estemar1979
12
5,723
Yale Forklift ERC40RG to ERC065ZG (E108) Parts Catalog 524140148
Download this document, you need 1500 Gallons
Brand: Yale
Type of Machine: Forklift
Model: Yale
ERC040RG, ERC040ZG, ERC050RG, ERC065ZG
ERC050ZG, ERC060RG, ERC060ZG, ERC065RG (E108)
Part Number: 524140148
Publication Date: 2003
Number of Pages: 448 Pages
1 GENERAL TRUCK
GENERAL TRUCK
FORK ERC 040-050 RG/ZG
FORK ERC 060-065 RG/ZG
LOAD BACKREST
NON-SUSPENSION SEAT WISE
NON-SUSPENSION SEAT SEARS
SUSPENSION SEAT GRAMMER
FULL SUSPENSION SEAT SHEET 1 OF 2
FULL SUSPENSION SEAT SHEET 2 OF 2
CONTROL PEDAL LINKAGE
DIRECTIONAL CONTROL PEDAL
LABEL AND PLATE LOCATION
COUNTERWEIGHT
OVERHEAD GUARD
HOOD
LATCH KIT
COVERS
FLOOR PLATES
2 ELECTRICAL SYSTEM
ELECTRICAL CONTACTOR HYDRAULIC
ELECTRICAL TRANSISTOR HYDRAULICS
CONTROL PANEL CONTACTOR HYDRAULIC
CONTROL PANEL TRANSISTOR HYDRAULIC
CONTACTOR PANEL CONTROL
CONTACTOR PANEL CONTACTOR HYDRAULIC
CONTACTOR 1A AND RB
CONTACTOR STEERING
CONTACTOR
INSTRUMENT PANEL
SHIFT LEVER
TRACTION MOTOR 9 IN. WITH BWI
TRACTION MOTOR 9 IN. WITHOUT BWI
TRACTION MOTOR 11 IN. WITH BWI
TRACTION MOTOR 11 IN. WITHOUT BWI
HYDRAULIC MOTOR WITHOUT BWI
HYDRAULIC MOTOR WITH OPEN CONSTRUCTION WITHOUT BWI ⇒S/N E108V-
HYDRAULIC MOTOR S/N E108V-16146Y⇒ For Motor 580024696, S/N E10
HYDRAULIC MOTOR WITH BWI
BATTERY CONNECTOR
WIRE HARNESS DASH
WIRE HARNESS FRONT LIGHTS
WIRE HARNESS MAIN
WIRE HARNESS CONTROL VALVE SWITCH
3 DRIVE UNIT
DRIVE UNIT ASSEMBLY
TRANSMISSION AND DIFFERENTIAL
DRIVE UNIT INSTALLATION EE, ES, CRE/FRE
DRIVE WHEEL AND TIRE
4 STEERING SYSTEM
STEERING AXLE ⇒S/N E108V-12739X INC. 12741, 12744, 12750, 1275
STEERING AXLE S/N E108V-12740X⇒ INC. 12727-12732 EXC. 12741, 1
STEERING POD
STEER WHEEL AND TIRE ASSEMBLY
STEERING CONTROL UNIT
GEAR PUMP
GEAR PUMP OPTIONAL
STEERING CYLINDER
HYDRAULIC STEERING SYSTEM
STEERING MOTOR WITHOUT BWI ⇒S/N E108V-17893A
STEERING MOTOR WITHOUT BWI S/N E108V-17894A⇒
STEERING MOTOR WITH BWI ⇒S/N E108V-17893A
STEERING MOTOR WITH BWI S/N E108V-17894A⇒
5 BRAKE SYSTEM
HYDRAULIC BRAKE ASSEMBLY
BRAKE PEDAL
PARK BRAKE LINKAGE SEAT ACTUATED ⇒S/N PENDING PER ECN 64854
PARK BRAKE LINKAGE SEAT ACTUATED S/N PENDING PER ECN 64854⇒
PARK BRAKE LINKAGE LEVER ACTUATED
PARK BRAKE SEAT ACTUATED ⇒S/N PENDING PER ECN 64854
PARK BRAKE SEAT ACTUATED S/N PENDING PER ECN 64854⇒
MASTER CYLINDER
6 HYDRAULIC SYSTEM
HAND LEVER
CONTROL VALVE ATTACHING PARTS TWO FUNCTION
CONTROL VALVE ATTACHING PARTS THREE FUNCTION
CONTROL VALVE ATTACHING PARTS FOUR FUNCTION
CONTROL VALVE TWO AND THREE FUNCTION
CONTROL VALVE FOUR FUNCTION
MAST INSTALLATION
TILT CYLINDER
HYDRAULIC MOTOR MOUNT
HYDRAULIC PUMP 12 CC
HYDRAULIC PUMP OPTIONAL
HYDRAULIC PUMP 19 CC
HYDRAULIC PUMP 19 CC SINGLE GEAR OPTIONAL
HYDRAULIC PUMP LOW NOISE
HYDRAULIC GROUP
HYDRAULIC TANK
7 LIFTING MECHANISM
OUTER MAST TWO STAGE LIMITED FREE-LIFT
INNER MAST TWO STAGE LIMITED FREE-LIFT
LIFT TWO STAGE LIMITED FREE-LIFT
LIFT CYLINDER TWO STAGE LIMITED FREE-LIFT ERC 040-050 RG/ZG
LIFT CYLINDER TWO STAGE LIMITED FREE-LIFT ERC 060-065 RG/ZG ⇒S
LIFT CYLINDER TWO STAGE LIMITED FREE-LIFT ERC 060-065 RG/ZG S/N€
CARRIAGE TWO STAGE LIMITED FREE-LIFT
