Yale Forklift Controller Flash .HEX & Programming Files – Service Collection 2025
This thread is to introduce a 2025 collection of Yale forklift controller flash files (.HEX) intended for professional diagnostic, programming, and controller replacement work.
If you need compatibility confirmation or have technical questions, feel free to reply or contact me directly.
*** Contact us to get a more details: admin@autorepairmanuals.ws or gallons@autorepairmanuals.ws ***
Service Installation
Service check program
Service fix error program
Service Remote Installation
By Teamview, Anydesk, Ultraview
---- Detail Description ----
Communication Cable
Nuvera IFAK Driver.zip Nuvera IFAK Driver 14.3 MB 02/22/2019
IFAK Driver required for Nuvera Fuel Cell communication with Nuvera Service GUI.
Controllers
Nuvera VSM Programming Tool and Instructions V3_4.zip Nuvera VSM Programming Tool and Instructions V3_4.zip 914.71 kB 12/09/2019
Compatible with Block 2 BBRs only. Please follow instructions located within the file for programming.
Controllers >> Control Software
Nuvera 36V Version 4.5.0 VSM Software Package.zip Nuvera 36V Version 4.5.0 VSM Software Package.zip 3.38 MB 09/23/2020
Nuvera 36V Version 4.5.0 VSM Software Package 3.00 MB 9/23/2020 Class 1 and Class 2 systems 36V VSM hex code Version 4.5.0. Also included is a revised DTC list and Troubleshooting. Not compatible with Block 1 COP units. Please use VSM install procedure. MD5 Checksum Value for download package (zip file): DB7EE0F7529B7560370E8AF9549AC1DB, MD5 Checksum for PELEC2V36S16P3_µC1_4.5.0.hex file: 9293EB458C17C92D8776119593E02B20
Nuvera 48V Version 4.5.0 VSM Software Package.zip Nuvera 48V Version 4.5.0 VSM Software Package.zip 3.38 MB 09/23/2020
Nuvera 48V Version 4.5.0 VSM Software Package 3.00 MB 9/23/2020 Class 1 and Class 2 systems 48V VSM hex code Version 4.5.0. Also included is a revised DTC list and Troubleshooting. Not compatible with Block 1 COP units. Please use VSM install procedure. MD5 Checksum Value for download package (zip file): CA9B9FEFD938E3B22D817DC13E50129D, MD5 Checksum for PELEC1V48S24P2_µC1_4.5.0.hex file: 6F72938CC82F5FC03F5A037752F9B138
Controllers >> Master Controller Software
Nuveras Software L2835.zip Nuveras Software L2835 646.17 kB 08/11/2022
Communication Cable >> IFAK Driver
1595698R8.-161194.zip IFAK Cable Upgrade V6.2.1 6.86 MB 08/23/2022
Vehicle >> Display
8851132R0.zip Display Software Code (V4.43) 466.12 kB 11/16/2021
America’s 11/16/21 – B. Crowell – Release of V4.43 Software 08/June/21 – R Drysdale – Added Hyster Unit code A250 & Yale Unit code A410 7/10/2020 – Display counterpart software w/VSM 4.42, adds SPED Maintenance Lift Lockout support.
Vehicle >> VSM
8858193R0.zip VSM Software Code (V4.58) 275.47 kB 09/20/2023
9/20/23 – V4.58 Software Release, Added support for new VSM Hardware, changes for EN1175 Compliance, resolve issues with reverse hyd control. 11/16/21 – V4.43 Software release 7/10/20 – V4.42 Software released, Added SPED Maintenance Lift Lockout
1595698R8.-161194.zip IFAK Cable driver V6.2.1 6.86 MB 08/23/2022
Vehicle >> Display
8851132R0.zip Display Application Code (V4.43) 466.12 kB 11/16/2021
ER Display Software v4.43 – Allows for SPED Option for Unclamp Doubletap feature
Vehicle >> VSM
8860371R0.zip VSM Application Code (V4.60) 277.21 kB 03/05/2025
05/March/25 V4.60 Software release. Please update to Display Application Code (V4.43) with VSM V4.60.
Communication Cable
81013600R0.zip Intelligent Battery Management System v3.0.7 32.8 MB 02/18/2025
This software is for diagnosing lithium-ion battery.
81010425R0.zip USB-CAN Tool Software 960.67 kB 02/17/2025
This is the driver for GCAN USBCAN-II Pro Analyzer.
Vehicle
81010426R1.zip CACTI Charger Display Language Package for HY 48-115V Lithium Battery 26.3 MB 03/30/2025
For downloading different language package for the display.
81010971R1.zip Configuration Software for FGCD Charge & Discharge Tool 15.4 MB 03/30/2025
For use with HY Lithium Battery.
Communication Cable
Vehicle
Communication Cable
Vehicle
Communication Cable
81013599R0.zip PICkit 3 Tool Software 111.2 MB 02/18/2025
This software is for transferring hex file to CACTI HWCD18 Lithium Battery Charger.
Vehicle
81013593R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V100A (CE only) 1.02 MB 02/17/2025
For use with PICkit 3 programmer to set the percentage state of charge (SOC) for charging lithium battery.
81013594R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V150A (CE only) 1.02 MB 02/17/2025
81013595R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V200A (LM Power Module) (CE only) 1.02 MB 02/18/2025
81013596R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V200A (Non-LM Power Module)(CE only) 1.02 MB 02/18/2025
81013597R0.zip CACTI Charger Control Panel Firmware – HWCD18-80V150A (CE only) 1.02 MB 02/18/2025
81013598R0.zip CACTI Charger Control Panel Firmware – HWCD18-80V200A (CE only) 1.02 MB 02/18/2025
Communication Cable
Vehicle
Communication Cable
Vehicle
Communication Cable
Vehicle
Vehicle
524146551R4.pdf Instructions – Smartset / GE Sentry / Dash Software (Release 5) 18.44 kB 06/02/2008
524146551R4.ZIP Smartset / GE Sentry / Dash Software (Release 5) 50.3 MB 06/03/2008
Controllers >> ETACC
550027876R11 instructions.pdf ETACC 2.4K Instructions (Update Only- Must Have Program 2.4J Installed prior to installation) 445.50 kB 01/28/2013
550027876R13.zip ETACC 2.4N (Update Only- Must Have Program 2.4K Installed prior to installation) 6.00 MB 08/09/2022
524283948R4.ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
ETACC Yale Instructions 4.pdf ETACC Program 2.4J Installation Instructions – “Version 2.4 J is sometimes referred to as version 2.42.” 1.12 MB 10/01/2012
550037243R0.zip Control Upgrade Software- Master Control- C36 (Revision 0) 518.54 kB 05/23/2011
550037243R0.pdf Control Upgrade Software- Master Control- C36 (Revision 0) Installation Instructions 203.23 kB 05/23/2011
Controllers >> Traction Controller Software
550037243R0.pdf Controller Upgrade Software – Traction – 72/80V 225.25 kB 08/01/2011
550040273R0.zip Controller Upgrade Software – Traction – 36/48V 225.10 kB 08/01/2011
550040273R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/48V 242.14 kB 08/01/2011
524283948r4.ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
550041199R0.zip Controller Upgrade Software – Traction –D216 2-3DBB & A908 2/3CBB 72/80V 225.25 kB 08/01/2011
550041199R0.pdf Controller Upgrade Software Installation Instructions – Traction –D216 2-3DBB & A908 2/3CBB 72/80V 242.03 kB 08/01/2011
Vehicle >> Vehicle – Programming Interface Software Tool
FieldProg Install and Use Guide v2.42.pdf Field Prog Install and Use Guide v2.42 660.90 kB 08/17/2023
Controllers >> Service Software Upgrade
8830603r0.zip C03 Control Software GEN6 Programming Tool 23.6 MB 09/20/2017
NOTE: GEN6 CONTROLLERS ONLY. DO NOT USE ON EARLIER VERSION CONTROLLERS. GEN6 controllers went into production in Oct. 2014. The GEN6 controllers are physically smaller than the previous versions and are light gray in color. Previous version controllers in this series truck were black.
Kollmorgandrivefilepusher.zip Danaher C25 File Pusher – (kollmorgandrivefilepusher.zip) 1.28 MB 04/28/2014
Drive Upgrade Tool- Traction & Pump Controller (C20) must be installed on the computer before the Danaher C25 File Pusher is downloaded and executed. The C25 File Pusher Updates the Drive Upgrade Tool.
550035435R2.zip Drive Upgrade Tool- Traction & Pump Controller (C20) 23.8 MB 09/07/2012
550035435R2.pdf Drive Upgrade Tool- Traction & Pump Controller Installation Instructions (C20) 2.51 MB 09/07/2012
Vehicle >> Display
Vehicle >> VSM
Operator Display >> Instrument cluster
8841494R1.zip HyPro Programming Tool v2.00 w/drivers 19.0 MB 07/03/2019
HyPro Programming Tool v2.00 for updating software on NCEA displays, such as used on End Riders & New Reach vehicles along with Class I Greensight VSMs. NOTE: Please review associated install & use guides. -Updated to include Drivers.
8858162R0.zip Field Prog (v2.42) 19.5 MB 06/16/2023
Field Prog version 2.42
8861234R0.zip HYpro v3.2.7 – programming tool 19.1 MB 04/04/2024
Updated HYpro from v3.2 to v3.2.7 — contains a critical update
8847774R0.zip Greensight VSM Firmware 247.21 kB 07/20/2020
Initial release of Firmware for Greensight Controller, to be used with Hypro.
Vehicle >> OAS display
8861917R0.zip OAS 7″ Display Software v1.3.6 35.5 MB 02/04/2025
2/5/2025: HST (Initial release) Change notes: Compatible with OAS version 1.35.XX and 1.36.XX, added font scaling based on string length, resolved issue where version info wasn’t always populated, added fault code 8206 “CDF Serial Number Does Not Match Expected Value”
IFAK Cable Upgrade V5.3.ZIP IFAK Cable Upgrade V5.3 14.5 MB 07/01/2013
Controllers >> AC Motor Controller
8823586R0.pdf Zapi FOC 2 Motor Controller Software Upgrader Instructions 368.66 kB 03/18/2016
FOC 2 – Field Orientated Control 2
8827248R0.zip ZAPI FOC 2 Motor Controller Software Upgrader version 1.12- FOC 2 Controller 8820249 1.01 MB 01/11/2017
NOTE: NOT ALL TRUCKS ARE FOC 2! (Field Orientated Control 2). Verify traction controller P/N is 8820249 (As seen on label) and the software version is 1.07 or higher BEFORE loading the FOC 2 software in the motor controllers! Please Contact RSE / PSG if unsure!
550097391r0.zip Zapi FOC Motor Controller Software Upgrader – FOC Traction 8809255 – FOC Pump 8810847 440.65 kB 01/24/2014
NOTE: NOT ALL TRUCKS ARE FOC! (Field Orientated Control). Verify traction controller P/N is 8809255 and the software version is 122 and the pump controller is P/N 8810847 and the software version is 115 BEFORE loading the FOC software in the motor controllers.
550097391R0.pdf Zapi FOC Motor Controller Software Upgrader Instructions 151.99 kB 01/24/2014
FOC – Field Orientated Control
550017122R1.pdf Zapi Motor Controller Software Instructions 166.85 kB 08/22/2011
550017122R1.zip Zapi Motor Controller Software Upgrader- (Rev. 1) – VFC only 427.53 kB 08/22/2011
8839093R1.zip ZAPI Motor Controller Software V1.17 871.69 kB 05/20/2020
v1.17 – Software supports the new Motor Thermal Sensor
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Controllers >> OAS controller
8861918R0.zip OAS Controller Software v1.35.54 482.10 kB 02/04/2025
2/4/2025-HST (Initial release) Change notes: Now requires OAS Serialized CDFs and generic OAS v35 software HYZ and OAS Display HYZ, optimized Object Detection (OD) algorithm, adjusted slowdown algorithm for Proximity Detection (PD), new DTCs for OD sensors, refined fault timer for OD, speed change rate adjustments.
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
8861234R0.zip HyPro Programming Tool v2.00 w/drivers 19.0 MB 07/03/2019
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
SPED
S01833210060.pdf GTC AlgoBMS Installation & User Guide 3.61 MB 09/03/2021
SPED – GTC AlgoBMS Installation & User Guide . pdf —- For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210010 – Firmware File .zip SPED – GCT AlgoBMS – Firmware File 306.79 kB 09/10/2021
Firmware File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210020 – Master Config File .zip SPED – GCT AlgoBMS – Master Configuration File 1.17 kB 09/10/2021
Master Configuration File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210030 – Slave Config File .zip SPED – GCT AlgoBMS – Slave Configuration File 1.16 kB 09/10/2021
Slave Configuration File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210040 – Programming Application.zip SPED – GCT AlgoBMS Diagnostic & Programming Software / Application 28.4 MB 09/10/2021
Vehicle >> Display
Vehicle >> VSM
SPED
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Spreader >> ELME
8859584R1.zip Diagnostic Software – ELME Neuron Controller 1.37 MB 05/15/2024
01-02-2024 – This is the diagnostic software for the ELME Neuron CAN-bus controller, to be used on truck series B3C0 (Stage V/ GBIV) and truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), J008E02500 (Stage V), J008E02500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
HyPro Install and Use Guide-EN.pdf HyPro Installation and Use Guide 664.95 kB 08/17/2023
Vehicle >> Display
4376521R0.zip Camera Display Application Software 9.36 MB 09/29/2023
29-09-2023 – Camera display application software, to be used with HyPro tool
Vehicle >> Display V5
81020722R0.zip Primary Display Application Software 14.4 MB 03/06/2025
06-03-2025 – New Release of the primary display application software to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
Vehicle >> VSM HW P/N 8844446 V5
81025389R0.zip VSM uc1 Application Software 792.58 kB 04/25/2025
25-04-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and VSM uc3 are updated at the same time!
81015029R0.zip VSM uc2 Application Software 42.48 kB 03/06/2025
06-03-2025 – Release of VSM uc2 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
81003855R0.zip VSM uc3 Application Software 39.36 kB 11/03/2024
06-03-2025 – Release of VSM uc3 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
Spreader >> ELME
Vehicle >> Display
Vehicle
Vehicle >> Diagnostic & Programming
Nuvera FCST v4.31.20.zip Nuvera FCST v4.31.20 279.8 MB 06/07/2022
Vehicle >> VSM
Nuvera B2D1 VSM Software 4.22.18.zip Nuvera B2D1 VSM Software 4.22.18 1.01 MB 06/07/2022
550041197R0.zip Controller Upgrade Software – Traction – 36/48V 224.95 kB 08/01/2011
550041197R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/48V 242.26 kB 08/01/2011
550041197R0.zip Controller Upgrade Software – Traction –B814/C814- 1-2CBB -48V 224.95 kB 08/01/2011
550041197R0.pdf Controller Upgrade Software Installation Instructions – Traction – B814/C814- 1-2CBB -48V 242.26 kB 08/01/2011
550041198R0.zip Controller Upgrade Software – Traction – 36/ 48V 225.26 kB 08/01/2011
550041201R1.zip Controller Upgrade Software – Traction –B839/C839 4-5CBB 80V 225.06 kB 05/29/2012
550041198R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/ 48V 242.53 kB 08/01/2011
550041201R1.pdf Controller Upgrade Software Installation Instructions – Traction –B839/C839 4-5CBB 80V 241.77 kB 05/29/2012
550041198R0.zip Controller Upgrade Software – Traction –B839/ C839 4-5CBB 48V 225.26 kB 08/01/2011
550041198R0.pdf Controller Upgrade Software Installation Instructions- Traction –B839/ C839 4-5CBB 48V 242.53 kB 08/01/2011
550089526R69.zip CCS (Common Control System) Field Service Tool v1.91 31.0 MB 10/31/2024
1.91 – Updated for new 3M tether interlock requirements on Order Selectors and for relaunch of CCS Reach trucks. – 1.90 – Updated for NCEA Reach VSM v2.27.13 for OAS tilt angle improvement, End Rider software v1.51 (41599-12 code), and adds Boot Force to VSM software download. – 1.89 – Updated software for NCEA Reach Current draw & performance issues, B-Series GPT Support for ReLION and resolution of 0x180 overcurrent faults. – 1.87 – Updated software for AC Reach (bugs/options/features) / – 1.86 – Updated software for AC Reach and GPT (0.53) / – 1.85 – Updated software for new B-Series GPT / – 1.84 – Support for new GPT, and OSBE changes. / – 1.83 – Support for NCEA OAS, and NCEA display corrections / – 1.81 – Support for dual brake Reach, and EER product / – 1.79 – Various bug fixes and additional vehicles added for B56.1 support / – 1.77 – Update to support B56.1 changes in multiple production products / – 1.76 – Update to support Class III front foot/bumper detection / – 1.75 – Update to fix NCEA VSM loading issues, support for EER Bumper Sensor system / – 1.73 – Update to support new reach VSM software for VAM telematics, CCS reach OAS Software, 3ws and CCS reach calibration fixes. / – 1.71 – Update to support latest OAS Software on Reach, OS, and 3WS. / – 1.69 – Update to support New Reach V2.20 SW, Order Selector & 3WS OAS SW / – 1.68 – Update to resolve NCEA programming issues, and improve Anti-Virus false warnings / – 1.67 – Update to resolve ER backward compatibility issues and updates for early production Reach. / – 1.66 – Updates to support production NCEA Reach Software. / – 1.63 – Added New End Rider EPAS & NCEA Reach support. / – 1.61 – Added Li-Ion and OSS expansion to Enclosed End Rider. / – 1.60 – Added Li-Ion support to AC Reach & 3W-STD, BDI range expansion on Enclosed End Rider. / – 1.59 – Expanded support for Temp Sensor Configurations, and Assisted Steer End Rider. / Notes: -USE ONLY CCS FST R30- VERSION 1.49 or HIGHER on C883 Series 3 wheel stand trucks (ESC030-040AD) with OSS (Operator Sensing System). -USE ONLY CCS FST R18- VERSION 1.35 or HIGHER on MPB045VG – A245 Series Trucks!!! Do not use on MPB045VG (A245) trucks with controllers that have a manufacturing date code before 14072C. Contact RSE for instructions pertaining to controllers produced earlier than 14072C.
