Yale Forklift A7R8 KDP35UX KDP50UX KDP70UX 4WD Parts Service Manual 2024
Brand: Yale
Type of Machine: Forklift
Type of Manual: Service Manual, Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Yale A7R8 KDP35UX KDP50UX KDP70UX 4WD Forklift
Year: 2024
List of Files:
PARTS MANUAL 550257534-[A7R8]-Y-PM-US-EN-(08-2024).pdf
Frame
FRAME AND COUNTERWEIGHT
HOODS AND COVERS, FLOORPLATES, AND SEAT
OVERHEAD GUARD
DECALS
ENGINE ASSEMBLY - MITSUBISHI D04EG
CYLINDER HEAD
LIFTING EYE
PLUG CYLINDER HEAD
VALVE MECHANISM
ROCKER COVER
CAMSHAFT AND TAPPET
CRANKCASE
DRAIN COCK AND PIPE
PLUG CRANKCASE
PLUG CRANKCASE
REAR PLATE
MAIN METAL
TIMING GEAR CASE
OIL PAN AND LEVEL GAUGE
PISTON
CONNECTING ROD
CRANKSHAFT
CRANK PULLEY
FLYWHEEL
TIMING GEAR
SIDE PTO
INLET SYSTEM
INLET PIPE
EXHAUST SYSTEM MANIFOLD
EXHAUST SYSTEM EGR GAS PIPE
EXHAUST SYSTEM EGR SYSTEM
OIL PUMP
OIL STRAINER
OIL SYSTEM
OIL COOLER
OIL FILTER
BREATHER
WATER PUMP
WATER PUMP PULLEY
COOLING SYSTEM
FAN
V-BELT
FUEL SYSTEM
FUEL SYSTEM INJECTOR
FUEL SYSTEM COMMON RAIL
FUEL FILTER
INJECTION PUMP
INJECTION PUMP INNER PARTS
STARTER ASSEMBLY 12V-2.2KW
GLOW PLUG AND WIRE
ALTERNATOR
ALTERNATOR ASSEMBLY 12V-50A
ENGINE CONTROL
INSTRUMENT SENSOR
INSTRUMENT HARNESS
ACCESSORY
NAMEPLATE
OVERHAUL GASKET KIT
ENGINE SYSTEM
ENGINE MOUNTING YANMAR 98 ENGINE
ENGINE MOUNTING MITSUBISHI S4S AND D04EG ENGINES
ENGINE MOUNTING KUBOTA V2403 ENGINE
ENGINE MOUNTING KUBOTA V2607 ENGINE
COOLING SYSTEM YANMAR 98 ENGINE
COOLING SYSTEM MITSUBISHI S4S AND D04EG ENGINE
COOLING SYSTEM KUBOTA V2403 AND V2607 ENGINES
EXHAUST SYSTEM YANMAR ENGINE
EXHAUST SYSTEM MITSUBISHI S4S ENGINE
EXHAUST SYSTEM MITSUBISHI D04EG ENGINE
EXHAUST SYSTEM KUBOTA V2403 ENGINE
EXHAUST SYSTEM KUBOTA V2607 ENGINE
ENGINE ASSEMBLY - KUBOTA V2607
CRANKCASE
OIL PAN
DIPSTICK AND GUDE
INLET VALVE AND EXHAUST VALVE
CYLINDER HEAD
ROCKER ARM SHAFT
HEAD COVER
FRONT COVER
PISTON AND CRANKSHAFT
FLYWHEEL
CAMSHAFT AND IDLE GEAR SHAFT
SUPPLY PUMP
FUEL FILTER
SEPARATOR
INJECTOR AND GLOW PLUG
INJECTION PIPE
FUEL PUMP ELECTRICAL
COMMON RAIL
ALTERNATOR
ALTERNATOR COMPONENT PARTS
STARTER
STARTER (COMPONENT PARTS)
SWITCH AND SENSOR
INJECTOR HARNESS
WIRE HARNESS BRACKET
WATER FLANGE AND THERMOSTAT
WATER PUMP
FAN AND PULLEY
INLET MANIFOLD
AIR CLEANER FLANGE AND THROTTLE VALVE
EXHAUST MANIFOLD
EGR VALVE
TURBO CHARGER
AIR CLEANER
DIESEL PARTICULATE FILTER MUFFLER
