Hyundai
86
176,834
Yanmar Engine 3TNV82A to 4TNV106T Service Manual 0BTNV-G00103
Brand: Yanmar
Type of Manual: Service Manual, Electric Diagram
Model: Yanmar 3TNV82A, 3TNV82A-B, 3TNV84, 3TNV84T, 3TNV84T-Z, 3TNV84T-B, 3TNV88
3TNV88-Z, 3TNV88-U, 3TNV88-B, 4TNV84, 4TNV84T, 4TNV84T-Z, 4TNV84T-B, 4TNV88, 4TNV106T
4TNV88-Z, 4TNV88-U, 4TNV88-B, 4TNV94L, 4TNV98, 4TNV98-Z, 4TNV98-E, 4TNV98T, 4TNV98T-Z, 4TNV106
Part Number: 0BTNV-G00103
Number of Pages: 376 Pages
Introduction
Yanmar Warranties
Yanmar Limited Warranty​
Emission System Warranty​
Yanmar Co., Ltd. Limited Emission Control System Warranty - USA Only​
Safety
Safety Statements​
Safety Precautions​
General Service Information
Component Identification​
Location of Labels​
Emission Control Regulations​
Emission Control Labels​
The 97/68/EC Directive Certified Engines​
Engine Family​
Function of Major Engine Components​
MAIN ELECTRONIC CONTROL COMPONENTS AND FEATURES​
Function of Cooling System Components​
Diesel Fuel​
Engine Oil​
Engine Coolant​
Specifications​
Principal Engine Specifications​
Engine Service Standards​
Tightening Torques for Standard Bolts and Nuts​
Abbreviations and Symbols​
Unit Conversions​
Periodic Maintenance
Before You Begin Servicing​
Introduction​
Periodic Maintenance Schedule​
Periodic Maintenance Procedures​
Introduction​
Cylinder Head Specifications​
Camshaft and Timing Gear Train Specifications​
Crankshaft and Piston Specifications​
Cylinder Block Specifications​
Special Torque Chart​
Special Service Tools​
Measuring Instruments​
2-Valve Cylinder Head​
4-Valve Cylinder Head​
Measuring and Adjusting Valve Clearance​
Crankshaft and Camshaft Components​
EGR system​
Fuel System
Introduction​
Fuel System Specifications​
Fuel System Diagram​
Fuel System Components​
Fuel Injection Pump​
Idle Sub Spring Adjustment​
Checking and Adjusting Fuel Injection Timing​
Fuel Injectors​
Introduction​
Cooling System Diagram​
Engine Coolant Pump Components​
Engine Coolant System Check​
Engine Coolant Pump​
Lubrication System
Introduction​
Oil Pump Service Information​
Lubrication System Diagram​
Checking Engine Oil Pressure​
Trochoid Oil Pump​
Trochoid Oil Pump​
Trochoid Oil Pump​
Turbocharger
Introduction​
Specifications​
Troubleshooting​
Turbocharger Components​
Turbocharger Component Functions​
Washing Procedure​
Periodic Inspection​
Starter Motor
Introduction​
Starter Motor Information​
Starter Motor Specifications​
Starter Motor Troubleshooting​
Starter Motor Components​
Starter Motor​
Introduction​
Dynamo and Alternator Information​
Alternator Specifications​
Dynamo Specifications​
Alternator Troubleshooting​
Alternator Components​
Alternator Wiring Diagram​
Alternator Standard Output​
Alternator​
Dynamo Component Location​
Dynamo Wiring Diagram​
Operation of Dynamo​
Dynamo Standard Output​
Testing of Dynamo​
Dynamo​
ELECTRONIC CONTROL SYSTEM
Engines available with the electronic control system​
Introduction​
ELECTRONIC CONTROL SYSTEM​
Electronic control harness connections​
Electric Wiring
Electric Wiring Precautions​
Electrical Wire Resistance​
Battery Cable Resistance​
Electrical Wire Sizes - Voltage Drop​
Conversion of AWG to European Standards​
Failure Diagnosis
Troubleshooting By Measuring Compression Pressure​
Quick Reference Table For Troubleshooting​
Electrical Wiring​