550053933R6.zip Class I / II Field Service Tool- Non CCS trucks Only 2.54 MB 02/06/2015
Ifak-6.06.zip Ifak-6.06.zip 21.2 MB 09/14/2022
NOTE: THIS IFAK DRIVER SOFTWARE IS COMPATIBLE WITH THE CURRENT IFAK CABLE, HOWEVER IS ONLY USED ON THIS TRUCK MODEL AT THIS TIME. CONTINUE TO USE THE PREVIOUS VERSION IFAK SOFTWARE ON OTHER TRUCK MODELS UNTIL IT IS ADDED TO AND SEEN ON THOSE MODELS.
550064182R0.pdf Next Generation 24 volt controller Software Instructions 178.80 kB 08/07/2012
550102172R0.zip Next Generation 24 volt controller Software Upgrader V001 906.76 kB 07/21/2014
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
524283948R4 (1).ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
550041198R0.zip ontroller Upgrade Software – Traction – 36/ 48V 225.26 kB 08/01/2011
550041199R0.zip Controller Upgrade Software – Traction – 72/80V 225.25 kB 08/01/2011
550041199R0.pdf Controller Upgrade Software Installation Instructions – Traction –72/80V 242.03 kB 08/01/2011
Vehicle
550041200R0.zip Controller Upgrade Software – Traction –E216 -2-3DBB 72/80V 224.84 kB 08/01/2011
550041200R0.pdf Controller Upgrade Software Installation Instructions – Traction –E216 -2-3DBB 72/80V 242.07 kB 08/01/2011
Vehicle
524245853A.zip Control Upgrade Software (Rev A) 538.84 kB 05/15/2006
Vehicle >> Display
Vehicle >> VSM
Controllers >> Steer Controller Software
8823665.zip Electric Steering Controller Software 523.35 kB 12/08/2015
Electric Steering Controller v5.12 requires VSM Application code v4.34 to operate and Display Application Code v4.34 to provide menu’s. (versions may be viewed via PCST > Diagnostic > Truck Information menu).
Vehicle >> Display
Vehicle >> VSM
524283948r4 (1).ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
Joystick >> Delta Tech
580093087R0.zip Side Stance Joystick Adjustment (Release 1) 32.97 kB 05/15/2008
524301764R1.zip Reach Truck Field Product Improvement Software (Version 1) 33.1 MB 02/15/2008
524320109R0.zip Reach Truck Field Product Improvement Software (Version 2) 24.1 MB 02/15/2008
524320109R1.zip Reach Truck Field Product Improvement Software (Version 3) 1.26 MB 08/27/2008
524312178R3.zip Reach Truck Steering Software (69A21200C006) 25.1 MB 04/01/2013
Vehicle >> VSM
4000448R3.zip VSM Software Update (Retail) 697.69 kB 01/28/2010
Communication Cable
Controllers
Controllers
8847930R0.zip 8847930R0 TOOL CDF UPLOADER V120P 574.59 kB 07/30/2020
CONTROL SOFTWARE TOOL CONFIG. FILE UPLOADER FOR ZAPI CONTROLLER
Controllers >> ZAPI Software
8817406R3.zip Diagnostic and programming Software CAN PC Console 6.09 MB 02/07/2024
This file release the new tool version 2.20, this improve the connection capability and it is mandatory to connect with new VNA electronics. Instructions about Can Device setup are included
8842177R1.zip Control software Master EPS Steering Motor 118.26 kB 01/25/2021
8842178R1.zip Control software Slave EPS Steering Motor 112.42 kB 01/25/2021
4178451R6.zip Control Software Traction/Pump Master ACE2 118.46 kB 12/14/2022
4178453R6.zip Control Software Traction/Pump Slave ACE2 109.00 kB 01/11/2023
4178454R4.zip Control Software VCM Master 95.55 kB 10/14/2019
4178455R4.zip Control Software VCM Slave 68.45 kB 10/14/2019
EPS 3 stage Gearbox NA6.23.zip Field Tool to update EPS Master & Slave to version 6.23, only using 3 stage gearbox 1.70 MB 03/02/2021
Pump for 9,9kW motor NA2.34.zip Field Tool to update Pump Controller Master & Slave to version 2.34, use only on truck having 9,9KW motor 1.46 MB 12/16/2022
This revision introduce improvement on Motor Management
Traction for 5,4kW motor NA2.34.zip Field Tool to update Traction Controller Master & Slave to version 2.34, use only on truck having 5,4KW drive motor 1.48 MB 12/16/2022
This revision introduce improvement on Motor Management This has to be used also on truck with 4KW motor (Russian Market)
VCM Standard NA0.27.zip Field Tool to update VCM Controller Master & Slave to version 0.27 1.23 MB 09/15/2020
Controllers
8843593R1.zip AWP Battery Calibration Tool 23.3 MB 01/22/2020
Tool to re-calibrate Battery Voltage with the ZAPI Controller. Voltage drop through the mast cable causes an offset that must be calibrated for, to enable accurate BDI readings. Updated Release V1.1 w/new ZIP method to avoid compliance issues with Win10 Explorer.
Communication Cable
81010425R0 USB-CAN Tool Software 960.67 kB 02/17/2025
Vehicle
Controllers
EPS 6.33 for Outdoor Reach truck.zip EPS 6.33 version 2.26 MB 12/20/2024
Upgrader for steering control software version 6.33, both Main and supervisor.
Pump for 14kW motor NA2.30.zip Field Tool to update Pump Controller Master & Slave to version 2.30, use only on truck having 14KW motor 1.92 MB 12/20/2022
Traction for 9,6kW motor NA2.36D.zip Field Tool to update Traction Controller Master & Slave to version 2.36, use only on truck having 6,4KW or 9,6KW drive motor 3.05 MB 09/10/2024
Version 2.36 fix issue with new direction switch, as described on Gram /Bulletin FB084R01
VCM Premium NA 2.55.zip Field Tool to update VCM Controller Master & Slave to version 2.55 2.38 MB 12/20/2024
Version 2.55 introduce the Li-Ion managed through CDF and a new condition for Lowering interlock by pass
Joystick >> CCS
4092475R1.zip CCS Sidestance Control Handle Software 76.2 MB 03/21/2014
This software should only be used under RSE direction, contact RSE before downloading.
4092475R1instructions.pdf CCS Sidestance Control Handle Software Instructions 1.68 MB 03/21/2014
Controllers
WinFlash.zip Winflash reprogramming tool for controllers 13.3 MB 03/15/2022
8811176R0.zip CAN FLASHER Software Uploader 1.30 MB 07/05/2012
1-13-00P.zip HYG RFID PLC software files 12.5 MB 10/07/2024
New software packages 1-13-00P for RFID PLC, Installation Instructions included. This new version introduce new options in the application menu. IMPORTANT NOTE : USE ONLY ON TRUCK UP TO SERIAL NUMBER ….T02999X
HYG RFID Programmer rev 1.6.1.0.zip RFID programmer 16.3 MB 02/01/2019
Tool to program RFID SPED features
HLOP UpgraderR1.zip Tool to update all truck controllers 678.62 kB 11/11/2021
This tool allow to upgrade High Level Order Picker This version updates split HLOP software from VNA and introduce Sicos software 3.18. This software has parameter Pressure Time , into adjustment menu. This is to prevent a possible initial cabin drop of 10cm, when lowering. Software included are: Sicos 3.18, Traction and Pump 3.08, Mhyrio 3.00, EPS 3.07.
upgrader_0.18 HLOP Standard.zip Tool to update all truck controllers 2.19 MB 05/12/2025
This tool to be used to upgrade High Level Order Picker, to be used ONLY on trucks with electronics to comply with EN1175:2020. Software included are: Sicos 0.18, Dual ACE2 0.06, EPS 0.07, VCM 0.03, Can Tiller 0.02,and Antennas 0.75
upgrader_0.18 HLOP Dual Control.zip Tool to update all truck controllers 2.28 MB 05/12/2025
This tool to be used to upgrade High Level Order Picker, to be used ONLY on trucks with electronics to comply with EN1175:2020 and DUAL SIDE CONTROLS. Software included are: Sicos 0.18, Dual ACE2 0.06, EPS 0.07, VCM 0.03, CANI/O 0.05, Can Tiller 0.02 and Antennas 0.75
550027876R13 (1).zip ETACC 2.4N (Update Only- Must Have Program 2.4K Installed prior to installation) 6.00 MB 08/09/2022
Sicos00.epf ETACC Update and installation instructions.zip Sicos00.epf ETACC Update file and installation instructions 172.05 kB 04/22/2016
New Sicos EPF file for ETACC to allow RFID option to be turned on
580082575R0.zip VNA AC2 Traction and Pump Software (Release 1) 140.85 kB 05/15/2007
580082579R0.zip VNA CAN TILLER Software (Release 1) 14.08 kB 05/15/2007
580082577R0.zip VNA EPS Software (Release 1) 104.45 kB 05/15/2007
580082578R0.zip VNA Mhyrio Software (Release 1) 30.94 kB 05/15/2007
580082576R1.zip VNA SICOS Software (Release 2) 100.89 kB 11/14/2007
2-00-00F.zip HYG RFID PLC Software files 19.2 MB 10/07/2024
Software packages 2-00-00F for RFID PLC, Installation instructions included. IMPORTANT NOTE: USE ONLY ON TRUCK FROM SERIAL NUMBER ….T03000X, WITH NEW ELECTRONIC SYSTEM.
580073638R0.ZIP VNA Software Upgrade Utility (Release 1) 675.93 kB 07/19/2007
upgrader_0.62 SICOS VNA1175_80V_V028 complete -joystick.zip Service tool to update all controller 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 80V AND JOYSTICK SEAT, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75 NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
VNA Service Upgrader for standard EEprom.zip Service Tool to update all controllers 710.86 kB 10/12/2021
USE ONLY ON TRUCK WITH SERIAL NUMBER UP TO 02999X Service too to update all trucks controller, have to be used on trucks fitted with standard memory Sicos. Sicos suitable p/n are 8537120 and 8537127 for US, 8539242 and 8539243 for EMEA and other regions. Software included are: Sicos 3.18, Traction and Pumps 3.11, Mhyrio 3.06, EPS 3.07, Cantiller 3.07
upgrader_0.62 SICOS VNA1175_48V_V028 complete – FWD Console.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 48V AND Forward Console, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75. NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
upgrader_0.62 SICOS VNA1175_80V_V028 complete – FWD Console.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 80V AND FORWARD CONSOLE, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75 NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file.
upgrader_0.62 SICOS VNA1175_48V_V028 complete – joystick.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 48V AND JOYSTICK SEAT, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75. NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
VNA Service Upgrader for extended EEprom .zip Service Tool to update all truck controllers 715.07 kB 10/12/2021
USE ONLY ON TRUCK WITH SERIAL NUMBER UP TO 02999X Service too to update all trucks controller, have to be used on trucks fitted with Extended memory Sicos. Sicos suitable p/n are 8848468 and 8848469 for US, 8848470 and 8848471 for EMEA and other regions. Software included are: Sicos 3.27, Traction and Pumps 3.17, Mhyrio 3.13, EPS 3.07, Cantiller 3.07
Controllers >> VNA Controller Software
8541875R5.zip Control software AC2 CONTROLLER PUMP/TRACTION VNA 140.60 kB 02/10/2022
8541879R7.zip Control software CAN TILLER VNA 12.40 kB 01/18/2013
8541877R7.zip Control software EPS VNA 90.46 kB 06/20/2012
8541878R4.zip Control software MHYRIO VNA 30.54 kB 02/10/2022
8541876R7.zip Control software SICOS VNA 99.57 kB 01/28/2021
8848472R2.zip Control software SICOS VNA extended memory 103.57 kB 02/10/2022
Vehicle >> Display
550297861R0.zip Yale 5″ Display Firmware v4.51 for HyPro v2.0 12.5 MB 02/19/2024
2/19/24 – Release of V4.51 Display Firmware, resolves calibration menu issues. 12/5/23 – Release of V4.43 Display firmware, fixes thermal warnings & indicator bugs. 2/6/23 – Release of V4.40 Display Firmware, fixes Impact Sensor bugs when used with telemetry 11/10/22 – (Fixed) Release of 5″ V3.96 Display firmware, minor bug corrections & rotary wheel fix. 5/5/22 – Release of 5″ V3.94 Display firmware with ICON/System improvements 6/11/21 – Release of 5″ V3.92 Display firmware for supporting OAS system. 5/20/21 – Release of 5″ Display firmware v3.91 for NA Reach to be used with HyPro v2.0 downloader. 5/21/20 – Release of 5″ Display firmware for NA Reach to be used with HyPro downloader.
550297863R0.zip Yale 7″ Display Firmware v4.51 for HyPro v2.0 12.5 MB 02/19/2024
2/19/24 – Release of V4.51 Display Firmware, resolves calibration menu issues. 12/5/23 – Release of V4.43 Display Firmware, fixes thermal warning and indicator bugs 2/6/23 – Release of V4.40 Display Firmware, fixes Impact Sensor bugs when used with telemetry 11/10/22 – (Fixed) Release of V3.96 for Yale 7″ Display, minor bug fixes and rotary wheel fix. 5/5/22 – Release of V3.94 for Yale 7″ Display to improve ICON/system functionality. 6/11/21 – Release of V3.92 for Yale 7″ Display to support OAS system. 5/20/2021 – Release of Yale 7″ Display Firmware v3.91 for NA NCEA Reach to be used with HyPro v2.0. 5/21/2020 – Release of Yale 7″ Display Firmware for NA NCEA Reach to be used with HyPro.
8541872r2.zip Control software – SICOS Display 44.99 kB 04/27/2016
Controllers
Keypad 582080458 R2 software.zip Software to upload functionality on keypad 75.84 kB 06/07/2024
Please refers to Service Gram FK004 for installation, use instructions. Rev 02 fix a bug due to quick OFF/ON
Upgrader RP_RS_2.32 Combi_EPS2.04_con_enc.zip Combi 2.32 and EPS 2.04 – Manage IL option and Key AM for Li-Ion battery 860.18 kB 09/14/2023
This upgrader will update both Combi and EPS, to the latest software release. To be used only on truck using EPS with feedback encoder.
Controllers >> Hydraulic Controller Software
8827190R8.zip Control Software Hydraulic COMBI AC1 51.43 kB 06/16/2020
8819928R3.zip Control Software Pump COMBI AC1 52.93 kB 11/03/2016
8819925R3.zip Control Software Steer AC0 86.58 kB 04/15/2016
4236586R2.zip Control Software Steer AC0 249.59 kB 10/14/2019
8819927R3.zip Control Software Traction COMBI AC1 72.72 kB 11/03/2016
8827189R8.zip Control Software Traction COMBI AC1 87.82 kB 06/16/2020
Controllers
Vehicle >> VSM
4000448R2.zip VSM Fore/Aft Software Update (Release 3) (Americas) 609.86 kB 01/14/2010
Update EPS MLOP 304.zip Control software EPS AC0 411.09 kB 12/17/2024
Update for Standard EPS version only. This update to version 3.04, in this revision, parameter Hardware setting / PT1000 TH Mot is available, to adapt to new temperature sensor.
Update EPS WG MLOP 308.zip Control software EPS AC0 WG 1.18 MB 12/20/2024
Update for EPS Wire Guidance version only. This update to version 3.08, in this revision, parameter Hardware setting / PT1000 TH Mot is available, to adapt to new temperature sensor.
MLOP Service Upgrader.zip Field tool for controller update 705.41 kB 03/06/2023
Service software, to update all controllers on truck. Software included are: Sicos 3.12, Traction and Pumps 3.04 (Combi), EPS 3.03.
Vehicle >> VSM
Controllers
EPS 2 stage Gearbox 2NA 6.23.zip Field Tool to update EPS Master & Slave to version 6.23, only using 2 stage gearbox 1.81 MB 03/02/2021
Vehicle >> Display
8807718R8.zip 8807718R8 (Display retail) 38.83 kB 12/21/2018
8817405R6.zip 8817405R6 (Display LCD Premium) 76.83 kB 10/14/2019
8817509R1.zip 8817509R1 TOOL SOFTWARE DISPLAY RETAIL 372.43 kB 04/21/2014
Joystick >> CCS
S01868240001R3.zip CCS Automation Vehicle Software Updater V3.0 9.06 MB 02/28/2022
1/19/22 – Updated to latest Reach Software 10/29/20 – Updated to latest version to support latest automation software. 9/17/20 – Release of AUTOMATION vehicle FST V1.0 – NOTE: For JBT automation vehicles, use this FST over the standard version listed. Do not use this version if the vehicle is NOT an automation vehicle.
