118
6,911
XCMG Wheel Loader XC958 Parts Catalogue EN
Brand: XCMG
Type of Machine: Wheel Loader
Type of Manual: Parts Catalogue
Model: XCMG XC958 Wheel Loader
PIN:XUG00958HMCB16947
Number of Pages: 638 Pages
253804322 XC958TH WHEEL LOADER
BUCKET
252918017 BUCKET
252917695 REPLACEABLE CUTTING PLATE ASSEMBLY
252917124 BUCKET
TIRE AND WHEEL RIM ASSEMBLY
253804821 TIRE AND WHEEL RIM ASSEMBLY
252919352 FIXED TIRE ASSY
252911479 FIXED TIRE ASSY
DRIVE AXLE SYSTEM
253803910 DRIVE AXLE SYSTEM
252120712 FRONT AXLE ASSY
275102460 FRONT AXLE ASSY
253803913 FRONT DRIVE SHAFT ASSY
253803730 FRONT DRIVE SHAFT ASSEMBLY
252115313 SUPPORT SEAT ASSEMBLY INSTALLATION
800358526 SUPPORT SEAT ASSEMBLY
253803912 INTERMEDIATE DRIVE SHAFT ASSEMBLY
253803731 INTERMEDIATE SHAFT ASSEMBLY
253803911 REAR DRIVE SHAFT ASSY
253803732 REAR DRIVE SHAFT ASSEMBLY
252919103 REAR AXLE ASSY
275102525 REAR ALXE ASSY
TRANSMISSION AND TORQUE CONVERTER SYSTEM
253803960 TRANSMISSION AND TORQUE CONVERTER SYSTEM
800359990 TRANSMISSION AND TORQUE CONVERTER ASSEMBLY
860537969 ENGINE CONNECTION
860537970 TORQUE CONVERTOR
860537971 ACTUATOR
860537972 TRANSMISSION HOUSING 1
860537973 TRANSMISSION HOUSING 2
860537974 COUNTERSHAFT
860537975 CONNECTOR
860537976 CLUTCH
860537977 CONNECTOR
860537978 CONNECTOR 2
860537979 CONNECTOR 3
860537980 CONNECTOR 4
860537981 OUTPUT1
860537982 OUTPUT2
860537638 PARKING BRAKING
860537983 PARKING BRAKE
860537984 POWER OUTPUT DEVICE
860537987 POWER OUTPUT DEVICE 2
860537988 POWER OUTPUT DEVICE 3
860537989 POWER OUTPUT DEVICE 4
860537991 SHIFTING SYSTEM 1
860116156 SPEED CONTROL VALVE
860537996 PRESSURE REGULATOR
860537999 INDUCTIVE SENSOR1
860538004 INDUCTIVE SENSOR2
860538005 EMERGENCY STEERING PUMP
860538006 TUBE
860538007 TUBE2
860538014 OIL PIPE
860560774 BULK PARTS
253803938 FILTER ELEMENT ESSY
252109128 BRACKET
252919192 SHOCK ABSORBERS
BRAKING SYSTEM
253803937 BRAKING SYSTEM
253804918 FRONT AXLE BRAKE COOLING PIPELINE
253804060 FRONT AXLE PIPELINE ASSY
253804056 BRAKE CONTROLLER ASSY
253804053 BRAKE CONTROLLER
253804046 MANUAL CONTROL BRAKE VALVE ASSEMBLY
253804054 HANDBRAKE BOOSTER CYLINDER ASSY
251800678 BRAKING CYLINDER ASSEMBLY
253804048 REAR AXLE BRAKE OIL PIPE
253804057 REAR AXLE PIPELINE ASSY
252120035 BOOSTER CYLINDER ASSY
252907708 VENTILATOR ASSY
252120036 BOOSTER PUMP UNIT
252908162 AIR BAG
253804047 COMBINATION VALVE ASSY
252910995 COMBINATION VALVE ASSY
UNDERCARRIAGE SYSTEM
253803994 UNDERCARRIAGE SYSTEM
253804038 LEFT LADDER
253804011 LEFT REAR FENDER
253804033 RIGHT REAR FENDER
253804016 RIGHT BOX
253801369 RIGHT LADDER
REAR FRAME SYSTEM
253803901 REAR FRAME SYSTEM
253800588 STEERING CYLINDER PIN ASSY
253804066 CAB FIXING ASSY
253804084 BAFFLE ASSEMBLY
