2009 Toyota Tundra Remote Programming
Test
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
not accepted.
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
