, (16'')
Two-Way - Beams, For 80 Series, 3-Bottom, (14'' Or 16'')
Two-Way - Beam Frame, For 80 Series, 1-Bottom, (16'' & 18''),
Two-Way - Shaft, Brace & Beaming Screw, For 70 & 80 Series,
Two-Way - Shaft, Yoke & Beaming Screw, For 70 & 80 Series
Two-Way - Pull Bar & Beaming Screw, For 80 Series, 1-Bottom,
Two-Way - Pull Bar & Lift Links, For 70 & 80 Series,
Two-Way - Lift Bar, For 3-Point Hitch, For 70 & 80 Series,
Two-Way - Shaft, Brace & Yoke, For 80 Series, 1-Bottom,
Two-Way - Automatic Spinning Attachment, For 80 Series,
Two-Way - Actuator, For 70 & 80 Series,
Two-Way - Relief Valve, For 70 & 80 Series, 2- & 3-Bottom,
Two-Way - Scraper, Front Gauge Wheel, For 70 & 80 Series
Two-Way - Front Gauge Wheel, For 70 & 80 Series,
Two-Way - Rear Gauge Wheel, For 70 & 80 Series,
Truss Bar, 70 & 80 Series, 3- & 4-Bottom,
Pull Bar & Beaming Screw, For 70 & 80 Series, 2 & 3-Bottom,
Pull Bar & Beaming Screw, For 73 & 83, 3-Bottom, (14 Or16 )
Spring Trip Stub Beam, For 70 Series (2-, 3- & 4-Bottom),
Stub Beams, For 70 & 80 Series, 4- & 5-Bottom (14'' Or 16'',
Stub Beams, For 70 & 80 Series (1-, 2-, 3-, 4- & 5-Bottom),
Stub Beam & Gusset Plates (Spring Trip), For 80 Series,
Rear Wheels, For 70 & 80 Series, 3- & 4-Bottom, (14 Or16 )
Gauge Wheel Extension, For 70 & 80 Series
Coulter, Single Arm Shear Bolt
Coulter, Single Arm Rubber Mounted
Coulter, Double Arm Shear Bolt
Plow Bottom, 386
Plow Bottom, 387
Plow Bottom, 392
Plow Bottom, 394 Slat
Landside Plates, 386 & 387 Bottoms
Trash Coverboards, 386 & 387 Bottoms, 390, 392 & 394 Bottoms
Brand: AGCO Allis
Model:
Mounted - Beams
Plow Bottom, 386
Plow Bottom, 387
Plow Bottom, 392
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
