Yale Forklift C909 GDP70VX To GLP190VX Parts Manual 550131971 2025
Brand: Yale
Type of Machine: Forklift
Model: Yale (C909) GDP70VX ; GLP170VX ; GDP175VX36 ; GLP175VX36 ; GDP190VX ; GLP190VX Forklift
Part Number: 550131971
Publication Date: 2025
Number of Pages: 900 Pages
General Truck
Counterweights And Rear Fenders
Fenders Dual Tires
Hood Assembly
Operator Compartment Platform
Seat Pan And Covers
Sound Abatement
Cowl Mount
Floorplates And Covers
Interior Panels And Covers
Full Suspension Seat Swivel And Non Swivel - Sheet 1 Of 4
Full Suspension Seat Recliner And Damper Kits - Sheet 2 Of 4
Full Suspension Seat Service Kits For Non Swivel And Swivel - Sheet 3 Of 4
Full Suspension Seat Attaching Parts Not Included With Seat - Sheet 4 Of 4
Seat Scissors Heavy Duty - Swivel And Non-Swivel Seats
Armrest Slider Assembly
Overhead Guard
Cab Attaching Parts
Cab Assembly - Without Air Conditioning
Cab Assembly - With Air Conditioning
Cab Main Assembly
Cab Right Hand Door Assembly
Cab Left Hand Door Assembly
Cab Window Wiper System
Cab Heater And Hoses - Kubota Diesel
Cab Heater And Hoses - Cummins Qsb 3.3l Diesel
Cab Heater - Without Air Conditioning
Cab Heater Control - Without Air Conditioning
Cab Heater - With Air Conditioning
Cab Heater Control - With Air Conditioning
Heater And Hoses Without Scr Kubota Diesel - With Cab
Heater And Hoses With Scr Kubota Diesel - With Cab - Sheet 1 Of 2
Heater And Hoses With Scr Kubota Diesel - With Cab - Sheet 2 Of 2
Heater Hoses With Scr Kubota Diesel - With Ohg
Cab Air Conditioning System - 3.8l Diesel (1 Of 2)
Cab Air Conditioning System - 3.8l Diesel (2 Of 2)
Condenser Assembly
Mini Lever Module Labels Hydraulic Control Functions
Labels Interior
Labels Exterior
Forks
Forks Optional
Cab Attaching Parts (→ 8/2023)
Cab Assembly - Without Air Conditioning (→ 8/2023)
Cab Assembly - With Air Conditioning (→ 8/2023)
Cab Main Assembly - Page 1 Of 2 (→ 8/2023)
Cab Main Assembly - Page 2 Of 2 (→ 8/2023)
Cab Right Hand Door Assembly (→ 8/2023)
Cab Left Hand Door Assembly (→ 8/2023)
Cab Window Wiper System (→ 8/2023)
Cab Main Assembly (8/2023 →)
Cab Headliner Assembly (8/2023 →)
Cab Steel Doors - Left And Right (8/2023 →)
Cab Sliding Window Assembly - Left And Right Door (8/2023 →)
Engine Assembly - Diesel
Engine Mounting And Torque Converter Kubota Diesel
Radiator Assembly
Radiator Fan, Shroud And Charge Air Hoses
Overhead Exhaust System Kubota 3.8l Diesel T4 - With Scr
Diesel Exhaust Fluid System Group Kubota Diesel 3.8l With Scr
Diesel Exhaust Fluid Tank Assembly Kubota Diesel 3.8l With Scr
Diesel Oxidation Catalyst Muffler Kubota Diesel 3.8l T4f
Scr Muffler Mounting
Scr Assembly
Diesel Particulate Filter Assembly - Kubota 3.8l Diesel
Diesel Particulate Filter Muffler Assembly - Kubota 3.8l Diesel
Air Cleaner Flange And Throttle Valve Kubota 3.8l Diesel T4
Fan Pulley Kubota 3.8l Diesel T4f
Cylinder Block Kubota Diesel 3.8l T4f
Dipstick Kubota Diesel 3.8l T4f
Oil Pan Kubota Diesel 3.8l T4f
Bearing Case Cover Kubota Diesel 3.8l T4f
Cylinder Head Kubota Diesel 3.8l T4f
Inlet And Exhaust Valves Kubota Diesel 3.8l T4f
Rocker Arm Shaft Kubota Diesel 3.8l T4f
Piston And Crankshaft Kubota Diesel 3.8l T4f
Cylinder Head Cover Kubota Diesel 3.8l T4f
Gear Case Kubota Diesel 3.8l T4f
Camshaft And Idle Gear Shaft Kubota Diesel 3.8l T4f
