2004 Toyota Tundra Double Cab Remote Programming
Test
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
