AGCO Allis Disc Harrow 2000 Series 2200 Series Parts Catalog 79001519
Brand: AGCO Allis
Type of Machine: Tillage, Disc Harrow
Model:
AGCO Allis 2000 Series Disc Harrow
AGCO Allis 2200 Series Disc Harrow
Part Number: 79001519
Number of Pages: 401 Pages
Publication Information
Frames - Frame & Scraper, No. 20 Series, D-10, D-12 & Ca,
Frames - Frame & Scraper, No. 20 Series, D-10, D-12 & Ca, 5-1 2 Foot
Frames - Frame & Scraper, No. 20 Series, D-14, D-15, D-17, Wd & Wd-45, 6-1 2 Foot
Frames - Frame & Scrapers, No. 20 Series, Ca, D-10 & D-12, 7 Foot
Frames - Frame & Scrapers, No. 20 Series, D-14, D-15, D-17, Wd & Wd-45, 7 Foot
Frames - Frame & Scrapers, No. 20 Series, D-14, D-15, D-17, Wd & Wd-45, 8 Foot
Hitches - Drawbar & Eye, F Snap-Coupler System, No. 20 Series 6-1 2, 7, & 8 Foot, D-14, D-15, D-17, Wd & Wd-45
Hitches - Lift Chains Snap-Coupler, F Snap-Coupler System, Ca, D-10 & D-12 No. 20 Series
Hitches - Lift Chains & Clevis, No. 20 Series, D-14, D-15, D-17 Wd & Wd-45
Hitches - Drawbar Eye & Chain Extension, No. 20 Ser. Disc Harrow Conversion, D-10 & D-12 High Clearance Tractors
Disc Gangs - Front & Rear Disc Gang, No. 20 Series, D-10, D-12, Ca, D-14, D-15, D-17, Wd, Wd-45 8 Foot
Disc Gangs - Front Disc Gang, No. 20 Series, Ca 5-1 2 Foot
Disc Gangs - Front Disc Gang, No. 20 Series, D-14, D-15, D-17, Wd & Wd-45 6-1 2 Foot
Disc Gangs - Rear Disc Gang, No. 20 Series, Ca 5-1 2 Foot
Disc Gangs - Rear Disc Gang, No. 20 Series, D-14, D-15, D-17, Wd & Wd-45 6-1 2 Foot
Frames - Frame & Scrapers, No. 109 Series
Frames - Main Frame, No. 110 Series
Hitches - Drawbar & Spring Bolt, No. 105, 107, 109 & 110 Series
Hitches - 3-Point Hitch Tower
Gang Bars - Front Gang Bars (R.H. & L.H.), 5 Foot, Right Side Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), Wide Spacing 6-1 2 Foot, Right Hand Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), No. 100 Series 6-1 2 Foot, Right Side Shown
Gang Bars - Rear Gang Bars (R.H. & L.H.), 5 Foot, Right Side Shown
Gang Bars - Rear Gang Bars (R.H. & L.H.), 6-1 2 Foot, Right Side Shown
Gang Bars - Rear Gang Bars (R.H. & L.H.), Wide Spacing - No. 100 Series 6-1 2 Foot, Right Side Shown
Gang Bars - Rear Gang Bars (R.H. & L.H.), Wide Spacing - No. 100 Series 8-1 2 Foot, Right Side Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), No. 110 Series, Right Side Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), Wide Spacing - No. 110 Series 10 Foot, Right Side Shown
Gang Bars - Rear Gang Bars - (R.H. & L.H.), No. 110 Series, Right Side Shown
Gang Bars - Bearing Brackets, No. 100 & 200 Series
Gang Bars - Bearing Brackets, No. 100, 200, & 2000 Series
Disc Gangs - Front & Rear Disc Gangs, 5 Foot
Disc Gangs - Front & Rear Gangs, Wide Spacing 6-1 2 Foot
Disc Gangs - Front & Rear Disc Gang, 6-1 2 Foot
Disc Gangs - Disc Gangs, No. 109 Series, Right Gang Shown
Disc Gangs - Front & Rear Disc Gangs, Wide Spacing No. 109 Series
Disc Gangs - Front Disc Gang, Wide Spacing No. 110 Series - 10 Foot
Disc Gangs - Front & Rear Disc Gang, No. 100 & 211 Series
Disc Gangs - Wide Blade Scrapers, No. 100 & 200 Series
Disc Gangs - Wide Blade Scrapers, Spring Loaded, No. 100, 200 & 2000 Series
Frames - Main Frame, Np. 209, 211, 214 & 215 Series, No. 212, 213 Series - 12 Foot
Frames - Frame, No. 210 Series