Flywheel And Housing Kubota Diesel 3.8l T4f
Supply Pump Kubota Diesel 3.8l T4f
Fuel Pipe Kubota 3.8l Diesel T4f
Injection Pipe Kubota Diesel 3.8l T4f
Fuel Rail Kubota Diesel 3.8l T4f
Alternator And Pulley Kubota Diesel 3.8l T4f
Starter Kubota Diesel 3.8l T4f
Water Pump Flange And Thermostat Kubota Diesel 3.8l T4f
Water Pump Kubota Diesel 3.8l T4f
Inlet Manifold Kubota Diesel 3.8l T4f
Exhaust Manifold Kubota Diesel 3.8l T4f
Turbocharger Kubota Diesel 3.8l T4f
Turbocharger Oil Plumbing Kubota Diesel 3.8l T4f
Oil Cooler Kubota Diesel 3.8l T4f
Egr Valve Kubota Diesel 3.8l T4f
Egr Cooler Kubota Diesel 3.8l T4f
Injector Harness Kubota Diesel 3.8l T4f
Sensors 3.8l Kubota Diesel With Dpf
Oil Separator Kubota 3.8l Diesel T4f
Breather And Separator Pipes Kubota 3.8l Diesel T4f
Closed Crankcase Breather Heater Kubota 3.8l Diesel T4f
Exhaust System Cummins Qsb 3.3l Diesel - With Cab
Exhaust System Cummins Qsb 3.3l Diesel - With Overhead Guard
Cooling System Cummins Qsb 3.3l Diesel
Radiator Mounting Cummins Qsb 3.3l Diesel
Radiator Assembly Cummins Qsb 3.3l
Fan Assembly Cummins Qsb 3.3l Diesel
Engine Mounting Cummins Qsb 3.3l Diesel
Lifting Bracket Cummins Qsb 3.3l Diesel
Flywheel Cummins Qsb 3.3l
Front Gear Housing Cummins Qsb 3.3l Diesel
Oil Pan Cummins Qsb 3.3l Diesel
Oil Filter And Cooler Cummins Qsb 3.3l Diesel
Oil Filler Arrangement Cummins Qsb 3.3l Diesel
Oil Level Gauge Cummins Qsb 3.3l Diesel
Crankcase Breather Cummins Qsb 3.3l Diesel
Turbocharger Cummins Qsb 3.3l Diesel
Turbocharger Plumbing Cummins Qsb 3.3l Diesel
Water Pump And Pulley Cummins Qsb 3.3l Diesel
Thermostat Cummins Qsb 3.3l Diesel
Water Outlet Connection Cummins Qsb 3.3l Diesel
Exhaust Manifold Cummins Qsb 3.3l Diesel
Air Intake Manifold Cummins Qsb 3.3l Diesel
Starting Aid Cummins Qsb 3.3l Diesel
Vibration Damper Cummins Qsb 3.3l Diesel
Starter Motor Cummins Qsb 3.3l Diesel
Flywheel Housing Cummins Qsb 3.3l Diesel
Cylinder Block Cummins Qsb 3.3l Diesel
Cylinder Head Cummins Qsb 3.3l Diesel
Valve Cover Cummins Qsb 3.3l Diesel
Oil Pump And Front Gear Cover Cummins Qsb 3.3l Diesel
Rocker Arm Shaft Cummins Qsb 3.3l Diesel
Piston And Connecting Rod Cummins Qsb 3.3l Diesel
Crankshaft Cummins Qsb 3.3l Diesel
Camshaft Cummins Qsb 3.3l Diesel
Remote Oil Filter, Hoses, And Attaching Parts Kubota Diesel 3.8l
Engine Assembly Kubota 3.8l Diesel With Doc
Radiator Assembly
Exhaust System Kubota 3.8l Diesel T4f - With Doc
Sensors 3.8l Kubota Diesel T4 With Doc
Exhaust System
Exhaust System Kubota Diesel
Diesel Particulate Filter Assembly - Kubota Diesel
Diesel Particulate Filter Muffler Assembly - Kubota Diesel
Overhead Exhaust System Kubota 3.8l Diesel - With Scr
Cooling System Kubota Diesel
Radiator Assembly Kubota Diesel
Charge Air Cooler Group Kubota Diesel
Charge Air Cooler Group Kubota Diesel 3.8l T4f
Fuel System-Diesel
Air Intake Kubota Diesel
Air Filter
Fuel System Kubota 3.8l Diesel
Fuel System Kubota 3.8l Diesel T4f
Breather And Separator Pipes Kubota Diesel
Oil Separator Kubota Diesel
Air Intake Cummins Qsb 3.3l Diesel
Fuel System Cummins Qsb 3.3l Diesel
Fuel Filter Cummins Qsb 3.3l Diesel
Water Separator Cummins Qsb 3.3l Diesel
Fuel Filter Plumbing Cummins Qsb 3.3l Diesel
Fuel Injector And Injector Plumbing Cummins Qsb 3.3l Diesel
