AGCO Allis Cotton Stripper 860 Parts Catalog 79005500
Brand: AGCO Allis
Type of Machine: Cotton Stripper
Model: AGCO Allis 860 Cotton Stripper
Part Number: 79005500
Number of Pages: 259 Pages
Engine - Engine Frame, Diesel
Engine - Cylinder Block, Diesel
Engine - Crankshaft, Diesel
Engine - Cylinder Head, Diesel
Engine - Piston & Connecting Rod, Diesel
Engine - Valve Operating Mechanism, Diesel
Engine - Oil Filter, Diesel
Engine - Oil Pan, Diesel
Engine - Timing Gear Cover, Diesel
Engine - Engine P.T.O. - L.H., Diesel
Fuel System - Fuel Tank & Lines, Diesel
Fuel System - Fuel Injection Lines, Diesel
Fuel System - Fuel Filters, Diesel
Fuel System - Hand Primer Pump, Diesel
Fuel System - Injection Pump, Housing & Drive, Diesel
Fuel System - Injection Pump, Transfer Pump, Head & Rotor
Fuel System - Engine Controls
Cooling System-Engine - Radiator, Diesel
Cooling System-Engine - Water Pump, Diesel
Cooling System-Engine - Rotary Screen
Air Intake & Exhaust System - Air Cleaner & Pre-Cleaner
Air Intake & Exhaust System - Manifold, Intake, Diesel
Air Intake & Exhaust System - Muffler, Diesel
Elect. System - Wiring Diagram, Lighting & Warning
Elect. System - Generator
Elect. System - Electrical System, Instrument Panel, Diesel
Elect. System - Fuel Gauge
Elect. System - Electrical System, Engine Accessory, Diesel
Elect. System - Starting Motor, Diesel
Elect. System - Head Lamp, Working & Driving
Elect. System - Caution Lamp, Front & Rear
Elect. System - Electrical System, Battery
Elect. System - Warning Light Actuator, Boll Box
Elect. System - Cab, Pressurizer
Multi-Row Stripper Head - Housing & Leveling Device
Multi-Row Stripper Head - Conveyor & Teeth
Multi-Row Stripper Head - Main Drive
Multi-Row Stripper Head - Drive Shafts & Brackets
Multi-Row Stripper Head - Header Drive & Backsheets
Multi-Row Stripper Head - Forward Reel
Multi-Row Stripper Head - Push Bar
Elevator & Conveyor - Elevator Housing
Elevator & Conveyor - Elevator Roller, Upper
Elevator & Conveyor - Elevator Roller, Lower
Elevator & Conveyor - Boll Box Conveyor
Frames - Main Frame
Frames - Basket Frame
Drives - Belts & Shields, Main Drive
Drives - Jackshaft, Main Drive
Drives - Extractor Drives - L.H.
Drives - Extractor Drives - R.H.
Drives - Drive Controls, Header Clutch
Drives - Drive Controls, Extractor
Extractor - Extractor Shields & Catwalk
Extractor - Extractor Fan
Extractor - Ducts, Air & Cotton
Extractor - Ducts & Trash Spouts, Extractor
Extractor - Extractor Housing, Exterior View
Extractor - Extractor Housing, Interior View
Extractor - Wad Breaker Cylinder
Extractor - Saw Cylinder
Extractor - Grids & Baffle, Extractor
Extractor - Boll Box & Control
Extractor - Boll Stop Housing
Basket - Basket, Left Front View
Basket - Basket, Right Rear View
Basket - Basket Top
Basket - Basket Height Extension
Basket - Braces & Supports
Basket - Safety Stands
Oper. Platform, Controls & Ladder - Steering Wheel & Housing
Oper. Platform, Controls & Ladder - Console
Oper. Platform, Controls & Ladder - Gear Shift Controls
Oper. Platform, Controls & Ladder - Controls Levers, Hyd.
Oper. Platform, Controls & Ladder - Brake Pedals & Controls
Oper. Platform, Controls & Ladder - Clutch Pedal
Oper. Platform, Controls & Ladder - Standard Seat
Oper. Platform, Controls & Ladder - Seat - Deluxe, Cushion
Oper. Platform, Controls & Ladder - Seat - Deluxe, Adj & Base
Oper. Platform, Controls & Ladder - Ladder
Oper. Platform, Controls & Ladder - Operator Platform
Cab - Cab, Front View
Cab - Cab, Rear View
Cab - Cab Mirror
Cab - Control Panel Housing
Cab - Heater
Cab - Cab Blower
Hydraulics - Steering Control Valve
Hydraulics - Hydraulic Pump
Hydraulics - Control Valve, Variable Speed
Hydraulics - Selector Valve, Stabilizer Cylinder
Hydraulics - Control Valve, Automatic Header Height Control
Hydraulics - Hydraulic Lines, Basket
Hydraulics - Hydraulic Lines, Pump & Reservoir
Hydraulics - Hydraulic Lines, Header & Variable Speed
Hydraulics - Hydraulic Lines, Power Steering
Hydraulics - Hydraulic Lines, Axle Stabilizer Cylinder
Hydraulics - Hydraulic Cylinder, Power Steering
Hydraulics - Hydraulic Cylinder, Basket Lift, 3 Bore
Hydraulics - Cylinder Helper Spring, Header Lift
Hydraulics - Hydraulic Lines, Automatic Header Height Control
Hydraulics - Shafts & Linkage, Auto. Header Height Control
Transmission - Change Gears
Transmission - Differential
Transmission - Transmission Gears & Shafts
Transmission - Input Shaft & Clutch
Final Drive, Steering Axle & Wheels - Final Drive
Final Drive, Steering Axle & Wheels - Input Drive Sheaves
Final Drive, Steering Axle & Wheels - Main Clutch & Shaft
Final Drive, Steering Axle & Wheels - Traction Drive, Idler
Final Drive, Steering Axle & Wheels - Hydraulic Wheels Brakes
Final Drive, Steering Axle & Wheels - Parking Brake
Final Drive, Steering Axle & Wheels - Clutch & Brake Linkage
Final Drive, Steering Axle & Wheels - Wheels & Steering Axle
Final Drive, Steering Axle & Wheels - Wheel Shields
Recommended Dealer Stock
