Yanmar Mini Excavator ViO57-6B Operation Manual MUB35ENMA00300
Brand: Yanmar
Model: Yanmar ViO57-6B Mini Excavator
Part Number: MUB35ENMA00300
Number of Pages: 193 Pages
A Description and illustration of the machine
Brand: Yanmar
1 Applications and regulations
1.1 Applications
1.2 Warranty
1.3 Driving permits
1.4 Lifting
1.5 Environmental regulations
2 Identification plates
2.1 Machine serial number plate
2.2 Engine serial number plate
2.3 Safety structure plate
2.4 Seat identification
2.5 Spare parts order and intervention request
3 Warning labels
3.1 Location of the warning adhesive labels
3.2 Explanation of the warning adhesive labels
4 General view of the machine
5 Description of the driving position
5.1 Start key
5.2 Operator display station
5.3 Joysticks and pedals
5.4 Switches
5.5 Power socket
5.6 Driver's seat
5.7 Seat support cover
5.8 Location for the tools and user manual
5.9 QR code
5.10 Fuses
5.11 Cabin
5.12 Headlights
5.13 Rear-view mirror(s)/Camera(s)
5.14 Fleet management system SMARTASSIST-REMOTE
6 Operation of the air conditioning
7 Covers
7.1 Bonnet
7.2 Cover B
7.3 Cover R
7.4 Rear cover
7.5 Upper cover
8 Using the electric fuel filling pump
9 Heating valve
10 Options
10.1 Long arm
10.2 Half-circuit
10.3 Circuit AUX1
10.4 Circuit AUX2
10.5 Circuit breaker
10.6 Document holder
10.7 Additional counterweights
10.8 Travel alarm
10.9 Lifting Kit
10.10 Operator protection
10.11 Separator/decanter alarm
10.12 Working headlights
10.13 Plug-in beacon and rear LED light
10.14 Fleet management system and immobiliser system
10.15 Better fuel filtering
10.16 Bio oil
10.17 Radio
10.18 Air conditioning
10.19 Diesel pump
10.20 Quick connector
10.21 Centralized greasing system
10.22 Continuous pressure hydraulic line
10.23 Rubber rollers for use with steel tracks
10.24 Automatic engine shutoff
B Operating instructions1 Basic precautions
1.1 Comply with your workplace's safety rules
1.2 Put the safety mechanisms in place
1.3 Wear suitable clothing and protective equipment
1.4 Operator health
1.5 Provide adequate ventilation when working in an enclosed space
1.6 Protect plants from hot air and exhaust fumes
1.7 Weather conditions
1.8 Fire hazard
1.9 Avoid removing the caps when the temperatures are high
1.10 Avoid crush injuries due to attachments
1.11 Have an extinguisher and a first aid kit
1.12 Unauthorised modifications
1.13 Precautions for optional parts and tools
1.14 Warning concerning the cab windows
1.15 Cabin's emergency exit
1.16 Air conditioning system
2 Usage precautions
2.1 Precautions before using the machine
2.2 Movement precautions
2.3 Working precautions
2.4 Parking precautions
2.5 Precautions for the attachments
2.6 Precautions for using optional attachments
2.7 Precautions for the battery
3 Checks before starting the machine
3.1 Overall visual inspection
3.2 Checking and topping up the level of cooling fluid
3.3 Checking and topping up the engine oil level
3.4 Checking and topping up the fuel level
3.5 Checking and topping up the hydraulic oil level
4 Checks after start-up
5 Checks after use
6 Operator LCD display station interfaces
6.1 Indication of functions
6.2 User Interface
6.3 Maintenance interface
6.4 Machine usage management interface
6.5 Configuration interface
7 Using the machine in cold weather
7.1 Preparation for use in cold weather
7.2 Starting in cold weather
7.3 Precautions after use
7.4 When cold weather is over
8 Rubber tracks
8.1 Correct use of rubber tracks
8.2 Comparison between rubber tracks / steel tracks
8.3 Rubber track warranty
8.4 Precautions for using rubber tracks
9 Handling the bucket
9.1 Machine stability when using with a bucket or an attachment
9.2 Operation of the retro bucket
9.3 Digging trenches
9.4 Loading
10 Attachment change by direct coupling
10.1 Installing the bucket
10.2 Removing the bucket
11 Load lifting
12 Using the hydraulic outlets
12.1 Description
12.2 AUX1 circuit selector
12.3 Precautions for using the attachment
13 Using the particle filter
13.1 Auto-regeneration
13.2 Assisted regeneration
13.3 Launching the regeneration
13.4 Manual regeneration of the particulate filter
14 Transporting the machine
14.1 Loading/unloading the machine
14.2 Immobilising the machine on the truck
14.3 Tying down the machine
14.4 Slinging the machine
15 Detecting anomalies
15.1 Phenomena that do not constitute faults
15.2 Detecting anomalies
16 If the battery is discharged
16.1 Precautions for connecting and disconnecting the starter cables
16.2 Connecting the starter cables
16.3 Starting the engine
16.4 Disconnecting the starter cables
16.5 Charging the battery
17 Machine recovery
C Periodic maintenance programme1 Maintenance precautions
1.1 Precautions before maintenance
1.2 Precautions during maintenance
2 Recommended greases and fluids
2.1 Grease
2.2 Cooling fluid
2.3 Gear oil
2.4 Engine oil
2.5 Fuel
2.6 Hydraulic oil
3 Periodic inspections and upkeeps
4 Maintenance by the operator
4.1 Daily maintenance
4.2 Maintenance every 50 hours
4.3 Non periodic maintenance
5 Maintenance by the dealer
5.1 After the first 50 hours of service
D Machine storage and end-of-life1 Conservation
2 Storage
3 Recommissioning
4 Dismantling
E Technical data1 Specifications
2 Working dimensions
3 Noise emitted by the machine
4 Vibrations emitted by the machine
F Lifting capacities1 Lifting ViO57–6B
2 Lifting ViO57–6B, with rear counterweight
AppendicesA Notes
B Lashing record
Index
- Yanmar Mini-Excavators B25V Service Manual
- YANMAR Crawler Backhoe model YB121U, YB151U ,YB121U-2, YB151U-2 Parts Catalog
- YANMAR Crawler Backhoe model YB451(-2) YB501(-2) Parts Catalog
- YANMAR Crawler Backhoe model YB201 (U) Parts Catalog
- YANMAR Crawler Backhoe model YB301(-1,-2) YB351(-1,-2) Parts Catalog
- Yanmar D27, D36 Marine Diesel Engine Service Manual
- YANMAR Wheel Backhoe model YB401W and YB401W-2 Parts Catalog
- YANMAR Crawler Backhoe model Vio70 for Europe Parts Catalog
- YANMAR AMMANN CRAWLER BACKHOE B12/B17 PARTS MANUAL
- YANMAR Crawler Backhoe model Vio 20 Parts Catalog
- YANMAR Crawler Backhoe model YB101 and B10 Parts Catalog
- Yanmar Engine 3TNA72L-UTB(YB10-2)Parts Catalog
- YANMAR Engine 2TR15/16/17/19/20/20C Parts Catalog
- YANMAR Tractor YM14 Parts Manual
- Yanmar Excavator ViO45-5 ViO55-5 Service Manual