Fuel Injection Pump Cummins Qsb 3.3l Diesel
Fuel Pump Plumbing Cummins Qsb 3.3l Diesel
Fuel Cap Diesel
Throttle Pedal Assembly And Attaching Parts Standard Pedal
Throttle Pedal Assembly And Attaching Parts Foot Directional Control Pedal
Def System Fluid Temperature Control - With Cab
Def System Fluid Temperature Control - With Overhead Guard
Rear Handle Ohg Or Cab
Cowl Electrical Electro-Hydraulic
Electrical Arrangement Cummins Qsb 3.3l Diesel
Engine Electrical System Kubota Diesel
Engine Electrical System Cummins Qsb 3.3l Diesel
Electronic Control Module And Sensors Cummins Qsb 3.3l Diesel
Alternator Electrical Kubota Diesel - Sealed Alternator
Alternator And Pulley Kubota Diesel - Sealed Alternator
Alternator Electrical Kubota Diesel - Standard Alternator
Alternator Electrical Kubota 3.8l Diesel T4 - Type S Alternator
Alternator And Mounting Cummins Qsb 3.3l Diesel
Sealed Alternator And Mounting Cummins Qsb 3.3l Diesel
Electrical System Right Hand Chassis
Battery Cables Kubota Diesel
Battery Disconnect Assembly Diesel
Battery Cables Cummins Qsb 3.3l Diesel
Brake Buzzer
Display Diesel Particulate Filter
Instrument Cluster
Lights Amber Lights - With Three Stage Mast
Lights Brake, Tail, Backup, Side, Turn Signals, Work, Strobe - With Cab
Lights Brake, Tail, Backup, Side, Turn Signals, Work, Strobe - With Overhead Guard
Load Weigh Electrical
Impact Sensor
Mast Electrical
Mini-Lever Controls With Armrest - Three Function (→ 2/2019)
Mini-Lever Controls Three Function - Without Rtst (2/2019 →)
Mini-Lever Controls Three Function - With Rtst (2/2019 →)
Mini-Lever Controls With Armrest - Four Function (→ 2/2019)
Mini-Lever Controls Four Function - Without Rtst (2/2019 →)
Mini-Lever Controls Four Function - With Rtst (2/2019 →)
Remote Key Switch
Seat Belt Switch Adapter
Transmission Electrical System Three Speed Transmission (→ S/N C909v01650t)
Transmission Electrical System Three Speed - Te-08 (S/N C909v01651t ↔ Pending Per Ecn 17195701)
Transmission Electrical System Three Speed Transmission (Pending Per Ecn 17195701 →)
Wire Harness Adapter - Low Fuel Pressure
Wire Harness (Cowl) With Foot Directional Control Or Return To Set Tilt
Wire Harness (Cowl) With Forward And Reverse Lever - Or Without Return To Set Tilt
Wire Harness Disconnect Switch - Kubota
Wire Harness Dpf Display
Wire Harness Ecm
Wire Harness Electronic Control Valve - Three Function
Wire Harness Electronic Control Valve - Four Function
Wire Harness Engine - Cummins Qsb 3.3l Diesel
Wire Harness Engine - Kubota Diesel 3.8l With Scr
Wire Harness (Engine) Kubota 3.8l Diesel With Doc
Wire Harness Lights With Overhead Guard
Wire Harness Rear - Kubota Diesel
Wire Harness Rear - Cummins Qsb 3.3l Diesel
Wire Harness Transmission-Three Speed (→ S/N C909v01650t)
Wire Harness Transmission Standard Three Speed - Used Only On Te-08 Controller (S/N C909v01651t ↔ Pending Per Ecn 17195701)
Wire Harness Transmission-Three Speed (Pending Per Ecn 17195701 →)
Wire Harness (Air Conditioning)
Wire Harness (Air Conditioning) Alternate
Wire Harness Rh Chassis - Kubota Engines (→ S/N C909v01650t)
Wire Harness Rh Chassis - Kubota And Gm (S/N C909v01651t ↔ 10/2019)
Wire Harness Rh Chassis - Kubota 3.8l (→ 10/2019)
Wire Harness Rh Chassis - Kubota 3.8l-With Seat Belt Sequence Module (→ S/N C909v01650t)
