XCMG Wheel Loader XC958 Parts Catalog
Brand: XCMG
Type of Machine: Wheel Loader
Model: XCMG XC958 Wheel Loader
Pin Number: XUG00958CNCB23739
Number of Pages: 712 Pages
253804659 Xc958asxii Wheel Loader
Quick Change Mechanism
253800616 Quick Change Mechanism
253808936 Quick Change Pipe
253804329 Quick-Change Bucket
253804340 Bucket
252917695 Replaceable Cutting Plate Assembly
252113973 Bucket Tooth Assembly
252113829 Quick-Change Fork
Tire And Wheel Rim Assembly
253804372 Tire And Wheel Rim Assembly
Drive Axle System
253804397 Drive Axle System
253804555 Rear Axle Assy
275302134 Rear Alxe Assy
252107994 Front Axle Pipeline
253800668 Rear Drive Shaft Assy
800362690 Rear Drive Shaft
253804553 Intermediate Drive Shaft Assembly
253804335 Intermediate Shaft Assembly
252115313 Support Seat Assembly Installation
800358526 Support Seat Assembly
252117648 Front Drive Shaft Assy
800360974 Front Drive Shaft
253804554 Front Axle Assy
Transmission And Torque Converter System
253804341 Transmission And Torque Converter System
253802438 Ventilator Assy
800365542 Transmission Assembly
860521093 Engine Connection
860521095 Input
860521097 Transmission Housing 1
860521099 Transmission Housing 2
860521098 Gearbox Casing3
860521103 Coupling1
860521142 Coupling2
860521143 Coupling3
860521144 Coupling4
860521317 Coupling5
860521318 Coupling6
860521369 Output1
860521370 Output2
860168223 Parking Braking1
860521398 Parking Braking2
860521399 Power Takeoff
860521400 Shifting System 1
860521438 Shifting System 2
860521439 Shifting System 3
860521440 Pressure Regulator
860521441 Pressure Oil Pump
860521455 Emergency Steering Pump
860521456 Inductive Sensor
860521457 Temperature Sensor
860521458 Filter Asm
860521459 Oil Filler Nozzle
860521460 Working Machine Wirecable
860626274 Controller
860521462 Part
253900428 Supply Tube Assy
253804549 Support Group
252919192 Shock Absorbers
Braking System
253804455 Braking System
253802728 Prefill Valve Assembly
253804635 Handbrake Valve Block Assembly
253008798 Pilot Pump Oil Outlet Block Assy
253804645 Energy Accumulator Mounting Assy
253804633 Foot Brake Valve Assembly
253802370 Pipe Clip Assembly
Undercarriage System
253804465 Undercarriage System
253807255 Left Box Assy
253900433 Left Ladder
253804011 Left Rear Fender
253900094 Right Rear Fender
253807972 Right Box
253801369 Right Ladder
Rear Frame System
253804373 Rear Frame System
253800588 Steering Cylinder Pin Assy
253804609 Baffle Assembly
253800922 Locking Rod Assy
252119277 Fixed Subframe Assy
253806908 Counter Weight
253803070 Fixed Bracket Assembly
Counterweight
253804338 Counterweight
253804342 Cooling System
253804558 Radiator Installation Assy
253900128 Radiator Assembly
253804564 Dual Variable Oil Dispersion Pipeline Assembly
252911080 Flange
253804562 Cooling Pipeline
253804572 Clapboard Assembly
Engine Hood Assembly
253804359 Engine Hood Assembly
253802394 Left Lower Door
253804478 Sealings Of Hydraulic Oil Tank
253804468 Hood
253802393 Right Lower Door
253802415 Agraffe
Lifting System
253802399 Lifting System
Engine Assembly
253804337 Engine Assembly
253804551 Intake And Exhaust System
800105240 Air Filter
800161264 Pump Drive Group
253805124 Engine-Transmission/Torque Converter Connection
800172922 Engine
860563036 Air Inlet Preheater
860563037 Gear Chamber Assembly
860509097 Subassembly Of Cylinder Body
860563038 Crankcase Ventilation
860563040 Coolant Auxiliary Heating
860563041 Air Compressor Air Inlet Pipe Plan
860563043 Torsion Damper
860563044 Electric Accessory
860563045 Thermostat Group
860563046 Alternator Group