Joystick >> CCS
Vehicle >> Display
Communication Cable
DPIcharger14.2.zip DPI Charger Software Version 14.2 6.89 MB 10/23/2015
FPI-152017 DPI Battery Charger Software Version 14.2- This software is used in conjunction with the Interface Cable P/N- SFP888000030 to perform FPI-152017. This FPI only affects chargers that connect to a Charge Port and should only be used to update DPI charger version 14.1 to 14.2. DO NOT use on versions earlier than 14.1. Download and understand the installation instructions prior to attempting the update.
14.2ChargerSoftwareInstallationReadMe.pdf FPI- 152017- 14.2 Charger Software Installation ReadMe 1.14 MB 10/23/2015
FPI-152017- This Readme file should be read and understood prior to attempting the installation and loading of the 14.2 Charger update software. When installing the software if asked to Update, CLICK NO! If you click Yes the License to# and License Key will be required. Use NACCO in all caps as the “License Key” and the License To# is- 5574a6ab677e9aff5360f964110378f789e4ebeb538e14b7f77312be55fd8d0f
550033141R10.zip Warehouse Updater Tool (V1.21) RSE Authorization Required Before Using. 1.07 MB 06/01/2017
Warehouse Updater Tool Instructions V1.20.pdf Warehouse Updater Tool Instructions V1.20 and newer 276.37 kB 04/01/2016
Communication Cable
Controllers
Nuvera Fuel Cell Class 3 Block 2 VSM SW V4.1.0.zip Nuvera Fuel Cell Class 3 Block 2 VSM SW V4.1.0.zip 6.54 MB 05/07/2021
Class 3 24v VSM Version 4.1.0 hex code. Compatible with both BBRHMI 2.1.0 (no buzzer) or BBRHMI 3.0.0 (buzzer). Not compatible with Block 1 and Block 1.5 COP units. Please use VSM install procedure.
Controllers
Nuvera Software A2023B.zip Nuvera Software A2023B 630.18 kB 08/30/2022
Controllers
TOOL ONBOARD CHARGER CURVE SETTING V1.0.2.zip TOOL ONBOARD CHARGER CURVE SETTING 374.74 kB 11/05/2024
new tool, to change charge curves profile into onboard charger. NOTE: To be used only for onboard chargers P/N 4252102 & 4131473 (these codes can be found on charger label)
MultiCan Tiller Tool R1.zip Diagnostic and programming tool for tiller card 995.34 kB 06/24/2021
This is to be used only on Rema MultiCan tiller card type, following service Gram / Bulletin LD078 – Suitable for both 32 and 64 bit systems
81012564R0.zip Telemetry – VAM Configuration Tool (LITE) – v2.10.4 1.37 MB 02/07/2025
Vehicle
Curtis CAN Tool V1.3.3.25.zip Third parties WHE (EU) diagnostic tool for PCST 57.7 MB 04/01/2021
NEW Curtis tool for PCST this version has a software download bug fixed, suitable to operate with WIN10 refers to LD062R03
A428 A418 1232E2226 VCL 2.14.zip Combi controller software 135.47 kB 06/12/2020
Latest production software VCL 2.14, to align the MDi parameters as per service Gram / bulletin FH018R01
Vehicle
Communication Cable
Controllers
8826535R1.zip 8826535R1 TOOL ONBOARD CHARGER CURVE SETTING 191.78 kB 06/12/2017
8850945R0.zip 8850945R0 TOOL CONFIG. FILE UPLOADER 838.70 kB 04/30/2021
CONTROL SOFTWARE TOOL CONFIG. FILE UPLOADER FOR CURTIS CONTROLLER
C.I.T. v1.0.1.zip Curtis Integrated Toolkit for PCST 121.9 MB 05/11/2021
Diagnost and programming tool
Platform Pallet Truck rev 03.zip Truck project file 9.02 MB 04/29/2022
This file is mandatory to install on laptop, to connect Curtis Integrated tool to the truck Rev 03: 1) fix a bug during controller change and CDF load 2) fix discrepancy on maintenance hours 3) fix issue with alarm ST48-2 Following Error 4) correct some translations error on instructions file.
Vehicle
Controllers
Nuvera Software a2012b.zip Nuvera Controllers Software A2012B 581.54 kB 09/09/2022
Controllers
Automatic Update for Combi ACX rev0.59.zip Software to update controller to version 0.59 680.29 kB 08/02/2024
Truck software for service use, version 0.59 Fix an issue with alarm 155A02, see LD083R01
Letrika controller update Y.zip Software to update combi controller 5.48 MB 11/08/2018
This software, can be used only on truck from serial number: B892T01684M, B860T01596M and C847T02650M
550027876R11 instructions (1).pdf ETACC 2.4K Instructions (Update Only- Must Have Program 2.4J Installed prior to installation) 445.50 kB 01/28/2013
AC End Rider Software Installation Instructions.pdf AC End Rider Software Installation Instructions 33.70 kB 12/03/2009
Vehicle
Vehicle >> Display
550217056R1.zip Display Firmware V1.04 9.95 MB 07/03/2019
Display Firmware V1.04, referred to in UE0005R00Y as “USB Archive.phd” for use with HyPro Software download tool and the USB Interface Dongle. V1.04 resolves; Serial Mis-Match errors, Intermittent Rabbit Function, non-real touch detections, lock-up conditions, and improves loading time.
Display Firmware V1.05 0.00 kB No data
Display Firmware V1.05, referred to in UE0005R00Y as “USB Archive.phd” for use with HyPro Software download tool and the USB Interface Dongle. V1.05 supports; End Rider EPAS Not necessary for Manual Steer Vehicles. NOTE: When using FST, version 1.63 or higher must be used.
8852262R1.zip Display V1.07 App/V4.87 Firmware for 2.8″ Parker Display 10.3 MB 04/12/2023
4/26/23 – BRC – Release of V1.07 Display Software (corrects Ahr issue, OSBE changes, and timeout issues.) 1/27/22 – BRC – Release of V1.06 Display Software (supports new End Rider Bumper/detection system). 6/10/21 – BRC – Release of updated Display software to support the new V6 Parker Displays on the End Rider. This software is required for proper touchscreen function on Rev 6 hardware. This software is compatible with Rev 5 displays
Vehicle >> Display
8803563R1.zip Control Software – Combi MPB (Rev 1) 63.47 kB 02/15/2011
Controllers
4177296R10.zip Control Software Master Combi Controller ACX 182.16 kB 02/12/2025
4177297R10.zip Control Software Slave Combi Controller ACX 83.60 kB 02/12/2025
Automatic update for Combi ACX rev. 1.59.zip Automatic update for combi controller ACX 1.10 MB 02/13/2025
Software update for Combi ACX controller, software version 1.59. On pedestrian stacker this new release, will manage SPED Bumper Switch option
4325578R2.zip Control software pump COMBI AC1 48.73 kB 02/10/2022
8851257R3.zip Field tool to update Master and Slave Combi controller 462.64 kB 07/20/2023
This tool will update Combi controller to latest version 018, used in production.
8851361R6.zip Field tool to update master and slave Steering controller 1.66 MB 11/29/2023
This upgrader will load version 005, able to fix error Vcap too low.
4326521R1.zip Control software EPS AC0 127.01 kB 02/10/2022
4326522R1.zip Control software truck config. EPS AC0 ZAPI 120.33 kB 02/10/2022
4325577R2.zip Control software traction COMBI AC1 87.69 kB 02/10/2022
Controllers
New Diagnostic and Programming tool for E843 truck
Double Platform Stacker rev 03.zip Truck Project File 10.5 MB 03/11/2025
This file is mandatory to install on laptop, in order to connect Curtis Integrated Tool to the truck Rev 03 , Fix a bug with acceleration when battery is below 50; made available parameter: Traction Manager -> HS/LS Multiplier -> Neutral Decel HS to LS, to adjust braking power in pedestrian mode; correct the alarm logbook time unit.
Vehicle
D843_12225113B.zip Steering controller software 133.03 kB 06/12/2020
To be used only on EPS 1222-5103 and Beyond. DO NOT USE on 1222-5102 OR LOWER
D843 12342388 service R1.zip Traction controller software update 109.01 kB 04/23/2020
VCL version 1.42 updates Li-Ion battery management. Suitable to be used on controller 1234-2383 and beyond. DO NOT USE nn 1234-2382,or lower. DO NOT USE on any version of 1234E
D843_1234E2338.zip Traction controller software update 146.08 kB 06/12/2020
VCL version 1.43 updates Li-Ion battery management. Suitable to be used on controller 1234E. DO NOT USE on standard 1234 controller
Controllers
Automatic update for Combi AC0 Electrical steer rev.1.59.zip Automatic update for combi controller AC0 with electrical steer 1.12 MB 02/13/2025
Service tool to update Combi AC0 ONLY ON TRUCK WITH ELECTRIC STEERING. THIS WILL AUTOMATICALLY UPDATE Combi 1.59 On pedestrian stacker this new release, will manage SPED Bumper Switch option
Automatic update for Integrated EPS rev 1.70.zip Automatic update for EPS integrated steering 590.58 kB 04/26/2022
Service tool to update the Integrated steering on electrical steering truck, rev. 1.70
Controllers
4169730R10.zip Control Software Master Combi Controller AC0 Mech. Steer. 183.33 kB 02/12/2025
4223064R8.zip Control Software Master Combi Controller AC0 Ped. Electric Steer. 185.27 kB 02/12/2025
4170214R10.zip Control Software Master Combi Controller ACX 182.16 kB 02/12/2025
4169731R10.zip Control Software Slave Combi Controller AC0 Mech. Steer 83.70 kB 02/12/2025
4223065R8.zip Control Software Slave Combi Controller AC0 Ped. Electric Steer. 83.90 kB 02/12/2025
4170215R10.zip Control Software Slave Combi Controller ACX 83.60 kB 02/12/2025
Automatic update for Combi AC0 Mechanical steer rev. 1.59.zip Automatic update for combi controller AC0 mechanical steering 1.11 MB 02/13/2025
Service tool to update Combi AC0 ONLY ON TRUCK WITH MECHANICAL STEER, THIS WILL AUTOMATICALLY UPDATE Combi 1.59 On pedestrian stacker this new release, will manage SPED Bumper Switch option
4215940R4.zip Control Software Master Steering Motor 137.81 kB 05/14/2019
4215941R4.zip Control Software Slave Steering Motor 127.38 kB 05/14/2019
Vehicle
Controllers
Platform Pallet Truck rev 06.zip Truck Project File 10.6 MB 03/10/2025
This file it is mandatory to install on laptop, to connect Curtis Integrated tool to the truck. Rev 06, Fix a bug with acceleration when battery is below 50; made available parameter: Traction Manager -> HS/LS Multiplier -> Neutral Decel HS to LS, to adjust braking power in pedestrian mode; correct the alarm logbook time unit.
Bridge Project File.zip Truck project file bridge 5.42 MB 07/04/2024
This file is mandatory to be loaded, BEFORE upgrade trucks with Project file Rev 05
4112035R4.zip Control Software Pump COMBI AC1 52.48 kB 02/04/2016
4128020R2.zip Control Software Pump COMBI AC1 7T 52.49 kB 02/04/2016
4112034R3.zip Control Software Traction COMBI AC1 67.56 kB 02/04/2016
4128019R2.zip Control Software Traction COMBI AC1 7T 67.57 kB 02/04/2016
4183978R8.zip Control Software Pump COMBI AC1 LLOP 51.97 kB 02/23/2021
4184319R8.zip Control Software Pump COMBI AC1 Tractor 7T 51.97 kB 02/23/2021
Controllers
Upgrader for Order Picker and Tow Tractor 5 Ton with FB potentiometer.zip automatic upgrader for combi and EPS controller, only for Order Picker and Tow Tractor 5T with FB potentiometer 557.21 kB 12/19/2018
For serial number compatibility and instructions, please, check service Bulletin / Gram LD075 – Combi software 1,69 and EPS 1.40
Upgrader for Tow Tractor 7 Ton with FB potentiometer.zip automatic upgrader for combi and EPS controller, only for Tow Tractor 7T with FB potentiometer 556.53 kB 12/19/2018
For serial number compatibility and instructions, please, check service Bulletin / Gram LD075 – Combi software NA7 1,69 and EPS 1.40
Upgrader for Tow Tractor 7 Ton with FB potentiometer (1).zip automatic upgrader for combi controller, only for Tow Tractor 7T with FB encoder 464.95 kB 11/04/2024
Update to Combi version 1.96
Automatic upgrader for Combi 1.96 on Standard LLOP and 5T Tow Tractor, with FB Encoder.zip Automatic upgrader for combi, only for Order Picker and Tow Tractor 5T with FB encoder 854.39 kB 11/04/2024
Automatic Upgrade for EPS rev 7.49, only with FB encoder.zip Service tool to update Double encoder EPS 951.94 kB 10/21/2022
Service Tool to update double FB Encoder EPS to version 7.49
4183977R8.zip Control Software Traction COMBI AC1 LLOP 85.42 kB 02/23/2021
4184318R8.zip Control Software Traction COMBI AC1 Tractor 7T 85.42 kB 02/23/2021
Vehicle >> Display
Engine >> GM 4.3L & 2.4L Teleflex GFI Fuel system
S3000 Flash Wizard Installation Instructions (Y).pdf S3000 Flash Wizard Installation Instructions 82.96 kB 10/25/2006
S3000.zip S3000 Flash Wizard Reprogramming Tool for GM 4.3L and 2.4L Engine Controllers 5.51 MB 04/10/2013
Engine >> Mazda 2.0L & 2.2L Aisan – GM Impco
PSI Display Software (build date 2-15-07).zip Display Software – PSI (Mazda/Aisan/GM Impco) (Build Date 2-15-07) 5.99 MB 03/06/2007
GCP Display Software (build date 3-13-12).zip GCP Display Impco fuel systems – GM & Mazda Engines 7.11 MB 04/09/2015
GCP Display Software (build date 3-13-12).zip — Enhanced recording features using .bplt files
FPI180002.zip FPI180002 8.29 MB 06/29/2018
Engine >> GM 2.4L Engine Controller Calibration Files
8806456R0.ZIP 2.4L Gasoline (2010) 181.49 kB 03/14/2011
GM 2.4L 2010 Injector Conversion.zip GM 2.4L 2010 injector conversion 172.61 kB 07/26/2017
G4-88_2.4_20070822.3_Gas_VH_2007a.zip GM 2.4L Gasoline (2007) 173.20 kB 08/07/2018
GFI 2-4 2006.1212 Gas.zip GM 2.4L Gasoline TeleFlex GFI 172.92 kB 01/11/2007
8806457R0.ZIP GM 2.4L LPG (2010) 180.99 kB 03/14/2011
GFI 2-4 2006.1212 LPG.zip GM 2.4L LPG TeleFlex GFI 172.31 kB 01/11/2007
Engine >> Mazda
IMPCO EPR FLASH REV-C.zip EPR Update to Rev C 5.27 MB 07/21/2009
IMPCO EPR FLASH REV-C (1).zip EPR Update to Rev C 5.27 MB 07/21/2009
Engine >> Mazda 2.0L Engine Controller Calibration Files
1528002E.zip 2.0L Gasoline (Rev E) 154.10 kB 03/27/2006
E1528020K_2.0LPG_2-3T.zip Mazda 2.0L LPG (Rev K) 503.56 kB 10/25/2011
Engine >> Mazda 2.2L Engine Controller Calibration Files
E1528000K_2.2LPG_2-3T.zip Mazda 2.2L LPG (Rev K) 503.56 kB 10/25/2011
Vehicle >> Display
DISPLAYAP0303.hex Display Application Code (V3.03) 74.91 kB 04/16/2012
8848368R0 (1).zip Display Application Code V4.02 — ONLY for New (ST32) Internal processor type 470.01 kB 10/21/2020
IMPORTANT — this software / code is for New (ST32) Internal processor type Displays ONLY. Factory installed Base Code V4.00 is revised to V4.02, to Fix “Stuck Button” bug in ST32 Internal Processor type displays.
Vehicle >> VSM
VSM269DP0216.hex VSM Application Code (SN =>A910V04412C, Excluding A910V04362-A910V04364C and A910V04372-A910V04375C) Version 2.16 508.88 kB 02/04/2006
8861995R0.zip VSM Application File (V5.92) 580.14 kB 08/13/2024
V5.92 Includes fixes for: L1/L2 transmission, Prevents truck abrupt forward movement when Operator Present System (OPS) is not satisfied. Increases OPS long timer condition from Accelerator Pedal Position (APP) >1% to >4%.
OptionalStrings0570.hex VSM Language Code (V5.70) 19.28 kB 10/01/2015
Reprogramming Mazda LPG ECUs (New rev mot files).pdf Reprogramming Mazda LPG ECUs (New rev mot files) 1.21 MB 10/25/2011
GM 2.4 LPG (2010) Certified.ZIP GM 2.4 LPG (2010) Certified TeleFlex GFI 180.99 kB 08/07/2018
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
8848228.zip 4G Display Software – PSI, Kubota (LPG) & Mazda (Impco) Engines 177.5 MB 01/20/2021
2280662B.zip 2.0L LPG (Rev B) 1.01 MB 06/08/2010
Vehicle >> Display
BSTDISP0330.zip Display Application Code (V3.30) 70.41 kB 02/07/2017
Engine >> GM 3.0L Engine Controller Calibration Files
ECM_Programming_Instructions.zip GM ECM Programming Instructions 121.34 kB 01/12/2005
Engine >> GM 4.3L Engine Controller Calibration Files
0925701G.zip GM 4.3L LPG (Rev G) 461.50 kB 08/07/2018
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Reprogramming Mazda LPG ECUs (Rev H).pdf Mazda ECU Reprogramming Instructions (Rev H) 1.12 MB 10/04/2006
Engine >> Mazda
E1528021J_2.0LPG_1-2T.zip Mazda 2.0L LPG (Rev J) 156.31 kB 10/25/2011
Vehicle >> Display
Vehicle >> VSM
Transmission >> Dana TE Series
8843818R2.zip Dashboard v3.8.12.0 Diagnostic Software 98.4 MB 11/01/2022
DashboardInstallationGuide – EN.pdf Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
also contains prerequisites conditions for successfully installing!
