AGCO Allis Farm Loaders A-C Parts Catalog 79006059
Brand: AGCO Allis
Type of Machine: Farm Loaders
Model: AGCO Allis A-C Farm Loaders
Part Number: 79006059
Number of Pages: 263 Pages
Frames - Frame & Bucket, Model 8
Frames - Frame & Bucket, Model 9, (Used Prior To Nov. 1959)
Frames - Boom, Model 9
Frames - Sub Frame, Models 9 & 90
Frames - Frame & Bucket, Model 14, (Used Prior To Nov. 1959)
Frames - Boom, Model 14
Frames - Sub Frame, Models 14 & 15
Frames - Frame & Bucket, Model 17, (Used Prior To Nov. 1959)
Frames - Boom, Models 15 & 17
Frames - Sub Frame, Model 17
Frames - Frame, Models 100-A & 100-B, D-10, D-12 & Ca Tractor
Frames - Boom, Models 100, D-10, D-12 & Ca
Frames - Frame, Models 140, 150 & 170
Frames - Side Frames, 160 Farm Loader
Frames - Frame, Model 180, (For 180 Tractor)
Frames - Boom, Model 10 Loader, D-10, D-12 & Ca Tractors
Frames - Grille Guard, Models 100-A & 100-B, D-10, D-12 & Ca
Buckets & Blades - Trip Lever, Models 9, 14, 15 & 17
Buckets & Blades - Material Bucket, Models 9, 10, 14, 15, 17
Buckets & Blades - Dozer Blade, Models 8, 9, 10, 14, 15, 17
Hydraulics - Cylinder, Models 100-A, 100-B & Ed-40
Hydraulics - Hydraulic Lines & Connectors, Models 9 & 90
Hydraulics - Hose Coupler Asy., Models 8, 9, 14, 15, 17, 90
Hydraulics - Hydraulic Lines & Connectors, Models 10 & 100
Hydraulics - Cylinder, Models 90, 100, 140, 150, 170 & 100-A
Hydraulics - Hydraulic Lines, 160 Farm Loader
Hydraulics - Hydraulic Lines & Connectors, Models 100-A
Hydraulics - Hydraulic Lines & Connectors, Models 8, 14, 15
Frames - Side Frames, With Oil Reservoir, 400 & 500 Series
Frames - Side Frames, Without Oil Reservoir, 400 & 500 Series
Frames - Side Frames, For Wd Tractors, 400 Series
Frames - Boom, 400 & 500 Series
Frames - Rear Mounting Brackets, 400 & 500 Series
Frames - Grille Guard, For D-17 Series Iv, D-19 & 190 Tractor
Frames - Grille Guard, 170, 180 & 190 Tractors, 500 Series
Frames - Grille Guard, 400 & 500 Series
Buckets & Blades - Dozer Blade -- 80'', 400 & 500 Series
Buckets & Blades - Manure Bucket & Dirt Pan, 42, 60 & 72
Buckets & Blades - Material Bucket -- 60'', 400 & 500 Series
Hydraulics - Hoses & Fittings, For Lift Cylinders
Hydraulics - Tubes, Hoses & Fittings -- Front
Hydraulics - Valve Controls & Hoses, For Wd Tractors
Hydraulics - Tubes & Couplings, For D-19 Tractor, 500 Series
Hydraulics - Pump, 400 & 500 Series
Hydraulics - Valve -- With Float Position, 400 & 500 Series,
Hydraulics - Lift Cylinder, 400 Series
Hydraulics - Pump Guard, For D-19 Tractor, 500 Series
Hydraulics - Valve Controls, 400 & 500 Series
Hydraulics - Hydraulic Lines, Front & Rear, For 160 Tractor
Frames - Side Frames & Supports
Frames - Boom & Stand
Frames - Grille Guard & Support
Frames - Fork Lift & Boom, 400 Loader
Hydraulics - Pump Drive, Mounting & Hoses, For 160 Tractor
Hydraulics - Pump Drive, Mounting & Hoses, For 6040 Tractor
Hydraulics - Valve
Buckets & Blades - Manure Bucket & Dirt Pan, 42'', 60'', 72''
Frames - Side Frames & Supports, (5040, 5045 & 5050)
Frames - Boom & Stand, (5040, 5045, 5050)
Frames - Grille Guard & Pipe Extension, (5040, 5045, 5050)
Hydraulics - Hydraulic Lines, (5040, 5045, 5050)
Hydraulics - Pump Drive, Mounting & Hoses, (5040, 5045, 5050)
Hydraulics - Lift Cylinder, For Tractors With 2-Wheel Drive,
Hydraulics - Lift Cylinders,For Tractors W Front Wheel Assist
Hydraulics - Valve, (5040, 5045, 5050)
Hydraulics - Valve Controls, (5040, 5045, 5050)
Buckets & Blades - Manure Bucket & Dirt Pan, 42, 60, 72
Buckets & Blades - Material Bucket -- 60, (5040, 5045, 5050)
Buckets & Blades - Dozer Blade -- 80'', (5040, 5045, 5050)
Frames - Boom
Hydraulics - Hydraulic Lines, Cylinders & Control Valve
Hydraulics - Hydraulic Lines, Selector Valve & Block
Hydraulics - Valves, Control Valve, Prior S N 1576
Hydraulics - Valves, Control Valve, Eff. S N 1576 Thru 3310
Hydraulics - Valves, Control Valve, Eff. S N 3311 & Up
Hydraulics - Valves, Selector Valve, Eff. S N 1717
Hydraulics - Cylinders, Lift Cylinder, 2 Bore X 17-1 2
Hydraulics - Cylinders, Tilt Cylinder, 2 Bore X 15 Stroke
Bucket - Material Bucket -- 48
Hydraulics - Hydraulic Lines, Boom End
Hydraulics - Hydraulic Lines, Tractor End
Hydraulics - Tilt Cylinder
Buckets - Manure Buckets, For 42, 60 & 72
Buckets - Material Buckets, For 42, 60, 72 & 80
Buckets - Manure Buckets, For 60'' & 72''
Buckets - Material Buckets, For 60'', 72'' & 80''
Frames - Mounting Supports, For 7000 Tractor
Frames - Attaching Adapter
Frames - Round Bale Handler, Loader Boom Mounted
Frames - Round Bale Carrier, 3-Point Hitch
Frames - Grapple Over Bucket
Frames - Hay Grapple Fork
Frames - Push-Off Hay Stacker
Hydraulics - Hydraulic Lines, For Accessory Cylinder
Hydraulics - Hydraulic Cylinders -- 2-1 2, Lift, For 7000 Tr
Hydraulics - Hydraulic Cylinders -- 3, Lift, 7020, 7030
Hydraulics - Hydraulic Cylinder -- 3, Tilt, All Models
Hydraulics - Hydraulic Cylinders -- 2, Round Bale Handler
Hydraulics - Hydraulic Cylinders -- 2, Grapple Over Bucket
Hydraulics - Hydraulic Cylinders -- 2, Hay Grapple Fork
Buckets & Blades - Manure Bucket -- 60, Dirt Plate & Snow
Buckets & Blades - Material Bucket -- 83
Buckets & Blades - Bucket Level Indicator
Buckets & Blades - Dozer Blade -- 8 Ft.
Brand: AGCO Allis
Hydraulics - Valve
Frames - Boom
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
