XCMG Truck Crane XCT80 Operation Manual
Brand: XCMG
Type of Machine: Truck Crane
Model: XCMG XCT80 Truck Crane
Publication Date: 2012
Number of Pages: 252 Pages
4-1 Planning
4-2 Crane Operation Management
4-2-1 Safe Working System
4-2-2 Crane Operation Plan
4-2-3 Faults And Accidents Report
4-3 Crane Settings
4-3-1 Crane Supporting Conditions
4-3-2 Obstacles Around Crane
4-3-3 Wind Load Influence
4-3-4 Crane Grounding
4-4 Multiple Cranes Lifting Operation
4-5 Lifting Weight
4-6 Disaster Treatment And Emergency Measures
4-6-1 Natural Disaster
4-6-2 Accident Disaster
4-7 Operation Instructions For The Crane In Out-Of-Service Condition
Chapter 5 Main Characteristics And Technical Parameters
5-1 Main Purposes And Characteristics
5-1-1 Main Purpose And Scope
5-1-2 Main Characteristics Of Xct80 Truck Crane
5-2 Conditions Of Use
5-3 Xct80 Truck Crane Technical Parameters And Rated Lifting Weight Char
5-4 Crane Main Structure Performance Parameters
Chapter6 Components And Functions Of Lower Crane Portion
6-1 General Overview
6-1-1 Power System
6-1-2 Transmission System
6-1-3 Driving System
6-1-4 Operating System
6-1-5 Cab And Covering Parts
6-1-6 Hydraulic System
6-1-7 Air Conditioning System
6-1-8 Electrical System
6-1-9 Auxiliary System
6-2 Main Components Introduction
6-3 Cab And Protective Device
6-3-1 The Cab Interior Equipments
6-3-2 Main Function Introduction Of Meters, Switches And Lights In The Cab
6-3-3 Other Device
6-3-4 Protective Devices
Chapter 7 Traveling Status On Highway
7-1 Preparations Before Traveling
7-1-1 Crane Traveling Mode On Highway
7-1-2 Inspection Of Vehicle Condition
7-1-3 The Use Of Air Conditioning
7-2 Operation Of Lower Crane Portion Engine
7-2-1 Check Before Starting The Engine
7-2-2 Start Lower Crane Portion Engine
7-2-3 Inspection After The Engine Startup
7-2-4 Flameout Of Engine
7-3 General Operation
7-3-1 Starting And Gear Shift
7-3-2 Trail Operation
7-3-3 Clutch Operating
7-3-4 Steering System
7-3-5 Braking System
7-4 Driving Cranes In Winter
7-4-1 Cooling System
7-4-2 Braking Device
7-4-3 Battery
Chapter8 Components And Functions Of Upper Crane Portion
8-1 General Overview
8-1-1 Lifting Device
8-1-2 Safety Device
8-1-3 Upper Crane Portion Control Room And Rotary Bearing System
8-1-4 Upper Crane Hydraulic System
8-1-5 Upper Crane Portion Electric System
8-2 Main Component Introduction
8-3 Operating Cab
8-3-1 Electric Device
8-3-2 Instrument Panel
8-3-3 Control Handle
8-3-4 Relay
8-3-5 Electric System Manual
8-4 Safety Device
8-4-1 Lifting Torque Limiter
8-4-2 Three-Coil Protector (Counter)
8-4-3 Length And Angle Sensor
8-4-4 Groove Jumping Device (Rope Block)
8-4-5 Level
8-4-6 Horn
8-4-7 Safety Control Switch
8-4-8 Hydraulic Unloading Valve
8-4-9 Hydraulic Oil Filter Blocking Alarm Lamp
8-4-10 Rotary Table Lock Device
Chapter9 Crane Accessory
9-1 Crane Accessory Selection
9-2 Mounting And Dismounting Of Auxiliary Lifting Mechanism
9-2-1 Operating Precautions
9-2-2 Mounting Auxiliary Lifting Mechanism
9-2-3 Dismounting Auxiliary Lifting Mechanism
9-3 Mounting And Dismounting Of Auxiliary Crane Arm
9-3-1 Operating Precautions
9-3-2 Component Name Of Auxiliary Crane Arm
9-3-3 Mounting Auxiliary Crane Arm
9-3-4 Mounting Angle Adjustment Of Auxiliary Crane Arm
9-3-5 Auxiliary Crane Arm Storage
9-4 Mounting And Dismounting Of Balance Weight
9-4-1 Operating Precautions
9-4-2 Balance Weight Combination
9-4-3 Mounting Balance Weight
9-4-4 Dismounting Balance Weight
9-5 Mounting And Dismounting Of Arm End Single Pulley
9-5-1 Operating Precautions
9-5-2 Mounting Arm End Single Pulley
9-5-3 Storing Arm End Single Pulley