DIESEL PARTICULATE FILTER MUFFLER SENSOR
PRESSURE PIPE
BREATHER PIPE AND SEPARATOR PIPE
OIL SEPARATOR
OIL PIPE TURBO CHARGER
OIL COOLER
ECU AND ACCESSORIES AND SERVICE PARTS
UPPER GASKET KIT OPTION
LOWER GASKET KIT OPTION
OIL FILTER
ENGINE ASSEMBLY - YANMAR 98
CYLINDER BLOCK
ENGINE GASKET KIT
CYLINDER HEAD
CRANKSHAFT, PISTONS, AND FLYWHEEL
CAMSHAFT AND DRIVE GEAR
INTAKE AND EXHAUST MANIFOLD
GEAR HOUSING
OIL PAN AND FLYWHEEL HOUSING
OIL SYSTEM
FUEL INJECTION PUMP
FUEL INJECTION SYSTEM
FUEL FILTER AND WATER SEPARATOR
STARTER MOTOR
GENERATOR
WATER COOLING SYSTEM
FUEL SYSTEM
AIR CLEANER ASSEMBLY YANMAR 98 ENGINE, MITSUBISHI S4S AND D04EG ENGINES
AIR CLEANER ASSEMBLY KUBOTA V2403 AND V2607 ENGINES
ACCELERATOR PEDAL YANMAR 98 AND MITSUBISHI S4S ENGINES
ACCELERATOR PEDAL MITSUBISHI D04EG ENGINE
FUEL SYSTEM YANMAR 98 AND MITSUBISHI S4S ENGINES
FUEL SYSTEM MITSUBISHI D04EG ENGINE
FUEL SYSTEM KUBOTA V2403 ENGINE
FUEL SYSTEM KUBOTA V2607 ENGINE
ELECTRICAL SYSTEM
ELECTRICAL SYSTEM PAGE 1 OF 4
ELECTRICAL SYSTEM PAGE 2 OF 4
ELECTRICAL SYSTEM PAGE 3 OF 4
ELECTRICAL SYSTEM PAGE 4 OF 4
ELECTRICAL SYSTEM YANMAR 98 AND MITSUBISHI S4S ENGINES - PAGE 1 OF 2
ELECTRICAL SYSTEM YANMAR 98 AND MITSUBISHI S4S ENGINES - PAGE 2 OF 2
ELECTRICAL SYSTEM MITSUBISHI D04EG ENGINE
ELECTRICAL SYSTEM KUBOTA V2403 ENGINE - PAGE 1 OF 3
ELECTRICAL SYSTEM KUBOTA V2403 ENGINE - PAGE 2 OF 3
ELECTRICAL SYSTEM KUBOTA V2403 ENGINE - PAGE 3 OF 3
ELECTRICAL SYSTEM KUBOTA V2607 ENGINE - PAGE 1 OF 3
ELECTRICAL SYSTEM KUBOTA V2607 ENGINE - PAGE 2 OF 2
ELECTRICAL SYSTEM KUBOTA V2607 ENGINE - PAGE 3 OF 3
FUSE BOX
DISPLAY
BATTERY AND TRAY
TRANSMISSION
TRANSMISSION PAGE 1 OF 3
TRANSMISSION PAGE 2 OF 3
TRANSMISSION PAGE 3 OF 3
HIGH SPEED SHAFT ASSEMBLY
LOW SPEED SHAFT ASSEMBLY
INPUT SHAFT ASSEMBLY
OUTPUT SHAFT ASSEMBLY
DIFFERENTIAL ASSEMBLY FRONT
DIFFERENTIAL ASSEMBLY REAR
DRIVE SHAFT
GEAR PUMP SHAFT
TOR-CON OIL COOLING SYSTEM
Drive Axle
DRIVE AXLE
WHEEL BRAKE ASSEMBLY LH
WHEEL BRAKE ASSEMBLY RH
DRIVE WHEEL AND TIRE
STEERING SYSTEM
STEERING AXLE ASSEMBLY
STEERING SYSTEM
STEERING AXLE MOUNTING
STEER WHEEL AND TIRE
BRAKE SYSTEM
BRAKE AND INCH CONTROL
HAND BRAKE
FOOT BRAKE
MASTER CYLINDER
HYDRAULIC SYSTEM
HYDRAULIC TANK
HYDRAULIC LEVERS TWO FUNCTION
HYDRAULIC LEVERS THREE FUNCTION
HYDRAULIC LEVERS FOUR FUNCTION
HYDRAULIC SYSTEM STEER SYSTEM
HYDRAULIC SYSTEM SUPPLY AND RETURN