Frames - Frame, No. 213 Series - 12-1 2 Foot
Frames - Depth Screw & Supports, No 210 & 213 Seres 12-1 2 Foot
Frames - Depth Screw & Support, No. 209, 211, 214 & 215 Series, No. 212 & 213 Series-12', Prior To Sep. 1962
Frames - Depth Screw & Supports, No 200 Series 209,211,212,213,214 & 215, No 2000 Series 14, 18 & 20', Eff Sept. 1962
Frames - Cross Shaft, No 209, 210, 211, 212, 214 & 215 Series, No 213 - 12' & 12-1 2', No 2000 Series 14, 18 & 20'
Frames - Axle & Wheel - 80 Tread, No 200 Series & 2200 Series
Frames - Axle & Wheel - 92 Tread, No 200 Series & 2200 Series
Frames - Middle Buster, 200, 2000 & 2200 Series Disc Harrows
Frames - Hitch Plate, No 200 & 2000 Series
Frames - Warning Light & Reflector Supports, No 200 & 2000 Series
Hitches - Drawbar & Lift Chains, No 210 & 213 Series, Prior To 1957
Hitches - Drawbar & Lift Chains, No 200 (Eff 1957) & 2000 Series
Hitches - Clevis Assembly, Traction Booster Drawbar Conversion, No 200 & 2000 Series
Hitches - Clevises, Traction Booster Drawbar Conversion, No 200 & 2000 Series, Eff. April 1963
Hitches - Clevises, Hitch & Hose Support, Standard Tractor Drawbar, No 200 & 2000 Series, Eff April 1963
Hitches - Hitch & Hose Support, Standard Tractor Drawbar, No 200 & 2000 Series
Hitches - Drawbar & Lift Links, Traction Booster & Standard Type, No 200 & 2000 Series
Hitches - Drawbar & Lift Links, Traction Booster Hitch (Telescoping, Links) & Standard Type, Eff. Dec. 1961
Hitches - Drawbar & Lift Links, Traction Booster (W Double Spring), & Standard Type, Eff. Sept. Thru Nov. 1962
Hitches - Drawbar & Lift Links, Traction Booster (W Double Spring) &, Standard Type, Eff. Dec 1962
Hitches - Drawbar & Beaming Screw (Hinge Type), No 200 (Eff Jan. 1959) & 2000 Series
Gang Bars - Front Gang Bars (R.H. & L.H.), No 200 Series 8-1 2', Right Side Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), Wide Spacing - No 200 Series 8-1 2'
Gang Bars - Front Gang Bars, No 210 Series, Right Side Shown
Gang Bars - Front Gang Bars (R.H. & L.H.), No 211 Series, Right Side Shown
Gang Bars - Front Gang Bars, No 212 Series 11', Rh & Lh - Rh Shown
Gang Bars - Front Gang Bars, No 213 Series 12', Rh & Lh - Rh Shown
Gang Bars - Front Gang Bars, No 213 Series 12-1 2', Right Side Shown
Gang Bars - Front & Rear Gang Bars, No 200 Series 14' Heavy Duty, Right Side Shown
Gang Bars - Front Gang Bars - Inner (Rh & Lh), No 214 & 215 Series, Right Side Shown - Fold-Up-Type
Gang Bars - Front Gang Bars - Outer (Rh & Lh), No 214 Series, Right Side Shown - Fold-Up-Type
Gang Bars - Front Gang Bars - Outer (Rh & Lh), No. 214 Series 13-1 2', Right Side Shown - Fold-Up-Type, Eff. Oct. 1961
Gang Bars - Front Gang Outer (Rh & Lh), No 215 Series, Right Side Shown - Fold-Up-Type
Gang Bars - Front Gang Bars - Outer (Rh & Lh), No 215 Series 15', Right Side Shown - Fold-Up-Type, Eff. Oct. 1961
Gang Bars - Front Gang Bars (Rh & Lh), No 214 Series, Right Side Shown - Straight Type
Gang Bars - Front Gang Bars (Rh & Lh), No 215 Series, Right Side Shown - Straight Type
Gang Bars - Rear Gang Bars (Rh & Lh), No 200 Series 8-1 2', Right Hand Shown
Gang Bars - Rear Gang Bars, No 210 Series, Right Side Shown
Gang Bars - Rear Gang Bars (Rh & Lh), No 211 Series, Right Side Shown
Gang Bars - Rear Gang Bars, No 212 Series 11', Rh & Lh - Rh Shown
