AGCO Allis Cotton Harvester 880 Parts Catalog 79005827
Brand: AGCO Allis
Type of Machine: Cotton Harvester
Model: AGCO Allis 880 Cotton Harvester
Part Number: 79005827
Number of Pages: 363 Pages
Engine - Engine Mount
Engine - Gasket Sets
Engine - Cylinder Block
Engine - Cylinder Head
Engine - Crankshaft
Engine - Flywheel & Adapter Plate
Engine - Piston & Connecting Rod
Engine - Timing Gear Cover
Engine - Idler Gear
Engine - Lubricating System, Oil Pump & Balancer
Engine - Lubricating System, Oil Pan
Engine - Lubricating System, Oil Cooler & Filter
Engine - P.T.O.
Air Intake & Exhaust System - Manifold & Intercooler, Intake
Air Intake & Exhaust System - Turbocharger, Airesearch
Air Intake & Exhaust System - Turbocharger, Lines
Air Intake & Exhaust System - Air Cleaner
Cooling System - Water Pump
Cooling System - Thermostat
Cooling System - Radiator
Cooling System - Rotary Screen
Fuel System - Fuel Injection System, Pump - Housing & Drive
Fuel System - Fuel Injection System, Pump - Advance
Fuel System - Fuel Injection System, Pump - Governor
Fuel System - Fuel Injection System, Lines, (Allis-Chalmers)
Fuel System - Fuel Injection System, Lines, (Bosch)
Fuel System - Fuel Injection System, Fuel Injector (Bosch)
Fuel System - Fuel Injection System, Fuel Filter
Fuel System - Fuel Injection System, Fuel Injector,
Fuel System - Fuel Tank & Lines
Electrical System - Engine & Battery Wiring
Electrical System - Engine Electrical System, Alternator
Electrical System - Starting Motor
Electrical System - Instruments & Gauges
Electrical System - Warning & Monitoring System
Electrical System - Hydraulic Controls
Electrical System - Engine Starting
Electrical System - Lighting System
Electrical System - Automatic Header Height Control
Electrical System - Pressurizer-Blower Asy., Wiring
Electrical System - Warning Light Actuator, Boll Box
Electrical System - Cigarette Lighter
Electrical System - Radio
Elevator & Conveyor - Elevator Housing
Elevator & Conveyor - Elevator Roller, Upper
Elevator & Conveyor - Elevator Roller, Lower
Elevator & Conveyor - Boll Box Conveyor
Frames - Main Frame
Frames - Basket Frame
Hitch & Lift - Hitch Linkage
Shields
Drives - Mainshaft
Drives - Jackshaft, Main Drive
Drives - Extractor Drives - L.H.
Drives - Extractor Drives - R.H.
Drives - Belts & Idlers, Main Drive
Drives - Drive Control, Extractor
Drives - Drive Control, Header Clutch
Extractor - Extractor Shields & Catwalk
Extractor - Extractor Fan
Extractor - Ducts, Air & Cotton
Extractor - Ducts & Trash Spouts, Extractor
Extractor - Extractor Housing, Exterior View
Extractor - Extractor Housing, Interior View
Extractor - Wad Breaker Cylinder
Extractor - Saw Cylinder
Extractor - Grids & Baffle, Extractor
Extractor - Boll Box & Control
Extractor - Boll Chute
Extractor - Trash Auger, Eff. S N 4833 And Up
Basket - Basket, Left Front View
Basket - Basket, Right Rear View
Basket - Basket Top
Basket - Basket Height Extension
Basket - Braces & Supports
Basket - Safety Stands
Operator's Platform, Controls & Ladder - Deck & Ladder
Operator's Platform, Controls & Ladder - Steering Column
Operator's Platform, Controls & Ladder - Console
Operator's Platform, Controls & Ladder - Cable Controls
Operator's Platform, Controls & Ladder - Engine Control
Operator's Platform, Controls & Ladder - Gearshift Controls
Operator's Platform, Controls & Ladder - Hydrostatic Control
Operator's Platform, Controls & Ladder - Standard Seat
Operator's Platform, Controls & Ladder - Seat - Deluxe
Hydraulics - Hydraulic Lines, Axle Stabilizer Cylinder
Hydraulics - Hydraulic Lines, Basket
Hydraulics - Hydraulic Lines, Brush Head Hook-Up
Hydraulics - Hydraulic Lines, Finger Header Tilt
Hydraulics - Hydraulic Lines, Header Lift
Hydraulics - Hydraulic Lines, Hydrostatic Transmission