OUTER MAST THREE STAGE FULL FREE-LIFT
INTERMEDIATE MAST THREE STAGE FULL FREE-LIFT
INNER MAST THREE STAGE FULL FREE-LIFT
MAIN LIFT THREE STAGE FULL FREE-LIFT
FREE-LIFT THREE STAGE FULL FREE-LIFT
MAIN CYLINDER THREE STAGE FULL FREE-LIFT
FREE-LIFT CYLINDER THREE STAGE FULL FREE-LIFT
CARRIAGE SIX ROLLER THREE STAGE FULL FREE-LIFT
OUTER MAST TWO STAGE FULL FREE-LIFT
INNER MAST TWO STAGE FULL FREE-LIFT
MAIN LIFT TWO STAGE FULL FREE-LIFT
FREE-LIFT TWO STAGE FULL FREE-LIFT
MAIN CYLINDER LEFT HAND TWO STAGE FULL FREE-LIFT ⇒S/N PENDING
MAIN CYLINDER LEFT HAND TWO STAGE FULL FREE-LIFT S/N€PENDING€PER
MAIN CYLINDER RIGHT HAND TWO STAGE FULL FREE-LIFT ⇒S/N PENDING
MAIN CYLINDER RIGHT HAND TWO STAGE FULL FREE-LIFT S/N€PENDING€PE
FREE-LIFT CYLINDER TWO STAGE FULL FREE-LIFT
CARRIAGE SIX ROLLER TWO STAGE FULL FREE-LIFT
OUTER MAST FOUR STAGE FULL FREE-LIFT
INTERMEDIATE NO. 1 MAST FOUR STAGE FULL FREE-LIFT
INTERMEDIATE NO. 2 MAST FOUR STAGE FULL FREE-LIFT
INNER MAST FOUR STAGE FULL FREE-LIFT
MAIN LIFT FOUR STAGE FULL FREE-LIFT
FREE-LIFT FOUR STAGE FULL FREE-LIFT
MAIN CYLINDER LEFT HAND FOUR STAGE FULL FREE-LIFT
MAIN CYLINDER RIGHT HAND FOUR STAGE FULL FREE-LIFT
FREE-LIFT CYLINDER FOUR STAGE FULL FREE-LIFT
CARRIAGE FOUR STAGE FULL FREE-LIFT
8 ATTACHMENTS AND HEADER HOSE GROUP
SIDE-SHIFT CARRIAGE ERC 040-050 RG/ZG
SIDE-SHIFT CARRIAGE ERC 060-065 RG/ZG
SIDE-SHIFT CYLINDER
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE LIMITED FREE-LIFT ERC 40-
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE LIMITED FREE-LIFT ERC 60-
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE FULL FREE-LIFT ERC 40-50
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE FULL FREE-LIFT ERC 60-65
INTEGRAL SIDE-SHIFT CARRIAGE THREE AND FOUR STAGE FULL FREE-LIFT
INTEGRAL SIDE-SHIFT CYLINDER
INTEGRAL SIDE-SHIFT HYDRAULIC HOSES TWO STAGE LIMITED FREE-LIFT
INTEGRAL SIDE-SHIFT HYDRAULIC HOSES TWO, THREE, AND FOUR STAGE F
HEADER HOSE TWO STAGE LIMITED FREE-LIFT
TUBE EXTENSION TWO STAGE LIMITED FREE-LIFT
HEADER HOSE THREE STAGE FULL FREE-LIFT
TUBE EXTENSION WITHOUT ROTATOR THREE STAGE FULL FREE-LIFT
TUBE EXTENSION WITH ROTATOR THREE STAGE FULL FREE-LIFT
HEADER HOSE TWO STAGE FULL FREE-LIFT
TUBE EXTENSION WITHOUT ROTATOR TWO STAGE FULL FREE-LIFT
TUBE EXTENSION WITH ROTATOR TWO STAGE FULL FREE-LIFT
HEADER HOSE FOUR STAGE FULL FREE-LIFT ⇒S/N E108-15246
HEADER HOSE FOUR STAGE FULL FREE-LIFT S/N E108V-15247⇒
TUBE EXTENSION FOUR STAGE FULL FREE-LIFT
9 OPTIONS
BRAKE AND BACK-UP LIGHT
DRIVE AND REAR LIGHTS
STROBE LIGHT
SPOT LIGHT
DOME LIGHT
BACK-UP ALARM
WIRE HARNESS REAR LIGHTS
BATTERY SLIDE AND ROLLER TRAY ⇒S/N E108V-11382
BATTERY SLIDE AND ROLLER TRAY S/N E108V-11383⇔S/N E108V-17489Z
BATTERY SLIDE AND ROLLER S/N E108V-17490Z⇒
WIRE HARNESS SWITCH
WIRE HARNESS TRACTION CUT-OUT
DC CONVERTOR
EMERGENCY POWER/SEAT SWITCH BYPASS
10 FIELD CONVERSION KITS
ELECTRICAL
FENDER
CONTROL VALVE
MAST TILT
TUBE EXTENSION TWO AND THREE STAGE FULL FREE-LIFT
HOSE TAKE-UP TWO STAGE LIMITED FREE-LIFT
HOSE TAKE-UP TWO STAGE FULL FREE-LIFT
HOSE TAKE-UP THREE STAGE FULL FREE-LIFT
HOSE TAKE-UP FOUR STAGE FULL FREE-LIFT