9-5-4 Crane Performance Of Arm End Single Pulley
9-6 Hook And Steel Wire Rope
9-6-1 Hook Selection
9-6-2 Hook Basic Structure
9-6-3 Steel Wire Rope Magnification Conversion
9-6-4 Crossing And Winding Method Of Steel Wire Rope
9-6-5 Crossing And Winding Of Steer Wire Rope Precautions
Chapter10 Crane Operation
10-1 Crane Operation Preparations
10-1-1 Check Before Crane Runing
10-1-2 Crane Operation Conditions Check
10-1-3 Air Conditioning Equipment Use
10-1-4 Operating Cab Seat Adjustment
10-1-5 Check The Winch Steel Wire Rope Position
10-1-6 Check Safety Device
10-2 Engine Operation
10-3 Power Take-Off Operation
10-4 Outrigger System Operation
10-4-1 Operating Precautions
10-4-2 Outrigger Operation Composition
10-4-3 Fold And Unfold Foot Plate
10-4-4 Fold And Unfold Horizontal Outrigger
10-4-5 Fold And Unfold Vertical Outrigger
10-4-6 Leveling Crane
10-5 Throttle Operation
10-5-1 Operating Precautions
10-5-2 Operating Method
10-6 Lifting Mechanism Operation
10-6-1 Operating Precautions
10-6-2 Main Lifting Mechanism Operation (Right Handle)
10-6-3 Auxiliary Lifting Mechanism Operation (Left Control Handle)
10-6-4 Free Trackslip Operation
10-7 Main Crane Boom Stretching Operation
10-7-1 Operating Precautions
10-7-2 Operating Method
10-8 Main Crane Boom Luffing Operation
10-8-1 Operating Precautions
10-8-2 Main Crane Boom Luffing Operation (Right Control Handle)
10-8-3relations Between Main Crane Boom Elevation Angle And Total Crane Weight And Working Radius
10-9 Slewing Operation
10-9-1 Operating Precautions
10-9-2 Slewing Operation (Left Control Handle)
10-10 Combined Action Instructions
Chapter11 Oil And Grease
11-1 Fuel And Engine Oil
11-2 Hydraulic Oil
11-3 Gear Oil
11-4 Grease
11-5 Domestic And Foreign Grease Comparison
11-6 Coolant
11-7 Waste Oil, Antifreeze Processing
Chapter 12 Crane Inspection And Maintenance
12-1 Overview
12-2 Inspection Items
12-2-1 Inspection Of Steel Structure Bearing Weight
12-2-2 Daily Inspection
12-2-3 Weekly Inspection
12-2-4 Inspection For Unusual Use
12-2-5 Test Requirements
12-3 Wire Rope Inspection
12-4 Hook Inspection
12-5 Drum, Pulley And Brake Inspection
12-5-1 Drum
12-5-2 Pulley
12-5-3 Brake
Chapter 13 Crane Transportation And Storage
13-1 Crane Transportation Mode
13-1-1 Highway Transportation
13-1-2 Rail Transportation
13-1-3 Shipping Transportation
13-2 Lorry Shipping Parts
13-2-1 Balance Weight Transportation
13-2-2 Hook Transport
13-3 Crane Storage
Chapter 14 Appendix
14-1 Terms
14-2 Lifting Commanding Gestures Diagram
14-2-1 Universal Gesture Signal
14-2-2 Special Gesture Signal
Brand: XCMG
4-1 Planning
4-3 Crane Settings
4-5 Lifting Weight
6-1-1 Power System
6-3-3 Other Device
7-4-3 Battery
8-1-2 Safety Device
8-3 Operating Cab
8-3-4 Relay
8-4 Safety Device
8-4-5 Level
8-4-6 Horn
11-2 Hydraulic Oil
11-3 Gear Oil
11-4 Grease
11-6 Coolant
12-1 Overview
12-5-1 Drum
12-5-2 Pulley
12-5-3 Brake
13-3 Crane Storage
Chapter 14 Appendix
14-1 Terms
- XCMG CRANE MODEL QY50K Operator and Repair manual
- XCMG Truck Crane QY 50 K Catalogue Parts 1
- XCMG Full Shop Manual DVD
- XCMG Truck Crane QY70K Parts Catalog EN ZH
- XCMG PDF 970MB Full Collection Manuals DVD
- XCMG Truck Crane QY 50 K Catalogue Parts 3
- XCMG Truck Crane QY50K Operation And Maintenance Manual
- XCMG Truck Crane QY 50 K Catalogue Parts 2
- XCMG Truck Crane QY 25K5 Catalogue Parts 2
- XCMG QY70KL Crane Operation Manual
- XCMG Truck Crane QY 70 K Catalogue Parts 2
- XCMG Wheel Loader ZL50G Service Manual
- XCMG Truck Crane QY 70 K Catalogue Parts 3
- XCMG Truck Crane QY 25K5 Catalogue Parts 1
- XCMG Truck Crane QY 16 50K Catalogue Parts 1
