Momed80
150
35,046
Zoomlion Articulating Boom Lifts ZA32J Service And Maintenance Manual 2021 EN
Brand: Zoomlion
Model: Zoomlion ZA32J Articulating Boom Lifts
Publication Date: 2021
Number of Pages: 130 Pages
Section 1 Maintenance Safety Instruction
1.1 Maintenance Personnel Duties, Requirements And Safety Equipment
1.1.1 Duties
1.1.2 Basic Requirements
1.1.3 Personnel Safety Equipment
1.2 Maintenance Precautions
1.2.1 Precautions
1.2.2 Precautions In Maintenance
Section 2 Technical Parameters
2.1 Performance
2.2 Specification And Performance
2.3 Capacity
2.4 Components Specification
2.4.1 Engine
2.4.2 Battery
2.5 Tire
2.6 Functional Speed
2.6.1 Operating Procedure When Testing Speed
2.6.2 Test Cautions
2.7 Torque Requirements
2.8 Lubrication
2.8.1 Hydraulic Oil
2.9 Pressure Setting
Section 3 General Introduction
3.1 Machine Preparation, Inspection And Maintenance
3.1.1 General Introduction
3.1.2 Preparation, Inspection And Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery And Daily Inspection
3.1.5 Machine Annual Inspection
3.1.6 Preventive Maintenance
3.2 Maintenance And Service Instruction
3.2.1 General Instruction
3.2.2 Safety And Operating Standards
3.2.3 Cleaning
3.2.4 Component Disassembly And Installation
3.2.5 Component Disassembly And Reinstallation
3.2.6 Pressure-Fit Parts
3.2.7 Bearing
3.2.8 Washer
3.2.9 Bolt And Torque Applications
3.2.10 Hydraulic Line And Electric Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Lubrication And Maintenance
3.3 Lubrication And Information
3.3.1 Hydraulic System
3.3.2 Hydraulic Oil And Filter
3.3.3 Hydraulic Exhaust System
3.3.4 Lubrication Pipeline Damage Inspection
3.3.5 Lubrication Cylinder Inspection
3.3.6 Lubrication Hose Inspection
3.4 Cylinder Drift Test
3.4.1 Platform Drift
3.4.2 Cylinder Drift
3.5 Pin And Bearing Inspection Instruction
3.5.1 Fiber Bearing
3.6 Welding On The Device
3.6.1 Perform The Following Operations When Welding On The Device
3.6.2 Not Perform The Following Operations When Welding On The Device
3.7 Use Insulating Grease In Electrical Connection Location
3.8 Engine Electrical System Maintenance
Section 4 Chassis And Turntable
4.1 Tire And Wheel
4.1.1 Tire Inflation
4.1.2 Tire Damage
4.1.3 Tire Replacement
4.1.4 Wheel Replacement
4.1.5 Wheel Installation
4.2 Swing Axle Exhaust And Locking Test
4.2.1 Floating Cylinder Exhaust
4.2.2 Swing Axle Lock Test
4.3 Chassis Angle Sensor System
4.4 Auxiliary Power System
4.5 Oscillating Axle System
4.6 Traveling Drive System
4.7 Travel Reducer
4.7.1 Disassembly
4.7.2 Installation
4.8 Traveling Motor
4.8.1 Disassembly
4.8.2 Installation
4.9 Axle Extending System
4.10 Axle Limit Switch Adjustable
4. 11 Steering Control System
4. 12 Traveling/Steering Speed Control
4. 13 Traveling Direction Systemr
4. 14 Rotary Motor
4. 15 Rotary Reducer
4. 15.1 Check And Maintain
4. 15.2 Replace The Gear Oil
4. 16 Slewing Bearing
4. 16.1 Slewing Bearing Lubrication
4. 16.2 Rotary Actuator Disassembly
4. 16.3 Disassembly
4. 17 Clearance Adjustment Of The Gear In Slewing Mechanism
4. 18 Generator
4. 18.1 Check And Maintain
4. 18.2 Check The Carbon Brush, Replace The Carbon Brush, Clean The Slip Ring
4. 19 Engine System
4. 19.1 Main Components Of Engine
4. 19.2 Fuel System
4. 19.3 Cooling System
4. 19.4 Lubrication System
4. 19.5 Control System
Section 5 Boom And Platform
5.1 Platform And Jib
5.1.1 Load Cell Disassembly
5.1.2 Rotary Actuator Disassembly
5.1.3 Jib Lifting Cylinder
5.2 Boom Assembly
5.2.1 Leveling Cylinder
5.2.2 Upper Boom
5.2.3 Upper Boom Lifting Cylinder
5.2.4 Upper Boom Cable
5.2.5 Upper Boom Telescopic Cylinder
5.2.6 Tower Boom And Its Cylinder Disassembly
5.2.7 Tower Boom Cable
5.2.8 Tower Boom Telescopic Cylinder
Section 6 Electrical System Maintenance
6.1 Fault Code
Section 7 Electrical Information And Schematic
7.1 General Introduction
7.2 Multimeter Basic Operation
7.2.1 Grounding
7.2.2 Backside Detection
7.2.3 Minimum Value/Maximum Value
7.2.4 Polarity
7.2.5 Range
7.2.6 Voltage Measurement
7.2.7 Resistence Measurement
7.2.8 Conduction Measurement
7.2.9 Current Measurement
7.3 Deutsch Connector
7.3.1 Dt/Dtp Series Connector Assembly
7.3.2 Dt/Dtp Series Connector Disassembly
7.3.3 Hd30/Hdp20 Series Connector Assembly
7.3.4 Hd30/Hdp20 Series Connector Disassembly
7.4 Electrical Schematics
7.5 Hydraulic Schematics
