Zoomlion Telescopic Boom Lifts ZT38J Service And Maintenance Manual 2023 EN
Brand: Zoomlion
Type of Machine: Telescopic Boom Lifts
Model: Zoomlion ZT38J Telescopic Boom Lifts
Publication Date: 2023
Number of Pages: 119 Pages
4.1.3 Tire replacement
4.1.4 Wheel replacement
4.1.5 Wheel installation
4.2 Swing Axle Exhaust and Locking Test
4.2.1 Floating cylinder exhaust
4.2.2 Swing axle lock test
4.3 Chassis Angle Sensor System
4.4 Auxiliary Power System
4.5 Oscillating Axle System
4.6 Traveling Drive System
4.7 Travel Reducer
4.7.1 Disassembly
4.7.2 Installation
4.8 Traveling Motor
4.8.1 Disassembly
4.8.2 Installation
4.9 Axle Extending System
4.10 Axle Limit Switch Adjustment
4.11 Steering Control System
4.12 Drive/Steer Speed Control
4.13 Drive Direction System
4.14 Rotary Motor
4.15 Rotary Reducer
4.15.1 Check and maintenance
4.15.2 Gear oil replacement
4.16 Slewing Bearing
4.16.1 Slewing bearing lubrication
4.16.2 Check and Maintenance
4.16.3 Disassembly
4.17 Slewing Gear Clearance Adjustment
4.18 Generator
4.18.1 Check and maintenance
4.18.2 Carbon brush and slip ring maintenance
SECTION 5 BOOM AND PLATFORM
5.1 Platform and Jib
5.1.1 Load cell
5.1.2 Rotary actuator
5.1.3 Jib lifting cylinder
5.2 Boom Assembly
5.2.1 Cable
5.2.2 Leveling cylinder
5.2.3 Lifting cylinder
5.2.4 Boom
5.2.5 Telescopic cylinder
5.2.6 Wire rope pulley disassembly
5.2.7 Wire rope and pulley check
5.3 Load Cell Check
5.3.1 Load cell check
5.3.2 Platform leveling sensor check
5.3.3 Boom tilting sensor check
5.3.4 Calibration of boom length sensor
5.3.5 Check of rope damage indication system
5.3.6 Drive speed limit check
SECTION 6 ELECTRICAL SYSTEM MAINTENANCE
6.1 Fault Code
6.2 Common Faults and Solutions
SECTION 7 ELECTRICAL INFORMATION AND SCHEMATIC
7.1 General Introduction
7.2 Multimeter Basic Operation
7.2.1 Grounding
7.2.2 Backside detection
7.2.3 Minimum value/maximum value
7.2.4 Polarity
7.2.5 Range
7.2.6 Voltage measurement
7.2.7 Resistance measurement
7.2.8 Conduction test
7.2.9 Current measurement
7.3 DEUTSCH Connector
7.3.1 DT/DTP series connector assembly
7.3.2 DT/DTP series connector disassembly
7.3.3 HD30/HDP20 series connector assembly
7.3.4 HD30/HDP20 series connector removal
7.4 Electrical Schematics
7.5 Hydraulic Schematics
Brand: Zoomlion
4.7 Travel Reducer
4.7.1 Disassembly
4.7.2 Installation
4.8 Traveling Motor
4.8.1 Disassembly
4.8.2 Installation
4.14 Rotary Motor
4.15 Rotary Reducer
4.16.3 Disassembly
4.18 Generator
5.1.1 Load cell
5.2 Boom Assembly
5.2.1 Cable
5.2.4 Boom
5.3 Load Cell Check
6.1 Fault Code
7.2.1 Grounding
7.2.4 Polarity
7.2.5 Range
- Zoomlion Truck Crane QY30V Operation and Maintenance Manual
- ZOOMLION Truck Crane QY30V lSPARE Parts Catalog
- Zoomlion Crawler Crane QUY260 Parts Manual_20131106
- Zoomlion Rough Terrain Crane RT551 Hydraulic Schematic 20140218
- Zoomlion TOWER CRANE L250-20 Instruction Manual
- Zoomlion RT55 Rough Terrain Crane Electric Shematic
- Zoomlion RT55 Rough Terrain Crane Hydraulic Schematic
- Zoomlion Full Shop Manual DVD
- Zoomlion RT75-2 Lower Rough Terrain Crane Hydraulic Shematic
- Zoomlion TOWER CRANE QTZ250(L250-16) Operator and Maintenance Manual
- Zoomlion RT55-2 Lower Rough Terrain Crane Hydraulic Shematic
- Zoomlion RT100 Lower Rough Terrain Crane Electric Shematic
- Zoomlion QLY20(420) ARTICULATED CRANE Operator & Service Manual
- Zoomlion (QY55)-42m Load Rating Charts
- Hirschmann HC4900 Operation Manual 5-section boom_20140818
