XCMG Truck Mounted Concrete Pump HB30V Parts Catalogue 2020 EN
Brand: XCMG
Type of Machine: Truck Mounted Concrete Pump
Type of Manual: Parts Catalogue
Model: XCMG HB30V Truck Mounted Concrete Pump
PIN: 202300382
Publication Date: 2020
Number of Pages: 283 Pages
152901617 TRUCK-MOUNTED CONCRETE BOOM PUMP
CHASSIS ASSEMBLY
158002683 CHASSIS ASSEMBLY
158002614 CHASSIS HYDRAULIC SYSTEM
158002825 PIPE ARRANGEMENT OF CLEANING AGITATION MIXING SYSTEM
158002827 PIPE ARRANGEMENT OF PUMPING CONTROL AND PISTON RETURN SYSTEM
158002814 PIPE ARRANGEMENT OF SWING SYSTEM
158002828 JOINT ASSEMBLY OF MAIN PUMPING VALVE
158002826 PIPE ARRANGEMENT OF PUMPING AND OIL-RETRUN SYSTEM
158002799 MAIN PUMP JOINT
158002816 PIPE ARRANGEMENT OF OIL-RETURN SYSTEM
158002829 PIPE ARRANGEMENT OF RADIATION SYSTEM
158000720 CHASSIS MODIFICATION
158002623 AUXILIARY FRAME
158002577 ELECTRICAL SYSTEM
158002578 MOUNTING ASSEMBLY OF WIRING HARNESS
158002584 MOUNTING ASSEMBLY OF ELECTRICAL CABINET
158002611 WATERWAY SYSTEM
159001664 PUMPING WATER PUMP AND MOTOR
159001672 PNEUMATIC SYSTEM
159001668 VALVE BODY ASSEMBLY
150015595 OIL TANK
158002572 PROTECTION DEVICE
150005916 CROSSER BOX
158002656 CHASSIS DELIVERY PIPE
150011926 COOLING SYSTEM OF ELECTRIC RADIATOR
158002669 LUBRICATION SYSTEM
158002840 LUBRICATION PIPE ARRANGEMENT OF DELIVERY CYLINDER
158002834 LUBRICATION PIPE ARRANGEMENT OF HOPPER
158002609 WATER TANK ASSEMBLY
SUPERSTRUCTURE ASSEMBLY
152401659 SUPERSTRUCTURE ASSEMBLY
152401658 SUPERSTRUCTURE HYDRAULIC SYSTEM
152402010 BOOM PIPE ARRANGEMENT
152402011 PIPE ARRANGEMENT OF BOOM MULTIPLE-WAY VALVE
152402008 PIPE ARRANGEMENT OF SWIVEL MOTOR
152401946 PIPE ARRANGEMENT OF STABILIZER MULTIPLE-WAY VALVE
152402002 STABILIZER PIPE ARRANGEMENT
152401649 BOOM ASSEMBLY
152401758 1ST BOOM SECTION
152401907 SECOND-SECTION BOOM
152402030 3RD BOOM SECTION
152401710 THE FOURTH SECTION
152401655 SUPERSTRUCTURE DELIVERY PIPE
152401650 DELIVERY PIPE OF 1ST BOOM SECTION
152401651 DELIVERY PIPE OF 2ND BOOM SECTION
152401653 DELIVERY PIPE OF 4TH BOOM SECTION
152401654 TURRET DELIVERY PIPE
152401652 DELIVERY PIPE OF THE 3RD BOOM SECTION
152401657 TURNTABLE ASSEMBLY
152401648 STATIONARY TURRET STRUCTURE
152401901 PLACING BOOM SUPPORT
152401647 OUTRIGGER ASSEMBLY
152401678 FRONT STABILIZER TELESCOPING SYSTEM
152400507 SWIVEL LUBRICATION
152400217 SLEWING BEARING
150006766 SLEWING MOVEMENT
230ROCK VALVE PUMPING MECHANISM
155302740 230ROCK VALVE PUMPING MECHANISM
155302612 INSTALLATION OF PUMPING SYSTEM
155302244 SUPPORTING SEAT OF MAIN OIL CYLINDER
155301721 Q23002.04III CORE PUMP
155301794 COVER PLATE
155301202 CLAMPING DEVICE
155302103 PISTON ASSEMBLY Φ230Φ75-M16
155302082 ROCK VALVE DRIVING
155300223 BEARING ASSEMBLY
155300219 ASSEMBLY OF REAR BEARING
155301763 DRIVING-CYLINDER OF DISTRIBUTION VALVE
155303008 HOPPER ASSEMBLY
155302446 MIXING SYSTEM
155302449 LEFT FLANGE ASSEMBLY
155302471 ASSEMBLY OF RIGHT FLANGE
155300567 Φ230ROCK VALVE ASSEMBLY
155300566 Φ230ROCK VALVE ASSEMBLY