253800922 LOCKING ROD ASSY
252910958 FIXED SUBFRAME ASSY
253804061 COUNTER FRAME LUBRICATION ASSY
253804073 ENGINE HOOD FIXING ASSY
BALLAST ASSY
253803921 BALLAST ASSY
COOLING SYSTEM
253803925 COOLING SYSTEM
253803928 DOUBLE VARIABLE OIL DISPERSION LINE
253803926 WATER PIPE
253803932 RADIATOR INSTALLATION ASSY
800358904 RADIATOR ASSEMBLY
253803923 SEAL
253805274 HYDRAULIC OIL RADIATOR PIPELINE ASSY
253804286 ACCUMULATOR COMPONENT
ENGINE HOOD ASSEMBLY
253803883 ENGINE HOOD ASSEMBLY
253802394 LEFT LOWER DOOR
253802393 RIGHT LOWER DOOR
253803879 SEALINGS OF HYDRAULIC OIL TANK
253802415 AGRAFFE
253803886 HOOD
253802573 ROOF ASSEMBLY
253803894 REAR SHIELD
LIFTING SYSTEM
253802399 LIFTING SYSTEM
ENGINE ASSEMBLY
253803945 ENGINE ASSEMBLY
253803954 FUEL TANK ASSY
253803957 OIL-OUTLET COMPONENT
253803956 OIL PIPE ASSY
800152540 ENGINE
860523057 COVER BOARD PART
860522706 MACHINE BODY PART
860523156 CYLINDER HEAD HOUSING PARTS
860523157 TIGHTENING PART
860523158 COVER
860523159 COVER BOARD PASSY
860523160 CAP PART
860523161 HOIST PART
860523162 VENTILATION PIPE ASSY
860523163 PISTON AND ROD GROUP
860523164 CRANKSHAFT
860523165 BELT PART
860523166 OIL SEALING PART
860523167 FLYWHEEL
860523168 GEAR PART
860523169 SUPPORT PART
860523170 HOUSING PART
860523171 COVER PART
860523173 TIGHTENING PART
860523174 SEAT PART(EAR SHAFT)
860545625 FLYWHEEL HOUSING GROUP
860523176 SUPPORT PART
860523177 EXHAUST PIPE ASSY
860523178 TIGHTENING PART
860523179 TURBOCHARGER SET
860523180 INLET PIPE PARTS
860523181 OIL PIPE PART
860523182 INLET PIPE PARTS
860523183 SHOCK ABSORBER ASSY
860523184 FAN PART
860523185 BELT PART
860523186 SUPPORT PART
860523187 CAMSHAFT GROUP
860523188 VALVE NECHNISM PART
860523189 FILLER PART
860523190 OIL SUMP ASSY
860523191 TIGHTENING PART
860523192 PUMP
860523193 FILTER PART
860523194 ENGINE OIL LINES GROUP
860523195 DIPSTICK PIPE SET
860523196 WATER PUMP ASSY
860523197 PIPE PART
860523198 THERMOSTAT ASSY
860523199 FUEL LINE ASSY
860523200 SPEEDER PART
860523201 CUTTER PART
860523202 FILTER
860523203 PIPE PART
860523204 MOTOR PART
860523205 GENERATOR
860523206 MUFFLER ASSY
860523212 FILTER PART
860523213 PIPE PART
860523214 COMPRESSOR PART
860523215 DUST EJECT TUBE
860523216 PIPE PART
860168255 VARIANT SUPPORTING COMPONENTS
252108687 ENGINE-TRANSMISSION/TORQUE CONVERTER CONNECTION
252100842 ACCELERATOR CONTROL
253803940 EXHAUST TAIL PIPE ASSY
253803952 INTAKE SUBASSEMBLY
253803962 OIL BATH
253803947 VENTILATOR ASSY
253803963 SUPPORT ASSEMBLY
CAB SYSTEM
253803899 CAB SYSTEM
253803983 CAB ASSEMBLY
253803897 INNER SETS
253800055 GLASS ASSY
253803288 GATE
253801179 RIGHT WINDOW
253800222 BOTTOM SEAL PLATE
802152478 STEERING COLUMN ASSEMBLY
253800239 A/C COVER ASSEMBLY
