Yanmar Mini Excavator ViO38-6 Parts Catalog CPB33ENMA00101
Brand: Yanmar
Model: Yanmar ViO38-6 Mini Excavator
Part Number: CPB33ENMA00101
Date: 2018
Number of Pages: 293 Pages
EQUIPMENTS
ARM
SHORT ARM
ARM ASSY, 1370
LONG ARM
ARM ASSY,1620
PTO
1/2 CIRCUIT
1/2 CIRCUIT LA
3RD PROPORTIONAL HYDRAULIC CIRCUIT
3RD PROPORTIONAL HYDRAULIC CIRCUIT LA
3RD CIRCUIT AM
3RD CIRCUIT PROP AM
3RD CIRCUIT PROP AM LA
3RD + 4TH CIRCUIT AM
LIFTING
RING
BUCKET LINK WITH RING
STANDARD
LINK ASSY,BUCKET
CAB'S EQUIPMENT
2 HEADLIGHTS
BEACON & LIGHTS REAR
BEACON
SAFETY VALVES
3 VALVES
ANTI-THEFT DEVICE
GPS KEYBOARD
ANTITHEFT,GPS
GPS TRACKER
BOX FOR DOCUMENTS
RADIO
SEAT
FABRIC SEAT
FABRIC SEAT Y
PVC SEAT
PVC SEAT Y
AIR CONDITIONING
AIR CON UNIT
CONDENSER ASSY
HEATING
ADDITIONAL COUNTERWEIGHT
QUICK CONNECTOR
YCEE
HYDRAULIC HAMMER
CEJN
GROMELLE
QUICK ATTACHMENT
CONTROL LINE AR PERMANENT PRESSURE
CONTROL LINE AR PERMANENT PRESSURE LA
HORN DISPLACEMENT
CRAWLER
RUBBER
IDLER WHEEL
SPRING ASSY
STEEL
STEEL CRAWLER
RUBBER PAD
CABIN
CABIN ASSY
GLASS
BAY GLASS SIDE R
WINDSHIELD
FRONT WINDSHIELD ASSY
DOOR
DOOR ASSY
INSIDE
OUTSIDE
HARNESS
CANOPY
VEHICLE
PAINTING
LABEL
BOARD LABEL DRIVE A
BOARD LABEL PICTO
KIT LABEL DECO
BOARD LABEL DRIVE B
CASE(TOOL)
MUFFLER
AIR CLEANER
ACCELERATOR
ENGINE MOUNT
RADIATOR SHROUD
RADIATOR & OIL COOLER
DUCT
FUEL TANK
FUEL PIPING
ELECTRIC PART
BATTERY
WITHOUT BATTERY SWITCH
WITH BATTERY SWITCH
HORN
GUIDE HARNESS
STARTER SWITCH
ELECTRIC PART (SEAT MOUNT)
PRESSURE SWITCH
WORK LAMP
INSTRUMENT PANEL(CANOPY)
INSTRUMENT PANEL(CABIN)A/C & HEATER SPEC
HARNESS(HEATER)
HARNESS AIR COND SPEC(E.S.S.)
CONTROLLER AIR COND SPEC(E.S.S.)
ELECTRIC PART (SA-R)
COVER(CONTROL)
SPROCKET & ROLLER
CONTROL VALVE BRACKET
TRAVEL LEVER
PEDAL ASSY, TRACK L
PEDAL ASSY, TRACK R
SWING PEDAL
LINK COVER
PEDAL COVER
BLADE LEVER
LOCK LEVER
TRAVEL FRAME
COUNTER WEIGHT
TURNING FRAME
TURNING BEARING
COVER,MULTI LEFT
COVER,UPPER RIGHT
COVER,TURNING FRAME
COVER,TRAVEL FRAME
COVER,FRAME GUARD LEFT
COVER,FRAME GUARD RIGHT
COVER,TURNING FRAME FRONT LEFT
COVER,TURNING FRAME FRONT RIGHT
COVER,LEVER
COVER,MONITOR CANOPY
COVER,MONITOR CABIN
SEAT MOUNT
COVER,SEAT MOUNT
SEAT PLATE
SEAT MOUNT,PLUG
COVER,REAR
BONNET,FRONT RIGHT
BONNET,REAR LEFT
BONNET,REAR RIGHT
CANOPY MOUNT
HYDRAULIC PUMP MOUNT
HYDRAULIC PUMP
PUMP ASSY
PUMP ASSY A/C
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
SWING CYLINDER
BLADE CYLINDER
TRAVEL MOTOR
TURNING MOTOR
SWIVEL JOINT
CONTROL VALVE(1/8)
CONTROL VALVE(2/8)
CONTROL VALVE(3/8)
CONTROL VALVE(4/8)
CONTROL VALVE(5/8)
CONTROL VALVE(6/8)
CONTROL VALVE(7/8)
CONTROL VALVE(8/8)
REMOTE CONTROL VALVE(RIGHT)
VALVE ASSY,R
JOYSTICK ASSY,R
REMOTE CONTROL VALVE(LEFT)
VALVE ASSY,L
SOLENOID VALVE AIR COND SPEC (E.S.S.)