Wire Harness Rh Chassis - Gm W/ Seat Belt Seq Intlk (S/N C909v01651t →)
Wire Harness Rh Chassis - Cummins Qsb 3.3l Diesel
Wire Harness Rh Chassis - Cummins Qsb 3.3l Diesel-With Seat Belt Sequence Module
Wire Harness Jumper - Head/Work Lights, 3 Stage Mast
Wire Harness Amber Lights - 3 Stage Mast
Wire Harness Sealed Alternator - Kubota Diesel
Wire Harness Sealed Alternator - Safety - Kubota Diesel
Wire Harness Sealed Alternator-Ds - Cummins Qsb 3.3l Diesel
Wire Harness Alternator-D - Cummins Qsb 3.3l Diesel
Transmission Mount
Torque Converter Cummins Qsb 3.3l Diesel
Transmission Cooling
Transmission Assembly Three Speed - Sheet 1 Of 2
Transmission Assembly Three Speed - Sheet 2 Of 2
Forward Clutch Low And Second Shaft Three Speed Transmission - Fwd1, Range2
Forward Clutch High And Output Shaft Three Speed Transmission - Fwd2
Reverse Clutch And First Shaft Three Speed Transmission - Rev1, Range 1
Control Valve Three Speed Transmission
Charge Pump
Pump Drive
Drive Axle
Drive Axle And Attaching Parts Wet Brake
Drive Axle Housing And Hub
Wet Brake Assembly
Drive Tire And Wheel
Drive Tire And Wheel Optional
Steering Wheel And Column
Steering Column Assembly
Steer Axle
Steer Axle
Steer Cylinder
Steer Cylinder
Steering Lines
Steering Control Unit
Steer Tire And Wheel
Brake Cooling System Single And Dual Pedal
Brake Valve Assembly
Brake Pedal Mounting
Brake Pedal Single Pedal
Brake Pedal Dual Pedal
Park Brake Assembly
Hydraulic Supply And Return
Unloader Valve
Gear Pump Assembly
Gear Pump
Dipstick And Breather
Hydraulic Filter
Hoist Hose And Attaching Parts
Control Valve And Steering Unit Assembly Three Function
Control Valve And Steering Unit Assembly Four Function
Valve Assembly, Lift And Lower Electronic Control Valve - Three And Four Function
Tilt Section Three And Four Function
Electro Hydraulic Poppet Valve Three And Four Function
Auxiliary One Section Three And Four Function
Auxiliary Two Section Four Function
Outlet Section Three And Four Function
Tilt Hydraulics
Tilt Cylinder And Mast Installation
Tilt Cylinders
Mast-Two Stage Limited Free-Lift
Mast And Carriage Assembly Two Stage Limited Free Lift - A643 Mast F80 Mast Series
Mast And Carriage Assembly Two Stage Limited Free- Lift (A643) - 5500 And 6000 Mm With Iss Carriage
Outer Mast Two Stage Limited Free-Lift - A643 Mast F80 Mast Series
Outer Mast Two Stage Limited Free-Lift - F80 Mast Series Without Carriage
Inner Mast Two Stage Limited Free-Lift - A643 Mast F80 Mast Series
Inner Mast Two Stage Limited Free-Lift - F80 Mast Series Without Carriage
Main Lift Cylinder Two Stage Limited Free-Lift - F80 Mast Series
Carriage F80 Mast Series
Header Hoses (F80 Mast Series) Two Stage Limited Free- Lift
Header Hoses (F80 Mast Series) Two Stage Limited Free Lift - Lift Height 5500mm And 6000mm
Header Hoses (A643 Mast Series) Two Stage Limited Free Lift - 5500 And 6000 Mm With Iss Carriage
Outer Mast Two Stage Limited Free-Lift - F90 Mast Series
Inner Mast Two Stage Limited Free-Lift - F90 Mast Series
Main Lift Cylinder Two Stage Limited Free-Lift - F90 Mast Series
Carriage F90 Mast Series
Header Hoses Two Stage Limited Free Lift - F90 Mast Series
Auxiliary Function Hoses Two Stage Limited Free-Lift
Fork Positioner Assembly
Mast-Three Stage Full Free-Lift
Mast And Carriage Assembly Three Stage Full Free-Lift - F80 Mast Series