HYDRAULIC SYSTEM TILT SYSTEM
TILT CYLINDER
Mast-Two Stage Limited Free-Lift
MAST ASSEMBLY
MAST HYDRAULIC SYSTEM TWO FUNCTION
MAST HYDRAULIC SYSTEM THREE FUNCTION - KDP35UX 4WD
MAST HYDRAULIC SYSTEM THREE FUNCTION - KDP50UX AND KDP70UX 4WD
MAST HYDRAULIC SYSTEM FOUR FUNCTION - KDP35UX
MAST HYDRAULIC SYSTEM FOUR FUNCTION - KDP50UX AND KDP70UX 4WD
LIFT CYLINDER
Mast-Three Stage Full Free-Lift
MAST ASSEMBLY KDP35UX 4WD
MAST ASSEMBLY KDP50UX 4WD, KDP70UX 4WD
MAST HYDRAULIC SYSTEM TWO FUNCTION - KDP35UX 4WD
MAST HYDRAULIC SYSTEM TWO FUNCTION - KDP50UX 4WD, KDP70UX 4WD
MAST HYDRAULIC SYSTEM THREE FUNCTION - KDP50UX 4WD, KDP70UX 4WD
MAST HYDRAULIC SYSTEM FOUR FUNCTION - KDP35UX 4WD
MAST HYDRAULIC SYSTEM FOUR FUNCTION - KDP50UX 4WD, KDP70UX 4WD
FRONT LIFT CYLINDER KDP35UX 4WD
FRONT LIFT CYLINDER KDP50UX 4WD, KDP70UX 4WD
REAR LIFT CYLINDER KDP35UX 4WD
REAR LIFT CYLINDER KDP50UX 4WD, KDP70UX 4WD
FORKS
LOAD BACKREST AND CARRIAGE TWO STAGE LIMITED FREE-LIFT
LOAD BACKREST AND CARRIAGE THREE STAGE FULL FREE-LIFT
OPTIONAL EQUIPMENT
LDSJ SIDESHIFT KDP35UX, KDP50UX
LDSJ SIDESHIFT KDP70UX
CASCADE SIDESHIFT
SEAT - NON SUSPENSION VINYL YH-38
SEAT - NON SUSPENSION VINYL SC29-36
SEAT - NON SUSPENSION VINYL SC29-37
SEAT - FULL SUSPENSION SC29-25, SC29-44
FIRE EXTINGUISHER
SPARK ARRESTER
SIDESHIFTER CYLINDER
MULTI-WAY VALVE
SIDESHIFT CYLINDER
HAND BRAKE ALARM
POSITIONER CYLINDER
SIDESHIFT FORK POSITIONER HYDRAULIC SYSTEM MAST-TWO STAGE LIMITED FREE LIFT - KDP70UX
SIDESHIFT FORK POSITIONER HYDRAULIC SYSTEM MAST-THREE STAGE FULL FREE LIFT - KDP70UX
SIDESHIFT FORK POSITIONER HYDRAULIC SYSTEM MAST-THREE STAGE FULL FREE LIFT - KDP35UX, KDP50UX
SIDESHIFT FORK POSITIONER HYDRAULIC SYSTEM MAST-TWO STAGE LIMITED FREE LIFT - KDP35UX, KDP50UX
SIDESHIFT FORK POSITIONER KDP70UX
SIDESHIFT FORK POSITIONER KDP35UX, KDP50UX
INTEGRAL SIDESHIFT MAST-TWO AND THREE STAGE LIMITED FREE LIFT - KDP70UX
INTEGRAL SIDESHIFT MAST-TWO AND THREE STAGE LIMITED FREE LIFT - KDP50UX
INTEGRAL SIDESHIFT MAST-TWO AND THREE STAGE LIMITED FREE LIFT - KDP35UX
INTEGRAL SIDESHIFT HYDRAULIC SYSTEM MAST-THREE STAGE FULL FREE LIFT
INTEGRAL SIDESHIFT HYDRAULIC SYSTEM MAST-TWO STAGE LIMITED FREE LIFT
HEATER
HEATER WITH HOSES
TOP FRAME AND MOUNTING
REAR FRAME COMPONENTS
BELT WHEEL MITSUBISHI S4S ENGINE
BELT WHEEL YANMAR 98 ENGINE
AIR CONDITIONER
AIR CONDITIONER TOP COVER ASSEMBLY
