AGCO Allis Manure Spreaders Parts Catalog 79001541
Brand: AGCO Allis
Type of Machine: Manure Spreaders
Part Number: 79001541
Number of Pages: 231 Pages
Boxes - Box -- Right Front View, 95a Spreader (P.T.O.)
Boxes - Box -- Left Rear View, 95a Spreader (P.T.O.)
Boxes - Box Bottom View, 95a Spreader (P.T.O.)
Boxes - Trough Attachment, Special Attachment, 95a Spreader
Boxes - Endgate Extension Attachment, Special Attachment
Frames - Axle & Wheel, 95g Spreader (Ground Drive)
Frames - Axle & Wheels, 95a Spreader (P.T.O.)
Frames - Drawbar Reinforcement, Special Attachment
Beaters - Lower Beater, 95a Spreader (P.T.O.)
Beaters - Lower Beater, 95g Spreader (Ground Drive)
Beaters - Upper Beater, 95a Spreader (P.T.O.)
Beaters - Slinger, 95a Spreader (P.T.O.)
Beaters - Raddle & Beater Control, 95a Spreader (P.T.O.)
Beaters - Feed Control Lever, 95g Spreader (Ground Drive)
Drives - P.T.O. Hitch Joint, 95a Spreader (P.T.O.)
Drives - P.T.O. Shaft Shield, 95a Spreader (P.T.O.)
Drives - P.T.O. Shaft, 95a Spreader (P.T.O.)
Drives - Drive Shaft & Slip Clutch, 95a Spreader (P.T.O.)
Drives - Gear Box & Supports, 95a Spreader (P.T.O.)
Drives - Ratchet Drive & Gear Box Shield, 95a Spreader(P.T.O)
Drives - Raddle Drive, 95a Spreader (P.T.O.)
Drives - Raddle Drive Control, 95g Spreader (Ground Drive)
Drives - Beater & Slinger Drive, 95a Spreader (P.T.O.)
Drives - Beater Drive Control, 95g Spreader (Ground Drive)
Drives - Beater Drive Shield, 95a Spreader (P.T.O.)
Drives - Beater Drive Shield, 95g Spreader (Ground Drive)
Raddles - Raddle, 95a Spreader (P.T.O.), 95g Spreader (Ground
Boxes - Box, L.H. Rear View
Boxes - Box, Bottom View
Boxes - Puddle Manure Attachment
Boxes - Litter Attachment
Frames - Wheel
Frames - Hitch Ball & Socket
Frames - Jack
Beaters - Beater Housing, L.H. Rear View
Beaters - Beater Housing, R.H. Front View
Beaters - Beaters & Drives
Beaters - Slingers
Drives - Gear Box
Drives - Ratchet
Drives - Beater Idler
Drives - Slinger Idler
Raddles - Raddle
Boxes - Material Box, Front View -- Right, 140, 140-S & 281
Boxes - Material Box, Front View -- Right, 180, 180-S & 299
Boxes - Material Box, Rear View -- Left, 140, 140-S & 281
Boxes - Material Box, Rear View -- Left, 180, 180-S & 299
Boxes - Material Box, Bottom View, 140, 140-S & 281
Boxes - Material Box, Bottom View, 180, 180-S & 299
Boxes - Endgate, 140 & 180
Boxes - Endgate, 140-S, 180-S, 281 & 299
Boxes - Endgate Extension, 140 & 180
Boxes - Trough, 140 & 180
Boxes - Trough, 140-S, 180-S, 281 & 299
Boxes - Pan, 140-S, 180-S, 281 & 299
Frames - Tongue, 180, 180-S & 299
Frames - Axle, 140 Prior S N 1226, 140-S Prior S N 351
Frames - Axle, Eff. 180 S N 351 & Up, 180-S & 299
Frames - Wheels, All Models
Frames - Jack -- Folding, 281 & 299
Frames - Drawbar Reinforcement, All Models
Beaters - Upper Beater, For 140 & 180
Beaters - Lower Beater, For 140 & 180
Beaters - Single Beater, For 140-S, 180-S, 281 & 299
Beaters - Slinger, For 140 & 180
Beaters - Beater Supports, For 140-S, 180-S, 281 & 299
Beaters - Beater & Raddle Control, All Models
Beaters - Rope Control, Beater & Raddle, For 281 & 299
Beaters - Control Lever -- Long, Beater & Raddle, All Models
Beaters - Control Lever - Short, Beater & Raddle, For 140-S
Drives - P.T.O., Shaft & Supports, 140 Prior S N 1226
Drives - P.T.O., 3-Joint Line, 140 Prior S N 1226
Drives - P.T.O., 2-Joint Line, 140 Eff. S N 1226 & Up
Drives - P.T.O. -- 2-Joint Line W O Slip Clutch
Drives - P.T.O., 2-Joint Line -- W Slip Clutch, 140-S & 180-S
Drives - Slip Clutch, 140 Eff. S N 1226 Thru 1500, 140-S
Drives - Gear Box Supports, 140 Prior S N 1101
Drives - Gear Box Supports, 140 Eff. S N 1226 & Up
Drives - Gear Box, All Models
Drives - Drive Shaft & Slip Clutch, 140 Prior S N 1226
Drives - Drive Shaft, For 140-S Eff. S N 351 Thru 850
Drives - Upper Beater & Slinger Drive, For 140 & 180
Drives - Beater & Slinger Drive Shield, For 140 & 180
Drives - Beater Drive Shield, All Models
Drives - Gear Box & Ratchet Drive Shield, All Models
Drives - Drive Chain Idler, For 140-S Eff. S N 351 Thru 850
Drives - Raddle Drive, All Models
Drives - Drive Sprocket & Bearing
Raddles - Raddle, 2-Chain, 140 & 140-S
Raddles - Raddle, 2-Chain, 180, 180-S & 299
Raddles - Raddle, 3-Chain
Frame - Frame, Wheel & Gate Asy., For 402f
Frame - Frame, Wheel & Gate Asy., For 804f
Frame - Hopper & Gate Asy., For 804f
Drives - Ground Drive, For 402f
Drives - Ground Drive, For 804f
Drives - Conveyor Drive & Web Belt, For 804f
Drives - Spinner Asy. -- Hopper Chute & Idler, For 402f
Drives - Spinner Asy -- Hopper And Idler, For 804f
Hydraulics - Hydraulic Brakes & Lines, For 402f
Brand: AGCO Allis
Frames - Wheel
Frames - Jack
Beaters - Slingers
Drives - Gear Box
Drives - Ratchet
Raddles - Raddle
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
