118
6,911
Xtreme Forklift XR1045 Parts Manual 2023
Brand: Xtreme
Type of Machine: Forklift
Type of Manual: Parts Manual, Electrical Diagram
Model: Xtreme XR1045 Forklift
Publication Date: 2023
Number of Pages: 409 Pages
Basic Assembly
Final Assembly
Chassis Assembly - Engine
Chassis Assembly - Axles
Chassis Assembly - Covers And Console
Pintle Hook Assembly
Boom Lights
Tail Or Turn Lights
Labels
Labels And Load Charts
Engine Transmission Assembly
Radiator Assembly
Overflow Tank Assembly
Air Cleaner Assembly
Fuel Tank Assembly
Transmission, Axles And Driveshafts
Transmission And Pump Assembly
Dipstick Tube Assembly
Front Axle Assembly
Rear Axle Assembly
Steering, Brakes, Wheels And Tires
Steering Column Assembly
Brake Valve Assembly
Kit, Mico Brake Pedal Xr1045-Xr2045 Assembly
Brake Valve Assembly, Mico
Accumulator Assembly
Accumulator Charge Valve Assembly
Brake Pressure Switch Assembly
Wheel Tire Assembly
Hydraulic Tank Assembly
Hydraulic Tank Lid Assembly
High-Pressure Filter Or Steering Valve Assembly
Rear Steering Valve Assembly
Distribution Manifold Assembly
Distribution Manifold Assembly - Valves (25211-001)
Isolation Manifold Assembly
Boom Manifold Assembly
Operator Control Valve Assembly
Front Handle Assembly
Sway Valve Handle Assembly
Rear Handle Assembly
Master Cylinder Assembly
Lift Cylinder Assembly
Extend Cylinder Assembly
Cylinder Collar Assembly
Extend Cylinder Housing Assembly
Extend Cylinder Support Assembly
Extend Cylinder Pin Assembly
Carriage Tilt Cylinder Assembly
Tilt Cylinder Sub-Assembly
Rotate Cylinder Assembly
Rotate Cylinder Subassemby
Axle Sway Cylinder Assembly-Front (29363-000)
Axle Sway Cylinder Assembly - Rear (29364-000)
Axle Sway Cylinder Sub-Assembly (29362-000r1)
Rear Axle Lock Manifold Assembly
Axle Cylinder Subassembly
Boom Hose Kit
Chassis Hose Kit
Rear Steer Hose Kit
Engine Harness 74hp 3.8 Cummins
Electrical Assembly
Electrical Center Assembly
Terminal Strip Assembly
Engine Replay Assembly
Battery Disconnect Switch Assembly
Fuse Block Assembly
Solenoid Assembly
Boom
Boom Assembly
Outer Boom Assembly
Mid Boom Assembly
Inner Boom Assembly
Inner Boom Subassembly
Angle Indicator Assembly
Adapter Assembly
Slide Block Assembly
Outer Boom Roller Assembly
Mid Boom Roller Assembly
Roller Assembly
Roller Assembly
Chain Sheave Assembly
Belleville Spring Stack
Tube Clamp Assembly No 2
Hose Clamp Assembly
Cab And Covers
Cab Assembly
Seat Assembly (14666-000)
Enclosed Cab Assembly
Front Control Console Assembly
Front Control Panel Assembly
Control Enclosure Subassembly
Side Control Console Assembly
Side Console Cover Assembly
Side Console Sub-Assembly
Accelerator Pedal Assembly
Front Cover Assembly
Engine Cover Assembly
Radiator Cover Assembly
Battery Cover Assembly
Rear Light Assembly
Radiator Shroud Assembly
Filler Plate Assembly
Console Roller Assembly
Standard Carriage Assembly
Carriage Pin Assembly
Fork Positioning Carriage Assembly
Fork Adjusting Manifold Assembly
Appendix A:pages Index
Appendix B:parts Index