Outer Mast Three Stage Full Free-Lift - F80 Mast Series
Intermediate Mast Three Stage Full Free-Lift - F80 Mast Series
Inner Mast Three Stage Full Free-Lift - F80 Mast Series
Main Lift Cylinder Three Stage Full Free-Lift - F80 Mast Series
Free Lift Cylinder Three Stage Full Free-Lift - F80 Mast Series
Outer Mast Three Stage Full Free-Lift - F90 Mast Series
Intermediate Mast Three Stage Full Free-Lift - F90 Mast Series
Inner Mast Three Stage Full Free-Lift - F90 Mast Series
Main Lift Cylinder Three Stage Full Free-Lift - F90 Mast Series
Free Lift Cylinder Three Stage Full Free-Lift - F90 Mast Series
Carriage Standard Hook Type - F90 Mast Series
Carriage Integral Side-Shift - F90 Mast Series
Fork Positioner Three Stage Full Free-Lift
Header Hoses Three Stage Full Free-Lift
Auxiliary Function Hoses Three Stage Full Free-Lift
Options
Strobe Light Led
Fire Extinguisher With Cab
Fire Extinguisher With Overhead Guard
Dual Mirrors With Cab
Dual Mirrors With Overhead Guard
Accumulator
Accumulator Long Wheel Base (5/2022 →)
Rain Top
Back-Up Alarm
Lifting Eye
Field Conversion Kits
Conversion Kit Transmission Controller - Apc214 To Apc312
Return To Set Tilt Kits
E-Hydraulic Control Conversion Kits
Add On Option Kits
Brake And Inching Pedal Conversion
Seat Conversion Kits
Miscellaneous Conversion Kits
Add On Option Kits Lights
Replacement Kits
Add On Telemetry Kits
Repair Kits
Numerical Index
User Support Information
Brand: Yale
General Truck
Fenders Dual Tires
Hood Assembly
Seat Pan And Covers
Sound Abatement
Cowl Mount
Overhead Guard
Cab Attaching Parts
Cab Main Assembly
Condenser Assembly
Labels Interior
Labels Exterior
Forks
Forks Optional
Radiator Assembly
Scr Assembly
Radiator Assembly
Exhaust System
Fuel System-Diesel
Air Filter
Fuel Cap Diesel
Brake Buzzer
Instrument Cluster
Impact Sensor
Mast Electrical
Remote Key Switch
Wire Harness Ecm
Transmission Mount
Charge Pump
Pump Drive
Drive Axle
Wet Brake Assembly
Steer Axle
Steer Axle
Steer Cylinder
Steer Cylinder
Steering Lines
Park Brake Assembly
Unloader Valve
Gear Pump Assembly
Gear Pump
Hydraulic Filter
Tilt Hydraulics
Tilt Cylinders
Options
Strobe Light Led
Accumulator
Rain Top
Back-Up Alarm
Lifting Eye
Add On Option Kits
Replacement Kits
Repair Kits
Numerical Index
- Yale Electric For MPB040 E (B827) MPW045 E (B802) Service Maintenance Manual
- Yale Forklift A875 Maintenance and Repair
- Yale Electric For Model MPB 040 AC (A827) Parts Manual
- YALE FORKLIFT A810 - GLP_GDP16-20AF_BF PARTS MANUALS
- Yale Class 5 Forklift Full Service Manual Tranining DVD
- Yale Electric For ERC ERP 030-040 TG (E807) Service Maintenance Manual
- Yale Electric For Model MP,MPB 040 AC Parts Manual
- Yale Model GDP/GLP20-30RF/TF (A875) Parts Manual
- Yale Electric For Model MPE 060-080LC, MPE 060-080SC (A803) Parts Manual
- Yale Forklift GDP030AF GDP040AF (B810) Parts Manual 524144914
- Yale Electric For Model ERC 030-040 AG-BG (A814) Service Maintenance Manual
- Yale Forklift ERC 45-70 VG (968) Workshop Manual
- Yale Electric For MCW025-E MCW030-E MCW040-E (C819) MSW030-E MSW040-E (C820 MRW020-E MRW030-E (C821)
- Yale Electric For MPE080-F(B890) MPE060-F(B896) Service Maintenance Manual
- Yale Electric For ERC 030-040 AF-AG-BG ERC-ERP 16-20 AAF(A814) Service Maintenance Manual
