Momed80
151
36,345
Xinchai Diesel Engine 498BPG A498BPG 498BT A498BT Parts Catalog 2008 EN ZH
Download this document, you need 250 Gallons
Language: English, Chinese
Brand: Xinchai
Type of Machine: Diesel Engine
Model: Xinchai 498BPG A498BPG 498BT A498BT Diesel Engine
Publication Date: 2008
Number of Pages: 60 Pages
498BPG 机体总成及附件-Body assembly and accessory
498BT 机体总成及附件-Body assembly and accessory
498BPG 气缸盖及配气机构-Cylinder head and gas exchanging system assembly
498BT 气缸盖及配气机构-Cylinder head and gas exchanging system assembly
498BPG 油底壳总成-Oil sump assembly
498BT 油底壳总成-Oil sump assembly
活塞连杆总成-Piston connecting rod assembly
498BPG 曲轴飞轮总成-Crankshaft flywheel assembly
498BT 曲轴飞轮总成- Crankshaft flywheel assembly
498BPG 正时齿轮传动系总成Timing gear train assembly
498BT 正时齿轮传动系总成Timing gear train assembly
气缸盖罩总成--Cylinder head cover assembly
机油泵、机油管路总成-Oil pump and oil pipe assembly
498BPG 冷却水泵、风扇部件-Cooling water pump and fan assembly
498BT 冷却水泵、风扇部件-Cooling water pump and fan assembly
燃油供油系统-Fuel supply system assembly
喷油泵总成-Fuel pump assembly
调速器-Governor
起动电机总成-Starting motor assembly
充电发电机总成-Charging generator assembly
机油滤清器总成-Oil filter assembly
