Hyundai
86
176,834
Yanmar Engine 6EY18LW 6EY18ALW Operation Manual RB-B39101
Brand: Yanmar
Type of Machine: Marine Auxiliary Engine
Model: Yanmar 6EY18LW 6EY18ALW Marine Auxiliary Engine
Part Number: RB-B39101
Number of Pages: 551 Pages
00 Engine Information
01 Introduction​
02 General Warnings And Cautions And Related Safety Data​
03 Technical Data​
04 General Data​
05 Schematic Diagram​
06 Preparation Setting Values​
07 Design Data-Tolerances Check​
08 Scheduled Inspection​
00 Engine Operation
09 Pre-Operation Procedurepre-Operation Procedure​
10 Normal Operation Procedure​
11 Post-Operation Procedure​
12 Emergency Procedure​
14 Operation Test​
15 Normal Operation Procedures Checklist​
16 General Fault Description​
00 Fuel Oil, Lubricating Oil, And Cooling Water
17 Fluid​
01 Cylinder Block And Cylinder Liner
01 Cylinder Block​
02 Cylinder Liner​
50 Parts List​
11 Cylinder Head
01 Cylinder Head​
02 Intake-Exhaust Valve​
03 Valve Seat​
04 Valve Guide​
05 Valve Bridge Guide​
06 Valve Rotator​
07 Nozzle Sleeve​
50 Parts List​
14 Timing Gear, Camshaft, And Intake-Exhaust Swing Arm
01 Timing Gear​
02 Camshaft​
03 Intake-Exhaust Swing Arm​
50 Parts List​
18 Air Cooler, Exhaust Manifold, Turbocharger And Supply Air Release
01 Air Cooler​
02 Exhaust Manifold​
03 Turbocharger (Tps)​
03 Turbocharger (Met)​
04 Supply Air Release​
50 Parts List​
21 Main Bearing, Crankshaft, And Flywheel
01 Main Bearing​
02 Crankshaft​
03 Flywheel​
50 Parts List​
22 Piston And Connecting Rod
01 Piston​
02 Connecting Rod​
03 Connecting Rod Bolt​
50 Parts List​
30 Lubricating Oil System
00 Lubricating Oil System​
01 Lubricating Oil Pump​
02 Lubricating Oil Pressure Control Valve​
03 Lubricating Oil Thermostat​
04 Lubricating Oil Strainer​
05 Lubricating Oil Cooler​
06 Lubricating Oil By-Pass Filter​
Fm200ds
06 Lubricating Oil By-Pass Filter Fm200-21​
07 Lubricating Oil Pipe (Pinion Lubrication)​
50 Parts List​
40 Cooling Devices
00 Cooling Water System (Engine-Installed Freshwater Pump)​
00 Cooling Water System (Freshwater-Seawater Dual System Specification)​
01 Cooling Water Pump​
02 Cooling Water Thermostat (High-Temperature Water)​
04 Cooling Water Selecting Valve (High-Temperature Water)​
05 Cooling Water Selecting Valve (Low-Temperature Water)​
05 By-Pass Valve​
06 Cooling Water Pipe (Freshwater-Seawater Dual System Specification)​
50 Parts List​
50 Fuel Devices
00 Fuel Oil System​
01 Fuel Injection Valve​
02 Fuel Feed Pump​
03 Fuel Injection Pump​
04 Fuel Injection Pump Drive Unit​
06 Fuel Oil Strainer (M.D.O. Specification)​
06 Fuel Oil Strainer (H.F.O Specification)​
07 Fuel Oil Pressure Control Valve​
08 Seal Pot​
09 Float Switch​
50 Parts List​
60 Governor And Governor Drive Unit
01 Governor (Nz)​
01 Governor (Psg) (Option)​
01 Governor (Ug-25+) (Option)​
02 Governor Drive Unit​
03 Speed Control Device​
04 Start-Stop Handle​
50 Parts List​
65 Special Attachments
01 Stop Solenoid Valve​
02 Operating Station Selector​
03 Pressure Gauge​
04 Digital Thermometer​
05 Fuel Injection Volume Control Air Piston And Stopping Air Piston​
05 Stopping Air Piston​
50 Parts List​
70 Starting Device
00 Air Starting Pipe Device​
01 Air Filter​
50 Parts List​
92 Disassembly Tools, Other Tools
01 Hydraulic Jack​
02 Other Tools​
50 Parts List​
Yanmar's Worldwide Service Network
Colophon
Cover 4