SOLENOID VALVE(P.T.O.)
HYDRAULIC OIL TANK
ACCUMULATOR
HYDRAULIC OIL PIPING (TANK - PUMP & CONTROL VALVE)
HYDRAULIC OIL PIPING (CONTROL VALVE - TURNING MOTOR)
HYDRAULIC OIL PIPING (CONTROL VALVE)(FITTING)(1)
HYDRAULIC OIL PIPING (CONTROL VALVE)(FITTING)(2)
HYDRAULIC OIL PIPING (CONTROL VALVE - RETURN & DRAIN)
HYDRAULIC OIL PIPING (CONTROL VALVE - BOOM BULKHEAD & SWING)
HYDRAULIC OIL PIPING (CONTROL VALVE - BOOM CYLINDER)
HYDRAULIC OIL PIPING (CONTROL VALVE - SWIVEL JOINT)
HYDRAULIC OIL PIPING (TRAVEL FRAME)
HYDRAULIC OIL PIPING (ARM CYLINDER & BUCKET CYLINDER)
HYDRAULIC OIL PIPING P.T.O (CONTROL VALVE - BOOM)
P.T.O.(BOOM END)
HYDRAULIC OIL PIPING P.T.O.(SOLENOID VALVE)
HYDRAULIC OIL PIPING AIR COND SPEC (E.S.S.)
HYDRAULIC OIL PIPING (CONTROL PIPING)
GREASING
BOOM BRACKET
BOOM
BUCKET ARM & LINK
PLUG(IMPLEMENT)
BLADE
ACCESSORY
ENGINE
CYLINDER BLOCK
GEAR HOUSING
FLYWHEEL HOUSING & OIL SUMP
CYLINDER HEAD & BONNET
SUCTION MANIFOLD
EXHAUST MANIFOLD & SILENCER
CAMSHAFT & DRIVING GEAR
CRANKSHAFT & PISTON
LUB.OIL SYSTEM
COOLING WATER SYSTEM
FUEL INJECTION PUMP
GOVERNOR
FUEL INJECTION VALVE
STARTING MOTOR
GENERATOR
ELECTRONIC CONTROL UNIT (ECU)
GASKET SET
MAINTENANCE KIT
KIT PER HOUR
SERVICE KIT 50H
SERVICE KIT 250H
SERVICE KIT 500H
SERVICE KIT 1000H+
DOCUMENTS
USER MANUAL
PARTS CATALOG
Brand: Yanmar
Date: 2018
EQUIPMENTS
ARM
SHORT ARM
ARM ASSY, 1370
LONG ARM
ARM ASSY,1620
PTO
1/2 CIRCUIT
1/2 CIRCUIT LA
3RD CIRCUIT AM
3RD CIRCUIT PROP AM
LIFTING
RING
STANDARD
LINK ASSY,BUCKET
CAB'S EQUIPMENT
2 HEADLIGHTS
BEACON
SAFETY VALVES
3 VALVES
ANTI-THEFT DEVICE
GPS KEYBOARD
ANTITHEFT,GPS
GPS TRACKER
BOX FOR DOCUMENTS
RADIO
SEAT
FABRIC SEAT
FABRIC SEAT Y
PVC SEAT
PVC SEAT Y
AIR CONDITIONING
AIR CON UNIT
CONDENSER ASSY
HEATING
QUICK CONNECTOR
YCEE
HYDRAULIC HAMMER
CEJN
GROMELLE
QUICK ATTACHMENT
HORN DISPLACEMENT
CRAWLER
RUBBER
IDLER WHEEL
SPRING ASSY
STEEL
STEEL CRAWLER
RUBBER PAD
CABIN
CABIN ASSY
GLASS
BAY GLASS SIDE R
WINDSHIELD
DOOR
DOOR ASSY
INSIDE
OUTSIDE
HARNESS
CANOPY
VEHICLE
PAINTING
LABEL
BOARD LABEL DRIVE A
BOARD LABEL PICTO
KIT LABEL DECO
BOARD LABEL DRIVE B
CASE(TOOL)
MUFFLER
AIR CLEANER
ACCELERATOR
ENGINE MOUNT
RADIATOR SHROUD
DUCT
FUEL TANK