AIR CONDITIONER AND MOUNTING
DOOR LOCK ASSEMBLY
DOOR SYSTEM
FULLY ENCLOSED CAB
CAP ASSEMBLY
FAN
TILT CYLINDER JACKET ASSEMBLY
SEMI-CLOSED DRIVER ROOM
LIGHT FRAME
FRONT BLOCKING COMPONENTS
FRONT GLASS AND MOUNTING
SWITCHING DEVICE
WEIGHING SYSTEM
CYLINDER ASSEMBLY 6781A-4439, 6062748
CYLINDER ASSEMBLY GC45-00-ZT
WIPER 550X450
WIPER
REAR WIPER
NUMERICAL INDEX
USER SUPPORT INFORMATION
Report an Error or Omission.pdf
SERVICE MANUAL 550257522-8000YRM2383-(07-2023)-US-EN.pdf
Forklift Truck Main Parts
Description of Forklift Truck Main Parts
Forklift Main Technical Parameters
Power System
Engine System
Drive Axle
Rear Steering Drive Axle
Disassembly and Assembly
Disassembly of Rear Steering Drive Axle Assembly
Adjustment of the Axle
Maintenance and Repair
Disassembly, Assembly, and Adjustment
Overview
Overview
Brake Master Cylinder
Wheel Brake
Automatic Clearance Regulator
Manual Brake
Adjustment of Brake Pedal
Maintenance
Main Pump
Control Valve and Bypass Valve
Hydraulic System Main Oil Circuit
Lift Cylinder
Limiting Valve
Tilt Cylinder
Main Oil Pump
Oil Filling Instructions
Troubleshoot Hydraulic System
Lifting System
Safety Procedures When Working Near Mast
Inside and Outside Masts
Bracket
Adjust
Overview
Engine Operations
Truck Operations
Instrument
Electrical Box
Battery
Electrical Schematics
DPF Regeneration Control (Only for the Trucks Equipped with Kubota V2403 or V2607 Engine)
Troubleshooting Codes for Kubota Engine
Troubleshoot Electrical System
Drive, Operation, and Routine Maintenance of Forklift Truck
Transporting the Forklift Truck
Towing
Long-Term Storage of Forklift Truck
Maintenance Procedures Prior to Operation
Cautions During the Operation
Brand: Yale
Year: 2024
List of Files:
Frame
OVERHEAD GUARD
DECALS
CYLINDER HEAD
LIFTING EYE
PLUG CYLINDER HEAD
VALVE MECHANISM
ROCKER COVER
CAMSHAFT AND TAPPET
CRANKCASE
DRAIN COCK AND PIPE
PLUG CRANKCASE
PLUG CRANKCASE
REAR PLATE
MAIN METAL
TIMING GEAR CASE
PISTON
CONNECTING ROD
CRANKSHAFT
CRANK PULLEY
FLYWHEEL
TIMING GEAR
SIDE PTO
INLET SYSTEM
INLET PIPE
OIL PUMP
OIL STRAINER
OIL SYSTEM
OIL COOLER
OIL FILTER
BREATHER
WATER PUMP
WATER PUMP PULLEY
COOLING SYSTEM
FAN
V-BELT
FUEL SYSTEM
FUEL FILTER
INJECTION PUMP
GLOW PLUG AND WIRE
ALTERNATOR
ENGINE CONTROL
INSTRUMENT SENSOR
INSTRUMENT HARNESS
ACCESSORY
NAMEPLATE
OVERHAUL GASKET KIT
ENGINE SYSTEM
CRANKCASE
OIL PAN
DIPSTICK AND GUDE
