Hyundai
86
178,635
Yanmar Excavator ViO57-6B Service Manual MMB35ENMA00103
Brand: Yanmar
Type of Machine: Excavator
Model: Yanmar ViO57-6B Excavator
Part Number: MMB35ENMA00103
Number of Pages: 792 Pages
1. General Cautions for Maintenance Work
1-1 Correct Work​
1-2 Safety Precautions​
1-3 Preparations​
1-4 Cautions for Disassembly and Reassembly​
1-5 Cautions for Removal and Installation of Hydraulic Equipment​
1-6 Cautions for Removal and Installation of Hydraulic Piping​
1-7 Cautions for Handling Seals​
1-8 Correct Installation of Hydraulic Hose​
1-9 Specifications of Hydraulic Hose​
1-10 Air Release of Hydraulic Equipment​
2. Technical Data
2-1 Specifications​
2-2 Outline Drawing and Working Area​
2-3 Weight List of Main Parts​
2-4 Lifting Capacity List​
2-5 Specifications for Attachment​
2-6 Periodic Inspection and Servicing​
2-7 Fuel, Lube Oil and Grease Recommended​
2-8 Hydraulic Circuit Schematic​
2-9 Wiring Diagram​
3. Service Standards
3-1 Machine Performance​
3-2 Engine​
3-3 Undercarriage​
3-3-1 Rubber Crawler Specifications​
3-4 Controls​
3-5 Hydraulic Equipment​
3-5-1 Hydraulic Cylinders​
3-6 Implement​
3-6-1 Front Attachments​
3-6-2 Blade Moving Device​
3-6-3 Bucket Teeth​
3-7 List of Tightening Torque​
3-7-1 Machine​
3-7-2 Engine​
3-7-3 Tightening Torque for General Bolts and Nuts​
3-7-4 Hydraulic Fitting​
3-8 Pressure Adjustment​
3-8-1 Relief Valves​
3-8-2 Swing Brake Valve​
3-8-3 Cut-Off Valve​
4. Engine
4-1 Safety​
4-1-1 Safety Statements​
4-1-2 Safety Precautions​
4-2 Engine​
4-2-1 Before You Begin Servicing​
4-2-2 Introduction​
4-2-3 Special Service Tools​
4-2-4 Measuring Instruments​
4-2-5 Cylinder Head​
4-2-6 Measuring and Adjusting Valve Clearance​
4-2-7 Crankshaft and Camshaft Components​
4-2-8 EGR system​
4-2-9 Intake Throttle​
4-3 Fuel System​
4-3-1 Before You Begin Servicing​
4-3-2 System Structure​
4-3-3 Fuel System Specifications​
4-3-4 Fuel System Diagram​
4-3-5 Fuel System Components​
4-4 Cooling System​
4-4-1 Before You Begin Servicing​
4-4-2 Introduction​
4-4-3 Cooling System Diagram​
4-4-4 Engine Coolant Pump Components​
4-4-5 Engine Coolant System Check​
4-4-6 Engine Coolant Pump​
4-5 Lubrication System​
4-5-1 Before You Begin Servicing​
4-5-2 Introduction​
4-5-3 Lubrication System Diagram​
4-5-4 Checking Engine Oil Pressure​
4-5-5 Oil Pump Components​
4-6 Turbocharger​
4-6-1 Before You Begin Servicing​
4-6-2 Introduction​
4-6-3 Specifications​
4-6-4 Troubleshooting​
4-6-5 Turbocharger Components​
4-6-6 Turbocharger Component Functions​
4-6-7 Washing Procedure​
4-6-8 Periodic Inspection​
4-7 Starter Motor​
4-7-1 Before You Begin Servicing​
4-7-2 Introduction​
4-7-3 Starter Motor Specifications​
4-7-4 Starter Motor Troubleshooting​
4-7-5 Starter Motor Components​
4-7-6 Starter Motor​
4-8 Alternator​
4-8-1 Before You Begin Servicing​
4-8-2 Introduction​
4-8-3 Alternator Specifications​
4-8-4 Alternator Troubleshooting​
4-8-5 Alternator Components​
4-8-6 Alternator Wiring Diagram​
4-8-7 Alternator Standard Output​
4-8-8 Alternator​
4-9 Electronic Control System​
4-9-1 Engines available with the electronic control system​
4-9-2 Before You Begin Servicing​
4-9-3 System Structure​
4-9-4 How to Remove and Reattach the Diesel Particulate Filter (DPF)​
4-9-5 SF and DPF Maintenance Kit​
4-9-6 Troubleshooting of Electronic Control System​
4-9-7 Replacement of Components​
4-9-8 Installation Position of Sensors​
4-10 Electric Wiring​
4-11 Failure Diagnosis.​