GM 4.3L 2010 Injector Conversion.zip GM 4.3L 2010 Injector Conversion 172.08 kB 07/26/2017
G4-100_4.3_20071214.5_GAS_2008_VH.zip GM 4.3L Gasoline (2008) 177.02 kB 02/04/2009
8806453R0.ZIP GM 4.3L Gasoline (2010) 181.79 kB 03/14/2011
GFI_86_4-3_LPG.zip GM 4.3L LPG (2006/2007) TeleFlex GFI 276.31 kB 10/17/2006
G4-97_4.3_20090115.6_LPG_2009_VH.zip GM 4.3L LPG (2008/2009) TeleFlex GFI 174.96 kB 03/03/2009
8806454R0.ZIP GM 4.3L LPG (2010) 180.32 kB 03/14/2011
Vehicle >> Display
Vehicle >> VSM
DashboardInstallationGuide – EN.pdf Dashboard v3.8.12.0 Diagnostic Software 98.4 MB 11/01/2022
8843818R2.zip Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
GM 4.3 LPG (2010) Certified.ZIP GM 4.3 LPG (2010) Certified TeleFlex GFI 180.32 kB 07/04/2011
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
8861995R0 (1).zip VSM Application File (V5.92) 580.14 kB 08/13/2024
Vehicle >> Display
Vehicle >> VSM
Vehicle Operating Software – NON Serial Number Specific
GM 4.3 LPG (2010) Non-certified.ZIP GM 4.3 LPG (2010) Non-certified TeleFlex GFI 180.34 kB 07/04/2011
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
8862897R0.zip 2.8 inch Display Application Code – ICE 10.0 – ( 4.0.438.013 ) 31.6 MB 12/17/2024
Display Application Code ICE 10.0 – ( Compatible / Use with VSM Application Code ICE 10.0 and up) HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
81015943R0 Display 5in.zip 5 inch Display Application Code – ICE 10.03 – ( 4.0.438.021 ) 44.9 MB 01/23/2025
Display Application Code ICE 10.03 – ( Compatible / Use with VSM Application Code – ICE10.02.01 ( v04.043.889.204 ) & onward ) HYZ file is for use with Field Prog v2.40 and greater and will program via CAN or USB by user choice.
8862718R0.zip 7 inch Display Application Code – ICE 10.0 – ( 4.0.438.006 ) 41.5 MB 07/25/2024
Display Application Code ICE 10.0 – ( Compatible / Use with VSM Application Code ICE 10.0 ( v04.043.889.148 & onward ) HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
Vehicle >> VSM
81008374R0.zip VSM Application Code – ICE10.02.01 ( v04.043.889.204 ) 1.37 MB 12/16/2024
Vehicle >> Display
81024501R0.zip 2.8 inch Display Application Code – ICE 10.1 – (V4.0.636.020) 30.5 MB 05/29/2025
Display Application Code ICE 10.1 – ( Compatible / Use with VSM Application Code ICE 10.01 (V04.044.438.227) and onward HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
81024502R0.zip 5 inch Display Application Code – ICE 10.1 – (V4.0.636.018) 45.4 MB 05/30/2025
Display Application Code ICE 10.1 – ( Compatible / Use with VSM Application Code – ICE10.1 (V04.044.438.227) & onward HYZ file is for use with Field Prog v2.40 and greater and will program via CAN or USB by user choice
81024503R0.zip 7 inch Display Application Code – ICE 10.1 – (V4.0.636.018) 45.4 MB 05/30/2025
Display Application Code ICE 10.01 – (Compatible / Use with VSM Application Code ICE 10.1 (V04.044.438.227 & onward HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
Vehicle >> VSM
V04.044.438.227.zip VSM Application Code – ICE10.1 ( v04.044.438.227) 1.34 MB 05/30/2025
0529801F.zip GM 3.0L LPG (Rev F) 459.02 kB 02/16/2005
0728801D.zip GM 3.0L Gasoline (Rev D) 459.02 kB 02/16/2005
0728801D.zip
0528801F.zip GM 3.0L LPG (Rev F) 459.02 kB 02/16/2005
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
kubotaenginereprog R2.pdf Kubota Engine Reprogramming PDF R2 537.12 kB 02/25/2016
550078022R2.zip Yale Kubota 3.8l Engine Reprogramming Tool 2.03 MB 02/25/2016
Adds the ability to program Kubota ACUs using the IFAK, and ECU programming. Programming Tool automatically detects file for ACU or ECU programming
Operator Display >> DPF Display
8811211R0.zip DPF Display Reprogramming Tool 946.95 kB 09/12/2014
8841792R0 1.zip DPF Display Software – Factory Version 361.37 kB 12/06/2023
8859491R0 DPF Display Software – with active regen inhibited 213.03 kB 12/06/2023
DPF Display Software – with active regen inhibited – intended for low duty applications
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
8859491R0.zip DPF Display Software – with active regen inhibited 213.03 kB 12/06/2023
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
8841792R0.zip DPF Display Software 11.01 361.37 kB 01/13/2020
DPF Display Software v11.01 updates the DPF Display reference Euro Stage-V Engines. v11.01 is backward compatible with older versions of DPF Display but requires truck/VSM Application Software v5.82 or higher, for use with Euro Stage-V engines.
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
EH108-69957.zip EH108-69957 2.65 MB 03/13/2017
Kubota 3.8 LPG w/Mechanical Cooling Fan
EH128-69956.zip EH128-69956 2.65 MB 03/13/2017
Kubota 3.8 LPG w/Hydraulic Cooling Fan
EH165-69953.zip EH165-69953 2.65 MB 03/13/2017
Kubota 3.8 Bi-Fuel(LPG & Gasoline)
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Engine >> Kubota
DashboardInsallationGuide – EN.pdf Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
also contatins prerequisites conditions for successfully installing!
Vehicle >> Display
Vehicle >> VSM
8848228.zip 4G Display Software – PSI, Kubota (LPG) & Mazda (Impco) Engines 177.5 MB 01/20/2021s
Controllers
4288786R0.zip Software Update Package 6.71 MB 06/12/2020
This kit will allow dealers to switch control settings in the hydraulic service tool
Hydraulic >> Danfoss
8820284R5.zip Danfoss Hydraulic Controller diagnostic software base packet 212.6 MB 03/04/2020
Install both base (8820284) and update (8820285) package.
8820285R6.zip Danfoss Hydraulic Controller diagnostic software update packet 20.3 MB 03/04/2020
8830112v25.zip Telemetry System Validation Software Tool V2.5 5.10 MB 09/12/2017
Transmission >> ZF Ergo Power Series
1_ZF-Testman-HYG-edition-Installation-help.pdf 1 Hyster-Yale Testman installation help 1.02 MB 09/15/2022
Help file for license registration / installation / laptop hardware or operating system replacement
2_ZF-TESTMAN-BaseInstall_06.2021.zip 2 Testman Diagnostic Software – Base Installation 06.2021 424.1 MB 02/06/2025
ZF-Testman Hyster-Yale Group Edition. – Testman requires individual license registration. – Read installation help before starting!
3_Application_Help_Ergopower_M_HYG_EN.pdf 3 HYG ZF-Testman Project related help for users 6.71 MB 09/15/2022
Read through this help file for using Testman with HYG Trucks, it explains the all the ZF-Testman functions. The most recent version of this document is within Testman via websync, it can be opened from Testman: after user terms are accepted, use help menu: open project related help or use Alt-F1 key combination.
8861234R0.zip HYPro v3.2.7 – programming tool 19.1 MB 04/04/2024
81029932R0.zip Primary Display Application Software 14.5 MB 06/04/2025
04-06-2025 – New Release of the primary display application software to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
81030165R0.zip VSM uc1 Application Software 818.61 kB 06/04/2025
04-06-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and VSM uc3 are updated at the same time!
81027489R0.zip VSM uc2 Application Software 42.66 kB 06/04/2025
04-06-2025 – Release of VSM uc2 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
81027490R0.zip VSM uc3 Application Software 39.44 kB 06/04/2025
04-06-2025 – Release of VSM uc3 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
HMC2.4L Woodward fuel system- Toolkit Download.pdf Hyundai Engine – Woodward Toolkit Download Instruction 1.65 MB 02/20/2023
ToolKit is used to create and run custom administration tools for many Woodward electronic products.
MI21_Main_02101_010.zip Hyundai Engine – Woodward Toolkit Software 1.22 MB 02/21/2023
MI21_Main_02101_010.wtool
LS Engine – ECU Programming Guide.zip LS Engine – ECU Programming Guide 1.25 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623A_K_R02.zip LS Engine – ECU Software for new EGR and dry brake 1.29 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623A_K_R02.ulp
0ULSMAPP_C222D11_MXFL5623B_K_R02.zip LS Engine – ECU Software for new EGR and wet brake 1.29 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623B_K_R02.ulp
0ULSMAPP_C222D11_MXFL5623A_R06.zip LS Engine – ECU Software for old EGR 1.29 MB 04/09/2024
0ULSMAPP_C222D11_MXFL5623A_R06.ulp
Engine >> Kubota
8862725R0.zip Diagnostic Software – Kubota V3800 237.8 MB 09/09/2024
Diagmaster is diagnostic software for Kubota Diesel Engine
8862726R0.zip Diagnostic Software – Kubota WG3800 335.8 MB 09/09/2024
KGST is diagnostic software for Kubota LP Gas Engine
Engine >> Kubota
Engine >> Kubota
Engine >> Kubota
0729801D.zip GM 3.0L Gasoline (Rev D) 256.3 MB 10/09/2018
ljlj
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Controllers >> Control Software
Vehicle >> Display
Vehicle >> Display
BSTDISP0220.zip Display Application Code (V2.20) 53.79 kB 08/27/2012
4_DE_EN_6008_758_704.pdf 4_DE_EN_6008_758_704.pdf 1.57 MB 01/16/2018
ZF-Testman base platform Operating instructions, use for reference only.
Controllers >> HVAC
HysterHVACV4.zip Hyster HVAC Update Package 1.56 MB 06/20/2023
26-06-2023 – RS – Uploaded Hyster HVAC Update Package
PEAK-SystemDriverSetup.zip PEAK System Driver Setup 136.2 MB 06/26/2023
26-06-2023 – RS – PEAK System Driver Setup
Vehicle >> Display
Vehicle >> Display V4
81041305R0.zip Primary Display Application Software 14.5 MB 07/23/2025
23-07-2025 – New Release of the primary display application software to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
Vehicle >> VSM HW P/N 8818581 V4
81027519R0.zip VSM uc1 Application Software 560.21 kB 05/22/2025
22-05-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
4331653R0.zip VSM uc2 Application Software 48.76 kB 09/20/2021
01-02-2024 – Release of VSM uc2 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
4374734R0.zip VSM uc3 Application Software 37.75 kB 09/15/2023
01-02-2024 – Release of VSM uc3 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
Communication Cable >> IFAK Driver
1595698R8.-161194.zip IFAK Cable Upgrade V6.2.1 6.86 MB 08/23/2022
Controllers >> HVAC
Vehicle >> Display
Vehicle >> VSM
1595698R8.-161194.zip IFAK Cable driver V6.2.1 6.86 MB 08/23/2022
SPED >> M&H Soot Filter
Sped ECUDiagnose v1_2_3_77.zip SPED M+H Diesel Particulate Filter Diagnostic Software 1.03 MB 10/04/2010
GM 2.4 LPG (2010) Non-certified.ZIP GM 2.4 LPG (2010) Non-certified TeleFlex GFI 181.00 kB 07/04/2011
8824222R0.zip Mazda 2.0L LPG (Impco) 689.77 kB 02/04/2016
Reference LD063 R00 – Corrects electronic fuel injection learning symptom, ( ~1600rpm at maximum accelerator pedal ).
8824223R0.zip Mazda 2.2L LPG (Impco) 680.42 kB 12/06/2019
Vehicle >> Display
Vehicle >> VSM
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
8818288R0.pdf Install Instructions – Node Patch for Windows 7 (Readme) 57.97 kB 03/19/2014
8818288R0 (1).pdf Install Instructions, Node Patch for Windows 7 (Readme) 57.97 kB 03/19/2014
524323291R0.zip Node Diagnostic Software 13.2 MB 10/17/2008
8818288R0.zip Node Patch for Windows 7 1.41 MB 03/19/2014
This Patch program allows the use of Parker Node V4.2 Diagnostic software with Windows 7, 32-bit or 64-bit operating systems.
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> Display
Smart Assist Instructions – OEM Update2.pdf Yanmar Smart Assist Direct (SA-D) download and installation instructions.pdf 459.27 kB 05/20/2025
.pdf contains the Yanmar Smart Assist Direct (SA-D) download and installation instructions
81041646R0.zip Field Prog (2.45.5) 19.9 MB 07/22/2025
•Adds support for AN Standard/Value programming (C3C1/C7S1) •Updates SN verification to allow programming if CDF transfer fails previously •Option to bypass SN verification for some HYZ files •Fixed issue with missing libraries when installing tool -User message operation issue corrected
HYG_SA-D Tool Requestnew.pdf HYG_SA-D Tool Request.pdf 209.75 kB 11/02/2022
PDF document contains semi-populated E-main link to request Yanmar SA-D Tool License for single technician.
Vehicle >> Display
Vehicle >> VSM
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
kubota reprogramming tool.zip Kubota 2.4 Engine Reprogramming Tool 88.3 MB 02/14/2017
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
Controller Firmware Chart R4.pdf Dashboard Controller Firmware Chart R4 (Readme) 28.63 kB 12/22/2014
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> PSI
8813538R4.zip Euro – PSI 2.0L LPG 2.59 MB 01/18/2017
For Euro PSI 2.0L LPG – improved engine speed control response. 8813538R4.zip contains 38901176-5.mot
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Engine >> PSI
8813543R4.zip Euro – PSI 2.4L LPG 2.59 MB 01/18/2017
For Euro PSI 2.4L LPG – improved engine speed control response. (8813543R4.zip contains 38901177-5.mot)
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
1595698R8.-161194 (1).zip IFAK Cable Upgrade V6.2.1 6.86 MB 08/23/2022
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Vehicle >> Display
Vehicle >> VSM
8806453R0 (1).ZIP GM 4.3L LPG (2006/2007) TeleFlex GFI 276.31 kB 10/17/2006
GFI_86_4-3_LPG.zip GM 4.3L LPG (2008/2009) TeleFlex GFI 174.96 kB 03/03/2009
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Vehicle – Programming Interface Software Tool
81041646R0.zip Field Prog (v2.45.5) 19.9 MB 07/22/2025
Field Prog version 2.45.5 User message operation issue corrected • Adds support for programming (C3C1/C7S1) series trucks • Updates Serial number verification to allow programming if CDF transfer fails previously • Fixed issue with missing libraries when installing tool.
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
0922701G.zip GM 4.3L LPG (Rev G) 461.50 kB 02/16/2005
Yale – Yanmar SA-D Tool – Request.pdf Yale – Yanmar SA-D Tool Licence – Request.pdf 119.52 kB 03/29/2022
PDF document contains semi-populated E-mail link to request Yanmar SA-D Tool Licence, per Technician.
FieldProg Install and Use Guide v2.42.pdf Field Prog Install and Use Guide v2.42 660.90 kB 08/17/2023
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
IFAK Cable Upgrade V5.3.ZIP IFAK Cable Upgrade V5.3 14.5 MB 07/01/2013
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
This thread is to introduce a 2025 collection of Yale forklift controller flash files (.HEX) intended for professional diagnostic, programming, and controller replacement work.
If you need compatibility confirmation or have technical questions, feel free to reply or contact me directly.
*** Contact us to get a more details: admin@autorepairmanuals.ws or gallons@autorepairmanuals.ws ***
Service Installation
Service check program
Service fix error program
Service Remote Installation
By Teamview, Anydesk, Ultraview
---- Detail Description ----
Communication Cable
Nuvera IFAK Driver.zip Nuvera IFAK Driver 14.3 MB 02/22/2019
IFAK Driver required for Nuvera Fuel Cell communication with Nuvera Service GUI.
Controllers
Nuvera VSM Programming Tool and Instructions V3_4.zip Nuvera VSM Programming Tool and Instructions V3_4.zip 914.71 kB 12/09/2019
Compatible with Block 2 BBRs only. Please follow instructions located within the file for programming.