252917730 CONTROL BOX BRACKET
AIR CONDITIONING SYSTEM
253803786 AIR CONDITIONING SYSTEM
253803785 EVAPORATOR ASSY
803591965 EVAPORATE ASSEMBLY
253803784 JOINT AND PIPE
252117723 COMPRESSOR ASSY
253801741 CONDENSER SUBASSEMBLY
803594843 AIR-CONDITION CONDENSER
253800449 ELECTRICAL COMPONENTS
REAR FENDER
253802412 REAR FENDER
253802403 LEFT BACK FENDER
253802402 LEFT REAR FENDER TRIM
253802411 RIGHT BACK FENDER
253802408 RIGHT REAR FENDER TRIM
FRONT FRAME SYSTEM
253803900 FRONT FRAME SYSTEM
253804215 BOOM CYLINDER FRAME PIN ASSY
253804240 BOOM FRAME HINGE PIN ASSY
252917993 FRONT COVER PLATE ASSY
253804247 BUCKET CYLINDER FRAME HINGE PIN ASSY
253804245 FRONT FRAME LUBRICATION PIPELINE
253800961 UPPER HINGED HOLE ASSEMBLY
253804213 FRONT/REAR FRAME CONNECTION ASSY
253804233 FRONT STEERING PIN ASSY
253800972 LOWER HINGE HOLE ASSY
ELECTRIC SYSTEM
253803914 ELECTRIC SYSTEM
253803915 FRONT FRAME ELECTRIC SYSTEM
803593874 LEFT HEADLAMP
253802045 LEFT LAMP HOLDER ASSEMBLY
803593875 RIGHT HEADLAMP
253802046 RIGHT LAMP HOLDER ASSEMBLY
253803917 ELECTRICAL
803588584 FOLDING MACHINE
802138059 WINDSHIELD WIPER
253803919 REAR FRAME ELECTRIC SYSTEM
HYDRAULIC SYSTEM
253803999 HYDRAULIC SYSTEM
253804044 WORKING HYDRAULIC SYSTEM (1)
252911076 FLANGE
253805281 SUPPORT PLATE ASSY
253804285 OIL RETURN BLOCK ASSY
253804292 HYDRAULIC TANK ASSY
253804282 GEAR PUMP ASSY
253804279 GEAR PUMP ASSY
253804000 WORKING HYDRAULIC SYSTEM (2)
252910618 BOOM STEEL PIPE FIXING ASSY
253804374 PIPE FIXING ASSY
253804375 PIPE FIXING ASSY
253804274 FRONT FRAME STEEL PIPE ASSY
253805240 TILT CYLINDER ASS’Y
804015667 LEFT BOOM CYLINDER
804015668 RIGHT BOOM CYLINDER
253803998 STEERING HYDRAULIC SYSTEM
253801336 CLAMP ASSEMBLY
253800554 STEERING LIMIT BAR ASSY
253804261 FLOW AMPLIFYING VALVE ASSY
253804259 LEFT STEERING CYLINDER ASSY
253804260 RIGHT STEERING CYLINDER ASSY
252119363 BZZ-100STEERING GEAR ASSY
252909537 LIMIT VALVE ASSY
253008798 PILOT PUMP OIL OUTLET BLOCK ASSY
253804001 OPERATING SYSTEM
252120639 PILOT VALVE ASSY
252115127 SXF
253007887 TWO-WAY BALL VALVE 6402 10 17 ASSY
253804280 PIPE CLIP ASSEMBLY
253006604 TWO-CIRCUIT HYDRAULIC DISTRIBUTOR VALVE SUBASSY
253804003 PIPE CLIP ASSEMBLY
253804002 ARTICULATED PIPELINE
253804272 PIPE CLIP ASSEMBLY
253804269 PIPE CLIP ASSEMBLY
253804281 MULTI-WAY VALVE THE OIL BLOCK ASSY
253804263 WORKING PUMP OIL OUTLET BLOCK ASSY
253804268 UNLOADING VALVE ASSY
252911080 FLANGE
252911076 FLANGE
WORK LINK SYSTEM
253803678 WORK LINK SYSTEM
253804099 BOOM ASSY
253804118 BOOM CYLINDER CONNECTING ASSY
253800644 BUCKET CONNECTING ASSY
253804097 PULL ROD SUBASSEMBLY
253804096 ROCKER ARM ASSY
CENTRAL PRESSURE MEASUREMENT SYSTEM
253805354 CENTRAL PRESSURE MEASUREMENT SYSTEM