CYLINDER HEAD
ROCKER ARM SHAFT
HEAD COVER
FRONT COVER
FLYWHEEL
SUPPLY PUMP
FUEL FILTER
SEPARATOR
INJECTION PIPE
COMMON RAIL
ALTERNATOR
STARTER
SWITCH AND SENSOR
INJECTOR HARNESS
WATER PUMP
FAN AND PULLEY
INLET MANIFOLD
EXHAUST MANIFOLD
EGR VALVE
TURBO CHARGER
AIR CLEANER
PRESSURE PIPE
OIL SEPARATOR
OIL COOLER
OIL FILTER
CYLINDER BLOCK
ENGINE GASKET KIT
CYLINDER HEAD
GEAR HOUSING
OIL SYSTEM
FUEL INJECTION PUMP
STARTER MOTOR
GENERATOR
FUEL SYSTEM
ELECTRICAL SYSTEM
FUSE BOX
DISPLAY
BATTERY AND TRAY
TRANSMISSION
DRIVE SHAFT
GEAR PUMP SHAFT
Drive Axle
DRIVE AXLE
STEERING SYSTEM
STEERING SYSTEM
BRAKE SYSTEM
HAND BRAKE
FOOT BRAKE
MASTER CYLINDER
HYDRAULIC SYSTEM
HYDRAULIC TANK
TILT CYLINDER
MAST ASSEMBLY
LIFT CYLINDER
FORKS
OPTIONAL EQUIPMENT
CASCADE SIDESHIFT
FIRE EXTINGUISHER
SPARK ARRESTER
MULTI-WAY VALVE
SIDESHIFT CYLINDER
HAND BRAKE ALARM
POSITIONER CYLINDER
HEATER
HEATER WITH HOSES
AIR CONDITIONER
DOOR LOCK ASSEMBLY
DOOR SYSTEM
FULLY ENCLOSED CAB
CAP ASSEMBLY
FAN
LIGHT FRAME
SWITCHING DEVICE
WEIGHING SYSTEM
WIPER 550X450
WIPER
REAR WIPER
NUMERICAL INDEX
Power System
Engine System
Drive Axle
Overview
Overview
Wheel Brake
Manual Brake
Maintenance
Main Pump
Lift Cylinder
Limiting Valve
Tilt Cylinder
Main Oil Pump
Lifting System
Bracket
Adjust
Overview
Engine Operations
Truck Operations
Instrument
Electrical Box
Battery
Towing
- Yale Electric For MPB040 E (B827) MPW045 E (B802) Service Maintenance Manual
- Yale Forklift A875 Maintenance and Repair
- Yale Electric For Model MPB 040 AC (A827) Parts Manual
- YALE FORKLIFT A810 - GLP_GDP16-20AF_BF PARTS MANUALS
- Yale Class 5 Forklift Full Service Manual Tranining DVD
- Yale Electric For ERC ERP 030-040 TG (E807) Service Maintenance Manual
- Yale Electric For Model MP,MPB 040 AC Parts Manual
- Yale Model GDP/GLP20-30RF/TF (A875) Parts Manual
- Yale Electric For Model MPE 060-080LC, MPE 060-080SC (A803) Parts Manual
- Yale Forklift GDP030AF GDP040AF (B810) Parts Manual 524144914
- Yale Electric For Model ERC 030-040 AG-BG (A814) Service Maintenance Manual
- Yale Forklift ERC 45-70 VG (968) Workshop Manual
- Yale Electric For MCW025-E MCW030-E MCW040-E (C819) MSW030-E MSW040-E (C820 MRW020-E MRW030-E (C821)
- Yale Electric For MPE080-F(B890) MPE060-F(B896) Service Maintenance Manual
- Yale Electric For ERC 030-040 AF-AG-BG ERC-ERP 16-20 AAF(A814) Service Maintenance Manual