Nuvera 36V Version 4.5.0 VSM Software Package.zip Nuvera 36V Version 4.5.0 VSM Software Package.zip 3.38 MB 09/23/2020
Nuvera 36V Version 4.5.0 VSM Software Package 3.00 MB 9/23/2020 Class 1 and Class 2 systems 36V VSM hex code Version 4.5.0. Also included is a revised DTC list and Troubleshooting. Not compatible with Block 1 COP units. Please use VSM install procedure. MD5 Checksum Value for download package (zip file): DB7EE0F7529B7560370E8AF9549AC1DB, MD5 Checksum for PELEC2V36S16P3_µC1_4.5.0.hex file: 9293EB458C17C92D8776119593E02B20
Nuvera 48V Version 4.5.0 VSM Software Package.zip Nuvera 48V Version 4.5.0 VSM Software Package.zip 3.38 MB 09/23/2020
Nuvera 48V Version 4.5.0 VSM Software Package 3.00 MB 9/23/2020 Class 1 and Class 2 systems 48V VSM hex code Version 4.5.0. Also included is a revised DTC list and Troubleshooting. Not compatible with Block 1 COP units. Please use VSM install procedure. MD5 Checksum Value for download package (zip file): CA9B9FEFD938E3B22D817DC13E50129D, MD5 Checksum for PELEC1V48S24P2_µC1_4.5.0.hex file: 6F72938CC82F5FC03F5A037752F9B138
Controllers >> Master Controller Software
Nuveras Software L2835.zip Nuveras Software L2835 646.17 kB 08/11/2022
Vehicle >> Display
8851132R0.zip Display Software Code (V4.43) 466.12 kB 11/16/2021
America’s 11/16/21 – B. Crowell – Release of V4.43 Software 08/June/21 – R Drysdale – Added Hyster Unit code A250 & Yale Unit code A410 7/10/2020 – Display counterpart software w/VSM 4.42, adds SPED Maintenance Lift Lockout support.
Vehicle >> VSM
8858193R0.zip VSM Software Code (V4.58) 275.47 kB 09/20/2023
9/20/23 – V4.58 Software Release, Added support for new VSM Hardware, changes for EN1175 Compliance, resolve issues with reverse hyd control. 11/16/21 – V4.43 Software release 7/10/20 – V4.42 Software released, Added SPED Maintenance Lift Lockout
Vehicle >> Display
8851132R0.zip Display Application Code (V4.43) 466.12 kB 11/16/2021
ER Display Software v4.43 – Allows for SPED Option for Unclamp Doubletap feature
Vehicle >> VSM
8860371R0.zip VSM Application Code (V4.60) 277.21 kB 03/05/2025
05/March/25 V4.60 Software release. Please update to Display Application Code (V4.43) with VSM V4.60.
Communication Cable
81013600R0.zip Intelligent Battery Management System v3.0.7 32.8 MB 02/18/2025
This software is for diagnosing lithium-ion battery.
81010425R0.zip USB-CAN Tool Software 960.67 kB 02/17/2025
This is the driver for GCAN USBCAN-II Pro Analyzer.
Vehicle
81010426R1.zip CACTI Charger Display Language Package for HY 48-115V Lithium Battery 26.3 MB 03/30/2025
For downloading different language package for the display.
81010971R1.zip Configuration Software for FGCD Charge & Discharge Tool 15.4 MB 03/30/2025
For use with HY Lithium Battery.
Communication Cable
Vehicle
Communication Cable
Vehicle
Communication Cable
81013599R0.zip PICkit 3 Tool Software 111.2 MB 02/18/2025
This software is for transferring hex file to CACTI HWCD18 Lithium Battery Charger.
Vehicle
81013593R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V100A (CE only) 1.02 MB 02/17/2025
For use with PICkit 3 programmer to set the percentage state of charge (SOC) for charging lithium battery.
81013594R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V150A (CE only) 1.02 MB 02/17/2025
81013595R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V200A (LM Power Module) (CE only) 1.02 MB 02/18/2025
81013596R0.zip CACTI Charger Control Panel Firmware – HWCD18-48V200A (Non-LM Power Module)(CE only) 1.02 MB 02/18/2025
81013597R0.zip CACTI Charger Control Panel Firmware – HWCD18-80V150A (CE only) 1.02 MB 02/18/2025
81013598R0.zip CACTI Charger Control Panel Firmware – HWCD18-80V200A (CE only) 1.02 MB 02/18/2025
Communication Cable
Vehicle
Communication Cable
Vehicle
Communication Cable
Vehicle
Vehicle
524146551R4.pdf Instructions – Smartset / GE Sentry / Dash Software (Release 5) 18.44 kB 06/02/2008
524146551R4.ZIP Smartset / GE Sentry / Dash Software (Release 5) 50.3 MB 06/03/2008
Controllers >> ETACC
550027876R11 instructions.pdf ETACC 2.4K Instructions (Update Only- Must Have Program 2.4J Installed prior to installation) 445.50 kB 01/28/2013
550027876R13.zip ETACC 2.4N (Update Only- Must Have Program 2.4K Installed prior to installation) 6.00 MB 08/09/2022
524283948R4.ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
ETACC Yale Instructions 4.pdf ETACC Program 2.4J Installation Instructions – “Version 2.4 J is sometimes referred to as version 2.42.” 1.12 MB 10/01/2012
550037243R0.zip Control Upgrade Software- Master Control- C36 (Revision 0) 518.54 kB 05/23/2011
550037243R0.pdf Control Upgrade Software- Master Control- C36 (Revision 0) Installation Instructions 203.23 kB 05/23/2011
Controllers >> Traction Controller Software
550037243R0.pdf Controller Upgrade Software – Traction – 72/80V 225.25 kB 08/01/2011
550040273R0.zip Controller Upgrade Software – Traction – 36/48V 225.10 kB 08/01/2011
550040273R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/48V 242.14 kB 08/01/2011
524283948r4.ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
550041199R0.zip Controller Upgrade Software – Traction –D216 2-3DBB & A908 2/3CBB 72/80V 225.25 kB 08/01/2011
550041199R0.pdf Controller Upgrade Software Installation Instructions – Traction –D216 2-3DBB & A908 2/3CBB 72/80V 242.03 kB 08/01/2011
Controllers >> Service Software Upgrade
8830603r0.zip C03 Control Software GEN6 Programming Tool 23.6 MB 09/20/2017
NOTE: GEN6 CONTROLLERS ONLY. DO NOT USE ON EARLIER VERSION CONTROLLERS. GEN6 controllers went into production in Oct. 2014. The GEN6 controllers are physically smaller than the previous versions and are light gray in color. Previous version controllers in this series truck were black.
Kollmorgandrivefilepusher.zip Danaher C25 File Pusher – (kollmorgandrivefilepusher.zip) 1.28 MB 04/28/2014
Drive Upgrade Tool- Traction & Pump Controller (C20) must be installed on the computer before the Danaher C25 File Pusher is downloaded and executed. The C25 File Pusher Updates the Drive Upgrade Tool.
550035435R2.zip Drive Upgrade Tool- Traction & Pump Controller (C20) 23.8 MB 09/07/2012
550035435R2.pdf Drive Upgrade Tool- Traction & Pump Controller Installation Instructions (C20) 2.51 MB 09/07/2012
Vehicle >> Display
Vehicle >> VSM
Operator Display >> Instrument cluster
8841494R1.zip HyPro Programming Tool v2.00 w/drivers 19.0 MB 07/03/2019
HyPro Programming Tool v2.00 for updating software on NCEA displays, such as used on End Riders & New Reach vehicles along with Class I Greensight VSMs. NOTE: Please review associated install & use guides. -Updated to include Drivers.
8858162R0.zip Field Prog (v2.42) 19.5 MB 06/16/2023
Field Prog version 2.42
8861234R0.zip HYpro v3.2.7 – programming tool 19.1 MB 04/04/2024
Updated HYpro from v3.2 to v3.2.7 — contains a critical update
8847774R0.zip Greensight VSM Firmware 247.21 kB 07/20/2020
Initial release of Firmware for Greensight Controller, to be used with Hypro.
Vehicle >> OAS display
8861917R0.zip OAS 7″ Display Software v1.3.6 35.5 MB 02/04/2025
2/5/2025: HST (Initial release) Change notes: Compatible with OAS version 1.35.XX and 1.36.XX, added font scaling based on string length, resolved issue where version info wasn’t always populated, added fault code 8206 “CDF Serial Number Does Not Match Expected Value”
Controllers >> AC Motor Controller
8823586R0.pdf Zapi FOC 2 Motor Controller Software Upgrader Instructions 368.66 kB 03/18/2016
FOC 2 – Field Orientated Control 2
8827248R0.zip ZAPI FOC 2 Motor Controller Software Upgrader version 1.12- FOC 2 Controller 8820249 1.01 MB 01/11/2017
NOTE: NOT ALL TRUCKS ARE FOC 2! (Field Orientated Control 2). Verify traction controller P/N is 8820249 (As seen on label) and the software version is 1.07 or higher BEFORE loading the FOC 2 software in the motor controllers! Please Contact RSE / PSG if unsure!
550097391r0.zip Zapi FOC Motor Controller Software Upgrader – FOC Traction 8809255 – FOC Pump 8810847 440.65 kB 01/24/2014
NOTE: NOT ALL TRUCKS ARE FOC! (Field Orientated Control). Verify traction controller P/N is 8809255 and the software version is 122 and the pump controller is P/N 8810847 and the software version is 115 BEFORE loading the FOC software in the motor controllers.
550097391R0.pdf Zapi FOC Motor Controller Software Upgrader Instructions 151.99 kB 01/24/2014
FOC – Field Orientated Control
550017122R1.pdf Zapi Motor Controller Software Instructions 166.85 kB 08/22/2011
550017122R1.zip Zapi Motor Controller Software Upgrader- (Rev. 1) – VFC only 427.53 kB 08/22/2011
8839093R1.zip ZAPI Motor Controller Software V1.17 871.69 kB 05/20/2020
v1.17 – Software supports the new Motor Thermal Sensor
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Controllers >> OAS controller
8861918R0.zip OAS Controller Software v1.35.54 482.10 kB 02/04/2025
2/4/2025-HST (Initial release) Change notes: Now requires OAS Serialized CDFs and generic OAS v35 software HYZ and OAS Display HYZ, optimized Object Detection (OD) algorithm, adjusted slowdown algorithm for Proximity Detection (PD), new DTCs for OD sensors, refined fault timer for OD, speed change rate adjustments.
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
8861234R0.zip HyPro Programming Tool v2.00 w/drivers 19.0 MB 07/03/2019
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
SPED
S01833210060.pdf GTC AlgoBMS Installation & User Guide 3.61 MB 09/03/2021
SPED – GTC AlgoBMS Installation & User Guide . pdf —- For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210010 – Firmware File .zip SPED – GCT AlgoBMS – Firmware File 306.79 kB 09/10/2021
Firmware File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210020 – Master Config File .zip SPED – GCT AlgoBMS – Master Configuration File 1.17 kB 09/10/2021
Master Configuration File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210030 – Slave Config File .zip SPED – GCT AlgoBMS – Slave Configuration File 1.16 kB 09/10/2021
Slave Configuration File – For use with SPED – GCT, Green Cubes Technology Integrated Li-Ion Battery Trucks within the 2-3.5T Electric Rider series.
S01833210040 – Programming Application.zip SPED – GCT AlgoBMS Diagnostic & Programming Software / Application 28.4 MB 09/10/2021
Vehicle >> Display
Vehicle >> VSM
SPED
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Spreader >> ELME
8859584R1.zip Diagnostic Software – ELME Neuron Controller 1.37 MB 05/15/2024
01-02-2024 – This is the diagnostic software for the ELME Neuron CAN-bus controller, to be used on truck series B3C0 (Stage V/ GBIV) and truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), J008E02500 (Stage V), J008E02500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
HyPro Install and Use Guide-EN.pdf HyPro Installation and Use Guide 664.95 kB 08/17/2023
Vehicle >> Display
4376521R0.zip Camera Display Application Software 9.36 MB 09/29/2023
29-09-2023 – Camera display application software, to be used with HyPro tool
Vehicle >> Display V5
81020722R0.zip Primary Display Application Software 14.4 MB 03/06/2025
06-03-2025 – New Release of the primary display application software to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
Vehicle >> VSM HW P/N 8844446 V5
81025389R0.zip VSM uc1 Application Software 792.58 kB 04/25/2025
25-04-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and VSM uc3 are updated at the same time!
81015029R0.zip VSM uc2 Application Software 42.48 kB 03/06/2025
06-03-2025 – Release of VSM uc2 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
81003855R0.zip VSM uc3 Application Software 39.36 kB 11/03/2024
06-03-2025 – Release of VSM uc3 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
Spreader >> ELME
Vehicle >> Display
Vehicle
Vehicle >> Diagnostic & Programming
Nuvera FCST v4.31.20.zip Nuvera FCST v4.31.20 279.8 MB 06/07/2022
Vehicle >> VSM
Nuvera B2D1 VSM Software 4.22.18.zip Nuvera B2D1 VSM Software 4.22.18 1.01 MB 06/07/2022
550041197R0.zip Controller Upgrade Software – Traction – 36/48V 224.95 kB 08/01/2011
550041197R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/48V 242.26 kB 08/01/2011
550041197R0.zip Controller Upgrade Software – Traction –B814/C814- 1-2CBB -48V 224.95 kB 08/01/2011
550041197R0.pdf Controller Upgrade Software Installation Instructions – Traction – B814/C814- 1-2CBB -48V 242.26 kB 08/01/2011
550041198R0.zip Controller Upgrade Software – Traction – 36/ 48V 225.26 kB 08/01/2011
550041201R1.zip Controller Upgrade Software – Traction –B839/C839 4-5CBB 80V 225.06 kB 05/29/2012
550041198R0.pdf Controller Upgrade Software Installation Instructions – Traction – 36/ 48V 242.53 kB 08/01/2011
550041201R1.pdf Controller Upgrade Software Installation Instructions – Traction –B839/C839 4-5CBB 80V 241.77 kB 05/29/2012
550041198R0.zip Controller Upgrade Software – Traction –B839/ C839 4-5CBB 48V 225.26 kB 08/01/2011
550041198R0.pdf Controller Upgrade Software Installation Instructions- Traction –B839/ C839 4-5CBB 48V 242.53 kB 08/01/2011
550089526R69.zip CCS (Common Control System) Field Service Tool v1.91 31.0 MB 10/31/2024
1.91 – Updated for new 3M tether interlock requirements on Order Selectors and for relaunch of CCS Reach trucks. – 1.90 – Updated for NCEA Reach VSM v2.27.13 for OAS tilt angle improvement, End Rider software v1.51 (41599-12 code), and adds Boot Force to VSM software download. – 1.89 – Updated software for NCEA Reach Current draw & performance issues, B-Series GPT Support for ReLION and resolution of 0x180 overcurrent faults. – 1.87 – Updated software for AC Reach (bugs/options/features) / – 1.86 – Updated software for AC Reach and GPT (0.53) / – 1.85 – Updated software for new B-Series GPT / – 1.84 – Support for new GPT, and OSBE changes. / – 1.83 – Support for NCEA OAS, and NCEA display corrections / – 1.81 – Support for dual brake Reach, and EER product / – 1.79 – Various bug fixes and additional vehicles added for B56.1 support / – 1.77 – Update to support B56.1 changes in multiple production products / – 1.76 – Update to support Class III front foot/bumper detection / – 1.75 – Update to fix NCEA VSM loading issues, support for EER Bumper Sensor system / – 1.73 – Update to support new reach VSM software for VAM telematics, CCS reach OAS Software, 3ws and CCS reach calibration fixes. / – 1.71 – Update to support latest OAS Software on Reach, OS, and 3WS. / – 1.69 – Update to support New Reach V2.20 SW, Order Selector & 3WS OAS SW / – 1.68 – Update to resolve NCEA programming issues, and improve Anti-Virus false warnings / – 1.67 – Update to resolve ER backward compatibility issues and updates for early production Reach. / – 1.66 – Updates to support production NCEA Reach Software. / – 1.63 – Added New End Rider EPAS & NCEA Reach support. / – 1.61 – Added Li-Ion and OSS expansion to Enclosed End Rider. / – 1.60 – Added Li-Ion support to AC Reach & 3W-STD, BDI range expansion on Enclosed End Rider. / – 1.59 – Expanded support for Temp Sensor Configurations, and Assisted Steer End Rider. / Notes: -USE ONLY CCS FST R30- VERSION 1.49 or HIGHER on C883 Series 3 wheel stand trucks (ESC030-040AD) with OSS (Operator Sensing System). -USE ONLY CCS FST R18- VERSION 1.35 or HIGHER on MPB045VG – A245 Series Trucks!!! Do not use on MPB045VG (A245) trucks with controllers that have a manufacturing date code before 14072C. Contact RSE for instructions pertaining to controllers produced earlier than 14072C.
550053933R6.zip Class I / II Field Service Tool- Non CCS trucks Only 2.54 MB 02/06/2015
Ifak-6.06.zip Ifak-6.06.zip 21.2 MB 09/14/2022
NOTE: THIS IFAK DRIVER SOFTWARE IS COMPATIBLE WITH THE CURRENT IFAK CABLE, HOWEVER IS ONLY USED ON THIS TRUCK MODEL AT THIS TIME. CONTINUE TO USE THE PREVIOUS VERSION IFAK SOFTWARE ON OTHER TRUCK MODELS UNTIL IT IS ADDED TO AND SEEN ON THOSE MODELS.
