XCMG Wheel Loader ZL50GN Parts Catalog
Brand: XCMG
Type of Machine: Wheel Loader
Model: XCMG ZL50GN Wheel Loader
Pin Number: XUG0050GJRCB15577
Number of Pages: 604 Pages
252120330 50gnv Wheel Loader
Bucket
252110032 Bucket
252110006 Bucket
Drive Axle System
252115132 Drive Axle System
252919352 Fixed Tire Assy
800302232 Steel Ring
252120712 Front Axle Assy
275102460 Front Axle Assy
252115202 Front Drive Shaft Installation
252113083 Front Drive Shaft Assembly
252115313 Support Seat Assembly Installation
800358526 Support Seat Assembly
252115204 Intermediate Drive Shaft Installation
252113085 Intermediate Shaft Assembly
252911475 Fixed Rear Drive Shaft Assy
800363722 Rear Drive Shaft Assembly
252919103 Rear Axle Assy
275102525 Rear Alxe Assy
252118293 Front And Rear Axle Brake Lines
252911479 Fixed Tire Assy
Transmission And Torque Converter System
252115353 Transmission And Torque Converter System
252115507 Engine-Gearbox Butt Assy
272200753 Zl50 Transmission Assembly
251806247 Ventilator Assy
252911394 Filter
803440533 Filter
252912236 Bracket
252919192 Shock Absorbers
252913917 Oil Pipe Assembly
Undercarriage System
252917807 Undercarriage System
252917805 Right Box
252917796 Right Rear Fender
252917791 Left Box
252917006 Left Ladder
252917793 Left Rear Fender
Rear Frame System
252121764 Rear Frame System
252910958 Fixed Subframe Assy
252121756 Baffle Assembly
252910960 Fixed Steering Pin Assy
252118038 Fixed Rod Assembly
252910961 Cab Fixing Assy
252910963 Engine Hood Fixing Assy
252912585 Subframe Grease Pipe Assy
252115110 Ballast Assy
252916966 Counterweight
Engine Hood Assembly
252116687 Engine Hood Assembly
252116689 Engine Hood Assembly (Befor Painted)
Engine Assembly
252117345 Engine Assembly
252100842 Accelerator Control
800157620 Engine
860167846 Machine Body Combined
860506858 Flywheel Housing Group
860506859 Timing Gear Housing Group
860500821 Crankshaft Sun Assy(Weichai Parts)
860506862 Flywheel Group
860506863 Piston And Connecting Rod Group
860167783 Cylinder Head Subassembly
860167856 Cylinder Head Cover Group
860167855 Valve Train Group
860167851 Camshaft Gear Cover Group
860167850 Crankshaft Pulley Group
860167849 Oil Pan Group
860500830 Dipstick Combination Group
860167848 Oil Pump Group
860500832 Oil Strainer Group
860500833 Engine Oil Cooler Cover Group
860500834 Engine Oil Filter Assy
860167847 Oil Filling Tube Group
860167790 Oil-Gas Separator Group
860167791 Water Pump Group
860167792 Water Pipe Connector Group
860167793 Water Outlet Pipe Group
860167794 Fan Bracket Group
860167795 Fan And Hub Group
860167796 Fuel Injection Pump Group
860167799 Fuel Injection Pump Group
860167800 Low Pressure Fuel Pipe Group
860167801 Fuel Filter Group
860167810 High Pressure Fuel Pipe Group
860507083 Intake Manifold Group
860167811 Turbocharger Group
860167812 Turbocharger Oil Pipe Group
860167813 Compressor Pipe Group
860167817 Air Filter Group
860167819 Exhaust Manifold Group
860167823 General-Use Wire And Sensor Group
860167825 Silencer Group
860167832 Accelerator Soft Shaft Group
860167834 Shut-Down Device Group
860167833 Air Compressor Group
860167836 Tensioner And Belt Group
860167837 Starter Motor Group
860167838 Packing Box Chassis Parts Group
860167839 Direct Delivery Parts Group
860167842 Parts Box Group
860167843 Alternator Group
860167844 Alternator Bracket Group
860167845 Thermostat Group
800350007 Radiator Assembly
252909566 Fuel Tank Assy
252614838 Shock Absorbers
252909774 Double Variable Oil Dispersion Line
252909772 Hydraulic Oil Radiator Pipeline
Cab System
252121349 Cab System
252121330 Cab Assembly
252919319 Inner Sets
252919318 Glass Assy
252920317 Flooring Mat
252910839 Steering Column Assembly
252914453 A/C Cover Assembly
252917730 Control Box Bracket
Air Conditioning System
252120370 Air Conditioning System
253808783 Compressor Assy
252120371 Joint And Pipe
252921005 Air-Conditioning Electrical Group
252921004 Evaporator Assy
269903165 Evaporator Assembly
252921002 Condenser Subassembly
269902536 Air-Condition Condenser
Braking System
252119976 Braking System
252908162 Air Bag
252115194 Cutoff Cylinder Assy
252115199 Cutoff Cylinder Assembly
252115193 Handbrake Booster Cylinder Assy
252908232 Handbrake Booster Cylinder Assembly
252115121 Front Axle Brake Oil Pipe Assy
252119808 Brake Controller Assy