Gang Bars - Rear Gang Bars, No 213 Series 12', Rh & Lh - Rh Shown
Gang Bars - Rear Gang Bars, No 213 Series - 12-1 2', Right Side Shown
Gang Bars - Rear Gang Bars - Inner (Rh & Lh), No 214 & 215
Gang Bars - Rear Gang Bars-Inner (Rh & Lh), N0 214 & 215 Series, Right Side Shown - Fold Up Type
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), Right Side Shown - Fold Up Type, No 214 Series
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), No 214 Series 13-1 2', Right Side Shown - Fold Up Type, Eff. Oct. 1961
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), No 215 Series, Right Side Shown - Fold Up Type
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), Np 215 Series 15', Right Side Shown - Fold-Up Type, Eff. Oct. 1961
Gang Bars - Hinges & Hinge Plates (Rh & Lh), 200 & 2000 Series Disc Harrows, Eff. Jan. 1965
Gang Bars - Rear Gang Bar (Rh & Lh), No 214 Series, Right Side Shown - Straight Type
Gang Bars - Rear Gang Bar (Rh & Lh), No 215 Series, Right Side Shown - Straight Type
Gang Bars - Truss Rods, No 214 & 215 Series, Fold-Up Type
Gang Bars - Truss Rods, No 214 & 215, Straight Type Gangs
Gang Bars - Bearing Brackets, No 100 & 200 Series
Gang Bars - Bearing Brackets, No 100, 200 & 2000 Series
Disc Gangs - Front Disc Gangs, Wide Spcing - No 200 Series 8-1 2'
Disc Gangs - Front & Rear Disc Gangs, No 200 Series 8-1 2'
Disc Gangs - Front & Rear Disc Gangs, No 210 Series
Disc Gangs - Front & Rear Disc Gang, No 100 & 211 Series
Disc Gangs - Outer Front & Rear Disc Gangs, 212 Series 11'
Disc Gangs - Front & Rear Disc Gang, Inner & Outer 213 Series 12', Inner Only 212 Series 11'
Disc Gangs - Front & Rear Disc Gangs, No 213 Series 12-1 2'
Disc Gangs - Front & Rear Disc Gang - Outer, No 214 Series
Disc Gangs - Front & Rear Disc Gang - Outer, No 214 Series 13-1 2', Eff. Oct. 1961
Disc Gangs - Front & Rear Disc Gang, No 215 Series, No 214 Series - Inner Only
Disc Gangs - Front & Rear Disc Gang, No 215 Series, No 214 Series - Inner Only, Eff. Oct. 1961
Disc Gangs - Front & Rear Disc Gang, No 200 Series 14' Heavy Duty
Disc Gangs - Wide Blade Scrapers, No 100 & 200 Series
Disc Gangs - Wide Blade Scrapers, Spring Loaded, No 100, 200 & 2000 Series
Disc Gangs - Scrapers & Scraper Bars, (One Piece Type)(Rh & Lh), No. 200 & 2000 Series, No. 200 Series 14' Heavy Duty Shown
Disc Gangs - Furrow Eradicator, No 200 & 2000 Series Disc Harrows
Disc Gangs - Drive Connector (Disc Gangs), 200 & 2000 Series Disc Harrows
Disc Gangs - Wrench Set
Frames - Main Frame, No 2000 Series 14, 18 & 20'
Frames - Depth, Screw & Supports, No 2000 Series 14, 18 & 20', Prior To Sept. 1962
Frames - Depth Screw & Supports, 200 Series 209, 211, 212, 213, 214 & 215, 2000 Series 14, 18 & 20', Eff. Sept. 1962
Frames - Cross Shaft, 209, 210, 211, 212, 214 & 215 Series, 213 12' & 12-1 2', 2000 Series 14, 18 & 20'
Frames - Dual Axle & Wheel (Rh & Lh), 2000 Series Disc Harrows 14, 18 & 20', Right Side Shown
Frames - Dual Axle & Wheel, 2000 & 2200 Series Disc Harrows
Frames - Hitch Plate, 200 & 2000 Series
Frames - Warning Light & Reflector Supports, 200 & 2000 Series
Hitches - Drawbar & Lift Chains, 200 (Eff. 1957) & 2000 Series
Hitches - Drawbar & Lift Links, Traction Booster Hitch, (Telescoping Links) & Standard Type, Eff. Dec. 1961
