118
6,911
XCMG Truck Crane QY70K Parts Manual EN ZH
Language: English, Chinese
Brand: XCMG
Type of Machine: Truck Crane
Model: XCMG QY70K Truck Crane
List of Files:
XCMG Crane Crane QY70K Parts Manual EN ZH Parts 1.pdf (78 Pages)
QY70K.00 汽车起重机 – Truck Crane
QY70K.01 起重钩 – Hook
QY65K.02Ⅱ 起重臂 – Boom
QY65K.03A 操纵室 – Control Cab
QY65K.11.1 操纵室电气 – Operating Cabs Electric System
QY65K.13A 上车液压布管 – Disposal of Hydraulic Pipeline
QY65K.05 转台 – Rotation Table
QY65K.06 回转支承 – Slewing Bearing
QY65K.07 回转机构 – Slewing Movement
QY65K.08 起升机构 – Lifting Movement
QY16K.09A 油门操纵 – Oil Valve Control
QY50K.14C 副起重臂 – Jib
QAY50.18 臂端单滑轮 – Boom Cap Single Pulley
QY70K.20 平衡重 – Balance
QY35K.29 副起重钩 – Sub-hook
QY70K.34 中长臂起重钩 – Mid Boom Hook
QY65K.90.1 主钩索具 – Steel Cable & Ringing
XCMG Crane Crane QY70K Parts Manual EN ZH Parts 2.pdf (88 Pages)
JSQF2800 驾驶室 – Cab (匹配 WD615.46 发动机)
JSQF2801 驾驶室 – Cab (匹配 WD615.338 发动机)
JSQF2802 驾驶室 – Cab (匹配 ISLE+350 及 QSL325 发动机)
XZ16K.25A 底盘照明系统 – Lighting System
XZ65K.26 大梁线束安装 – Beam Wires (匹配 WD615.46 发动机)
XZ50K.26II 大梁线束安装 – Beam Wires (匹配 ISLE+350 及 QSL325 发动机)
XZ60K.26 大梁线束安装 – Beam Wires (匹配 WD615.338 发动机)
XZ16K.74A 电瓶箱安装 – Battery Box
XZ35K.39A 贮气筒安装 – Air Reservoir Assembly
XZ16K.41A 气路阀安装 – Air Valve Assembly
XZ60K.42 气路系统布管 – Pneumatic Circuit Pipe Assembly
XZ50K.45 发动机安装 – Engine Install (WD615.46)
XZ50K.45II 发动机安装 – Engine Install (ISLE+350)
XZ50K.45III 发动机安装 – Engine Install (QSL325)
XZ60K.45 发动机安装 – Engine Install (WD615.338)
XZ50K.46A 燃油箱 – Fuel Tank
XZ25K.47 消声器安装 – Muffler Assembly
XZ16K.47II 消声器安装 – Muffler Assembly
XZ50K.48 散热器安装 – Radiator Assembly (WD615.46 / WD615.338)
XZ25K.48 散热器安装 – Radiator Assembly (ISLE+350 / QSL325)
XZ65K.50A 变速箱 – Gear-box
XZ65K.51A 油泵装置 – Oil Pump Assembly (力士乐油泵)
XZ65K.51II 油泵装置 – Oil Pump Assembly (Park 油泵)
XZ60K.53 传动轴 – Transmission Shaft
XZ60K.11 一轴 – First Axle
XZ60K.12 二轴 – Second Axle
XZ60K.13 三轴 – Third Axle
XZ60K.14 四轴 – Fourth Axle
XZ60K.55 前悬架 – Front Suspension
XZ16K.58A 后悬架 – Rear Suspension
XZ60K.37 转向液压系统 – Steering Hydraulic System
XZ60K.65 转向系统 – Steering System
XZ30K.61 发动机罩 – Shield for Diesel Engine
XZ60K.67 空滤器安装 – Air Filter Assembly
XZ50K.70A 变速操纵 – Transmission Operation
XZ16K.83A 空调装置 – Air Conditioning Unit (ISLE+350 / QSL325)
XZ25K.83A 空调装置 – Air Conditioning Unit (WD615.46 / WD615.338)
QY60K.66 液压油箱 – Hydraulic Oil Tank
QY60K.72 支腿操纵系统 – Outrigger Operation System
QY60K.65 下车配管总成 – Carrier Pipe Assembly (力士乐油泵)
QY60K.65.1 回油泄油配管 – Pipes for oil return and oil drain
QY60K.65.2 泵进出油配管 – Pipes for pressure oil
QY60K.65.3 泵进出油配管 – Pipes for pressure oil
QY60K.65.4 支腿内部配管 – Pipes for outrigger
QY60K.65.5 前支腿配管 – Pipes for front outrigger oil
QY60K.65II 下车配管总成 – Carrier Pipe Assembly (Park 油泵)
QY60K.65II.1 回油泄油配管 – Pipes for oil return and oil drain
QY60K.65II.2 泵进出油配管 – Pipes for pressure oil
QY65K.68 水平油缸 – Level Cylinder
QY65K.69.1 前垂直油缸 – The front Vertical Cylinder
QY65K.69.2 后垂直油缸 – The front Vertical Cylinder
QY60K.76 第五支腿油缸 – No.5 Vertical Cylinder
QY16K.70B 中心回转体安装 – Center Revolving Body (WD615.46)
QY16K.70II 中心回转体安装 – Center Revolving Body
XZ60K.11II 一轴总成 – First Axle
XZ60K.12II 二轴总成 – Second Axle
XZ50K.56C 中桥 – Middle Axle
XZ50K.57C 后桥 – Rear Axle
XCMG Crane Crane QY70K Parts Manual EN ZH Parts 3.pdf (78 Pages)