860563047 Alternator Group
860563085 Front Suspension Bracket Of Engine
860563048 Speed Sensor Assembly
860145885 Fan Drive
860563049 Fan Drive Group
860563050 Fuel Filter Position
860563051 Cummins Filtration Connecting Pipeline
860563052 Flywheel Housing
860563053 Flywheel Housing Assembly
860509084 Fuel Pump
860563236 Oil Supply System Accessory 1
860563237 Oil Supply System Accessory 2
860563054 Fuel Line
860563055 Flywheel
860563056 Front Gear Cover
860563057 Warm-Air Assembly
860563058 Steering Pump Assembly
860563238 Intake Hose
860563059 Air Intake Connector
860563060 Air Intake Connector Assembly
860563061 Intake Manifold
860563239 Air Outlet Connector
860563062 Engine Lifting Eye
860563063 Engine Lug Component
860563064 Engine Oil Cooler
860563065 Full-Flow Oil Filter
860563066 Oil Scale
860563067 Pump
860563068 Oil Filling Tube Group
860563069 Oil Sump Assy
860563070 Accessory Drive Belt Pulley
860563071 Engine Control Module
860563240 Turbocharger Set
860563241 Part
860563242 Cylinder Head Component
860563072 Rocker Arm Assy
860563073 Engine Coolant Vent
860563074 Thermal Insulation Cover
860563076 Motor Starting Assembly
860563243 Distance Piece
860563077 Motor Starting
860563078 Booster Plan
860563244 Torque Converter Cooler
860563079 Booster Pipe
860563080 Air Valve Chamber Cover Plan
860563081 Pipe
860563082 Outlet Connection
860563083 Pump Drive
860563245 Water Pump Assy
860563246 Belt Tensioner
860563084 Electronic Control Module Harness
860563247 Exhaust Connection
253804539 Engine Assembly
252614838 Shock Absorbers
253804546 Oil Pipe Assy
253900424 Ventilator Assy
253804545 Oil-Outlet Component
253803954 Fuel Tank Assy
Cab System
253804336 Cab System
253804484 Cab Assembly
253807657 Right Window
253803897 Inner Sets
253800055 Glass Assy
253800227 Noise Reduction Package
253812372 Gate
253800222 Bottom Seal Plate
253800238 Cab Installation Assy
802152478 Steering Column Assembly
253800239 A/C Cover Assembly
253800221 Evaporimeter Cover
253804886 Right Pilot Control Box
253804903 Front Frame Assembly
253804908 Rear Frame Assembly
Air Conditioning System
253804370 Air Conditioning System
253804488 Evaporator Assy
803591965 Evaporate Assembly
253804487 Joint And Pipe
253601713 Compressor Assy
252108227 Compressor Bracket
253801741 Condenser Subassembly
803594843 Air-Condition Condenser
253800449 Electrical Components
Rear Fender
253802412 Rear Fender
Concentrated-Lubricating System
253804376 Concentrated-Lubricating System
253804605 Lubrication Pump Assy
801143501 Concentrate Lubrication System
253804604 Working Linkage Lube Line
253804601 Front Frame Lubrication Pipeline
253804603 Rear Frame Lubrication Pipeline
Front Frame System
253804371 Front Frame System
253800972 Lower Hinge Hole Assy
253800961 Upper Hinged Hole Assembly
253804213 Front/Rear Frame Connection Assy
253804233 Front Steering Pin Assy
253804247 Bucket Cylinder Frame Hinge Pin Assy
252917993 Front Cover Plate Assy
253804240 Boom Frame Hinge Pin Assy
253804215 Boom Cylinder Frame Pin Assy
Electric System
253804378 Electric System
253804382 Front Frame Electric System
253802104 Left Lamp Holder Assembly
253802103 Right Lamp Holder Assembly
253804383 Electrical
802156160 Windshield Wiper
803588584 Folding Machine
803803841 Central Control Box
802138059 Windshield Wiper
253804381 Rear Frame Electric System
253804454 Hydraulic System
253804456 Working Hydraulic System (1)
253803153 Support Plate Assy
252911076 Flange
252911073 Flange
253804638 Unloading Valve Assy
253011383 Pressure Control Valve Assy
253804639 Hydraulic Tank Assy
