Momed80
150
35,046
Zoomlion Telescopic Boom Lifts ZT30J Service And Maintenance Manual 2020 EN
Brand: Zoomlion
Type of Machine: Telescopic Boom Lifts
Model: Zoomlion ZT30J Telescopic Boom Lifts
Publication Date: 2020
Number of Pages: 123 Pages
Section 1 Maintenance Safety Instruction
1.1 Maintenance Personnel Duties, Requirements And Safety Equipment
1.1.1 Duties
1.1.2 Basic Requirements
1.1.3 Personnel Safety Equipment
1.2 Maintenance Precautions
1.2.1 Precautions
1.2.2 Precautions In Maintenance
Section 2 Technical Parameters
2.1 Performance
2.2 Specification And Performance
2.3 Capacity
2.4 Components Specification
2.4.1 Engine
2.4.2 Battery
2.5 Tire
2.6 Function Speed
2.6.1 Operating Procedure When Testing Speed
2.6.2 Test Cautions
2.7 Torque Requirements
2.8 Lubrication
2.8.1 Hydraulic Oil
2.9 Pressure Setting
Section 3 General Introduction
3.1 Machine Preparation, Inspection And Maintenance
3.1.1 General Introduction
3.1.2 Preparation, Inspection And Maintenance
3.1.3 Pre-Delivery And Daily Inspections
3.1.4 Machine Annual Inspection
3.1.5 Preventive Maintenance
3.2 Maintenance And Instruction
3.2.1 General Description
3.2.2 Safety And Operating Standards
3.2.3 Cleaning
3.2.4 Component Disassembly And Installation
3.2.5 Component Disassembly And Reinstallation
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Washer
3.2.9 Bolt And Torque Applications
3.2.10 Hydraulic Line And Electric Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Lubrication And Maintenance
3.3 Lubrication And Information
3.3.1 Hydraulic System
3.3.2 Hydraulic Oil
3.3.3 Hydraulic Oil Replacement
3.3.4 Lubrication Specification
3.4 Cylinder Drift Test
3.4.1 Platform Drift
3.4.2 Cylinder Drift
3.5 Pin And Bearing Inspection Instructions
3.5.1 Fiber Bearing
3.6 Welding On The Device
3.6.1 Please Perform The Following Operations When Welding On The Device
3.6.2 Do Not Perform The Following Operations When Welding On The Device
3.7 Use Insulating Grease In Electrical Connection Locations
3.8 Engine Electrical System Maintenance
Section 4 Chassis And Turntable
4.1 Tire And Wheel
4.1.1 Tire Inflation
4.1.2 Tire Damage
4.1.3 Tire Replacement
4.1.4 Wheel Replacement
4.1.5 Wheel Installation
4.2 Swing Axle Exhaust And Locking Test
4.2.1 Floating Cylinder Exhaust
4.2.2 Swing Axle Lock Test
4.3 Chassis Angle Sensor System
4.4 Auxiliary Power System
4.5 Oscillating Axle System
4.6 Traveling Drive System
4.7 Travel Reducer
4.7.1 Disassembly
4.7.2 Installation
4.8 Traveling Motor
4.8.1 Disassembly
4.8.2 Installation
4.9 Rotary Motor
4.10 Rotary Reducer
4.10.1 Check And Maintenance
4.10.2 Gear Oil Replacement
4.11 Rotary Bearing
4.11.1 Rotary Bearing Lubrication
4.11.2 Check And Maintenance
4.11.3 Disassembly
4.12 Slewing Gear Clearance Adjustment
4.13 Generator
4.13.1 Check And Maintenance
4.13.2 Carbon Brush And Slip Ring Maintenance
Section 5 Boom And Platform
5.1 Platform And Jib
5.1.1 Load Cell
5.1.2 Rotary Actuator
5.1.3 Jib Lifting Cylinder
5.2 Boom Assembly
5.2.1 Cable
5.2.2 Leveling Cylinder
5.2.3 Lifting Cylinder
5.2.4 Boom
5.2.5 Telescopic Cylinder
5.2.6 Wire Rope Pulley Disassembly
5.2.7 Wire Rope And Pulley Check
5.3 Load Cell Check
5.3.1 Load Cell Check
5.3.2 Platform Leveling Sensor Check
5.3.3 Boom Tilting Sensor Check
5.3.4 Calibration Of Boom Length Sensor
5.3.5 Check Of Rope Damage Indication System
5.3.6 Drive Speed Limit Check
Section 6 Hydraulic And Electrical System Maintenance
6.1 Hydraulic Filter Maintenance
6.1.1 High Pressure Filter
6.1.2 Oil Filling Filter
6.1.3 Return Oil Filter
6.2 Pressure Setting
6.3 Starting Procedure
6.3.1 Drive Pump Oiling
6.3.2 Exhaust Air In The Pump Inlet Pipe
6.4 Fault Code
6.5 Common Faults And Methods
Section 7 Electrical Information And Schematic
7.1 General Introduction
7.2 Multimeter Basic Operation
7.2.1 Grounding
7.2.2 Backside Detection
7.2.3 Minimum Value/Maximum Value
7.2.4 Polarity
7.2.5 Range
7.2.6 Voltage Measurement
7.2.7 Resistance Measurement
7.2.8 Conduction Test
7.2.9 Current Measurement
7.3 Deutsch Connector
7.3.1 Dt/Dtp Series Connector Assembly
7.3.2 Dt/Dtp Series Connector Disassembly
7.3.3 Hd30/Hdp20 Series Connector Assembly
7.3.4 Hd30/Hdp20 Series Connector Removal
7.4 Electrical Schematics
7.5 Hydraulic Schematics