4-11-1 Special Service Tools​
4-11-2 Troubleshooting By Measuring Compression Pressure​
4-12 Troubleshooting​
4-12-1 Quick Reference Table for Troubleshooting​
5. Electric System
5-1 Electric Equipment of Machine​
5-1-1 Parts Layout of Electrical Equipment​
5-1-2 LCD Monitor and Alarm Systems​
5-2 Circuit Description of Engine Start and Stop​
5-3 Engine ECU (engine controller)​
5-3-1 Engine ECU​
5-3-2 Circuit Description of Auto Deceleration Mode​
5-3-3 Circuit Description of Eco Mode​
5-3-4 Control Functions​
5-4 Battery​
5-5 Error Code List​
6. Hydraulic Equipment
6-1 Outline​
6-1-1 Control Valve Operation​
6-1-2 Additional Operation of Control Valve​
6-2 Circuit Operation​
6-2-1 Boom​
6-2-2 Arm​
6-2-3 Bucket​
6-2-4 Swing​
6-2-5 Boom Swing​
6-2-6 Blade​
6-2-7 Travel​
6-2-8 Non-Deviation Travel (with Boom, Arm or Boom Swing Operation)​
6-2-9 Non-Deviation Travel (with Bucket Operation)​
6-2-10 Simultaneous Operation of Boom Up and Arm Retract​
6-2-11 Simultaneous Operation of Boom Up and Bucket​
6-2-12 Simultaneous Operation of Boom Up and Swing​
6-2-13 Simultaneous Operation of Arm and Bucket​
6-2-14 Hydraulic P.T.O.​
6-2-15 Travel Alarm​
6-2-16 Auto Deceleration​
6-3 Hydraulic Pump​
6-4 Control Valve​
6-5 Pilot Valve​
6-6 Swing Motor​
6-7 Travel Motor​
6-8 Proportional solenoid valve for P.T.O​
7. Adjustment and Repair
7-1 Engine and Electric Equipment​
7-1-1 Removal and Reinstallation of Engine​
7-1-2 Removal and Reinstallation of Starter Motor​
7-1-3 Removal and Reinstallation of Radiator and Oil Cooler​
7-1-4 Removal and Reinstallation of Fan Belt and Compressor Driving Belt​
7-1-5 Removal and Reinstallation of Engine ECU​
7-2 Undercarriage​
7-2-1 Outline​
7-2-2 Main Parts​
7-2-3 Points of Reassembly (Rubber Track)​
7-2-4 Points of Reassembly (Steel Track)​
7-2-5 Removal and Reinstallation of Crawler​
7-2-6 Removal and Reinstallation of Travel Motor​
7-2-7 Disassembly and Reassembly of Idler​
7-2-8 Disassembly and Reassembly of Track Roller​
7-2-9 Disassembly and Reassembly of Carrier Roller​
7-2-10 Installation of Floating Seal​
7-2-11 Drawings of Jig​
7-3 Controls​
7-3-1 Mechanical Control Linkage​
7-3-2 Adjustment of Travel Levers​
7-3-3 Adjustment of Boom Swing Pedal​
7-3-4 Adjustment of Blade Lever​
7-3-5 Adjustment of Lock Lever​
7-4 Swing Bearing​
7-5 Hydraulic Equipment​
7-5-1 Removal and Reinstallation of Hydraulic Pump​
7-5-2 Removal and Reinstallation of Control Valve​
7-5-3 Removal and Reinstallation of Pilot Valves (L and R)​
7-5-4 Removal and Reinstallation of Swing Motor​
7-5-5 Removal and Reinstallation of Swivel Joint​
7-5-6 Disassembly and Reassembly of Swivel Joint​
7-5-7 Disassembly and Reassembly of Hydraulic Cylinder​
7-5-8 Removal and Reinstallation of Hydraulic Oil Tank​
7-5-9 Piping Layout​
7-6 Work Implements​
7-6-1 Removal and Reinstallation of Work Implements​
7-7 Cabin​
7-7-1 Removal and Reinstallation of Cabin​
7-7-2 Disassembly and Reassembly of Cabin​
7-8 Air Conditioner​
7-8-1 Removal and Reinstallation of Air Conditioner​
8. Troubleshooting
8-1 Non-Breakdowns​
8-1-1 Natural Release of Bucket​
8-1-2 Discontinuous Arm Movement​
8-1-3 Drifting of Upperstructure on Quick Travel Operation​
8-1-4 Thermal Shock of Travel Motor​
8-1-5 Elongation of Boom Swing Cylinder on 68 degrees Swing​
8-1-6 Time Lag on Travel Speed Switching​
8-1-7 Fluctuation in Oil Level of Hydraulic Oil Tank Due to Temperature Change​
8-2 Quick Reference Table for Troubleshooting​