Hitches - Drawbar & Lift Links, Traction Booster (Double Spring), & Standard Type Hitch, Eff Sept. 1962 Thru Nov. 1962
Hitches - Drawbar & Lift Links, Traction Booster (Double Spring) &, Standard Type Hitch, Eff. Dec. 1962
Hitches - Clevises, Hitch & Hose Support, Standard Tractor Drawbar, No 200 & 2000 Series, Eff. April 1963
Gang Bars - Front Gang Bars (Rh & Lh), No 2000 Series 14' Inner 18 & 20', Right Side Shown
Gang Bars - Front Gang Bars - Outer (Rh & Lh), No 2000 Series 18', Right Side Shown - Fold-Up Type
Gang Bars - Front Gang Bars - Outer (Rh & Lh), No 2000 Series 20', Right Side Shown - Fold-Up Type
Gang Bars - Rear Gang Bars (Rh & Lh), No 2000 Series 14' - Inner 18 & 20'
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), No 2000 Series 18', Right Side Shown - Fold-Up Type
Gang Bars - Rear Gang Bars - Outer (Rh & Lh), No 2000 Series 20', Right Side Shown - Fold-Up Type
Disc Gangs - Front & Rear Disc Gang, No 2000 Series, Inner 14' & 18' - Inner & Outer 20'
Disc Gangs - Front & Rear Disc Gang, No 2000 Series, Outer 1 4' - Center &, Outer 18' - Center 20'
Disc Gangs - Scrapers & Scraper Bars, (One Piece Type)(Rh & Lh), No 200 & 2000 Series, No 200 Series 14' Heavy Duty Shown
Frames - Main Frame, 2214, 2216, 2218 & 2220 (14,16,18 & 20'), 2200 Series Disc Harrows
Frames - Main Frame, 2214 Fold-Up Disc Harrows 14', 2200 Series Disc Harrows
Frames - Main Frame, 2209, 2210 & 2212 (9, 10, & 12'), 2200 Series Disc Harrows
Frames - Cross Shafts, 2200 Series Disc Harrows
Frames - Axle & Wheel 80 Tread, No 200 Series & 2200 Series
Frames - Warning Light & Reflector Supports, 2200 Series Disc Harrows
Hitches - Drawbar & Hitches, 2200 Series Disc Harrows
Hitches - Clevises & Hitch Plate, Asae Tractor Drawbar, 2200 Series Disc Harrows, Eff. Aug. 1967
Gang Bars - Gang Bars, Front & Rear (Non-Folding), 2200 Series Disc Harrows
Gang Bars - Gang Bars (Inner-Front & Rear - Folding), 2214, 2216, 2218 & 2220(14, 16,18 & 20'), 2200 Series Disc Harrows
Gang Bars - Gang Bars (Outer-Front & Rear - Folding), 2214, 2216, 2218 & 2220(14, 16,18 & 20 ), 2200 Series Disc Harrows
Gang Bars - Bearing Brackets, 2200 Series Disc Harrows
Gang Bars - Disc Gang (Front & Rear), (Inner & Outer), (6 Blade Gang Shown), 2200 Series Disc Harrows
Gang Bars - Scrapers & Scraper Bars (Rh & Lh), (6 Scraper Asy. Shown), 2200 Series Disc Harrows
Gang Bars - Drive Connector, Disc Gangs, 22000 Series Disc Harrows
Gang Bars - Furrow Eradicator, 2200 Series Disc Harrows
Gang Bars - Wrench Set
Hitch - Hitch, Squadron Hitch, No. 200 Series & 2200 Series
Hitch - Drawbar Extension & Hose Support, Sqaudron Hitch, No 200 Series & 2200 Series
Hitch - Tool Bar & Drawbars, Squadron Hitch - No 200 & 2200 Series
Hitch - Hose Support & Jack, Squadron Hitch - No 200 & 2200 Series
Hitch - Hydraulic Lines, Squadron Hitch, No 200 Series Disc Harrow, No 2200 Series Disc Harrow
Wheels - Caster Wheel (Rh & Lh), Squadron Hitch - No 200 Series, Lh Shown, Prior To Oct. 1965
Wheels - Transport Wheel, Squadron Hitch, 200 & 2200 Series, Eff. Oct. 1965
Sway Bars - Sway Bars & Frame Brackets, Squadron Hitch - 200 & 2200 Series
Sway Bars - Sway Bars & Frame Brackets, Squadronhitch -200 Series 14' Heavy Duty
Recommended Dealer List - Recommended Dealer Stock
Brand: AGCO Allis
Model:
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