252119809 Brake Controller
252115196 Manual Control Brake Valve Assy
252115198 Manual Control Brake Valve Assembly
252120035 Booster Cylinder Assy
252120036 Booster Pump Unit
252115118 Rear Axle Brake Oil Pipe Assy
252115117 Air Reservoir Air Inlet Pipe Assy
252910995 Combination Valve Assy
803004037 Multifunctional Unloading Valve
800987392 Sh380a-3511010 Combination Valve Service Package
Electric System
252116663 Electric System
252115067 Front Frame Electric System
252919396 Left Lamp Holder Assembly
252919395 Right Lamp Holder Assembly
252116661 Rear Chassis Electrical System
803545523 Light
252116666 Cab Electrical System
802138058 Windshield Wiper
803545523 Light
803690782 Central Control Box
252116704 Cab Harness Sealing Assembly
802138059 Windshield Wiper
803588584 Folding Machine
Front Frame System
252911582 Front Frame System
252910982 Fixed Boom Cylinder Assy
252910974 Fixed Bucket Cylinder Assy
252917993 Front Cover Plate Assy
252910983 Fixed Boom Assy
252920855 Front Frame Lubrication Pipeline
252910985 Front Frame Upper Hinge Hole Assy
252910984 Front/Rear Frame Connection Assy
252910981 Lower Hinge Hole Assy
252910976 Fixed Steering Pin Assy
252116536 Hydraulic System
252121755 Working Hydraulic System (1)
252121738 Hydraulic Oil Tank Assembly
252121740 Fuel Tank Return Steel Pipe Assy
252911838 Oil Return Steel Pipe Fixing Assy
252116834 Oil Return Connector Block Assy
252121743 Steering Pump Oil Suction Hose Assy
252911953 Steering Pump Oil Suction Steel Pipe Assy
252121739 Working Pump Oil Suction Hose Assy
252911974 Working Pump Oil Suction Steel Pipe Assy
251808358 Steering Pump Assy
252911952 P7260-100/10working Pump Assy
252115450 Working Hydraulic System (2)
252115137 D32 Multi-Way Valve Pipeline Assy
253809295 Pipe Clamp Of Swing Arm
252910618 Boom Steel Pipe Fixing Assy
803078310 Right Boom Cylinder
252115449 Xgyg01-137bucket Cylinder Assy
803078309 Left Boom Cylinder
252911914 Steering Hydraulic System
251811243 Bzz-100steering Gear Assy
252911913 Flow Amplifying Valve Assy
252911078 Right Steering Cylinder Assy
252911081 Left Steering Cylinder Assy
252909533 Clamp Assembly
252909537 Limit Valve Assy
253007928 Right Limit Valve Assy
252909536 Steering Limit Bar Assy
252909539 Flow Amplifying Valve Hose Fixing Assy
252911912 Cutting Ferrule
252113931 Steering Gear Hose Fixing Assy
252116537 Operate System
252911367 Clamp Assembly
252113935 Clamp Assembly
252911397 Cutting Ferrule
252911943 Pilot Pump Oil Outlet Block Assy
252116730 Cab Pilot Pipeline
252120051 Distribution Valve Assy
252912140 Pressure Selector Valve Assy
252116539 Articulated Pipeline
252909530 Bucket Steel Pipe Fixing Assy
252909515 Pipe Clip Assembly
253007886 Distribution Valve Oil Return Steel Pipe Assy
253008147 Distribution Valve Oil Inlet Block Installation Assy
252909967 Pipe Clip Assembly
252911981 Steering Pump Oil Outlet Block Assy
252911986 Working Pump Oil Outlet Block Assy
252913180 Unloading Valve
252909514 Clamp Assembly
252116540 Central Pressure Measurement System
253007929 Pressure Gauge Adaptor Installation Assembly
Work Link System
252120816 Work Link System
252120820 Boom Assy
252915070 Rocker Arm Assy
252911277 Pull Rod Subassembly
252911278 Bucket Connecting Assy
252911279 Boom Cylinder Connecting Assy
Brand: XCMG
Bucket
252110032 Bucket
252110006 Bucket
Drive Axle System
252911394 Filter
803440533 Filter
252912236 Bracket
252917805 Right Box
252917791 Left Box
Rear Frame System
Engine Assembly
800157620 Engine
Cab System
Braking System
252908162 Air Bag
Electric System
803545523 Light
803545523 Light
Front Frame System
Work Link System
252120820 Boom Assy
- XCMG Wheel loader ZL50G service manual
- XCMG Road Grader Parts Handbook GR215A
- XCMG ZL50G Wheel Loader Parts Manual
- XCMG ZL30G Wheel Loader Parts List
- XCMG LW420F Wheel Loader Instruction Manual
- XCMG Excavator Loader WZ30-25 Parts Catalog EN ZH
- XCMG LW500F Wheel Loader Parts Manual part 1
- XCMG GR215 Parts Manual
- XCMG YL16 YL 20 Types Pneumatic Tyre Roller Parts List
- XCMG YZ 16 JC YZ 18JC Vibratory Roller Operation and Maintenace Manual
- XCMG ZL50A.2 Spare Parts
- XCMG LW500F Wheel Loader Parts Manual part 2
- XCMG XS 160 XS 190 Parts List of Vibratory Roller
- XCMG LW330F Wheel Loader Parts Manual
- XCMG PAT DS 380 Parts Manual