550064182R0.pdf Next Generation 24 volt controller Software Instructions 178.80 kB 08/07/2012
550102172R0.zip Next Generation 24 volt controller Software Upgrader V001 906.76 kB 07/21/2014
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
524283948R4 (1).ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
550041198R0.zip ontroller Upgrade Software – Traction – 36/ 48V 225.26 kB 08/01/2011
550041199R0.zip Controller Upgrade Software – Traction – 72/80V 225.25 kB 08/01/2011
550041199R0.pdf Controller Upgrade Software Installation Instructions – Traction –72/80V 242.03 kB 08/01/2011
Vehicle
550041200R0.zip Controller Upgrade Software – Traction –E216 -2-3DBB 72/80V 224.84 kB 08/01/2011
550041200R0.pdf Controller Upgrade Software Installation Instructions – Traction –E216 -2-3DBB 72/80V 242.07 kB 08/01/2011
Vehicle
524245853A.zip Control Upgrade Software (Rev A) 538.84 kB 05/15/2006
Vehicle >> Display
Vehicle >> VSM
Controllers >> Steer Controller Software
8823665.zip Electric Steering Controller Software 523.35 kB 12/08/2015
Electric Steering Controller v5.12 requires VSM Application code v4.34 to operate and Display Application Code v4.34 to provide menu’s. (versions may be viewed via PCST > Diagnostic > Truck Information menu).
Vehicle >> Display
Vehicle >> VSM
524283948r4 (1).ZIP ETACC Diagnostic Software Program 2.4J (32 & 64 bit compatible) Must remove all previous versions of ETACC BEFORE installing. Replaces 2.11 & 2.40 22.6 MB 10/01/2012
Joystick >> Delta Tech
580093087R0.zip Side Stance Joystick Adjustment (Release 1) 32.97 kB 05/15/2008
524301764R1.zip Reach Truck Field Product Improvement Software (Version 1) 33.1 MB 02/15/2008
524320109R0.zip Reach Truck Field Product Improvement Software (Version 2) 24.1 MB 02/15/2008
524320109R1.zip Reach Truck Field Product Improvement Software (Version 3) 1.26 MB 08/27/2008
524312178R3.zip Reach Truck Steering Software (69A21200C006) 25.1 MB 04/01/2013
Vehicle >> VSM
4000448R3.zip VSM Software Update (Retail) 697.69 kB 01/28/2010
Communication Cable
Controllers
Controllers
8847930R0.zip 8847930R0 TOOL CDF UPLOADER V120P 574.59 kB 07/30/2020
CONTROL SOFTWARE TOOL CONFIG. FILE UPLOADER FOR ZAPI CONTROLLER
Controllers >> ZAPI Software
8817406R3.zip Diagnostic and programming Software CAN PC Console 6.09 MB 02/07/2024
This file release the new tool version 2.20, this improve the connection capability and it is mandatory to connect with new VNA electronics. Instructions about Can Device setup are included
8842177R1.zip Control software Master EPS Steering Motor 118.26 kB 01/25/2021
8842178R1.zip Control software Slave EPS Steering Motor 112.42 kB 01/25/2021
4178451R6.zip Control Software Traction/Pump Master ACE2 118.46 kB 12/14/2022
4178453R6.zip Control Software Traction/Pump Slave ACE2 109.00 kB 01/11/2023
4178454R4.zip Control Software VCM Master 95.55 kB 10/14/2019
4178455R4.zip Control Software VCM Slave 68.45 kB 10/14/2019
EPS 3 stage Gearbox NA6.23.zip Field Tool to update EPS Master & Slave to version 6.23, only using 3 stage gearbox 1.70 MB 03/02/2021
Pump for 9,9kW motor NA2.34.zip Field Tool to update Pump Controller Master & Slave to version 2.34, use only on truck having 9,9KW motor 1.46 MB 12/16/2022
This revision introduce improvement on Motor Management
Traction for 5,4kW motor NA2.34.zip Field Tool to update Traction Controller Master & Slave to version 2.34, use only on truck having 5,4KW drive motor 1.48 MB 12/16/2022
This revision introduce improvement on Motor Management This has to be used also on truck with 4KW motor (Russian Market)
VCM Standard NA0.27.zip Field Tool to update VCM Controller Master & Slave to version 0.27 1.23 MB 09/15/2020
Controllers
8843593R1.zip AWP Battery Calibration Tool 23.3 MB 01/22/2020
Tool to re-calibrate Battery Voltage with the ZAPI Controller. Voltage drop through the mast cable causes an offset that must be calibrated for, to enable accurate BDI readings. Updated Release V1.1 w/new ZIP method to avoid compliance issues with Win10 Explorer.
Communication Cable
81010425R0 USB-CAN Tool Software 960.67 kB 02/17/2025
Vehicle
Controllers
EPS 6.33 for Outdoor Reach truck.zip EPS 6.33 version 2.26 MB 12/20/2024
Upgrader for steering control software version 6.33, both Main and supervisor.
Pump for 14kW motor NA2.30.zip Field Tool to update Pump Controller Master & Slave to version 2.30, use only on truck having 14KW motor 1.92 MB 12/20/2022
Traction for 9,6kW motor NA2.36D.zip Field Tool to update Traction Controller Master & Slave to version 2.36, use only on truck having 6,4KW or 9,6KW drive motor 3.05 MB 09/10/2024
Version 2.36 fix issue with new direction switch, as described on Gram /Bulletin FB084R01
VCM Premium NA 2.55.zip Field Tool to update VCM Controller Master & Slave to version 2.55 2.38 MB 12/20/2024
Version 2.55 introduce the Li-Ion managed through CDF and a new condition for Lowering interlock by pass
Joystick >> CCS
4092475R1.zip CCS Sidestance Control Handle Software 76.2 MB 03/21/2014
This software should only be used under RSE direction, contact RSE before downloading.
4092475R1instructions.pdf CCS Sidestance Control Handle Software Instructions 1.68 MB 03/21/2014
Controllers
WinFlash.zip Winflash reprogramming tool for controllers 13.3 MB 03/15/2022
8811176R0.zip CAN FLASHER Software Uploader 1.30 MB 07/05/2012
1-13-00P.zip HYG RFID PLC software files 12.5 MB 10/07/2024
New software packages 1-13-00P for RFID PLC, Installation Instructions included. This new version introduce new options in the application menu. IMPORTANT NOTE : USE ONLY ON TRUCK UP TO SERIAL NUMBER ….T02999X
HYG RFID Programmer rev 1.6.1.0.zip RFID programmer 16.3 MB 02/01/2019
Tool to program RFID SPED features
HLOP UpgraderR1.zip Tool to update all truck controllers 678.62 kB 11/11/2021
This tool allow to upgrade High Level Order Picker This version updates split HLOP software from VNA and introduce Sicos software 3.18. This software has parameter Pressure Time , into adjustment menu. This is to prevent a possible initial cabin drop of 10cm, when lowering. Software included are: Sicos 3.18, Traction and Pump 3.08, Mhyrio 3.00, EPS 3.07.
upgrader_0.18 HLOP Standard.zip Tool to update all truck controllers 2.19 MB 05/12/2025
This tool to be used to upgrade High Level Order Picker, to be used ONLY on trucks with electronics to comply with EN1175:2020. Software included are: Sicos 0.18, Dual ACE2 0.06, EPS 0.07, VCM 0.03, Can Tiller 0.02,and Antennas 0.75
upgrader_0.18 HLOP Dual Control.zip Tool to update all truck controllers 2.28 MB 05/12/2025
This tool to be used to upgrade High Level Order Picker, to be used ONLY on trucks with electronics to comply with EN1175:2020 and DUAL SIDE CONTROLS. Software included are: Sicos 0.18, Dual ACE2 0.06, EPS 0.07, VCM 0.03, CANI/O 0.05, Can Tiller 0.02 and Antennas 0.75
550027876R13 (1).zip ETACC 2.4N (Update Only- Must Have Program 2.4K Installed prior to installation) 6.00 MB 08/09/2022
Sicos00.epf ETACC Update and installation instructions.zip Sicos00.epf ETACC Update file and installation instructions 172.05 kB 04/22/2016
New Sicos EPF file for ETACC to allow RFID option to be turned on
580082575R0.zip VNA AC2 Traction and Pump Software (Release 1) 140.85 kB 05/15/2007
580082579R0.zip VNA CAN TILLER Software (Release 1) 14.08 kB 05/15/2007
580082577R0.zip VNA EPS Software (Release 1) 104.45 kB 05/15/2007
580082578R0.zip VNA Mhyrio Software (Release 1) 30.94 kB 05/15/2007
580082576R1.zip VNA SICOS Software (Release 2) 100.89 kB 11/14/2007
2-00-00F.zip HYG RFID PLC Software files 19.2 MB 10/07/2024
Software packages 2-00-00F for RFID PLC, Installation instructions included. IMPORTANT NOTE: USE ONLY ON TRUCK FROM SERIAL NUMBER ….T03000X, WITH NEW ELECTRONIC SYSTEM.
580073638R0.ZIP VNA Software Upgrade Utility (Release 1) 675.93 kB 07/19/2007
upgrader_0.62 SICOS VNA1175_80V_V028 complete -joystick.zip Service tool to update all controller 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 80V AND JOYSTICK SEAT, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75 NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
VNA Service Upgrader for standard EEprom.zip Service Tool to update all controllers 710.86 kB 10/12/2021
USE ONLY ON TRUCK WITH SERIAL NUMBER UP TO 02999X Service too to update all trucks controller, have to be used on trucks fitted with standard memory Sicos. Sicos suitable p/n are 8537120 and 8537127 for US, 8539242 and 8539243 for EMEA and other regions. Software included are: Sicos 3.18, Traction and Pumps 3.11, Mhyrio 3.06, EPS 3.07, Cantiller 3.07
upgrader_0.62 SICOS VNA1175_48V_V028 complete – FWD Console.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 48V AND Forward Console, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75. NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
upgrader_0.62 SICOS VNA1175_80V_V028 complete – FWD Console.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 80V AND FORWARD CONSOLE, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75 NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file.
upgrader_0.62 SICOS VNA1175_48V_V028 complete – joystick.zip Service tool to update all controllers 3.15 MB 03/19/2025
TO BE USED ONLY ON TRUCK WITH SERIAL NUMBER FROM 03000X, TRUCKS WITH NEW ELECTRIC SYSTEM 48V AND JOYSTICK SEAT, TO COMPLY WITH EN1175:2020 This will update all controllers to following versions: Sicos 0.62, Dual ACE2 0.26, ACE2 0.15, EPS 0.29, Can Tiller 0.14, VCM 0.13, Antenna 0.75. NOTE: after the update some parameters need to be checked and correctly set, as per the .pdf included into .zip file
VNA Service Upgrader for extended EEprom .zip Service Tool to update all truck controllers 715.07 kB 10/12/2021
USE ONLY ON TRUCK WITH SERIAL NUMBER UP TO 02999X Service too to update all trucks controller, have to be used on trucks fitted with Extended memory Sicos. Sicos suitable p/n are 8848468 and 8848469 for US, 8848470 and 8848471 for EMEA and other regions. Software included are: Sicos 3.27, Traction and Pumps 3.17, Mhyrio 3.13, EPS 3.07, Cantiller 3.07
Controllers >> VNA Controller Software
8541875R5.zip Control software AC2 CONTROLLER PUMP/TRACTION VNA 140.60 kB 02/10/2022
8541879R7.zip Control software CAN TILLER VNA 12.40 kB 01/18/2013
8541877R7.zip Control software EPS VNA 90.46 kB 06/20/2012
8541878R4.zip Control software MHYRIO VNA 30.54 kB 02/10/2022
8541876R7.zip Control software SICOS VNA 99.57 kB 01/28/2021
8848472R2.zip Control software SICOS VNA extended memory 103.57 kB 02/10/2022
Vehicle >> Display
550297861R0.zip Yale 5″ Display Firmware v4.51 for HyPro v2.0 12.5 MB 02/19/2024
2/19/24 – Release of V4.51 Display Firmware, resolves calibration menu issues. 12/5/23 – Release of V4.43 Display firmware, fixes thermal warnings & indicator bugs. 2/6/23 – Release of V4.40 Display Firmware, fixes Impact Sensor bugs when used with telemetry 11/10/22 – (Fixed) Release of 5″ V3.96 Display firmware, minor bug corrections & rotary wheel fix. 5/5/22 – Release of 5″ V3.94 Display firmware with ICON/System improvements 6/11/21 – Release of 5″ V3.92 Display firmware for supporting OAS system. 5/20/21 – Release of 5″ Display firmware v3.91 for NA Reach to be used with HyPro v2.0 downloader. 5/21/20 – Release of 5″ Display firmware for NA Reach to be used with HyPro downloader.
550297863R0.zip Yale 7″ Display Firmware v4.51 for HyPro v2.0 12.5 MB 02/19/2024
2/19/24 – Release of V4.51 Display Firmware, resolves calibration menu issues. 12/5/23 – Release of V4.43 Display Firmware, fixes thermal warning and indicator bugs 2/6/23 – Release of V4.40 Display Firmware, fixes Impact Sensor bugs when used with telemetry 11/10/22 – (Fixed) Release of V3.96 for Yale 7″ Display, minor bug fixes and rotary wheel fix. 5/5/22 – Release of V3.94 for Yale 7″ Display to improve ICON/system functionality. 6/11/21 – Release of V3.92 for Yale 7″ Display to support OAS system. 5/20/2021 – Release of Yale 7″ Display Firmware v3.91 for NA NCEA Reach to be used with HyPro v2.0. 5/21/2020 – Release of Yale 7″ Display Firmware for NA NCEA Reach to be used with HyPro.
8541872r2.zip Control software – SICOS Display 44.99 kB 04/27/2016
Controllers
Keypad 582080458 R2 software.zip Software to upload functionality on keypad 75.84 kB 06/07/2024
Please refers to Service Gram FK004 for installation, use instructions. Rev 02 fix a bug due to quick OFF/ON
Upgrader RP_RS_2.32 Combi_EPS2.04_con_enc.zip Combi 2.32 and EPS 2.04 – Manage IL option and Key AM for Li-Ion battery 860.18 kB 09/14/2023
This upgrader will update both Combi and EPS, to the latest software release. To be used only on truck using EPS with feedback encoder.
Controllers >> Hydraulic Controller Software
8827190R8.zip Control Software Hydraulic COMBI AC1 51.43 kB 06/16/2020
8819928R3.zip Control Software Pump COMBI AC1 52.93 kB 11/03/2016
8819925R3.zip Control Software Steer AC0 86.58 kB 04/15/2016
4236586R2.zip Control Software Steer AC0 249.59 kB 10/14/2019
8819927R3.zip Control Software Traction COMBI AC1 72.72 kB 11/03/2016
8827189R8.zip Control Software Traction COMBI AC1 87.82 kB 06/16/2020
Controllers
Vehicle >> VSM
4000448R2.zip VSM Fore/Aft Software Update (Release 3) (Americas) 609.86 kB 01/14/2010
Update EPS MLOP 304.zip Control software EPS AC0 411.09 kB 12/17/2024
Update for Standard EPS version only. This update to version 3.04, in this revision, parameter Hardware setting / PT1000 TH Mot is available, to adapt to new temperature sensor.
Update EPS WG MLOP 308.zip Control software EPS AC0 WG 1.18 MB 12/20/2024
Update for EPS Wire Guidance version only. This update to version 3.08, in this revision, parameter Hardware setting / PT1000 TH Mot is available, to adapt to new temperature sensor.
MLOP Service Upgrader.zip Field tool for controller update 705.41 kB 03/06/2023
Service software, to update all controllers on truck. Software included are: Sicos 3.12, Traction and Pumps 3.04 (Combi), EPS 3.03.
Vehicle >> VSM
Controllers
EPS 2 stage Gearbox 2NA 6.23.zip Field Tool to update EPS Master & Slave to version 6.23, only using 2 stage gearbox 1.81 MB 03/02/2021
Vehicle >> Display
8807718R8.zip 8807718R8 (Display retail) 38.83 kB 12/21/2018
8817405R6.zip 8817405R6 (Display LCD Premium) 76.83 kB 10/14/2019
8817509R1.zip 8817509R1 TOOL SOFTWARE DISPLAY RETAIL 372.43 kB 04/21/2014
Joystick >> CCS
S01868240001R3.zip CCS Automation Vehicle Software Updater V3.0 9.06 MB 02/28/2022
1/19/22 – Updated to latest Reach Software 10/29/20 – Updated to latest version to support latest automation software. 9/17/20 – Release of AUTOMATION vehicle FST V1.0 – NOTE: For JBT automation vehicles, use this FST over the standard version listed. Do not use this version if the vehicle is NOT an automation vehicle.
Joystick >> CCS
Vehicle >> Display
Communication Cable
DPIcharger14.2.zip DPI Charger Software Version 14.2 6.89 MB 10/23/2015
FPI-152017 DPI Battery Charger Software Version 14.2- This software is used in conjunction with the Interface Cable P/N- SFP888000030 to perform FPI-152017. This FPI only affects chargers that connect to a Charge Port and should only be used to update DPI charger version 14.1 to 14.2. DO NOT use on versions earlier than 14.1. Download and understand the installation instructions prior to attempting the update.
14.2ChargerSoftwareInstallationReadMe.pdf FPI- 152017- 14.2 Charger Software Installation ReadMe 1.14 MB 10/23/2015
FPI-152017- This Readme file should be read and understood prior to attempting the installation and loading of the 14.2 Charger update software. When installing the software if asked to Update, CLICK NO! If you click Yes the License to# and License Key will be required. Use NACCO in all caps as the “License Key” and the License To# is- 5574a6ab677e9aff5360f964110378f789e4ebeb538e14b7f77312be55fd8d0f
550033141R10.zip Warehouse Updater Tool (V1.21) RSE Authorization Required Before Using. 1.07 MB 06/01/2017
Warehouse Updater Tool Instructions V1.20.pdf Warehouse Updater Tool Instructions V1.20 and newer 276.37 kB 04/01/2016
Communication Cable
Controllers
Nuvera Fuel Cell Class 3 Block 2 VSM SW V4.1.0.zip Nuvera Fuel Cell Class 3 Block 2 VSM SW V4.1.0.zip 6.54 MB 05/07/2021
Class 3 24v VSM Version 4.1.0 hex code. Compatible with both BBRHMI 2.1.0 (no buzzer) or BBRHMI 3.0.0 (buzzer). Not compatible with Block 1 and Block 1.5 COP units. Please use VSM install procedure.