Hydraulics - Oil Cooler
Hydraulics - Hydraulic Lines, Power Steering
Hydraulics - Hydraulic Lines, Pump & Valves (Hydro)
Hydraulics - Reservoir
Hydraulics - Pump, Hydro
Hydraulics - Steering Control Valve
Hydraulics - Selector Valve, Stabilizer Cylinder
Hydraulics - Control Valve, Header
Hydraulics - Control Valve, Port Plate
Hydraulics - Control Valve, Tilt & Basket
Hydraulics - Valve Stack Asy., Mounting
Hydraulics - Hydraulic Cylinder, Basket Lift
Hydraulics - Hydraulic Cylinder, Header Tilt
Hydraulics - Hydraulic Cylinder, Power Steering
Transmission, Final Drive, Steering Axle & Wheels
Transmission, Final Drive, Steering Axle & Wheels - Manifold
Transmission, Final Drive, Steering Axle & Wheels - Motor
Transmission, Final Drive, Steering Axle & Wheels - Pump
Cab - Cab, Front View, Prior To S N 4833
Cab - Cab, Front View, Eff. S N 4833 And Up
Cab - Cab, Rear View
Cab - Cab Mirror
Cab - Heater, Prior To S N 4833
Cab - Heater, Eff. S N 4833 And Up
Cab - Cab Blower, Prior To S N 4833
Cab - Control Panel Housing, Prior To S N 4833
Cab - Control Panel Housing, Eff. S N 4833 And Up
Cab - Air Conditioner - Lines
Cab - Air Conditioner - Compressor
Cab - Air Conditioner - Condenser
Cab - Air Conditioner - Evaporator
Multi-Row Stripper Head - Housing & Leveling Device
Multi-Row Stripper Head - Conveyor & Teeth
Multi-Row Stripper Head - Stalk Walker & Teeth
Multi-Row Stripper Head - Drive Shafts & Brackets
Multi-Row Stripper Head - Header Drive & Backsheets
Multi-Row Stripper Head - Forward Reel
Multi-Row Stripper Head - Push Bar, Prior To S N 4833
Brush Head - Main Frame, Std. & Narrow Rows
Brush Head - Frame, 40'' Extension
Brush Head - Auger, Std. & Narrow Rows
Brush Head - Drives, Gearbox & Supports - All Models
Brush Head - Gearbox, Exploded View, All Models
Brush Head - Drives, Auger Slip Clutch, All Models
Brush Head - Drives, Row Unit Slip Clutch
Brush Head - P.T.O. Shafts & Joints, All Models
Brush Head - Drives, Belts - All Models
Brush Head - Row Unit, Outer Sheet Metal, All Models
Brush Head - Row Unit, Sheet Metal & Lower Supports
Brush Head - Row Unit, Divider Points -- L.H. & R.H.
Brush Head - Row Unit, Sensing Shoe & Linkage, All Models
Brush Head - Row Unit, Brush Row & Linkage, All Models
Brush Head - Row Unit, Auger Asy., All Models
Brush Head - Row Unit, Upper Drives, Auger & Brush Rolls
Brush Head - Hydraulic Lines, Row Units 1 & 2
Brush Head - Hydraulic Lines, Row Units 3 & 4
Brush Head - Hydraulic Lines, 40'' Extension
Brush Head - Hydraulic Lines, Lift Cylinder & Safety Strap
Brush Head - Hydraulics, Control Valve
Brush Head - Hydraulic Lift Cylinder
Brush Head - Safety Shields, All Models
Brand: AGCO Allis
Engine - Crankshaft
Engine - Idler Gear
Engine - P.T.O.
Frames - Main Frame
Shields
Drives - Mainshaft
Basket - Basket Top
Cab - Cab Mirror
- Valtra Trator Workshop Manuals, Service Manuals & Fault Codes
- Valtra Tractor A83H A93H Workshop Service Manual
- Agco Task Controller Software Version 1.7.X Operator Manual 72571675A
- Agco Task Controller Software Version 1.7.X Operator Manual 72571678A DE
- Agco Tractor EEM4 Troubleshooting Manual
- Agco Tractor EEM4StageV Troubleshooting Manual
- Agco Console C1000 Operator Manual 72571625B DE
- Agco Tractor EEM4F Troubleshooting Manual
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000005B
- Agco Console C1000 Operator Manual 72571544B
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000023B PL
- Agco Auto-Guide 3000 Advanced Operator's Manual ACZ000009B DE
- AGCO Allis Semi Mounted 2000 3000 Wheel Type Moldboard Plow 2500 Parts Catalog 79003823
- AGCO Allis Sickle Bar Mower 3 5 7 B C B-IND WC Parts Catalog 9001530B
- AGCO Allis Sickle Bar Mower 80R 80R3 80S 80T 82R 82S 82T Parts Catalog 79001529