253804637 Plunger Pump Assy
253804644 Gear Pump Assy
253804398 Working Hydraulic System (2)
804015667 Left Boom Cylinder
804015668 Right Boom Cylinder
252910618 Boom Steel Pipe Fixing Assy
253804505 Front Frame Steel Pipe Assy
253805240 Tilt Cylinder Ass’y
253811532 Left Boom Cylinder Explosion Proof Valve Assy
253811534 Right Boom Cylinder Explosion Proof Valve Assy
253811559 Flameproof Valve Components
253804399 Steering Hydraulic System
252119363 Bzz-100steering Gear Assy
253800554 Steering Limit Bar Assy
252909537 Limit Valve Assy
253804259 Left Steering Cylinder Assy
253804577 Connector Block Subassembly
253804578 Flow Amplifying Valve Assy
252909533 Clamp Assembly
253804260 Right Steering Cylinder Assy
253804400 Operating System
253007887 Two-Way Ball Valve 6402 10 17 Assy
253805425 Pilot Valve Assy
253806013 Pipe Clip Assembly
253807101 Oil Source Valve Assembly
253804280 Pipe Clip Assembly
253804588 D32
252115127 Sxf
253811533 Explosion Proof Valve Pipeline Assy
253804401 Articulated Pipeline
253804536 Connector Block Subassembly
252120067 Distribution Valve Oil Inlet Block Installation Assy
252909515 Pipe Clip Assembly
253804374 Pipe Fixing Assy
253804375 Pipe Fixing Assy
253804415 Three-Circuit Hydraulic System
253804408 Fixed Bracket Assembly
253804414 Fixed Bracket Assembly
253804464 Hy-Independent Radiating System
253011026 Radiator Motor Assy
252911069 Flange
253306194 Reversing Valve Assy
252119308 Cooling Pump Assy
253807971 Stabilizer Module System
253404476 Stabilizer Module Assy
253403418 Accumulator Fixed Support Plate Assembly
253403415 Support Plate Assy
253804403 Emergency Steering System
253304083 Safety Valve Assembly
803075776 Electric Pump
253804584 Quick Coupler Hydraulic System
253804581 Pipe Clip Assembly
253305084 Pipe Clip Assembly
253804586 Electromagnetic Reversing Valve Assy
Work Link System
253804366 Work Link System
253804360 Rocker Arm Assy
253804361 Boom Assy
253900209 Boom Cylinder Connecting Assy
253809743 Bucket Connecting Assy
253804362 Pull Rod Subassembly
Central Pressure Measurement System
253804489 Central Pressure Measurement System
253804492 Pressure Measurement Pipe
253804493 Transmission Pressure Measurement Pipe
Brand: XCMG
253804340 Bucket
Drive Axle System
860521095 Input
860521103 Coupling1
860521142 Coupling2
860521143 Coupling3
860521144 Coupling4
860521317 Coupling5
860521318 Coupling6
860521369 Output1
860521370 Output2
860521462 Part
Braking System
253807972 Right Box
Rear Frame System
Counterweight
252911080 Flange
253804468 Hood
253802415 Agraffe
Lifting System
Engine Assembly
800172922 Engine
860145885 Fan Drive
860509084 Fuel Pump
860563054 Fuel Line
860563055 Flywheel
860563066 Oil Scale
860563067 Pump
860563241 Part
860563081 Pipe
Cab System
253812372 Gate
Rear Fender
Front Frame System
Electric System
252911076 Flange
252911073 Flange
253804588 D32
252115127 Sxf
252911069 Flange
Work Link System
253804361 Boom Assy
- XCMG Wheel loader ZL50G service manual
- XCMG Road Grader Parts Handbook GR215A
- XCMG ZL50G Wheel Loader Parts Manual
- XCMG ZL30G Wheel Loader Parts List
- XCMG LW420F Wheel Loader Instruction Manual
- XCMG Excavator Loader WZ30-25 Parts Catalog EN ZH
- XCMG LW500F Wheel Loader Parts Manual part 1
- XCMG GR215 Parts Manual
- XCMG YL16 YL 20 Types Pneumatic Tyre Roller Parts List
- XCMG YZ 16 JC YZ 18JC Vibratory Roller Operation and Maintenace Manual
- XCMG ZL50A.2 Spare Parts
- XCMG LW500F Wheel Loader Parts Manual part 2
- XCMG XS 160 XS 190 Parts List of Vibratory Roller
- XCMG LW330F Wheel Loader Parts Manual
- XCMG PAT DS 380 Parts Manual
