XCMG Truck Crane XCT80 for Weichai Parts Catalog EN ZH
Language: English, Chinese
Brand: XCMG
Type of Machine: Truck Crane
Model: XCMG XCT80 Truck Crane
Publication Date: 2012
Number of Pages: 424 Pages
Preface
Truck Crane
Hook
Pulley Assembly
Boom
Boom Assembly
Support
Roller
2nd Section
3rd Section
Rope Guide Roller
4th Section
Pulley
5th Section
Telescoping Units
Rope Seat
Guied Bracket
Guide Pulley
Roller
Operator' s Cab
Rotation Table
Stable Wheel Assy
Slewing Ring
Slewing Movement
Lifting Movement
Truck Crane Electric System
Operating Cabs Electric System
Control Box Assembly
Controller Assembly
Right Controller
Turntable Electric System
Electric Appliances for Boom
Electric Appliances for Jib
Moment Limit Device System
Electric of Single Top
Superstructure Piping Assembly
Pipe for Inlet &Return and Leakage
Main Valve Assembly
Pipe for Guide Control' s
Pilot Control Valve Assembly
Romote Control Valve Assembly
Pipe for Elevating,Telescoping and Rotary
Telescopic Control Valve Assembly
Luffing Counterbalance Valve Assembly
Pipeg for Counterweight
Counterweight Valve Assembly
Shunt Valve Assembly
Load Control Valve Assembly
Pipe for Winching
Fast Fitting Assembly
Winch Brake Valve Assembly
Jib
Jib Assembly
1st Jib Boom
2nd Jib Boom
Middle Bracket
Back Bracket
Bracket
I Assenmbly of Telescopic I Cylinder
II Assenmbly of Telescopic II Cylinder
Boom End Single Chain Wheel
Hood
Counter Weight
Luffing Cylinder
Sub_hook
Mid Boom Hook
Auxiliary Winch
Bracket Assembly
Steel Cable & Rigging
Main Steel Cable & Rigging
AuxSteel Cable & Rigging
Counterweight Cylinde
Truck Crane Chassis
First Axle
Second Axle Assembly
Third Axle Assembly
Forth Axle Assembly
Chassis Illumination System
Beam Wires
Sliding Beam Assembly
Chassis Plate
Covering Plate Installation
Steering Hydraulic System
Air Valve Assembly
Air Dryer Assembly
Air Reservoir Assembly
I Air Reservoir Assembly I
Foot Relay Valve Assembly
Hand Relay Valve Assembly
Solenoid Valve Assembly
Pneumatic Circuit Pipe Assembly
Carrier Pipe Assembly
Pipes for Pump Oil Return and Oil Drai
Pipes for Vavle to Outrigger
Pipes for Front Outrigger Oil
Pipes for Back Outrigger
Oil Pump Assembly
Oil Tank
Engine Install
Silencer Install
Radiator Assembly
Gear-box Fixing
Propeller Shaft
Front Suspension
Shield for Diesel Engine
Filter Installation
Transmission Operation
Battery Box
Bearing Carrier for Boom
Rear Suspension
Spare Tire Support
Air-condition Assembly
Brand: XCMG
Preface
Truck Crane
Hook
Pulley Assembly
Boom
Boom Assembly
Support
Roller
2nd Section
3rd Section
Rope Guide Roller
4th Section
Pulley
5th Section
Telescoping Units
Rope Seat
Guied Bracket
Guide Pulley
Roller
Operator' s Cab
Rotation Table
Stable Wheel Assy
Slewing Ring
Slewing Movement
Lifting Movement
Controller Assembly
Right Controller
Main Valve Assembly
Pipe for Winching
Jib
Jib Assembly
1st Jib Boom
2nd Jib Boom
Middle Bracket
Back Bracket
Bracket
Hood
Counter Weight
Luffing Cylinder
Sub_hook
Mid Boom Hook
Auxiliary Winch
Bracket Assembly
Truck Crane Chassis
First Axle
Third Axle Assembly
Forth Axle Assembly
Beam Wires
Chassis Plate
Air Valve Assembly
Air Dryer Assembly
Oil Pump Assembly
Oil Tank
Engine Install
Silencer Install
Radiator Assembly
Gear-box Fixing
Propeller Shaft
Front Suspension
Filter Installation
Battery Box
Rear Suspension
Spare Tire Support
- XCMG CRANE MODEL QY50K Operator and Repair manual
- XCMG Truck Crane QY 50 K Catalogue Parts 1
- XCMG Full Shop Manual DVD
- XCMG Truck Crane QY70K Parts Catalog EN ZH
- XCMG PDF 970MB Full Collection Manuals DVD
- XCMG Truck Crane QY 50 K Catalogue Parts 3
- XCMG Truck Crane QY50K Operation And Maintenance Manual
- XCMG Truck Crane QY 50 K Catalogue Parts 2
- XCMG Truck Crane QY 25K5 Catalogue Parts 2
- XCMG QY70KL Crane Operation Manual
- XCMG Truck Crane QY 70 K Catalogue Parts 2
- XCMG Wheel Loader ZL50G Service Manual
- XCMG Truck Crane QY 70 K Catalogue Parts 3
- XCMG Truck Crane QY 25K5 Catalogue Parts 1
- XCMG Truck Crane QY 16 50K Catalogue Parts 1
