Hyundai
86
176,834
Yanmar Engine 3TNV88C to 4TNV98CT Service Manual OBTN4-EN0027
Brand: Yanmar
Type of Manual: Service Manual, Electric Diagrams
Model: Yanmar 3TNV88C, 3TNV86CT, 3TNV86CHT, 3TN86CHT, 4TNV88C, 4TNV86CT
4TNV86CHT, 4TN86CHT, 4TNV98C, 4TNV98CT
Part Number: OBTN4-EN0027
Number of Pages: 326 Pages
Introduction
YANMAR Warranties
YANMAR Limited Warranty​
Emission System Warranty​
YANMAR POWER TECHNOLOGY CO., LTD. Limited Emission Control System Warranty​
Safety
Safety Statements​
Safety Precautions​
General Service Information
Component Identification​
Location of Labels​
Emission Control Regulations​
Emission Control Labels​
Engine Family​
Function of Major Engine Components​
Function of Cooling System Components​
Main Electronic Control Components and Features​
Installation Position of Sensors​
Diesel Fuel​
Engine Lubricating Oil​
Engine Coolant​
Specifications​
Principal Engine Specifications​
Engine Service Standards​
Tightening Torques for Standard Bolts and Nuts​
Abbreviations and Symbols​
Unit Conversions​
Periodic Maintenance
Before You Begin Servicing​
Introduction​
Periodic Maintenance Schedule​
Periodic Maintenance Procedures​
INTRODUCTION​
Cylinder Head Specifications​
Camshaft and Timing Gear Train Specifications​
Crankshaft and Piston Specifications​
Cylinder Block Specifications​
Special Torque Chart​
Special Service Tools​
Measuring Instruments​
Cylinder Head​
Measuring and Adjusting Valve Clearance​
Crankshaft and Camshaft Components​
EGR System​
Intake Throttle​
Exhaust Throttle​
Fuel System
System Structure​
Fuel System Specifications​
Fuel System Diagram​
Fuel System Components​
INTRODUCTION​
Cooling System Diagram​
Engine Coolant Pump Components​
Engine Coolant System Check​
Engine Coolant Pump​
Lubrication System
Introduction​
Oil Pump Service Information​
Lubrication System Diagram​
Checking Engine Lubricating Oil Pressure​
Oil Pump Components​
Turbocharger
Introduction​
Specifications​
Troubleshooting​
Turbocharger Components​
Turbocharger Component Functions​
Periodic Inspection​
Removal and Installation of Turbocharger​
Cleaning Procedure​
Starter Motor
INTRODUCTION​
Starter Motor Information​
Starter Motor Specifications​
Starter Motor Troubleshooting​
Starter Motor Components​
Starter Motor​
Introduction​
Dynamo and Alternator Information​
Alternator Specifications​
Dynamo Specifications​
Alternator Troubleshooting​
Alternator Components​
Alternator Wiring Diagram​
Alternator Standard Output​
Alternator​
Dynamo Component Location​
Dynamo Wiring Diagram​
Operation of Dynamo​
Dynamo Standard Output​
Testing of Dynamo​
Dynamo​
Electronic Control System
Introduction​
System Structure​
HOW TO REMOVE AND REATTACH THE DIESEL PARTICULATE FILTER (DPF)​
SF and DPF Maintenance Kit​
Troubleshooting of Electronic Control System​
Replacement of Components​
Electronic Control Harness Connections​
Electric Wiring
Electric Wiring Precautions​
Electrical Wire Resistance​
Battery Cable Resistance​
Electrical Wire Sizes - Voltage Drop​
Conversion of AWG to European Standards​
Failure Diagnosis
Troubleshooting by Measuring Compression Pressure​
Measured Value and Troubleshooting​
Quick Reference Table for Troubleshooting​