Controllers
Nuvera Software A2023B.zip Nuvera Software A2023B 630.18 kB 08/30/2022
Controllers
TOOL ONBOARD CHARGER CURVE SETTING V1.0.2.zip TOOL ONBOARD CHARGER CURVE SETTING 374.74 kB 11/05/2024
new tool, to change charge curves profile into onboard charger. NOTE: To be used only for onboard chargers P/N 4252102 & 4131473 (these codes can be found on charger label)
MultiCan Tiller Tool R1.zip Diagnostic and programming tool for tiller card 995.34 kB 06/24/2021
This is to be used only on Rema MultiCan tiller card type, following service Gram / Bulletin LD078 – Suitable for both 32 and 64 bit systems
81012564R0.zip Telemetry – VAM Configuration Tool (LITE) – v2.10.4 1.37 MB 02/07/2025
Vehicle
Curtis CAN Tool V1.3.3.25.zip Third parties WHE (EU) diagnostic tool for PCST 57.7 MB 04/01/2021
NEW Curtis tool for PCST this version has a software download bug fixed, suitable to operate with WIN10 refers to LD062R03
A428 A418 1232E2226 VCL 2.14.zip Combi controller software 135.47 kB 06/12/2020
Latest production software VCL 2.14, to align the MDi parameters as per service Gram / bulletin FH018R01
Vehicle
Communication Cable
Controllers
8826535R1.zip 8826535R1 TOOL ONBOARD CHARGER CURVE SETTING 191.78 kB 06/12/2017
8850945R0.zip 8850945R0 TOOL CONFIG. FILE UPLOADER 838.70 kB 04/30/2021
CONTROL SOFTWARE TOOL CONFIG. FILE UPLOADER FOR CURTIS CONTROLLER
C.I.T. v1.0.1.zip Curtis Integrated Toolkit for PCST 121.9 MB 05/11/2021
Diagnost and programming tool
Platform Pallet Truck rev 03.zip Truck project file 9.02 MB 04/29/2022
This file is mandatory to install on laptop, to connect Curtis Integrated tool to the truck Rev 03: 1) fix a bug during controller change and CDF load 2) fix discrepancy on maintenance hours 3) fix issue with alarm ST48-2 Following Error 4) correct some translations error on instructions file.
Vehicle
Controllers
Nuvera Software a2012b.zip Nuvera Controllers Software A2012B 581.54 kB 09/09/2022
Controllers
Automatic Update for Combi ACX rev0.59.zip Software to update controller to version 0.59 680.29 kB 08/02/2024
Truck software for service use, version 0.59 Fix an issue with alarm 155A02, see LD083R01
Letrika controller update Y.zip Software to update combi controller 5.48 MB 11/08/2018
This software, can be used only on truck from serial number: B892T01684M, B860T01596M and C847T02650M
550027876R11 instructions (1).pdf ETACC 2.4K Instructions (Update Only- Must Have Program 2.4J Installed prior to installation) 445.50 kB 01/28/2013
AC End Rider Software Installation Instructions.pdf AC End Rider Software Installation Instructions 33.70 kB 12/03/2009
Vehicle
Vehicle >> Display
550217056R1.zip Display Firmware V1.04 9.95 MB 07/03/2019
Display Firmware V1.04, referred to in UE0005R00Y as “USB Archive.phd” for use with HyPro Software download tool and the USB Interface Dongle. V1.04 resolves; Serial Mis-Match errors, Intermittent Rabbit Function, non-real touch detections, lock-up conditions, and improves loading time.
Display Firmware V1.05 0.00 kB No data
Display Firmware V1.05, referred to in UE0005R00Y as “USB Archive.phd” for use with HyPro Software download tool and the USB Interface Dongle. V1.05 supports; End Rider EPAS Not necessary for Manual Steer Vehicles. NOTE: When using FST, version 1.63 or higher must be used.
8852262R1.zip Display V1.07 App/V4.87 Firmware for 2.8″ Parker Display 10.3 MB 04/12/2023
4/26/23 – BRC – Release of V1.07 Display Software (corrects Ahr issue, OSBE changes, and timeout issues.) 1/27/22 – BRC – Release of V1.06 Display Software (supports new End Rider Bumper/detection system). 6/10/21 – BRC – Release of updated Display software to support the new V6 Parker Displays on the End Rider. This software is required for proper touchscreen function on Rev 6 hardware. This software is compatible with Rev 5 displays
Vehicle >> Display
8803563R1.zip Control Software – Combi MPB (Rev 1) 63.47 kB 02/15/2011
Controllers
4177296R10.zip Control Software Master Combi Controller ACX 182.16 kB 02/12/2025
4177297R10.zip Control Software Slave Combi Controller ACX 83.60 kB 02/12/2025
Automatic update for Combi ACX rev. 1.59.zip Automatic update for combi controller ACX 1.10 MB 02/13/2025
Software update for Combi ACX controller, software version 1.59. On pedestrian stacker this new release, will manage SPED Bumper Switch option
4325578R2.zip Control software pump COMBI AC1 48.73 kB 02/10/2022
8851257R3.zip Field tool to update Master and Slave Combi controller 462.64 kB 07/20/2023
This tool will update Combi controller to latest version 018, used in production.
8851361R6.zip Field tool to update master and slave Steering controller 1.66 MB 11/29/2023
This upgrader will load version 005, able to fix error Vcap too low.
4326521R1.zip Control software EPS AC0 127.01 kB 02/10/2022
4326522R1.zip Control software truck config. EPS AC0 ZAPI 120.33 kB 02/10/2022
4325577R2.zip Control software traction COMBI AC1 87.69 kB 02/10/2022
Controllers
New Diagnostic and Programming tool for E843 truck
Double Platform Stacker rev 03.zip Truck Project File 10.5 MB 03/11/2025
This file is mandatory to install on laptop, in order to connect Curtis Integrated Tool to the truck Rev 03 , Fix a bug with acceleration when battery is below 50; made available parameter: Traction Manager -> HS/LS Multiplier -> Neutral Decel HS to LS, to adjust braking power in pedestrian mode; correct the alarm logbook time unit.
Vehicle
D843_12225113B.zip Steering controller software 133.03 kB 06/12/2020
To be used only on EPS 1222-5103 and Beyond. DO NOT USE on 1222-5102 OR LOWER
D843 12342388 service R1.zip Traction controller software update 109.01 kB 04/23/2020
VCL version 1.42 updates Li-Ion battery management. Suitable to be used on controller 1234-2383 and beyond. DO NOT USE nn 1234-2382,or lower. DO NOT USE on any version of 1234E
D843_1234E2338.zip Traction controller software update 146.08 kB 06/12/2020
VCL version 1.43 updates Li-Ion battery management. Suitable to be used on controller 1234E. DO NOT USE on standard 1234 controller
Controllers
Automatic update for Combi AC0 Electrical steer rev.1.59.zip Automatic update for combi controller AC0 with electrical steer 1.12 MB 02/13/2025
Service tool to update Combi AC0 ONLY ON TRUCK WITH ELECTRIC STEERING. THIS WILL AUTOMATICALLY UPDATE Combi 1.59 On pedestrian stacker this new release, will manage SPED Bumper Switch option
Automatic update for Integrated EPS rev 1.70.zip Automatic update for EPS integrated steering 590.58 kB 04/26/2022
Service tool to update the Integrated steering on electrical steering truck, rev. 1.70
Controllers
4169730R10.zip Control Software Master Combi Controller AC0 Mech. Steer. 183.33 kB 02/12/2025
4223064R8.zip Control Software Master Combi Controller AC0 Ped. Electric Steer. 185.27 kB 02/12/2025
4170214R10.zip Control Software Master Combi Controller ACX 182.16 kB 02/12/2025
4169731R10.zip Control Software Slave Combi Controller AC0 Mech. Steer 83.70 kB 02/12/2025
4223065R8.zip Control Software Slave Combi Controller AC0 Ped. Electric Steer. 83.90 kB 02/12/2025
4170215R10.zip Control Software Slave Combi Controller ACX 83.60 kB 02/12/2025
Automatic update for Combi AC0 Mechanical steer rev. 1.59.zip Automatic update for combi controller AC0 mechanical steering 1.11 MB 02/13/2025
Service tool to update Combi AC0 ONLY ON TRUCK WITH MECHANICAL STEER, THIS WILL AUTOMATICALLY UPDATE Combi 1.59 On pedestrian stacker this new release, will manage SPED Bumper Switch option
4215940R4.zip Control Software Master Steering Motor 137.81 kB 05/14/2019
4215941R4.zip Control Software Slave Steering Motor 127.38 kB 05/14/2019
Vehicle
Controllers
Platform Pallet Truck rev 06.zip Truck Project File 10.6 MB 03/10/2025
This file it is mandatory to install on laptop, to connect Curtis Integrated tool to the truck. Rev 06, Fix a bug with acceleration when battery is below 50; made available parameter: Traction Manager -> HS/LS Multiplier -> Neutral Decel HS to LS, to adjust braking power in pedestrian mode; correct the alarm logbook time unit.
Bridge Project File.zip Truck project file bridge 5.42 MB 07/04/2024
This file is mandatory to be loaded, BEFORE upgrade trucks with Project file Rev 05
4112035R4.zip Control Software Pump COMBI AC1 52.48 kB 02/04/2016
4128020R2.zip Control Software Pump COMBI AC1 7T 52.49 kB 02/04/2016
4112034R3.zip Control Software Traction COMBI AC1 67.56 kB 02/04/2016
4128019R2.zip Control Software Traction COMBI AC1 7T 67.57 kB 02/04/2016
4183978R8.zip Control Software Pump COMBI AC1 LLOP 51.97 kB 02/23/2021
4184319R8.zip Control Software Pump COMBI AC1 Tractor 7T 51.97 kB 02/23/2021
Controllers
Upgrader for Order Picker and Tow Tractor 5 Ton with FB potentiometer.zip automatic upgrader for combi and EPS controller, only for Order Picker and Tow Tractor 5T with FB potentiometer 557.21 kB 12/19/2018
For serial number compatibility and instructions, please, check service Bulletin / Gram LD075 – Combi software 1,69 and EPS 1.40
Upgrader for Tow Tractor 7 Ton with FB potentiometer.zip automatic upgrader for combi and EPS controller, only for Tow Tractor 7T with FB potentiometer 556.53 kB 12/19/2018
For serial number compatibility and instructions, please, check service Bulletin / Gram LD075 – Combi software NA7 1,69 and EPS 1.40
Upgrader for Tow Tractor 7 Ton with FB potentiometer (1).zip automatic upgrader for combi controller, only for Tow Tractor 7T with FB encoder 464.95 kB 11/04/2024
Update to Combi version 1.96
Automatic upgrader for Combi 1.96 on Standard LLOP and 5T Tow Tractor, with FB Encoder.zip Automatic upgrader for combi, only for Order Picker and Tow Tractor 5T with FB encoder 854.39 kB 11/04/2024
Automatic Upgrade for EPS rev 7.49, only with FB encoder.zip Service tool to update Double encoder EPS 951.94 kB 10/21/2022
Service Tool to update double FB Encoder EPS to version 7.49
4183977R8.zip Control Software Traction COMBI AC1 LLOP 85.42 kB 02/23/2021
4184318R8.zip Control Software Traction COMBI AC1 Tractor 7T 85.42 kB 02/23/2021
Vehicle >> Display
Engine >> GM 4.3L & 2.4L Teleflex GFI Fuel system
S3000 Flash Wizard Installation Instructions (Y).pdf S3000 Flash Wizard Installation Instructions 82.96 kB 10/25/2006
S3000.zip S3000 Flash Wizard Reprogramming Tool for GM 4.3L and 2.4L Engine Controllers 5.51 MB 04/10/2013
Engine >> Mazda 2.0L & 2.2L Aisan – GM Impco
PSI Display Software (build date 2-15-07).zip Display Software – PSI (Mazda/Aisan/GM Impco) (Build Date 2-15-07) 5.99 MB 03/06/2007
GCP Display Software (build date 3-13-12).zip GCP Display Impco fuel systems – GM & Mazda Engines 7.11 MB 04/09/2015
GCP Display Software (build date 3-13-12).zip — Enhanced recording features using .bplt files
FPI180002.zip FPI180002 8.29 MB 06/29/2018
Engine >> GM 2.4L Engine Controller Calibration Files
8806456R0.ZIP 2.4L Gasoline (2010) 181.49 kB 03/14/2011
GM 2.4L 2010 Injector Conversion.zip GM 2.4L 2010 injector conversion 172.61 kB 07/26/2017
G4-88_2.4_20070822.3_Gas_VH_2007a.zip GM 2.4L Gasoline (2007) 173.20 kB 08/07/2018
GFI 2-4 2006.1212 Gas.zip GM 2.4L Gasoline TeleFlex GFI 172.92 kB 01/11/2007
8806457R0.ZIP GM 2.4L LPG (2010) 180.99 kB 03/14/2011
GFI 2-4 2006.1212 LPG.zip GM 2.4L LPG TeleFlex GFI 172.31 kB 01/11/2007
Engine >> Mazda
IMPCO EPR FLASH REV-C.zip EPR Update to Rev C 5.27 MB 07/21/2009
IMPCO EPR FLASH REV-C (1).zip EPR Update to Rev C 5.27 MB 07/21/2009
Engine >> Mazda 2.0L Engine Controller Calibration Files
1528002E.zip 2.0L Gasoline (Rev E) 154.10 kB 03/27/2006
E1528020K_2.0LPG_2-3T.zip Mazda 2.0L LPG (Rev K) 503.56 kB 10/25/2011
Engine >> Mazda 2.2L Engine Controller Calibration Files
E1528000K_2.2LPG_2-3T.zip Mazda 2.2L LPG (Rev K) 503.56 kB 10/25/2011
Vehicle >> Display
DISPLAYAP0303.hex Display Application Code (V3.03) 74.91 kB 04/16/2012
8848368R0 (1).zip Display Application Code V4.02 — ONLY for New (ST32) Internal processor type 470.01 kB 10/21/2020
IMPORTANT — this software / code is for New (ST32) Internal processor type Displays ONLY. Factory installed Base Code V4.00 is revised to V4.02, to Fix “Stuck Button” bug in ST32 Internal Processor type displays.
Vehicle >> VSM
VSM269DP0216.hex VSM Application Code (SN =>A910V04412C, Excluding A910V04362-A910V04364C and A910V04372-A910V04375C) Version 2.16 508.88 kB 02/04/2006
8861995R0.zip VSM Application File (V5.92) 580.14 kB 08/13/2024
V5.92 Includes fixes for: L1/L2 transmission, Prevents truck abrupt forward movement when Operator Present System (OPS) is not satisfied. Increases OPS long timer condition from Accelerator Pedal Position (APP) >1% to >4%.
OptionalStrings0570.hex VSM Language Code (V5.70) 19.28 kB 10/01/2015
Reprogramming Mazda LPG ECUs (New rev mot files).pdf Reprogramming Mazda LPG ECUs (New rev mot files) 1.21 MB 10/25/2011
GM 2.4 LPG (2010) Certified.ZIP GM 2.4 LPG (2010) Certified TeleFlex GFI 180.99 kB 08/07/2018
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
8848228.zip 4G Display Software – PSI, Kubota (LPG) & Mazda (Impco) Engines 177.5 MB 01/20/2021
2280662B.zip 2.0L LPG (Rev B) 1.01 MB 06/08/2010
Vehicle >> Display
BSTDISP0330.zip Display Application Code (V3.30) 70.41 kB 02/07/2017
Engine >> GM 3.0L Engine Controller Calibration Files
ECM_Programming_Instructions.zip GM ECM Programming Instructions 121.34 kB 01/12/2005
Engine >> GM 4.3L Engine Controller Calibration Files
0925701G.zip GM 4.3L LPG (Rev G) 461.50 kB 08/07/2018
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Reprogramming Mazda LPG ECUs (Rev H).pdf Mazda ECU Reprogramming Instructions (Rev H) 1.12 MB 10/04/2006
Engine >> Mazda
E1528021J_2.0LPG_1-2T.zip Mazda 2.0L LPG (Rev J) 156.31 kB 10/25/2011
Vehicle >> Display
Vehicle >> VSM
Transmission >> Dana TE Series
8843818R2.zip Dashboard v3.8.12.0 Diagnostic Software 98.4 MB 11/01/2022
DashboardInstallationGuide – EN.pdf Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
also contains prerequisites conditions for successfully installing!