FUEL PIPING
ELECTRIC PART
BATTERY
WITH BATTERY SWITCH
HORN
GUIDE HARNESS
STARTER SWITCH
PRESSURE SWITCH
WORK LAMP
HARNESS(HEATER)
COVER(CONTROL)
SPROCKET & ROLLER
TRAVEL LEVER
PEDAL ASSY, TRACK L
PEDAL ASSY, TRACK R
SWING PEDAL
LINK COVER
PEDAL COVER
BLADE LEVER
LOCK LEVER
TRAVEL FRAME
COUNTER WEIGHT
TURNING FRAME
TURNING BEARING
COVER,MULTI LEFT
COVER,UPPER RIGHT
COVER,TURNING FRAME
COVER,TRAVEL FRAME
COVER,LEVER
COVER,MONITOR CABIN
SEAT MOUNT
COVER,SEAT MOUNT
SEAT PLATE
SEAT MOUNT,PLUG
COVER,REAR
BONNET,FRONT RIGHT
BONNET,REAR LEFT
BONNET,REAR RIGHT
CANOPY MOUNT
HYDRAULIC PUMP
PUMP ASSY
PUMP ASSY A/C
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
SWING CYLINDER
BLADE CYLINDER
TRAVEL MOTOR
TURNING MOTOR
SWIVEL JOINT
CONTROL VALVE(1/8)
CONTROL VALVE(2/8)
CONTROL VALVE(3/8)
CONTROL VALVE(4/8)
CONTROL VALVE(5/8)
CONTROL VALVE(6/8)
CONTROL VALVE(7/8)
CONTROL VALVE(8/8)
VALVE ASSY,R
JOYSTICK ASSY,R
VALVE ASSY,L
HYDRAULIC OIL TANK
ACCUMULATOR
P.T.O.(BOOM END)
GREASING
BOOM BRACKET
BOOM
BUCKET ARM & LINK
PLUG(IMPLEMENT)
BLADE
ACCESSORY
ENGINE
CYLINDER BLOCK
GEAR HOUSING
SUCTION MANIFOLD
CRANKSHAFT & PISTON
LUB.OIL SYSTEM
FUEL INJECTION PUMP
GOVERNOR
STARTING MOTOR
GENERATOR
GASKET SET
MAINTENANCE KIT
KIT PER HOUR
SERVICE KIT 50H
SERVICE KIT 250H
SERVICE KIT 500H
SERVICE KIT 1000H+
DOCUMENTS
USER MANUAL
PARTS CATALOG
- Yanmar Mini-Excavators B25V Service Manual
- YANMAR Crawler Backhoe model YB121U, YB151U ,YB121U-2, YB151U-2 Parts Catalog
- YANMAR Crawler Backhoe model YB451(-2) YB501(-2) Parts Catalog
- YANMAR Crawler Backhoe model YB201 (U) Parts Catalog
- YANMAR Crawler Backhoe model YB301(-1,-2) YB351(-1,-2) Parts Catalog
- Yanmar D27, D36 Marine Diesel Engine Service Manual
- YANMAR Wheel Backhoe model YB401W and YB401W-2 Parts Catalog
- YANMAR Crawler Backhoe model Vio70 for Europe Parts Catalog
- YANMAR AMMANN CRAWLER BACKHOE B12/B17 PARTS MANUAL
- YANMAR Crawler Backhoe model Vio 20 Parts Catalog
- YANMAR Crawler Backhoe model YB101 and B10 Parts Catalog
- Yanmar Engine 3TNA72L-UTB(YB10-2)Parts Catalog
- YANMAR Engine 2TR15/16/17/19/20/20C Parts Catalog
- YANMAR Tractor YM14 Parts Manual
- YANMAR SMViO45-5 ViO55-5 Service Manual