GM 4.3L 2010 Injector Conversion.zip GM 4.3L 2010 Injector Conversion 172.08 kB 07/26/2017
G4-100_4.3_20071214.5_GAS_2008_VH.zip GM 4.3L Gasoline (2008) 177.02 kB 02/04/2009
8806453R0.ZIP GM 4.3L Gasoline (2010) 181.79 kB 03/14/2011
GFI_86_4-3_LPG.zip GM 4.3L LPG (2006/2007) TeleFlex GFI 276.31 kB 10/17/2006
G4-97_4.3_20090115.6_LPG_2009_VH.zip GM 4.3L LPG (2008/2009) TeleFlex GFI 174.96 kB 03/03/2009
8806454R0.ZIP GM 4.3L LPG (2010) 180.32 kB 03/14/2011
Vehicle >> Display
Vehicle >> VSM
DashboardInstallationGuide – EN.pdf Dashboard v3.8.12.0 Diagnostic Software 98.4 MB 11/01/2022
8843818R2.zip Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
GM 4.3 LPG (2010) Certified.ZIP GM 4.3 LPG (2010) Certified TeleFlex GFI 180.32 kB 07/04/2011
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
8861995R0 (1).zip VSM Application File (V5.92) 580.14 kB 08/13/2024
Vehicle >> Display
Vehicle >> VSM
Vehicle Operating Software – NON Serial Number Specific
GM 4.3 LPG (2010) Non-certified.ZIP GM 4.3 LPG (2010) Non-certified TeleFlex GFI 180.34 kB 07/04/2011
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
8862897R0.zip 2.8 inch Display Application Code – ICE 10.0 – ( 4.0.438.013 ) 31.6 MB 12/17/2024
Display Application Code ICE 10.0 – ( Compatible / Use with VSM Application Code ICE 10.0 and up) HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
81015943R0 Display 5in.zip 5 inch Display Application Code – ICE 10.03 – ( 4.0.438.021 ) 44.9 MB 01/23/2025
Display Application Code ICE 10.03 – ( Compatible / Use with VSM Application Code – ICE10.02.01 ( v04.043.889.204 ) & onward ) HYZ file is for use with Field Prog v2.40 and greater and will program via CAN or USB by user choice.
8862718R0.zip 7 inch Display Application Code – ICE 10.0 – ( 4.0.438.006 ) 41.5 MB 07/25/2024
Display Application Code ICE 10.0 – ( Compatible / Use with VSM Application Code ICE 10.0 ( v04.043.889.148 & onward ) HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
Vehicle >> VSM
81008374R0.zip VSM Application Code – ICE10.02.01 ( v04.043.889.204 ) 1.37 MB 12/16/2024
Vehicle >> Display
81024501R0.zip 2.8 inch Display Application Code – ICE 10.1 – (V4.0.636.020) 30.5 MB 05/29/2025
Display Application Code ICE 10.1 – ( Compatible / Use with VSM Application Code ICE 10.01 (V04.044.438.227) and onward HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
81024502R0.zip 5 inch Display Application Code – ICE 10.1 – (V4.0.636.018) 45.4 MB 05/30/2025
Display Application Code ICE 10.1 – ( Compatible / Use with VSM Application Code – ICE10.1 (V04.044.438.227) & onward HYZ file is for use with Field Prog v2.40 and greater and will program via CAN or USB by user choice
81024503R0.zip 7 inch Display Application Code – ICE 10.1 – (V4.0.636.018) 45.4 MB 05/30/2025
Display Application Code ICE 10.01 – (Compatible / Use with VSM Application Code ICE 10.1 (V04.044.438.227 & onward HYZ file is for use with Field Prog v2.33 and greater and will program via CAN or USB by user choice.
Vehicle >> VSM
V04.044.438.227.zip VSM Application Code – ICE10.1 ( v04.044.438.227) 1.34 MB 05/30/2025
0529801F.zip GM 3.0L LPG (Rev F) 459.02 kB 02/16/2005
0728801D.zip GM 3.0L Gasoline (Rev D) 459.02 kB 02/16/2005
0728801D.zip
0528801F.zip GM 3.0L LPG (Rev F) 459.02 kB 02/16/2005
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
kubotaenginereprog R2.pdf Kubota Engine Reprogramming PDF R2 537.12 kB 02/25/2016
550078022R2.zip Yale Kubota 3.8l Engine Reprogramming Tool 2.03 MB 02/25/2016
Adds the ability to program Kubota ACUs using the IFAK, and ECU programming. Programming Tool automatically detects file for ACU or ECU programming
Operator Display >> DPF Display
8811211R0.zip DPF Display Reprogramming Tool 946.95 kB 09/12/2014
8841792R0 1.zip DPF Display Software – Factory Version 361.37 kB 12/06/2023
8859491R0 DPF Display Software – with active regen inhibited 213.03 kB 12/06/2023
DPF Display Software – with active regen inhibited – intended for low duty applications
Controllers >> Control Software
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
8859491R0.zip DPF Display Software – with active regen inhibited 213.03 kB 12/06/2023
Vehicle >> Display
Vehicle >> VSM
Communication Cable >> IFAK Driver
Vehicle >> Display
Vehicle >> VSM
1595698R8.-161194.zip IFAK Cable Upgrade V6.2.1 6.86 MB 08/23/2022
Engine >> Kubota
Vehicle >> Display
8841792R0.zip DPF Display Software 11.01 361.37 kB 01/13/2020
DPF Display Software v11.01 updates the DPF Display reference Euro Stage-V Engines. v11.01 is backward compatible with older versions of DPF Display but requires truck/VSM Application Software v5.82 or higher, for use with Euro Stage-V engines.
Vehicle >> VSM
1595698R8.-161194.zip IFAK Cable driver V6.2.1 6.86 MB 08/23/2022
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
EH108-69957.zip EH108-69957 2.65 MB 03/13/2017
Kubota 3.8 LPG w/Mechanical Cooling Fan
EH128-69956.zip EH128-69956 2.65 MB 03/13/2017
Kubota 3.8 LPG w/Hydraulic Cooling Fan
EH165-69953.zip EH165-69953 2.65 MB 03/13/2017
Kubota 3.8 Bi-Fuel(LPG & Gasoline)
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Engine >> Kubota
DashboardInsallationGuide – EN.pdf Dashboard v3.8.12.0 Install Instructions (Readme) 1.16 MB 03/24/2021
also contatins prerequisites conditions for successfully installing!
Vehicle >> Display
Vehicle >> VSM
8848228.zip 4G Display Software – PSI, Kubota (LPG) & Mazda (Impco) Engines 177.5 MB 01/20/2021s
Controllers
4288786R0.zip Software Update Package 6.71 MB 06/12/2020
This kit will allow dealers to switch control settings in the hydraulic service tool
Hydraulic >> Danfoss
8820284R5.zip Danfoss Hydraulic Controller diagnostic software base packet 212.6 MB 03/04/2020
Install both base (8820284) and update (8820285) package.
8820285R6.zip Danfoss Hydraulic Controller diagnostic software update packet 20.3 MB 03/04/2020
8830112v25.zip Telemetry System Validation Software Tool V2.5 5.10 MB 09/12/2017
Transmission >> ZF Ergo Power Series
1_ZF-Testman-HYG-edition-Installation-help.pdf 1 Hyster-Yale Testman installation help 1.02 MB 09/15/2022
Help file for license registration / installation / laptop hardware or operating system replacement
2_ZF-TESTMAN-BaseInstall_06.2021.zip 2 Testman Diagnostic Software – Base Installation 06.2021 424.1 MB 02/06/2025
ZF-Testman Hyster-Yale Group Edition. – Testman requires individual license registration. – Read installation help before starting!
3_Application_Help_Ergopower_M_HYG_EN.pdf 3 HYG ZF-Testman Project related help for users 6.71 MB 09/15/2022
Read through this help file for using Testman with HYG Trucks, it explains the all the ZF-Testman functions. The most recent version of this document is within Testman via websync, it can be opened from Testman: after user terms are accepted, use help menu: open project related help or use Alt-F1 key combination.
8861234R0.zip HYPro v3.2.7 – programming tool 19.1 MB 04/04/2024
81029932R0.zip Primary Display Application Software 14.5 MB 06/04/2025
04-06-2025 – New Release of the primary display application software to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER.
81030165R0.zip VSM uc1 Application Software 818.61 kB 06/04/2025
04-06-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (X12T3 / X12T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and VSM uc3 are updated at the same time!
81027489R0.zip VSM uc2 Application Software 42.66 kB 06/04/2025
04-06-2025 – Release of VSM uc2 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
81027490R0.zip VSM uc3 Application Software 39.44 kB 06/04/2025
04-06-2025 – Release of VSM uc3 Application Software, to be used with HyPro tool Truck series A924, A994, B3C0 (Stage V/ GBIV), A2B0, A6B0 and on Truck serial numbers R007E02500, K876E02500, F214E02500 (Stage V), F214E03500 (T3/T4), D236E02500 (Stage V), D236E03500 (T3/T4), J008E02500 (Stage V), J008E03500 (T3/T4), F222E02500 (Stage V), F222E03500 (QSM11T3 / QSL9T4), D917E02500 (Stage V), D917E03500 (X12T3 / X12T4), K117E03500 (X12T3 / X12T4) AND AFTER. Please make sure the primary display software, VSM uc1, uc2 and uc3 are updated at the same time!
HMC2.4L Woodward fuel system- Toolkit Download.pdf Hyundai Engine – Woodward Toolkit Download Instruction 1.65 MB 02/20/2023
ToolKit is used to create and run custom administration tools for many Woodward electronic products.
MI21_Main_02101_010.zip Hyundai Engine – Woodward Toolkit Software 1.22 MB 02/21/2023
MI21_Main_02101_010.wtool
LS Engine – ECU Programming Guide.zip LS Engine – ECU Programming Guide 1.25 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623A_K_R02.zip LS Engine – ECU Software for new EGR and dry brake 1.29 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623A_K_R02.ulp
0ULSMAPP_C222D11_MXFL5623B_K_R02.zip LS Engine – ECU Software for new EGR and wet brake 1.29 MB 04/08/2024
0ULSMAPP_C222D11_MXFL5623B_K_R02.ulp
0ULSMAPP_C222D11_MXFL5623A_R06.zip LS Engine – ECU Software for old EGR 1.29 MB 04/09/2024
0ULSMAPP_C222D11_MXFL5623A_R06.ulp
Engine >> Kubota
8862725R0.zip Diagnostic Software – Kubota V3800 237.8 MB 09/09/2024
Diagmaster is diagnostic software for Kubota Diesel Engine
8862726R0.zip Diagnostic Software – Kubota WG3800 335.8 MB 09/09/2024
KGST is diagnostic software for Kubota LP Gas Engine
Engine >> Kubota
Engine >> Kubota
Engine >> Kubota
0729801D.zip GM 3.0L Gasoline (Rev D) 256.3 MB 10/09/2018
ljlj
IFAK Cable Upgrade V5.3.ZIP IFAK Cable Upgrade V5.3 14.5 MB 07/01/2013
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> Display
BSTDISP0220.zip Display Application Code (V2.20) 53.79 kB 08/27/2012
4_DE_EN_6008_758_704.pdf 4_DE_EN_6008_758_704.pdf 1.57 MB 01/16/2018
ZF-Testman base platform Operating instructions, use for reference only.
Vehicle >> Vehicle – Programming Interface Software Tool
Controllers >> HVAC
HysterHVACV4.zip Hyster HVAC Update Package 1.56 MB 06/20/2023
26-06-2023 – RS – Uploaded Hyster HVAC Update Package
PEAK-SystemDriverSetup.zip PEAK System Driver Setup 136.2 MB 06/26/2023
26-06-2023 – RS – PEAK System Driver Setup
Vehicle >> Display
Vehicle >> Display V4
81041305R0.zip Primary Display Application Software 14.5 MB 07/23/2025
23-07-2025 – New Release of the primary display application software to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
Vehicle >> VSM HW P/N 8818581 V4
81027519R0.zip VSM uc1 Application Software 560.21 kB 05/22/2025
22-05-2025 – Release of VSM uc1 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
4331653R0.zip VSM uc2 Application Software 48.76 kB 09/20/2021
01-02-2024 – Release of VSM uc2 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
4374734R0.zip VSM uc3 Application Software 37.75 kB 09/15/2023
01-02-2024 – Release of VSM uc3 Application Software, to be used with HyPro tool on Truck series C238, B674, P007, J876, N019, J877, B3C0 (T3) and truck serial numbers R007E02499, K876E02499, F214E02499 (Stage V), F214E03499 (T3/T4), D236E02499 (Stage V), D236E03499 (T3/T4), J008E02499 (Stage V), J008E03499 (T3/T4), F222E02499 (Stage V), F222E03499 (QSM11T3 / QSL9T4), D917E02499 (Stage V), D917E03499 (QSM11T3 / QSL9T4), K117E03499 AND BEFORE.
Controllers >> HVAC
Vehicle >> Display
Vehicle >> VSM
SPED >> M&H Soot Filter
Sped ECUDiagnose v1_2_3_77.zip SPED M+H Diesel Particulate Filter Diagnostic Software 1.03 MB 10/04/2010
GM 2.4 LPG (2010) Non-certified.ZIP GM 2.4 LPG (2010) Non-certified TeleFlex GFI 181.00 kB 07/04/2011
8824222R0.zip Mazda 2.0L LPG (Impco) 689.77 kB 02/04/2016
Reference LD063 R00 – Corrects electronic fuel injection learning symptom, ( ~1600rpm at maximum accelerator pedal ).
8824223R0.zip Mazda 2.2L LPG (Impco) 680.42 kB 12/06/2019
Vehicle >> Display
Vehicle >> VSM
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
8818288R0.pdf Install Instructions – Node Patch for Windows 7 (Readme) 57.97 kB 03/19/2014
8818288R0 (1).pdf Install Instructions, Node Patch for Windows 7 (Readme) 57.97 kB 03/19/2014
524323291R0.zip Node Diagnostic Software 13.2 MB 10/17/2008
8818288R0.zip Node Patch for Windows 7 1.41 MB 03/19/2014
This Patch program allows the use of Parker Node V4.2 Diagnostic software with Windows 7, 32-bit or 64-bit operating systems.
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> Display
Smart Assist Instructions – OEM Update2.pdf Yanmar Smart Assist Direct (SA-D) download and installation instructions.pdf 459.27 kB 05/20/2025
.pdf contains the Yanmar Smart Assist Direct (SA-D) download and installation instructions
81041646R0.zip Field Prog (2.45.5) 19.9 MB 07/22/2025
•Adds support for AN Standard/Value programming (C3C1/C7S1) •Updates SN verification to allow programming if CDF transfer fails previously •Option to bypass SN verification for some HYZ files •Fixed issue with missing libraries when installing tool -User message operation issue corrected
HYG_SA-D Tool Requestnew.pdf HYG_SA-D Tool Request.pdf 209.75 kB 11/02/2022
PDF document contains semi-populated E-main link to request Yanmar SA-D Tool License for single technician.
Vehicle >> Display
Vehicle >> VSM
Engine >> Mazda
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
kubota reprogramming tool.zip Kubota 2.4 Engine Reprogramming Tool 88.3 MB 02/14/2017
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
Controller Firmware Chart R4.pdf Dashboard Controller Firmware Chart R4 (Readme) 28.63 kB 12/22/2014
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> PSI
8813538R4.zip Euro – PSI 2.0L LPG 2.59 MB 01/18/2017
For Euro PSI 2.0L LPG – improved engine speed control response. 8813538R4.zip contains 38901176-5.mot
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Engine >> PSI
8813543R4.zip Euro – PSI 2.4L LPG 2.59 MB 01/18/2017
For Euro PSI 2.4L LPG – improved engine speed control response. (8813543R4.zip contains 38901177-5.mot)
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Hydraulic >> Parker
1595698R8.-161194 (1).zip IFAK Cable Upgrade V6.2.1 6.86 MB 08/23/2022
Hydraulic >> Parker
Hydraulic >> Parker
Hydraulic >> Parker
Vehicle >> Display
Vehicle >> VSM
8806453R0 (1).ZIP GM 4.3L LPG (2006/2007) TeleFlex GFI 276.31 kB 10/17/2006
GFI_86_4-3_LPG.zip GM 4.3L LPG (2008/2009) TeleFlex GFI 174.96 kB 03/03/2009
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
81041646R0.zip Field Prog (v2.45.5) 19.9 MB 07/22/2025
Field Prog version 2.45.5 User message operation issue corrected • Adds support for programming (C3C1/C7S1) series trucks • Updates Serial number verification to allow programming if CDF transfer fails previously • Fixed issue with missing libraries when installing tool.
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
0922701G.zip GM 4.3L LPG (Rev G) 461.50 kB 02/16/2005
Yale – Yanmar SA-D Tool – Request.pdf Yale – Yanmar SA-D Tool Licence – Request.pdf 119.52 kB 03/29/2022
PDF document contains semi-populated E-mail link to request Yanmar SA-D Tool Licence, per Technician.
FieldProg Install and Use Guide v2.42.pdf Field Prog Install and Use Guide v2.42 660.90 kB 08/17/2023
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Engine >> Kubota
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
Vehicle >> Display
Vehicle >> VSM
- Yale Forklift Full Set PDF (Parts & Manuals)
- YALE Forklift DIESEL SERVICE MANUAL
- [ARMS] Yale Forklift Service Manuals 10.2018
- Yale Forklift PDF 14,4GB Service & Parts Manuals Full Model Updated 2019 DVD
- Yale Forklift Spare Parts PDF Full Set
- Yale Forklift Parts Manuals New Models
- Yale PC Service Tool 4.88 [2016] Full Instruction
- Yale Forklift Full Shop Manual DVD
- Yale PC Service Tool 4.89 [2016] Full Instruction
- Yale Forklift Full Set Manual DVD
- Yale PC Service Tool v4.93 [2019]
- Yale PC Service Tool v4.91
- Yale Forklift Program Collection
- Yale Forklift Class 1-5 Service Manuals Updated [02.2022] Full Model DVD
- Yale Forklift Collection Model Parts Catalog CD
